74LVT125BQ
74LVT125BQ
    NEXPERIA(安世)
74LVT125BQ 数据手册
74LVT125; 74LVTH125 3.3 V quad buffer; 3-state Rev. 8 — 18 August 2021 Product data sheet 1. General description The 74LVT125; 74LVTH125 is a quad buffer/line driver with 3-state outputs controlled by the output enable inputs (nOE). A HIGH on nOE causes the outputs to assume a high impedance OFF-state. Bus hold data inputs eliminate the need for external pull-up resistors to define unused inputs. This device is fully specified for partial power down applications using IOFF. The IOFF circuitry disables the output, preventing the potentially damaging backflow current through the device when it is powered down. 2. Features and benefits • • • • • • • • • • • • • • • • Quad bus interface 3-state buffers Wide supply voltage range from 2.7 to 3.6 V BiCMOS high speed and output drive Output capability: +64 mA and -32 mA Direct interface with TTL levels Overvoltage tolerant inputs to 5.5 V Bus hold data inputs eliminate need for external pull-up resistors to hold unused inputs Live insertion and extraction permitted No bus current loading when output is tied to 5 V bus Power-up 3-state IOFF circuitry provides partial Power-down mode operation Latch-up performance exceeds 500 mA per JESD 78 Class II Level B Complies with JEDEC standard JESD8C (2.7 V to 3.6 V) ESD protection: • HBM EIA/JESD22-A114-A exceeds 2000V • MM EIA/JESD22-A115-A exceeds 200V Specified from -40 °C to 85 °C 3. Ordering information Table 1. Ordering information Type number Package 74LVT125D Temperature range Name Description Version -40 °C to +85 °C SO14 plastic small outline package; 14 leads; body width 3.9 mm SOT108-1 -40 °C to +85 °C TSSOP14 plastic thin shrink small outline package; 14 leads; body width 4.4 mm SOT402-1 -40 °C to +85 °C DHVQFN14 plastic dual in-line compatible thermal enhanced very thin quad flat package; no leads; 14 terminals; body 2.5 × 3 × 0.85 mm SOT762-1 74LVTH125D 74LVT125PW 74LVTH125PW 74LVT125BQ 74LVTH125BQ 74LVT125; 74LVTH125 Nexperia 3.3 V quad buffer; 3-state 4. Functional diagram 2 1A 1 1OE 5 2A 4 2OE 9 3A 10 3OE 12 4A 13 4OE 1Y 3 2 2Y 1 6 3Y 6 4 8 9 8 10 4Y 11 3 EN1 5 11 13 nOE mna229 Logic symbol Fig. 2. nY nA 12 mna228 Fig. 1. 1 IEC logic symbol mna227 Fig. 3. Logic diagram (one buffer) 5. Pinning information 5.1. Pinning 1 1Y 3 12 4A 4 11 4Y 2A 5 2Y 6 2 13 4OE 1Y 3 12 4A 2OE 4 11 4Y 7 8 2A 5 10 3OE 3Y 2Y 6 9 7 8 10 3OE 9 3A 001aac477 (1) This is not a ground pin. There is no electrical or mechanical requirement to solder the pad. In case soldered, the solder land should remain floating or connected to GND. 3Y Pin configuration SOT108-1 (SO14) and SOT402-1 (TSSOP14) Product data sheet GND(1) Transparent top view 3A 001aac476 74LVT_LVTH125 13 4OE 2OE 14 VCC 1A GND Fig. 4. 2 GND 1 1A 14 VCC terminal 1 index area 74LVT125 74LVTH125 1OE 1OE 74LVT125 74LVTH125 Fig. 5. Pin configuration SOT762-1 (DHVQFN14) All information provided in this document is subject to legal disclaimers. Rev. 8 — 18 August 2021 © Nexperia B.V. 2021. All rights reserved 2 / 13 74LVT125; 74LVTH125 Nexperia 3.3 V quad buffer; 3-state 5.2. Pin description Table 2. Pin description Symbol Pin Description 1OE 1 1 output enable input (active LOW) 1A 2 1 data input 1Y 3 1 data output 2OE 4 2 output enable input (active LOW) 2A 5 2 data input 2Y 6 2 data output GND 7 ground (0 V) 3Y 8 3 data output 3A 9 3 data input 3OE 10 3 output enable input (active LOW) 4Y 11 4 data output 4A 12 4 data input 4OE 13 4 output enable input (active LOW) VCC 14 supply voltage 6. Functional description Table 3. Function table H = HIGH voltage level; L = LOW voltage level; X = don’t care; Z = high-impedance OFF-state. Control Input Output nOE nA nY L L L L H H H X Z 74LVT_LVTH125 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 8 — 18 August 2021 © Nexperia B.V. 2021. All rights reserved 3 / 13 74LVT125; 74LVTH125 Nexperia 3.3 V quad buffer; 3-state 7. Limiting values Table 4. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V). Symbol Parameter Conditions Min Max Unit -0.5 +4.6 V [1] -0.5 +7.0 V [1] VCC supply voltage VI input voltage VO output voltage output in OFF-state or HIGH-state -0.5 +7.0 V IIK input clamping current VI < 0 V - -50 mA IOK output clamping current VO < 0 V - -50 mA IO output current output in LOW-state - 128 mA output in HIGH-state - -64 mA -65 +150 °C - 150 °C Tstg storage temperature Tj junction temperature [1] [2] [2] The input and output negative voltage ratings may be exceeded if the input and output clamp current ratings are observed. The performance capability of a high-performance integrated circuit in conjunction with its thermal environment can create junction temperatures which are detrimental to reliability. 8. Recommended operating conditions Table 5. Recommended operating conditions Symbol Parameter Conditions Min Typ Max Unit VCC supply voltage 2.7 - 3.6 V VI input voltage 0 - 5.5 V VIH HIGH-level input voltage 2.0 - - V VIL LOW-level input voltage - - 0.8 V IOH HIGH-level output current - - -32 mA IOL LOW-level output current none - - 32 mA current duty cycle ≤ 50 %;f ≥ 1 kHz - - 64 mA 0 - 10 ns/V -40 - +85 °C Δt/ΔV input transition rise and fall rate Tamb ambient temperature in free air 9. Static characteristics Table 6. Static characteristics At recommended operating conditions; voltages are referenced to GND (ground = 0 V). Symbol Parameter Conditions Min Typ [1] Max Unit - -0.9 -1.2 V - V Tamb = -40 °C to +85 °C VIK input clamping voltage IIK = -18 mA; VCC = 2.7 V VOH HIGH-level output voltage IOH = -100 μA; VCC = 2.7 V to 3.6 V 74LVT_LVTH125 Product data sheet VCC - 0.2 VCC - 0.1 IOH = -8 mA; VCC = 2.7 V 2.4 2.5 - V IOH = -32 mA; VCC = 3.0 V 2.0 2.2 - V All information provided in this document is subject to legal disclaimers. Rev. 8 — 18 August 2021 © Nexperia B.V. 2021. All rights reserved 4 / 13 74LVT125; 74LVTH125 Nexperia 3.3 V quad buffer; 3-state Symbol Parameter Conditions VOL VCC = 2.7 V LOW-level output voltage Min Typ [1] Max Unit IOL = 100 μA - 0.1 0.2 V IOL = 24 mA - 0.3 0.5 V IOL = 16 mA - 0.25 0.4 V IOL = 32 mA - 0.3 0.5 V IOL = 64 mA - 0.4 0.55 V - 1 10 μA - ±0.1 ±1 μA VCC = 3.6 V; VI = VCC - 0.1 1 μA VCC = 3.6 V; VI = 0 V - -1 -5 μA - 1 ±100 μA 75 150 - μA - -150 -75 μA VCC = 3.0 V II input leakage current all input pins VCC = 0 V or 3.6 V; VI = 5.5 V control pins VCC = 3.6 V; VI = VCC or GND data pins [2] IOFF power-off leakage current VCC = 0 V; VI or VO = 0 V to 4.5 V IBHL bus hold LOW current VCC = 3 V; VI = 0.8 V IBHH bus hold HIGH current VCC = 3 V; VI = 2.0 V IBHLO bus hold LOW overdrive current VCC = 3.6 V; VI = 0 V to 3.6 V 500 - - μA IBHHO bus hold HIGH overdrive current VCC = 3.6 V; VI = 0 V to 3.6 V - - -500 μA ILO output leakage current output in HIGH-state when VO > VCC; VO = 5.5 V; VCC = 3.0 V - 60 125 μA - ±1 ±100 μA output HIGH: VO = 3.0 V - 1 5 μA output LOW: VO = 0.5 V - -1 -5 μA outputs HIGH - 0.13 0.19 mA outputs LOW - 2 7 mA [5] - 0.13 0.19 mA [6] - 0.1 0.2 mA IO(pu/pd) power-up/power-down output current VCC ≤ 1.2 V; VO = 0.5 V to VCC; VI = GND or VCC; nOE = don’t care IOZ VCC = 3.6 V; VI = VIH or VIL OFF-state output current ICC supply current [3] [4] VCC = 3.6 V; VI = GND or VCC; IO = 0 A outputs disabled ΔICC additional supply current per input pin; VCC = 3 V to 3.6 V; one input at VCC - 0.6 V and other inputs at VCC or GND CI input capacitance VI = 0 V or 3.0 V - 4 - pF CO output capacitance outputs disabled; VO = 0 V or 3.0 V - 8 - pF [1] [2] [3] [4] [5] [6] Typical values are measured at VCC = 3.3 V and Tamb = 25 °C. Unused pins at VCC or GND. This is the bus hold overdrive current required to force the input to the opposite logic state. This parameter is valid for any VCC between 0 V and 1.2 V with a transition time of up to 10 ms. From VCC = 1.2 V to VCC = 3.0 V to 3.6 V a transition time of 100 μs is permitted. This parameter is valid for Tamb = 25 °C only. ICC is measured with outputs pulled to VCC or GND. This is the increase in supply current for each input at the specified voltage level other than VCC or GND. 74LVT_LVTH125 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 8 — 18 August 2021 © Nexperia B.V. 2021. All rights reserved 5 / 13 74LVT125; 74LVTH125 Nexperia 3.3 V quad buffer; 3-state 10. Dynamic characteristics Table 7. Dynamic characteristics Voltages are referenced to GND (ground = 0 V); for test circuit see Fig. 8. Symbol Parameter Conditions Min Typ [1] Max Unit Tamb = -40 °C to +85 °C tPLH nAn to nY; see Fig. 6 LOW to HIGH propagation delay VCC = 2.7 V VCC = 3.0 V to 3.6 V tPHL VCC = 2.7 V VCC = 3.0 V to 3.6 V VCC = 3.0 V to 3.6 V VCC = 2.7 V VCC = 3.0 V to 3.6 V VCC = 3.0 V to 3.6 V - - 4.9 ns 1.0 2.9 3.9 ns - - 6.0 ns 1.0 3.4 4.7 ns - - 6.5 ns 1.1 3.4 4.7 ns - - 5.7 ns 1.8 3.7 5.1 ns - - 4.0 ns 1.3 2.6 4.5 ns nOE to nY; see Fig. 7 LOW to OFF-state propagation delay VCC = 2.7 V VCC = 3.0 V to 3.6 V [1] ns nOE to nY; see Fig. 7 HIGH to OFF-state propagation delay VCC = 2.7 V tPLZ ns 4.0 nOE to nY; see Fig. 7 OFF-state to LOW propagation delay tPHZ 4.5 nOE to nY; see Fig. 7 OFF-state to HIGH propagation delay VCC = 2.7 V tPZL 2.7 nAn to nY; see Fig. 6 HIGH to LOW propagation delay tPZH 1.0 Typical values are at VCC = 3.3 V and Tamb = 25 °C. 10.1. Waveforms and test circuit VI nA input VM VM GND tPLH tPHL VOH VM nY output VOL VM mnb072 VM = 1.5 V. VOL and VOH are typical voltage output levels that occur with the output load. Fig. 6. Propagation delay input (nA) to output (nY) 74LVT_LVTH125 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 8 — 18 August 2021 © Nexperia B.V. 2021. All rights reserved 6 / 13 74LVT125; 74LVTH125 Nexperia 3.3 V quad buffer; 3-state VI nOE input VM GND tPZL tPLZ 3.0 V VM nY output VOL + 0.3 V VOL t PZH t PHZ VOH nY output VOH - 0.3 V VM 0V 001aac475 VM = 1.5 V. VOL and VOH are typical voltage output levels that occur with the output load. Fig. 7. Enable and disable times of 3-state outputs VI negative pulse tW 90 % VM 0V VI positive pulse 0V VM 10 % tf tr tr tf 90 % VM VM 10 % tW VEXT VCC PULSE GENERATOR VI RL VO DUT RT CL RL 001aae235 Test data is given in Table 8. Definitions test circuit: RL = Load resistance. CL = Load capacitance including jig and probe capacitance. RT = Termination resistance should be equal to output impedance Zo of the pulse generator. VEXT = Test voltage for switching times. Fig. 8. Test circuit for measuring switching times Table 8. Test data Input Load VEXT VI fi tW tr, tf CL RL tPHZ, tPZH tPLZ, tPZL tPLH, tPHL 2.7 V ≤ 10 MHz 500 ns ≤ 2.5 ns 50 pF 500 Ω GND 6V open 74LVT_LVTH125 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 8 — 18 August 2021 © Nexperia B.V. 2021. All rights reserved 7 / 13 74LVT125; 74LVTH125 Nexperia 3.3 V quad buffer; 3-state 11. Package outline SO14: plastic small outline package; 14 leads; body width 3.9 mm SOT108-1 D E A X c y HE v M A Z 8 14 A2 Q A (A 3) A1 pin 1 index θ Lp 1 L 7 e detail X w M bp 0 2.5 5 mm scale DIMENSIONS (inch dimensions are derived from the original mm dimensions) UNIT A max. A1 A2 A3 bp c D (1) E (1) e HE L Lp Q v w y Z (1) mm 1.75 0.25 0.10 1.45 1.25 0.25 0.49 0.36 0.25 0.19 8.75 8.55 4.0 3.8 1.27 6.2 5.8 1.05 1.0 0.4 0.7 0.6 0.25 0.25 0.1 0.7 0.3 inches 0.069 0.010 0.057 0.004 0.049 0.01 0.019 0.0100 0.35 0.014 0.0075 0.34 0.16 0.15 0.05 0.01 0.01 0.004 0.028 0.012 0.244 0.039 0.028 0.041 0.228 0.016 0.024 θ o 8 o 0 Note 1. Plastic or metal protrusions of 0.15 mm (0.006 inch) maximum per side are not included. REFERENCES OUTLINE VERSION IEC JEDEC SOT108-1 076E06 MS-012 Fig. 9. JEITA EUROPEAN PROJECTION ISSUE DATE 99-12-27 03-02-19 Package outline SOT108-1 (SO14) 74LVT_LVTH125 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 8 — 18 August 2021 © Nexperia B.V. 2021. All rights reserved 8 / 13 74LVT125; 74LVTH125 Nexperia 3.3 V quad buffer; 3-state TSSOP14: plastic thin shrink small outline package; 14 leads; body width 4.4 mm D SOT402-1 E A X c y HE v M A Z 8 14 Q A2 pin 1 index (A 3 ) A1 A θ Lp 1 L 7 detail X w M bp e 0 2.5 5 mm scale DIMENSIONS (mm are the original dimensions) UNIT A max. A1 A2 A3 bp c D (1) E (2) e HE L Lp Q v w y Z (1) θ mm 1.1 0.15 0.05 0.95 0.80 0.25 0.30 0.19 0.2 0.1 5.1 4.9 4.5 4.3 0.65 6.6 6.2 1 0.75 0.50 0.4 0.3 0.2 0.13 0.1 0.72 0.38 8o 0o Notes 1. Plastic or metal protrusions of 0.15 mm maximum per side are not included. 2. Plastic interlead protrusions of 0.25 mm maximum per side are not included. OUTLINE VERSION SOT402-1 REFERENCES IEC JEDEC JEITA EUROPEAN PROJECTION ISSUE DATE 99-12-27 03-02-18 MO-153 Fig. 10. Package outline SOT402-1 (TSSOP14) 74LVT_LVTH125 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 8 — 18 August 2021 © Nexperia B.V. 2021. All rights reserved 9 / 13 74LVT125; 74LVTH125 Nexperia 3.3 V quad buffer; 3-state DHVQFN14: plastic dual in-line compatible thermal enhanced very thin quad flat package; no leads; 14 terminals; body 2.5 x 3 x 0.85 mm B D SOT762-1 A A A1 E c detail X terminal 1 index area terminal 1 index area C e1 e v w b 2 6 C A B C y y1 C L 1 7 14 8 Eh e k 13 9 Dh X k 0 2 Dimensions (mm are the original dimensions) Unit max nom min mm A(1) 1 A1 b 0.05 0.30 0.02 0.25 0.00 0.18 4 mm scale c D(1) Dh E(1) Eh e e1 0.2 3.1 3.0 2.9 1.65 1.50 1.35 2.6 2.5 2.4 1.15 1.00 0.85 0.5 2 k L v 0.2 0.5 0.4 0.3 0.1 w y 0.05 0.05 y1 0.1 Note 1. Plastic or metal protrusions of 0.075 mm maximum per side are not included. Outline version SOT762-1 References IEC JEDEC JEITA sot762-1_po European projection Issue date 15-04-10 15-05-05 MO-241 Fig. 11. Package outline SOT762-1 (DHVQFN14) 74LVT_LVTH125 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 8 — 18 August 2021 © Nexperia B.V. 2021. All rights reserved 10 / 13 74LVT125; 74LVTH125 Nexperia 3.3 V quad buffer; 3-state 12. Abbreviations Table 9. Abbreviations Acronym Description BiCMOS Bipolar Complementary Metal Oxide Semiconductor CMOS Complementary Metal Oxide Semiconductor DUT Device Under Test ESD ElectroStatic Discharge HBM Human Body Model MM Machine Model TTL Transistor-Transistor Logic 13. Revision history Table 10. Revision history Document ID Release date Data sheet status Change notice Supersedes 74LVT_LVTH125 v.8 20210818 Product data sheet - Modifications: • • • • • The format of this data sheet has been redesigned to comply with the identity guidelines of Nexperia. Legal texts have been adapted to the new company name where appropriate. Type numbers 74LVT125DB and 74LVTH125DB (SOT337-1/SSOP14) removed. Section 1 and Section 2 updated. Fig. 7 aligned with test conditions (errata). 74LVT_LVTH125 v.7 20160531 Modifications: • • 74LVT_LVTH125 v.7 Product data sheet - 74LVT125 v.6 The format of this data sheet has been redesigned to comply with the new identity guidelines of NXP Semiconductors. Legal texts have been adapted to the new company name where appropriate. 74LVT_LVTH125 v.6 20060306 Modifications: • 74LVT125 v.5 20050210 Product data sheet - 74LVT125 v.4 74LVT125 v.4 20050207 Product data sheet - 74LVT125 v.3 74LVT125 v.3 20040624 Product data sheet - 74LVT125 v.2 74LVT125 v.2 19980219 Product specification - 74LVT125 v.1 74LVT125 v.1 - - - - 74LVT_LVTH125 Product data sheet Product data sheet - 74LVT125 v.5 Section 3: Added type numbers 74LVTH125D, 74LVTH125DB, 74LVTH125PW and 74LVTH125BQ. All information provided in this document is subject to legal disclaimers. Rev. 8 — 18 August 2021 © Nexperia B.V. 2021. All rights reserved 11 / 13 74LVT125; 74LVTH125 Nexperia 3.3 V quad buffer; 3-state 14. Legal information injury, death or severe property or environmental damage. Nexperia and its suppliers accept no liability for inclusion and/or use of Nexperia products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Data sheet status Quick reference data — The Quick reference data is an extract of the product data given in the Limiting values and Characteristics sections of this document, and as such is not complete, exhaustive or legally binding. Document status [1][2] Product status [3] Definition Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] [2] [3] Please consult the most recently issued document before initiating or completing a design. The term 'short data sheet' is explained in section "Definitions". The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the internet at https://www.nexperia.com. Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Nexperia sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between Nexperia and its customer, unless Nexperia and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the Nexperia product is deemed to offer functions and qualities beyond those described in the Product data sheet. Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, Nexperia does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Nexperia takes no responsibility for the content in this document if provided by an information source outside of Nexperia. In no event shall Nexperia be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation - lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Notwithstanding any damages that customer might incur for any reason whatsoever, Nexperia’s aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of Nexperia. Right to make changes — Nexperia reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. Suitability for use — Nexperia products are not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical systems or equipment, nor in applications where failure or malfunction of an Nexperia product can reasonably be expected to result in personal 74LVT_LVTH125 Product data sheet Applications — Applications that are described herein for any of these products are for illustrative purposes only. Nexperia makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using Nexperia products, and Nexperia accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the Nexperia product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. Nexperia does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using Nexperia products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). Nexperia does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — Nexperia products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nexperia.com/profile/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Nexperia hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Nexperia products by customer. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from competent authorities. Non-automotive qualified products — Unless this data sheet expressly states that this specific Nexperia product is automotive qualified, the product is not suitable for automotive use. It is neither qualified nor tested in accordance with automotive testing or application requirements. Nexperia accepts no liability for inclusion and/or use of non-automotive qualified products in automotive equipment or applications. In the event that customer uses the product for design-in and use in automotive applications to automotive specifications and standards, customer (a) shall use the product without Nexperia’s warranty of the product for such automotive applications, use and specifications, and (b) whenever customer uses the product for automotive applications beyond Nexperia’s specifications such use shall be solely at customer’s own risk, and (c) customer fully indemnifies Nexperia for any liability, damages or failed product claims resulting from customer design and use of the product for automotive applications beyond Nexperia’s standard warranty and Nexperia’s product specifications. Translations — A non-English (translated) version of a document is for reference only. The English version shall prevail in case of any discrepancy between the translated and English versions. Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. All information provided in this document is subject to legal disclaimers. Rev. 8 — 18 August 2021 © Nexperia B.V. 2021. All rights reserved 12 / 13 74LVT125; 74LVTH125 Nexperia 3.3 V quad buffer; 3-state Contents 1. General description...................................................... 1 2. Features and benefits.................................................. 1 3. Ordering information....................................................1 4. Functional diagram.......................................................2 5. Pinning information......................................................2 5.1. Pinning.........................................................................2 5.2. Pin description............................................................. 3 6. Functional description................................................. 3 7. Limiting values............................................................. 4 8. Recommended operating conditions..........................4 9. Static characteristics....................................................4 10. Dynamic characteristics............................................ 6 10.1. Waveforms and test circuit........................................ 6 11. Package outline.......................................................... 8 12. Abbreviations............................................................ 11 13. Revision history........................................................11 14. Legal information......................................................12 © Nexperia B.V. 2021. All rights reserved For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 18 August 2021 74LVT_LVTH125 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 8 — 18 August 2021 © Nexperia B.V. 2021. All rights reserved 13 / 13
74LVT125BQ 价格&库存
很抱歉,暂时无法提供与“74LVT125BQ”相匹配的价格&库存,您可以联系我们找货
