Battery Holders
Surface Mounting Technology (SMT)
Horizontal mounting
Features
• Easy and fast replacement of the battery
• Designed for automatic pick&place mounting
• Safe retention of coin cell
• Automated battery mounting possible
• Clear separation of connections
• Protection against short-circuits
• Protection against inverse polarity (polarized)
• Protection against leak currents
• Robust design
• Suitable for reflow-soldering
Specifications
• Holder material: heat-resistant, glass fibre
filled LCP
• Flammability rating UL 94 V-0
• Battery contacts: spring stainless steel AISI 301,
nickel-plated throughout. Solder area tin-plated
throughout, min. thickness 5 µm.
• Contact resistance between contacts and the
cell is less than 100 m (measured through
AC 1kHz; depending on the case material of
the cell).
UL recognition, file E218732
• Operating temperature range: –40/+100°C
Dimensions
Model
SMTU357-LF
SMTU1220-LF
SMTU1225-LF
SMTU1632-LF
SMTU2032-LF
SMTU2430-LF
SMTU2450N-LF
SMTU2477N-LF
SM2X2016-LF
For use with
Renata cell
357 (SR44W)
CR1220
CR1225
CR1632
CR2032
CR2430
CR2450N1)
CR2477N
CR2016
A
23.3
23.7
23.7
27.7
32.0
36.4
36.4
36.4
32.0
Dimensions (mm)
B
C
D
E
19.9 11.6 12.0 7.55
20.3 12.5 12.7
4.8
20.3 12.5 12.7
4.8
24.3 16.0 14.5
5.4
28.5 20.0 16.1
5.4
33.0 24.5 16.1
4.9
33.0 24.5 16.1
7.5
33.0 24.5 16.1 10.3
28.5 20.0 16.1
5.4
F
20.7
21.1
21.1
25.1
29.4
33.8
33.8
33.8
29.4
Weight Part.No.*
(g)
0.85 701132
0.80 701114
0.70 701115
0.80 701130
0.95 701116
1.05 701117
1.45 701118
1.65 701119
0.95 701113
*Packaging: Industrial Bulk (IB-Trays)
1) Not suitable for
CR2450HT
24
www.renata.com
Battery Holders
Through-hole mounting
Horizontal mounting
Features
• Robust design
• Suitable for wave-soldering
±0.3
Specifications
filled LCP
AC 1kHz; depending on the case material of the
cell).
±0.3
Dimensions
Model
For use with
Renata cell
HU357-LF
357 (SR44W)
HU1225-LF
CR1225
HU1632-LF
CR1632
HU2032-LF
CR2032
HU2430-LF
CR2430
HU2450N-LF CR2450N1)
HU2477N-LF CR2477N
B
19.9
20.3
24.3
28.5
33.0
33.0
33.0
Dimensions (mm)
C
D
E
11.6
12.0
7.4
12.5
12.7
4.5
16.0
14.5
5.2
20.0
16.1
5.2
24.5
16.1
4.7
24.5
16.1
7.3
24.5
16.1 10.1
F
18.65
19.1
23.0
27.2
31.7
31.75
31.8
Weight
(g)
0.84
0.70
0.80
0.95
1.05
1.45
1.65
Part.No.*
701133
701105
701131
701106
701107
701108
701109
1) Not suitable for
CR2450HT
the swiss power source
25
Battery Holders
Vertical mounting
VBH2032-1 - Vertical battery holder for Renata coin cell CR2032 / CR2032MFR
Features
• Small PCB footprint
• Robust design
Specifications
• Holder material: polyamide
• Operating temperature range: -40/+85°C
Dimensions (mm)
Model
VBH2032-1
For use with Renata cell
Weight (g)
Part. No.*
CR2032
1.6
700579
26
www.renata.com
Battery Holders
Through-hole mounting with positioning pins
Battery holders for CR2450N or CR2477N
Vertical and horizontal versions
Features
• Snap-on fixing for coin cells
• Robust design
• Easy and safe PCB mounting due to additional
positioning pins
Specifications
• Flammability rating UL 94 V-2
• Battery contacts: Nickel 99.6 DIN 17740
AC 1kHz).
• Solder and positioning pins tin plated throughout, min. thickness 5 µm.
• Operating temperature range: –40/+85°C
NH5077-LF Vertical version
NL5077-LF Horizontal version
Model
For use with
Renata cell
Weight
(g)
Part.No.*
NH5077-LF
CR2450N1), CR2477N
2.4
701111
NL5077-LF
CR2450N , CR2477N
2.9
701112
1)
1) Not suitable for
CR2450HT
27
Battery Holders
Packaging options
Battery holders can be supplied in different packaging
Industrial Bulk multi-cell trays
Packaging Code: IB
Industrial Bulk packaging is the standard
packaging for manufacturers.
The number of battery holders per tray depends
on the respective model. So does the number of
trays per shrink pack.
Tape&Reel packaging
Packaging Code: TR
For SMT-battery holders there is a Tape&Reel
packaging solution available.
Tape&Reel packaging is ideal for high-speed,
automated manufacturing lines.
The number of battery holders per reel depends on
Quantity per reel:
Model
Quantity per Reel
Part.No.*
SMTU1225-LF TR
750 pieces
701230
SMTU1632-LF TR
520 pieces
701231
SMTU2032-LF TR
485 pieces
701232
SMTU2430-LF TR
490 pieces
701233
SMTU2450N-LF TR
350 pieces
701234
SMTU2477N-LF TR
250 pieces
701235
SM2X2016-LF TR
485 pieces
701236
*Packaging: Tape&Reel (TR)
28
www.renata.com
Mouser Electronics
Authorized Distributor
Click to View Pricing, Inventory, Delivery & Lifecycle Information:
Renata:
SMTU2032-LF SMTU2477N-LF SMTU1632-LF.TR
很抱歉,暂时无法提供与“SMTU2032-LF”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 100+4.79468100+0.57823
- 500+4.26203500+0.51399
- 1000+3.978121000+0.47975
- 国内价格
- 1+4.00625
- 30+3.86810
- 100+3.59181
- 500+3.31551
- 1000+3.17737
