HC-1.2-5PWT
HC-1.2-5PWT
    HCTL(华灿天禄)
    SMD,P=1.2mm
    HC-1.2-5PWT
HC-1.2-5PWT 数据手册
深圳市华灿天禄电子有限公司 物料承认书 SPECIFICATION FOR APPROVAL 客户名称: Customer: 产品名称: Description: 规格型号: Modelno: 1.2MM系列 物料编号: Cust P/N: 出厂签章 校 对Issuer 审 核Engineer 李攀进 批 准Approver 罗观彬 承认签章 CUSTOMER 校 对Issuer 审 核Engineer 批 准Approver 地址:深圳市宝安区40区安乐科技创新园B栋726 TEL:0755-27204342 FAX:0755-29785862 Http://www.HCTLDZ.com E-mail: jinpan.hu@hctldz.com 确认合格后烦请回签一份给我司存档,谢谢! Pls. sign acknowledge and re-turn document to us after confirming, thank you ! PRODUCT SPECIFICATION 1. 产规/Product name and part number Product Name 1.2mm PITCH WIRE TO BOARD CONNECTOR Terminal Copper alloy Housing REC:High-temp Plastic;Color : Black. lammability Wafer Assembly ST. (DIP/SMT) Rating :UL94 V-0 Wafer Assembly R.A SMT (DIP/SMT) 2. 额定电压电流及使用线径/Ratings and applicable wires ITEM STANDARD 50V DC/AC(rms) Rated Voltage(Max) 额定电压(最高) AWG.#28 1.5A AWG.#30 1.0A Applicable wires 使用线径 #30~ #28 Insulation O.D 绝缘外径 Φ0.6~Φ0.7mm Ambient Temperature 使用温度范围 -25℃~+85℃ 3. 特性测试/Performance 3-1.电气特性/Electrical performance ITEM 3-1-1 Test condition 接触阻抗 将公母对插,二头接上微电流电压测试。 Contact Mate connectors, reassure by dry circuit ,20mV Resistance 3-1-2 绝缘阻抗 3-1-3 20mΩ(MAX) MAX,10mA.(EIA-364-23) 将公母对插,二头接上电压测试 Insulation Mate connectors, apply 500V DC between adjacent resistance terminal or ground. (EIA-364-21) 高压测试 Dielectric strength 3-1-4 Requirement 100MΩ(MIN) 将公母对插,相邻的二支端子接上高压测试 没有损坏/没有电弧 Mate connectors, apply 500V AC for 1 minute between 产生 adjacent terminal or ground. (EIA-364-20) No breakdown and flashover 铆线端子接触 将铆线端子,二头接上微电流电压测试。 阻抗 Contact Crimp the applicable wire to the terminal, measured by Resistance on dry circuits, 20mV MAX., 10mA MAX. 5 milliohms MAX Crimped Portion Product Description Product NO:WF-12-001 Wafer1.2mm 系列 APPROVED BY CHECKED BY MADE BY JASON ABEL TOM REVISION DATE SHEET NO A/0 2018.10.25 1/8 DOCUMENT NO WF-12-001 PRODUCT SPECIFICATION 3-2.机械特性/Mechanical performance ITEM Test condition 3-2-1 Requirement 公母对插插拔 10 次,机器行走速度 Insertion force and 25±3mm/分钟。 withdrawal force Insert and withdraw connectors 整组插拔力测试 at the speed rate of 25 ± 第 5 参照 Refer to paragraph 5 3mm/minute(EIA-364-13) 3-2-2 端子固定住,将端子从线材拔出, Wire 机器行走速度 25±3mm/分钟。 Size force Fix the crimped terminal, apply (AWG) 导电体保持力(铆线端 axial pull out force on the wire 子) at the speed rate of 25 ± Crimping pull out 3mm/minute (EIA 364-35) 3-2-3 Terminal insertion force 插入力(铆线端 子) 3-2-4 Strength 30 10N(1.0kgf ) 5N (0.5kgf) MIN (kgf) MIN 将端子插入塑胶,测试插入值 Insert the crimped terminal into 14.7N(1.5kgf) MAX the housing (EIA-364-13) Terminal/Housing retention force 将端子从塑胶中拔出,测试拔出值 Apply axial pull out force at the speed rate of 25±3mm/minute on 塑胶保持力 4N(0.4kgf) MIN the terminal assembled (铆线端子) 3-2-5 Crimp 28 In the housing. Pin 将铜针从塑胶中推出,测试推出值 retention force Apply axial push force at the (单 PIN 保持力) speed rate of 25±3mm/minute. 2N(0.2kgf) MIN 3-3.环境特性测试/Environmental performance and others ITEM 3-3-1 Test condition 重复插拔 Repeated insertion 3-3-2. Requirement 十次插拔后,测量接触阻抗 接触阻抗 When mated up to10 cycles repeatedly by the Contact withdrawal rate of 10 cycles per minute Resistance 温升测试 最大容许电流通电,温度测定。 温度上升 Temperature Rise (按需测试) Product Description (EIA-364-70 METHOD 2) Temperature Carrying rated current load. 20mΩ MAX 30℃ MAX Rise Product NO:WF-12-001 Wafer1.2mm 系列 APPROVED BY CHECKED BY MADE BY JASON ABEL TOM REVISION DATE SHEET NO A/0 2018.10.25 2/8 DOCUMENT NO WF-12-001 PRODUCT ITEM SPECIFICATION Test condition Requirement 3-3-3 DC 1mA 通电状态下;嵌合轴沿 XYZ 三个方向振动; 振幅 1.5mm;频率 10-55-10Hz/分;历时 2 小时 振动测试 接触阻抗 Duration : 2 hours in each X.Y.Z. axes (EIA-364-28) 瞬间 Discontinuity 3-3-4 高温测试 20mΩ MAX Resistance Sweep time:10-55-10Hz in 1 minute (按需测试) No Damage Contact Amplitude:1.5mm P-P Vibration 外观 Appearance 将公座与母座连接至于环境温度85±2℃测试时间 外观 Appearance Heat Resistance 96小时,再放置与室温下1~2小时 接触阻抗 (按需测试) 85±2℃,96hours(EIA-364-17 ) Contact 1.0 microsecond MAX No Damage 20mΩ MAX Resistance 3-3-5 低温测试 将公座与母座连接至于环境温度-25±3℃测试时 Cold Resistance (按需测试) 间 96 小时,再放置于温室下 1~2 小时 外观 Appearance 接触阻抗 Appearance 温度 60±2℃,湿度 90~95%,时间 96 小时。 Temperature:60±2℃,Relative No Damage 接触阻抗 20mΩ Contact MAX Resistance humidity:90~95%(RH)(EIA-364-31B) (按需测试) MAX Resistance 3-3-6 Humidity 20mΩ Contact -25±3℃,96hours(EIA-364-17 ) 恒温恒湿测试 No Damage 耐电压 Dielectric Strength 没有损坏/没 有电弧产生 3-3-7 盐雾测试 时间 12 小时,盐水体比例 5±1%,温度 35±2℃。 Salt spray 12 hours exposure to a salt spray from the 5 ±1% solution at 35±2℃.(EIA-364-26) 外观 Appearance No Damage 接触阻抗 Contact Resistancee 3-3-8 20mΩ MAX 时间:3±0.5 秒, 沾锡性测试 温度:245±5℃ Solderability Soldering time:3±0.5sec, 95%以上沾锡面积 solder temperature:245±5℃ (EIA-364-52) Product Description Product NO:WF-12-001 Wafer1.2mm 系列 APPROVED BY CHECKED BY MADE BY JASON ABEL TOM REVISION DATE SHEET NO A/0 2018.10.25 3/8 DOCUMENT NO WF-12-001 PRODUCT ITEM SPECIFICATION Test condition 2-3-9 Requirement 1). Reflow part 260±5℃ Peak 220℃ MIN. 60sec.MAX. 2). Pre-heat part 180℃, 0~120sec. Resistance to soldering Appearance No Damage 无 heat 外观 损坏、变形 焊热性测试 4. 产品规格尺寸及材质请参考工程图面/Product shape, Dimensions and materials 5. 整组插拔力/Insertion force and withdrawal force (UNIT:N/Kgf) 极数 NO.OF CKT 单位:UNIT 插入力(最大值):Insertion(MAX) 拔出力(最小值):Withdrawal(MIN) 初始:1ST 3 次:3ST 10 次:10ST 初始:1ST 3 次:3ST 10 次:10ST 2 N{kgf} 18{1.8} 18{1.8} 18{1.8} 4.0{0.41} 1.8{0.18} 1.2{0.12} 3 N{kgf} 21{2.1} 21{2.1} 21{2.1} 4.0{0.41} 1.8{0.18} 1.2{0.12} 4 N{kgf} 24{2.4} 24{2.4} 24{2.4} 4.0{0.41} 1.8{0.18} 1.2{0.12} 5 N{kgf} 27{2.8} 27{2.8} 27{2.8} 2.5{0.26} 1.8{0.18} 1.2{0.12} 6 N{kgf} 30{3.1} 30{3.1} 30{3.1} 2.5{0.26} 1.8{0.18} 1.2{0.12} 7 6.产品符合 ROHS/HF 要求/Lead free and ROHS/HF compliant product Product Description Product NO:WF-12-001 Wafer1.2mm 系列 REVISION APPROVED BY CHECKED BY MADE BY JASON ABEL TOM DATE SHEET NO 2018.10.25 4/8 DOCUMENT NO WF-12-001 PRODUCT SPECIFICATION 7.连接器操作标准/CONNECTOR HANDLING CRITERIA 操作图示标准/Operating standards here ITEM 7-1-1 Align plug on top of receptacle as per datum shown in fig.1.Press down the plug at ighlighted area toward the eceptacle to mate the connectors. 7-1-2 During mating process, If incase the plug is angle mated towards the straight part of mating entrance as in fig. 2, the allow angle must not exceed 5° Product Description Product NO:WF-12-001 Wafer1.2mm 系列 REVISION APPROVED BY CHECKED BY MADE BY JASON ABEL TOM DATE SHEET NO 2018.10.25 5/8 DOCUMENT NO WF-12-001 PRODUCT SPECIFICATION 操作图示标准/Operating standards here ITEM 7-1-2 Align plug on top of receptacle as per datum shown in fig.1.Press down the plug at ighlighted area toward the eceptacle to mate the connectors. 7-1-3 When connector is fully mated, as shown in fig. 3.1, check for any incomplete mating which will cause damaged contacts as shown in fig. 3.2 Product Description Product NO:WF-12-001 Wafer1.2mm 系列 REVISION APPROVED BY CHECKED BY MADE BY JASON ABEL TOM DATE SHEET NO 2018.10.25 6/8 DOCUMENT NO WF-12-001 PRODUCT SPECIFICATION 操作图示标准/Operating standards here ITEM 7-1-4 Connector unmating method, Hold gently on plug wires and pull up to unmate the connector as per fig. 4 shown. 7-1-5 For unmating process, plug wires pull and stress angle must be maintained within 15° as per fig.5 shown Product Description Product NO:WF-12-001 Wafer1.2mm 系列 REVISION APPROVED BY CHECKED BY MADE BY JASON ABEL TOM DATE SHEET NO 2018.10.25 7/8 DOCUMENT NO WF-12-001 PRODUCT SPECIFICATION 操作图示标准/Operating standards here ITEM 7-1-6 Connector shall not be unmated horizontally as shown in fig. 6 to prevent part damage 7-1-7 Application consideration Make certain the areas & space where the connector placed are clear and sufficient to prevent over stress on plug wires as example shown in fig. 7 Product Description Product NO:WF-12-001 Wafer1.2mm 系列 REVISION APPROVED BY CHECKED BY MADE BY JASON ABEL TOM DATE SHEET NO 2018.10.25 8/8 DOCUMENT NO WF-12-001
HC-1.2-5PWT 价格&库存
很抱歉,暂时无法提供与“HC-1.2-5PWT”相匹配的价格&库存,您可以联系我们找货
