LMV358A-SR
LMV358A-SR
    3PEAK(思瑞浦)
    SOIC8_150MIL
LMV358A-SR 数据手册
3PEAK LMV321A/LMV358A/LMV324A 80μA, 1.0MHz, Micro-Power Rail-to-Rail I/O Op Amps Features Description  Upgrade to LMV321/LMV358/LMV324 Family  Stable 1.0MHz GBWP with Low IQ of Only 80μA Typical per Amplifier  0.7V/μs Slew Rate  Excellent EMIRR performance: 80dB(1GHz)  Offset Voltage Tolerance: 400μV Max.  Offset Voltage Temperature Drift: 1uV/°C  Input Bias Current: 1pA Typical  High Output Current: 50mA (1.0V Drop)  CMRR/PSRR: 95dB/90dB  Beyond the Rails Input Common-Mode Range  Outputs Swing to within 6mV Max of each Rail  No Phase Reversal for Overdriven Inputs  No Crossover Distortion  Drives 2kΩ Resistive Loads  Single +2.1V to +6.0V Supply Voltage Range  –40°C to 125°C Operation Range  ESD Rating: Robust 8KV – HBM, 2KV – CDM  Green, Popular Type Package LMV321A/358A/324A are CMOS single, dual, and quad op-amps with low offset, stable high frequency response, low power, low supply voltage, and rail-to-rail inputs and outputs. They incorporate 3PEAK‟s proprietary and patented design techniques to achieve best in-class performance among all micro-power CMOS amplifiers. The LMV321A/358A/324A are unity gain stable with Any Capacitive Load with a Constant 1.0MHz gain-bandwidth product, 0.7V/μs slew rate while consuming only 80μA of supply current per amplifier. Analog trim and calibration routine reduces input offset voltage tolerance to below 400μV. Adaptive biasing and dynamic compensation enables the LMV321A /358A/324A to achieve „THD+NOISE‟ for 1kHz and 10kHz 2VPP signal at -105dB and -90dB, respectively. Beyond the rails input and rail-to-rail output characteristics allow the full power-supply voltage to be used for signal range. This combination of features makes the LMV321A /358A/324A superior among rail-to-rail input /output CMOS op amps in its power class. The LMV321A/358A/324A are ideal choices for battery-powered applications because they minimize errors due to power supply voltage variations over the lifetime of the battery and maintain high CMRR even for a rail-to-rail input op-amp. Applications  Active Filters, ASIC Input or Output Amplifier  Sensor Interface  Smoke/Gas/Environment Sensors  Portable Instruments and Mobile Device  Audio Output  PCMCIA Cards  Battery or Solar Powered Systems  Medical Equipment  Piezo Electrical Transducer Amplifier The LMV321A/358A/324A can be used as cost-effective plug-in replacements for many commercially available op amps to reduce power and improve input/output range and performance. 3PEAK and the 3PEAK logo are registered trademarks of 3PEAK INCORPORATED. All other trademarks are the property of their respective owners. Pin Configuration (Top View) LMV321A 5-Pin SOT23/SC70 (-T and -C Suffixes) +In 1 -VS 2 -In 3 LMV358A 8-Pin SOIC/MSOP (-S and -V Suffixes) 5 +VS 4 Out Out A 1 -In A 2 +In A 3 -VS 4 A LMV324A 14-Pin SOIC/TSSOP (-S and -T Suffixes) 8 +VS 7 Out A 1 Out B -In A 2 13 -In D -In B +In A 3 12 +In D 5 +In B +VS 4 11 -VS +In B 5 10 +In C B www.3peakic.com.cn Out D 6 A B 14 D C -In B 6 9 -In C Out B 7 8 Out C Rev. A.02 1 LMV321A / LMV358A / LMV324A 80μA, 1.0MHz, Micro-Power Rail-to-Rail I/O Op Amps Order Information Model Name Order Number LMV321A LMV358A LMV324A Package Marking Information Transport Media, Quantity LMV321A -TR 5-Pin SOT23 Tape and Reel, 3,000 321 LMV321A -CR 5-Pin SC70 Tape and Reel, 3,000 321 LMV358A -SR 8-Pin SOP Tape and Reel, 4,000 LMV358A LMV358A -VR 8-Pin MSOP Tape and Reel, 3,000 LMV358A LMV324A -SR 14-Pin SOP Tape and Reel, 2,500 LMV324A LMV324A -TR 14-Pin TSSOP Tape and Reel, 3,000 LMV324A Absolute Maximum Ratings Note 1 + Supply Voltage: V – V – Note 2 ..............................7.0V – Operating Temperature Range........–40°C to 125°C + Input Voltage............................. V – 0.3 to V + 0.3 Input Current: +IN, –IN Maximum Junction Temperature................... 150°C Note 3.......................... ±20mA Storage Temperature Range.......... –65°C to 150°C Note 4…............. Infinite Lead Temperature (Soldering, 10 sec) ......... 260°C Output Short-Circuit Duration Current at Supply Pins……………............... ±60mA Note 1: Stresses beyond those listed under Absolute Maximum Ratings may cause permanent damage to the device. Exposure to any Absolute Maximum Rating condition for extended periods may affect device reliability and lifetime. Note 2: The op amp supplies must be established simultaneously, with, or before, the application of any input signals. Note 3: The inputs are protected by ESD protection diodes to each power supply. If the input extends more than 500mV beyond the power supply, the input current should be limited to less than 10mA. Note 4: A heat sink may be required to keep the junction temperature below the absolute maximum. This depends on the power supply voltage and how many amplifiers are shorted. Thermal resistance varies with the amount of PC board metal connected to the package. The specified values are for short traces connected to the leads. ESD, Electrostatic Discharge Protection Symbol Parameter Condition Minimum Level Unit HBM Human Body Model ESD MIL-STD-883H Method 3015.8 8 kV CDM Charged Device Model ESD JEDEC-EIA/JESD22-C101E 2 kV Thermal Resistance 2 Package Type θJA θJC Unit 5-Pin SOT23 250 81 ° C/W 5-Pin SC70 395 165 ° C/W 8-Pin SOP 158 43 ° C/W 8-Pin MSOP 210 45 ° C/W 14-Pin SOP 120 36 ° C/W 14-Pin TSSOP 180 35 ° C/W Rev. A.02 www.3peakic.com.cn LMV321A/LMV358A/ LMV324A 80μA, 1.0MHz, Micro-Power Rail-to-Rail I/O Op Amps Electrical Characteristics The specifications are at TA = 27° C. VS = +2.1 V to +6.0 V, or ± 1.05 V to ± 3.0 V, RL = 2kΩ, CL =100pF.Unless otherwise noted. SYMBOL VOS VOS TC PARAMETER CONDITIONS MIN TYP MAX UNITS 0.6 1 1.4 mV Input Offset Voltage VCM = Vss+0.1V Input Offset Voltage Drift -40° C to 125° C 1 TA = 27 ° C 1 TA = 85 ° C 25 pA 0.001 pA μV/° C 10 pA IB Input Bias Current IOS Input Offset Current Vn Input Voltage Noise f = 0.1Hz to 10Hz 7 μVPP en in Input Voltage Noise Density Input Current Noise 27 nV/√Hz fA/√Hz CIN Input Capacitance f = 1kHz f = 1kHz Differential Common Mode VCM = 0V to 2.5V CMRR PSRR Common Mode Rejection Ratio Common-mode Input Voltage Range Power Supply Rejection Ratio AVOL VCM 85 2 8 7 95 V– -0.3 pF dB V++0.3 V VCM = 0V, VS = 3V to 5V 77 90 dB Open-Loop Large Signal Gain RLOAD = 10kΩ 98 120 dB VOL, VOH Output Swing from Supply Rail RLOAD = 10kΩ ROUT Closed-Loop Output Impedance G = 1, f =1kHz, IOUT = 0 RO Open-Loop Output Impedance ISC 3 6 mV 0.002 Ω f = 1kHz, IOUT = 0 125 Ω Output Short-Circuit Current Sink or source current 100 IO Output Current Sink or source current, Output 1V Drop 50 VDD Supply Voltage IQ 2.1 120 mA mA 6.0 V 120 μA Quiescent Current per Amplifier VS = 5V 80 PM Phase Margin RLOAD = 1kΩ, CLOAD = 60pF 65 ° GM Gain Margin RLOAD = 1kΩ, CLOAD = 60pF 15 dB Gain-Bandwidth Product f = 1kHz AV = 1, VOUT = 1.5V to 3.5V, CLOAD = 60pF, RLOAD = 1kΩ 1.0 MHz 0.7 V/μs 58.6 3.7 4.9 kHz 0.003 % 110 dB GBWP SR FPBW tS THD+N Xtalk Slew Rate Full Power Bandwidth Note 1 Settling Time, 0.1% Settling Time, 0.01% Total Harmonic Distortion and Noise Channel Separation AV = –1, 1V Step f = 1kHz, AV =1, RL = 2kΩ, VOUT = 1Vp-p f = 1kHz, RL = 2kΩ μs Note 1: Full power bandwidth is calculated from the slew rate FPBW = SR/π • VP-P www.3peakic.com.cn Rev. A.02 3 LMV321A / LMV358A / LMV324A 80μA, 1.0MHz, Micro-Power Rail-to-Rail I/O Op Amps Typical Performance Characteristics VS = ±2.75V, VCM = 0V, RL = Open, unless otherwise specified. Offset Voltage Production Distribution Unity Gain Bandwidth vs. Temperature 2.0 4000 Number = 20000 pcs 1.8 3000 1.5 2500 1.3 GBW(MHz) Population 3500 2000 1500 1.0 0.8 0.5 1000 0.3 500 0.0 -50 其他 600 650 700 750 800 850 900 950 1000 1050 1100 1150 1200 1250 1300 0 0 100 150 Temperature(℃) Offset Voltage(uV) Open-Loop Gain and Phase Input Voltage Noise Spectral Density 140 1000 200 120 Phase 60 50 40 Gain 0 20 0 Phase (°) 100 80 Noise(nV/√Hz) 150 100 Gain(dB) 50 100 10 -50 -20 -100 -40 -60 0.1 10 1k 100k 1 -150 1000M 10M 1 10 Input Bias Current vs. Temperature 10k 100k 1M 0 40 -5 Input Bias Current(pA) Input Bias Current(pA) 1k Input Bias Current vs. Input Common Mode Voltage 50 30 20 10 -10 -15 -20 0 -10 -40 -20 0 20 40 60 Temperature(℃) 4 100 Frequency(Hz) Frequency (Hz) Rev. A.02 80 100 120 -25 0 1 2 3 4 5 Common Mode Voltage(V) www.3peakic.com.cn LMV321A/LMV358A/ LMV324A 80μA, 1.0MHz, Micro-Power Rail-to-Rail I/O Op Amps Typical Performance Characteristics VS = ±2.75V, VCM = 0V, RL = Open, unless otherwise specified. (Continued) Common Mode Rejection Ratio CMRR vs. Frequency 160 140 140 120 120 CMRR(dB) CMRR(dB) 100 80 60 40 100 80 60 40 20 20 0 0 0 1 2 3 4 5 1 10 100 Common-mode Voltage(V) 10k 100k 1M Frequency(Hz) Quiescent Current vs. Temperature Short Circuit Current vs. Temperature 120 140 VCM= 2.5V 120 Current(mA) 100 Supply current(μA) 1k VCM= 5.0V 80 60 VCM= 0V ISOURCE 100 ISINK 80 60 40 40 20 20 0 0 -50 -50 0 50 100 0 100 150 Temperature(℃) Temperature(℃) Power-Supply Rejection Ratio Quiescent Current vs. Supply Voltage 120 120 PSRR+ 100 Supply current (uA) 100 PSRR- 80 PSRR(dB) 50 150 60 40 20 80 60 40 20 0 0 -20 1.5 0.1 10 1k Frequency(Hz) www.3peakic.com.cn 100k 2 2.5 3 3.5 4 4.5 5 Supply Voltage (V) Rev. A.02 5 LMV321A / LMV358A / LMV324A 80μA, 1.0MHz, Micro-Power Rail-to-Rail I/O Op Amps Typical Performance Characteristics VS = ±2.75V, VCM = 0V, RL = Open, unless otherwise specified. (Continued) PSRR vs. Temperature CMRR vs. Temperature 140 120 120 CMRR(-dB) PSRR(-dB) 100 80 60 100 80 60 40 40 20 20 0 0 -50 0 50 100 -50 150 0 50 100 150 Temperature(℃) Temperature(℃) EMIRR IN+ vs. Frequency Large-Scale Step Response 90 Gain = 1 RL = 10kΩ 2V/div 80 EMIRR IN+ (dB) 70 60 50 40 30 2V/div 20 10 0 1 10 100 1000 Time (50μs/div) Frequency (MHz) Gain = +10 ±V = ±2.5V 1V/div Time (50μs/div) 6 Positive Over-Voltage Recovery 2V/div Gain = +10 ±V = ±2.5V 1V/div 2V/div Negative Over-Voltage Recovery Rev. A.02 Time (50μs/div) www.3peakic.com.cn LMV321A/LMV358A/ LMV324A 80μA, 1.0MHz, Micro-Power Rail-to-Rail I/O Op Amps Typical Performance Characteristics VS = ±2.75V, VCM = 0V, RL = Open, unless otherwise specified. (Continued) 0.1 Hz TO 10 Hz Input Voltage Noise Offset Voltage vs Common-Mode Voltage 1500 5μV/div Offset voltage Change(μV) 1000 500 0 -500 -1000 -1500 0 1 Time (1s/div) 3 4 5 Common-mode voltage(V) Positive Output Swing vs. Load Current Negative Output Swing vs. Load Current 120 0 100 -20 25℃ -40℃ 125℃ -40 80 -60 Iout(mA) Iout(mA) 2 60 -80 40 25℃ -100 -40℃ 20 -120 125℃ 0 -140 0 1 2 3 4 5 0 1 2 3 4 5 Vout Dropout (V) Vout Dropout (V) Offset Voltage vs. Temperature Offset voltage Change(μV) 80 70 60 50 40 30 20 10 0 -50 0 50 100 150 Temperature(℃) www.3peakic.com.cn Rev. A.02 7 LMV321A / LMV358A / LMV324A 80μA, 1.0MHz, Micro-Power Rail-to-Rail I/O Op Amps Pin Functions -IN: Inverting Input of the Amplifier. possible should be used between power supply pins or +IN: Non-Inverting Input of Amplifier. between supply pins and ground. OUT: Amplifier Output. The voltage range extends to V- or -Vs: Negative Power Supply. It is normally tied to within mV of each supply rail. ground. It can also be tied to a voltage other than V+ or +Vs: Positive Power Supply. Typically the voltage ground as long as the voltage between V+ and V– is from is from 2.1V to 6.0V. Split supplies are possible as long 2.1V to 6.0V. If it is not connected to ground, bypass it as the voltage between V+ and V– is between 2.1V and with a capacitor of 0.1μF as close to the part as possible. 6.0V. A bypass capacitor of 0.1μF as close to the part as Operation The LMV321A/358A/324A input signal range extends beyond the negative and positive power supplies. The output can even extend all the way to the negative supply. The input stage is comprised of two CMOS differential amplifiers, a PMOS stage and NMOS stage that are active over different ranges of common mode input voltage. The Class-AB control buffer and output bias stage uses a proprietary compensation technique to take full advantage of the process technology to drive very high capacitive loads. This is evident from the transient over shoot measurement plots in the Typical Performance Characteristics. Applications Information Low Supply Voltage and Low Power Consumption The LMV321A/358A/324A of operational amplifiers can operate with power supply voltages from 2.1V to 6.0V. Each amplifier draws only 80μA quiescent current. The low supply voltage capability and low supply current are ideal for portable applications demanding HIGH CAPACITIVE LOAD DRIVING CAPABILITY and WIDE BANDWIDTH. The LMV321A/358A/324A is optimized for wide bandwidth low power applications. They have an industry leading high GBWP to power ratio and are unity gain stable for ANY CAPACITIVE load. When the load capacitance increases, the increased capacitance at the output pushed the non-dominant pole to lower frequency in the open loop frequency response, lowering the phase and gain margin. Higher gain configurations tend to have better capacitive drive capability than lower gain configurations due to lower closed loop bandwidth and hence higher phase margin. Low Input Referred Noise The LMV321A/358A/324A provides a low input referred noise density of 27nV/√Hz at 1kHz. The voltage noise will grow slowly with the frequency in wideband range, and the input voltage noise is typically 7μVP-P at the frequency of 0.1Hz to 10Hz. Low Input Offset Voltage The LMV321A/358A/324A has a low offset voltage tolerance of 400μV maximum which is essential for precision applications. The offset voltage is trimmed with a proprietary trim algorithm to ensure low offset voltage for precision signal processing requirement. Low Input Bias Current The LMV321A/358A/324A is a CMOS OPA family and features very low input bias current in pA range. The low input bias current allows the amplifiers to be used in applications with high resistance sources. Care must be taken to minimize PCB Surface Leakage. See below section on “PCB Surface Leakage” for more details. PCB Surface Leakage 8 Rev. A.02 www.3peakic.com.cn LMV321A/LMV358A/ LMV324A 80μA, 1.0MHz, Micro-Power Rail-to-Rail I/O Op Amps In applications where low input bias current is critical, Printed Circuit Board (PCB) surface leakage effects need to be considered. Surface leakage is caused by humidity, dust or other contamination on the board. Under low humidity 12 conditions, a typical resistance between nearby traces is 10 Ω. A 5V difference would cause 5pA of current to flow, which is greater than the LMV321A/358A/324A OPA‟s input bias current at +27°C (±1pA, typical). It is recommended to use multi-layer PCB layout and route the OPA‟s -IN and +IN signal under the PCB surface. The effective way to reduce surface leakage is to use a guard ring around sensitive pins (or traces). The guard ring is biased at the same voltage as the sensitive pin. An example of this type of layout is shown in Figure 1 for Inverting Gain application. 1. For Non-Inverting Gain and Unity-Gain Buffer: a) Connect the non-inverting pin (VIN+) to the input with a wire that does not touch the PCB surface. b) Connect the guard ring to the inverting input pin (VIN–). This biases the guard ring to the Common Mode input voltage. 2. For Inverting Gain and Trans-impedance Gain Amplifiers (convert current to voltage, such as photo detectors): a) Connect the guard ring to the non-inverting input pin (VIN+). This biases the guard ring to the same reference voltage as the op-amp (e.g., VDD/2 or ground). b) Connect the inverting pin (VIN–) to the input with a wire that does not touch the PCB surface. Guard Ring VIN+ VIN- +VS Figure 1 Ground Sensing and Rail to Rail Output The LMV321A/358A/324A has excellent output drive capability, delivering over 100mA of output drive current. The output stage is a rail-to-rail topology that is capable of swinging to within 5mV of either rail. Since the inputs can go 100mV beyond either rail, the op-amp can easily perform „True Ground Sensing‟. The maximum output current is a function of total supply voltage. As the supply voltage to the amplifier increases, the output current capability also increases. Attention must be paid to keep the junction temperature of the IC below 150°C when the output is in continuous short-circuit. The output of the amplifier has reverse-biased ESD diodes connected to each supply. The output should not be forced more than 0.5V beyond either supply, otherwise current will flow through these diodes. ESD The LMV321A/358A/324A has reverse-biased ESD protection diodes on all inputs and output. Input and out pins cannot be biased more than 200mV beyond either supply rail. Feedback Components and Suppression of Ringing Care should be taken to ensure that the pole formed by the feedback resistors and the parasitic capacitance at the inverting input does not degrade stability. For example, in a gain of +2 configuration with gain and feedback resistors of 10k, a poorly designed circuit board layout with parasitic capacitance of 5pF (part +PC board) at the amplifier‟s inverting input will cause the amplifier to ring due to a pole formed at 3.2MHz. An additional capacitor of 5pF across the feedback resistor as shown in Figure 2 will eliminate any ringing. Careful layout is extremely important because low power signal conditioning applications demand high-impedance circuits. The layout should also minimize stray capacitance at the OPA‟s inputs. However some stray capacitance may be unavoidable and it may be necessary to add a 2pF to 10pF capacitor across the feedback resistor. Select the smallest capacitor value that ensures stability. www.3peakic.com.cn Rev. A.02 9 LMV321A / LMV358A / LMV324A 80μA, 1.0MHz, Micro-Power Rail-to-Rail I/O Op Amps 5pF 10kΩ VOUT 10kΩ CPAR VIN Figure 2 Driving Large Capacitive Load The LMV321A/358A/324A of OPA is designed to drive large capacitive loads. Refer to Typical Performance Characteristics for “Phase Margin vs. Load Capacitance”. As always, larger load capacitance decreases overall phase margin in a feedback system where internal frequency compensation is utilized. As the load capacitance increases, the feedback loop‟s phase margin decreases, and the closed-loop bandwidth is reduced. This produces gain peaking in the frequency response, with overshoot and ringing in output step response. The unity-gain buffer (G = +1V/V) is the most sensitive to large capacitive loads. When driving large capacitive loads with the LMV321A/358A/324A (e.g., > 200 pF when G = +1V/V), a small series resistor at the output (RISO in Figure 3) improves the feedback loop‟s phase margin and stability by making the output load resistive at higher frequencies. RISO VOUT VIN CLOAD Figure 3 Power Supply Layout and Bypass The LMV321A/358A/324A OPA‟s power supply pin (VDD for single-supply) should have a local bypass capacitor (i.e., 0.01μF to 0.1μF) within 2mm for good high frequency performance. It can also use a bulk capacitor (i.e., 1μF or larger) within 100mm to provide large, slow currents. This bulk capacitor can be shared with other analog parts. Ground layout improves performance by decreasing the amount of stray capacitance and noise at the OPA‟s inputs and outputs. To decrease stray capacitance, minimize PC board lengths and resistor leads, and place external components as close to the op amps‟ pins as possible. Proper Board Layout To ensure optimum performance at the PCB level, care must be taken in the design of the board layout. To avoid leakage currents, the surface of the board should be kept clean and free of moisture. Coating the surface creates a barrier to moisture accumulation and helps reduce parasitic resistance on the board. Keeping supply traces short and properly bypassing the power supplies minimizes power supply disturbances due to output current variation, such as when driving an ac signal into a heavy load. Bypass capacitors should be connected as closely as possible to the device supply pins. Stray capacitances are a concern at the outputs and the inputs of the amplifier. It is recommended that signal traces be kept at least 5mm from supply lines to minimize coupling. A variation in temperature across the PCB can cause a mismatch in the Seebeck voltages at solder joints and other points where dissimilar metals are in contact, resulting in thermal voltage errors. To minimize these thermocouple effects, orient resistors so heat sources warm both ends equally. Input signal paths should contain matching numbers 10 Rev. A.02 www.3peakic.com.cn LMV321A/LMV358A/ LMV324A 80μA, 1.0MHz, Micro-Power Rail-to-Rail I/O Op Amps and types of components, where possible to match the number and type of thermocouple junctions. For example, dummy components such as zero value resistors can be used to match real resistors in the opposite input path. Matching components should be located in close proximity and should be oriented in the same manner. Ensure leads are of equal length so that thermal conduction is in equilibrium. Keep heat sources on the PCB as far away from amplifier input circuitry as is practical. The use of a ground plane is highly recommended. A ground plane reduces EMI noise and also helps to maintain a constant temperature across the circuit board. Instrumentation Amplifier The LMV321A/358A/324A OPA is well suited for conditioning sensor signals in battery-powered applications. Figure 4 shows a two op-amp instrumentation amplifier, using the LMV321A/358A/324A OPA. The circuit works well for applications requiring rejection of Common Mode noise at higher gains. The reference voltage (VREF) is supplied by a low-impedance source. In single voltage supply applications, VREF is typically VDD/2. RG R1 VREF R2 R2 R1 VOUT V2 V1 VOUT =(V1  V2 )(1  R1 2 R1  )  VREF R2 RG Figure 4 Gain-of-100 Amplifier Circuit Figure 5 shows a Gain-of-100 amplifier circuit using two LMV321A/358A/324A OPAs. It draws 74uA total current from supply rail, and has a -3dB frequency at 100kHz. Figure 6 shows the small signal frequency response of the circuit. +0.9V VIN VOUT -0.9V 90.9k 10k 90.9k 10k Figure 5: 100kHz, 74μA Gain-of-100 Amplifier www.3peakic.com.cn Rev. A.02 11 LMV321A / LMV358A / LMV324A 80μA, 1.0MHz, Micro-Power Rail-to-Rail I/O Op Amps Figure 6: Frequency response of 100kHz, 74uA Gain-of-100 Amplifier Buffered Chemical Sensor (pH) Probe The LMV321A/358A/324A OPA has input bias current in the pA range. This is ideal in buffering high impedance chemical sensors such as pH probe. As an example, the circuit in Figure 7 eliminates expansive low-leakage cables that that is required to connect pH probe to metering ICs such as ADC, AFE and/or MCU. A LMV321A/358A/324A OPA and a lithium battery are housed in the probe assembly. A conventional low-cost coaxial cable can be used to carry OPA‟s output signal to subsequent ICs for pH reading. BATTERY 3V (DURACELL DL1620) R1 10M GENERAL PURPOSE COMBINATION pH PROBE (CORNING 476540) pH PROBE COAX To ADC/AFE/MCU R2 10M ALL COMPONENTS CONTAJNED WITHIN THE pH PROBE Figure 7: Buffer pH Probe Two-Pole Micro-power Sallen-Key Low-Pass Filter Figure 8 shows a micro-power two-pole Sallen-Key Low-Pass Filter with 400Hz cut-off frequency. For best results, the filter‟s cut-off frequency should be 8 to 10 times lower than the OPA‟s crossover frequency. Additional OPA‟s phase margin shift can be avoided if the OPA‟s bandwidth-to-signal ratio is greater than 8. The design equations for the 2-pole Sallen-Key low-pass filter are given below with component values selected to set a 400Hz low-pass filter cutoff frequency: 12 Rev. A.02 www.3peakic.com.cn LMV321A/LMV358A/ LMV324A 80μA, 1.0MHz, Micro-Power Rail-to-Rail I/O Op Amps C1 400pF VIN VOUT R1 1MΩ C2 400pF R2 1MΩ R1 = R 2 = R = 1M C1 = C2 = C = 400pF Q = Filter Peaking Factor = 1 R4 2MΩ R3 2MΩ f -3dB = 1/(2  RC ) = 400Hz R 3 = R 4 /(2-1/Q) ; with Q = 1, R 3 =R 4 Figure 8 Portable Gas Sensor Amplifier Gas sensors are used in many different industrial and medical applications. Gas sensors generate a current that is proportional to the percentage of a particular gas concentration sensed in an air sample. This output current flows through a load resistor and the resultant voltage drop is amplified. Depending on the sensed gas and sensitivity of the sensor, the output current can be in the range of tens of microamperes to a few milli-amperes. Gas sensor datasheets often specify a recommended load resistor value or a range of load resistors from which to choose. There are two main applications for oxygen sensors – applications which sense oxygen when it is abundantly present (that is, in air or near an oxygen tank) and those which detect traces of oxygen in parts-per-million concentration. In medical applications, oxygen sensors are used when air quality or oxygen delivered to a patient needs to be monitored. In fresh air, the concentration of oxygen is 20.9% and air samples containing less than 18% oxygen are considered dangerous. In industrial applications, oxygen sensors are used to detect the absence of oxygen; for example, vacuum-packaging of food products. The circuit in Figure 9 illustrates a typical implementation used to amplify the output of an oxygen detector. With the components shown in the figure, the circuit consumes less than 100μA of supply current ensuring that small form-factor single- or button-cell batteries (exhibiting low mAh charge ratings) could last beyond the operating life of the oxygen sensor. The precision specifications of these amplifiers, such as their low offset voltage, low TC-VOS, low input bias current, high CMRR, and high PSRR are other factors which make these amplifiers excellent choices for this application. 10 MΩ 1% 100 kΩ 1% VOUT Oxygen Sensor City Technology 4OX2 I O2 100 kΩ 1% 100 Ω 1% VOUT  1Vin Air ( 21% O 2 ) I DD  0.7uA Figure 9 www.3peakic.com.cn Rev. A.02 13 LMV321A / LMV358A / LMV324A 80μA, 1.0MHz, Micro-Power Rail-to-Rail I/O Op Amps Revision History The revision history provided is for informational purposes only and is believed to be accurate, but not warranted. Please go to web to make sure you have the latest revision. Revision Rev. A 14 Rev. A.02 Change Initial Release www.3peakic.com.cn LMV321A/LMV358A/ LMV324A 80μA, 1.0MHz, Micro-Power Rail-to-Rail I/O Op Amps Package Outline Dimensions SC70-5 /SOT-353 Dimensions Dimensions In Millimeters In Inches Min Max Min Max A 0.900 1.100 0.035 0.043 A1 0.000 0.100 0.000 0.004 A2 0.900 1.000 0.035 0.039 b 0.150 0.350 0.006 0.014 C 0.080 0.150 0.003 0.006 D 2.000 2.200 0.079 0.087 E 1.150 1.350 0.045 0.053 E1 2.150 2.450 0.085 0.096 e 0.650TYP 0.026TYP e1 1.200 0.047 L 0.525REF 0.021REF L1 0.260 0.460 0.010 0.018 θ 0° 8° 0° 8° Symbol 1.400 0.055 SOT23-5 Dimensions Dimensions In Millimeters In Inches Min Max Min Max A 1.050 1.250 0.041 0.049 A1 0.000 0.100 0.000 0.004 A2 1.050 1.150 0.041 0.045 b 0.300 0.400 0.012 0.016 C 0.100 0.200 0.004 0.008 D 2.820 3.020 0.111 0.119 E 1.500 1.700 0.059 0.067 E1 2.650 2.950 0.104 0.116 e 0.950TYP 0.037TYP e1 1.800 0.071 L 0.700REF 0.028REF L1 0.300 0.460 0.012 0.024 θ 0° 8° 0° 8° Symbol www.3peakic.com.cn 2.000 Rev. A.02 0.079 15 LMV321A / LMV358A / LMV324A 80μA, 1.0MHz, Micro-Power Rail-to-Rail I/O Op Amps Package Outline Dimensions SOP-8 A2 C θ L1 A1 e E D Symbol E1 b 16 Rev. A.02 Dimensions Dimensions In In Millimeters Inches Min Max Min Max A1 0.100 0.250 0.004 0.010 A2 1.350 1.550 0.053 0.061 b 0.330 0.510 0.013 0.020 C 0.190 0.250 0.007 0.010 D 4.780 5.000 0.188 0.197 E 3.800 4.000 0.150 0.157 E1 5.800 6.300 0.228 0.248 e 1.270 TYP 0.050 TYP L1 0.400 1.270 0.016 0.050 θ 0° 8° 0° 8° www.3peakic.com.cn LMV321A/LMV358A/ LMV324A 80μA, 1.0MHz, Micro-Power Rail-to-Rail I/O Op Amps Package Outline Dimensions MSOP-8 Dimensions Dimensions In In Millimeters Inches Min Max Min Max A 0.800 1.200 0.031 0.047 A1 0.000 0.200 0.000 0.008 A2 0.760 0.970 0.030 0.038 b 0.30 TYP 0.012 TYP C 0.15 TYP 0.006 TYP D 2.900 e 0.65 TYP E 2.900 3.100 0.114 0.122 E1 4.700 5.100 0.185 0.201 L1 0.410 0.650 0.016 0.026 θ 0° 6° 0° 6° Symbol E E1 A A2 e b D 3.100 0.114 0.122 0.026 A1 R1 R θ L1 www.3peakic.com.cn L L2 Rev. A.02 17 LMV321A / LMV358A / LMV324A 80μA, 1.0MHz, Micro-Power Rail-to-Rail I/O Op Amps Package Outline Dimensions TSSOP-14 Dimensions E1 E A A2 e c D Symbol In Millimeters MIN TYP MAX A - - 1.20 A1 0.05 - 0.15 A2 0.90 1.00 1.05 b 0.20 - 0.28 c 0.10 - 0.19 D 4.86 4.96 5.06 E 6.20 6.40 6.60 E1 4.30 4.40 4.50 e L A1 R1 R 0.65 BSC 0.45 0.60 0.75 L1 1.00 REF L2 0.25 BSC R 0.09 - - θ 0° - 8° θ L1 18 Rev. A.02 L L2 www.3peakic.com.cn LMV321A/LMV358A/ LMV324A 80μA, 1.0MHz, Micro-Power Rail-to-Rail I/O Op Amps Package Outline Dimensions SOP-14 D E1 Dimensions E In Millimeters Symbol e b A A2 A1 MIN TYP MAX A 1.35 1.60 1.75 A1 0.10 0.15 0.25 A2 1.25 1.45 1.65 b 0.36 D 8.53 8.63 8.73 E 5.80 6.00 6.20 E1 3.80 3.90 4.00 e L www.3peakic.com.cn 1.27 BSC 0.45 0.60 0.80 L1 1.04 REF L2 0.25 BSC θ L L1 0.49 0° 8° θ L2 Rev. A.02 19
LMV358A-SR 价格&库存
很抱歉,暂时无法提供与“LMV358A-SR”相匹配的价格&库存,您可以联系我们找货
LMV358A-SR
    • 1+0.59700
    • 200+0.38640
