DSK22 THRU DSK210
SURFACE MOUNT SCHOTTKY BARRIER RECTIFIER
Reverse Voltage - 20 to 100 Volts
FEATURES
SOD-123FL
The plastic package carries Underwriters Laboratory
Flammability Classification 94V-0
Metal silicon junction,majority carrier conduction
Low power loss,high efficiency
High forward surge current capability
High temperature soldering guaranteed:
250 C/10 seconds,0.375”(9.5mm) lead length,
5 lbs. (2.3kg) tension
1.8± 0.1
1.0±0.2
Cathode Band
Top View
0.10-0.30
2.8±0.1
1.3± 0.15
Forward Current - 2.0 Ampere
0.6±0.25
MECHANICAL DATA
Case: JEDEC SOD-123FL molded plastic body
Terminals: Solderable per MIL-STD-750,
Method 2026
Polarity: Color band denotes cathode end
Mounting Position: Any
Weight:0.0007 ounce, 0.02 grams
3.7±0.2
Dimensions in millimeters
MAXIMUM RATINGS AND ELECTRICAL CHARACTERISTICS
Ratings at 25 C ambient temperature unless otherwise specified.
Single phase half-wave 60Hz,resistive or inductive load,for capacitive load current derate by 20%.
MDD Catalog Number
Maximum repetitive peak reverse voltage
Maximum RMS voltage
Maximum DC blocking voltage
Maximum average forward rectified current
Peak forward surge current
8.3ms single half sine-wave superimposed on
rated load (JEDEC Method)
Maximum instantaneous forward voltage at 2.0A
Maximum DC reverse current
TA=25 C
at rated DC blocking voltage
TA=100 C
Typical junction capacitance (NOTE 1)
Operating junction temperature range
Storage temperature range
SYMBOLS DSK22 DSK23 DSK24 DSK25 DSK26 DSK27 DSK28 DSK29 DSK210
K22
K23
K24
K25
K26
K27
K28
K29
K210
21
30
40
28
40
50
35
50
60
42
60
70
49
70
80
56
80
90
63
90
100
70
100
UNITS
I(AV)
2.0
VOLTS
VOLTS
VOLTS
Amp
IFSM
40.0
Amps
VRRM
VRMS
VDC
VF
CJ
0.85
0.5
IR
TJ
TSTG
0.70
0.55
5.0
10.0
80
220
-50 to +125
mA
pF
-50 to +150
-50 to +150
Volts
C
C
Note:1.Measured at 1MHz and applied reverse voltage of 4.0V D.C.
2014-03 01版
http://www.microdiode.com
1.6
Single Phase
Half Wave 60Hz
Resistive or
inductive Load
1.2
0.8
DSK22-DSK26
DSK27-DSK210
0.4
50
75
100
125
150
PEAK FORWARD SURGE CURRENT,
AMPERES
FIG. 1- FORWARD CURRENT DERATING CURVE
2.0
FIG. 2-MAXIMUM NON-REPETITIVE PEAK FORWARD
SURGE CURRENT
40
32
24
16
8
175
8.3ms SINGLE HALF SINE-WAVE
(JEDEC Method)
1
AMBIENT TEMPERATURE, C
FIG. 3-TYPICAL INSTANTANEOUS FORWARD
CHARACTERISTICS
1
TJ=25 C
PULSE WIDTH=300 µs
1%DUTY CYCLE
0.1
DSK22-DSK24
DSK25-DSK26
DSK27-DSK210
0.01
0.2
0.4
0.6
0.8
1.0
10
100
NUMBER OF CYCLES AT 60 Hz
1.1
INSTANTANEOUS REVERSE CURRENT,
MILLAMPERES
CURRENT,AMPERES
AVERAGE FORWARD RECTIFIED CURRENT,
AMPERES
RATINGS AND CHARACTERISTIC CURVES DSK22 THRU DSK210
FIG. 4-TYPICAL REVERSE CHARACTERISTICS
100
10
1
TJ=75 C
0.1
TJ=25 C
0.01
0.001
INSTANTANEOUS FORWARD VOLTAGE,
VOLTS
TJ=100 C
60
80
100
PERCENT OF PEAK REVERSE VOLTAGE,%
JUNCTION CAPACITANCE, pF
FIG. 5-TYPICAL JUNCTION CAPACITANCE
2000
1000
DSK22-DSK24
DSK25-DSK210
100
TJ=25 C
10
0.1
1.0
10
100
REVERSE VOLTAGE,VOLTS
2014-03 01版
很抱歉,暂时无法提供与“DSK24 K24”相匹配的价格&库存,您可以联系我们找货
