HER502 THRU HER508 DO-27
High Efficiency Silicon Rectifiers
Reverse Voltage - 100 to 1000 V
Forward Current – 5 A
FEATURES
For surface mounted applications
Low profile package
Open Junction chip
Ideal for automated placement
Lead free in comply with EU RoHS 2011/65/EU directives
MECHANICAL DATA
Case: DO-201AD/ DO-27
Terminals: Solderable per MIL-STD-750, Method 2026
Approx. Weight: 0. 98 g / 0.0345oz
DO-201AD/ DO-27
Maximum Ratings and Electrical characteristics
Ratings at 25 °C ambient temperature unless otherwise specified.
Single phase half-wave 60 Hz, resistive or inductive load, for capacitive load current derate by 20 %.
Symbols
HER502
HER503
HER505
HER506
HER507
HER508
Units
Maximum Repetitive Peak Reverse Voltage
VRRM
100
200
400
600
800
1000
V
Maximum RMS voltage
VRMS
70
140
280
420
560
700
V
Maximum DC Blocking Voltage
VDC
100
200
400
600
800
1000
V
Parameter
Maximum Average Forward Rectified Current
at Tc = 100 °C
IF(AV)
5.0
A
Peak Forward Surge Current 8.3 ms Single
Half Sine Wave Superimposed on Rated Load
IFSM
150.0
A
Maximum Instantaneous Forward Voltage at 5.0A
VF
1.0
1.4
Maximum DC Reverse Current T a = 25 °C
at Rated DC Blocking Voltage
T a=125 °C
1.7
10
500
IR
V
μA
Maxinum reverse recovery time(Note 1)
Trr
Typical Junction Capacitance( Note 2)
Cj
100.0
pF
RθJA
65
°C/W
Tj, Tstg
-55 ~ +150
°C
Typical Thermal Resistance
Operating and Storage Temperature Range
50
75
nS
(1)Measured at 1 MHz and applied reverse voltage of 4 V D.C
(2)Reverse recovery time test condition: IF=0.5A IR=1.0A Irr=0.25A
www.yfwdiode.com
1/3
Dongguan YFW Electronics Co, Ltd.
Ratings And Characteristic Curves
FIG. 2-MAXIMUM NON-REPETITIVE PEAK FORWARD
SURGE CURRENT PERLEG
350
Peak Forward Surage Current
Amperes
8.0
7.0
300
6.0
Amperes
FIG. 1- DERATING CURVE OUTPUT RECTIFIED CURRENT
250
5.0
200
4.0
3.0
2.0
1.0
0.0
60
80
100
120
140
150
f=60Hz
100
50
1Cycle
1
10
100
Number of cycles
Lead Temperature
Instantaneous Forward Current
Amperes
200
100
TJ=25 C
PULSE WIDTH=300 µs
1%DUTY CYCLE
10
1
HER601-HER604
HER605
HER606-HER608
0.1
0.4
0.8
1.2
1.6
2.0
22
Tj = 125°C
10
1.0
Tj = 25°C
0.1
0.01
60
80
100
120
140
Percent Of Rated Peak Reverse Voltage(%)
Volts
www.yfwdiode.com
100
Micro Amperes
Instantaneous Reverse Leakage Current
FIG. 4-TYPICAL REVERSE LEAKAGE CHARACTERISTICS
FIG. 3-TYPICAL FORWARD VOLTAGE CHARACTERISTICS
2/3
Package Outline
DO-201AD(DO-27)
D
DIMENSIONS
A
DIM
A
B
C
D
Cathode
Mark
B
INCHES
MIN
----.048
1.000
MAX
.370
.250
.052
MM
MIN
----1.20
25.40
MAX
9.50
6.40
1.30
NOTE
D
C
Summary of Packing Options
Package
DO-201AD(DO-27)
www.yfwdiode.com
Packing Description
Packing Quantity
BOX
250/1000/1250
3/3
Industry Standard
EIA-481-1
很抱歉,暂时无法提供与“HER508”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+0.37911
- 20+0.34566
- 100+0.31221
- 500+0.27876
- 1000+0.26315
- 2000+0.25200
