TS19820CS
Taiwan Semiconductor
Single-Stage Power Factor Correction Dimmable LED Driver
with 3.3V Voltage Regulator Output
DESCRIPTION
FEATURES
The TS19820 is a single-stage active power factor
correction (PFC) switch-mode power supply IC
supporting high PF over a wide AC input voltage
range.
Output current modulation dimming is
controlled from a dedicated pin capable of either PWM
or linear analog signal input. The TS19820 achieves
high
accuracy
lineand
load-regulation
in
discontinuous conduction mode (DCM) architecture.
Output switching regulation is controlled with pulse
frequency modulation (PFM) which is particularly
suited for high conversion efficiency and high PF even
at low output power levels. The TS19820 also features
a 3.3V LDO output for MCU applications. Integrated
protection features such as an external switching
MOSFET gate drive voltage clamp, VCC over-voltage
protection, and system output open/short circuit
protection increase system reliability.
SOP-8
Supports PWM & Linear dimming
Embedded 3.3V LDO output for MCU
Low cost BOM
High Power Factor >0.9
Pulse Frequency Modulation (PFM) Control
Discontinuous Conduction Mode Control
No Opto-Coupler Required
Gate output voltage clamp
LED open and short protection
Over Current Protection (OCP)
Internal Over Temperature Protection (OTP)
Low start-Up current
Compliant to RoHS Directive 2011/65/EU and in
accordance to WEEE 2002/96/EC.
● Halogen-Free according to IEC 61249-2-21
APPLICATION
Smart LED lighting
Infrared remote control light
Motion sensing LED light
Pin Definition:
1. CS
8. VCC
2. DIM
7. OUT
3. COM
6. GND
4. LDO
5. ZCDX
Notes: MSL 3 (Moisture Sensitivity Level) per J-STD-020
TYPICAL APPLICATION CIRCUIT
Fuse
MOV
AC Input
90V~264V
TS19820CS
CS
1
VCC
DIM
OUT
COM
GND
LDO
ZCDX
Version: A1806
TS19820CS
ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise specified) (Note 1)
PARAMETER
SYMBOL
LIMIT
UNIT
Power Supply Pin
VCC
40
V
DIM Voltage to GND
VRT
-0.3 to 5.5
V
OUT Voltage to GND
VOUT
-0.3 to 40
V
CS Voltage to GND
VCS
-0.3 to 5.5
V
ZCDX Voltage to GND
VZCDX
-0.3 to 40
V
LDO Voltage to GND
VLDO
-0.3 to 5.5
V
COM Voltage to GND
VCOM
-0.3 to 5.5
V
Operating Temperature Range
TOPR
-40 to 105
°C
Junction Temperature Range
TJ
-40 to +150
°C
Storage Temperature Range
TSTG
-65 to +150
°C
Lead Temperature (Soldering 10 sec)
TLEAD
260
°C
PD
0.6
W
HBM
2
kV
MM
200
V
SYMBOL
LIMIT
UNIT
Thermal Resistance - Junction to Case
RӨJC
50
°C/W
Thermal Resistance - Junction to Ambient
RӨJA
208
°C/W
SYMBOL
LIMIT
UNIT
Power Supply Pin
VCC
V
DIM Voltage to GND
VOTP
-0.3 to 5
V
OUT Voltage to GND
VOUT
-0.3 to 19
V
CS Voltage to GND
VCS
-0.3 to 5
V
VCOM
-0.3 to 5
V
VZCDX
3.5 to 20
V
Operating Junction Temperature Range
TJ
-40 to +125
°C
Operating Ambient Temperature Range
TOPA
-40 to +85
°C
Power Dissipation @ TA=25 °C
ESD Rating (Human Body Mode)
(Note 2)
ESD Rating (Machine Mode)
THERMAL PERFORMANCE
PARAMETER
RECOMMENDED OPERATING CONDITIONS
PARAMETER
COM Voltage to GND
ZCDX Voltage to GND
(Note 3)
2
(Note 3)
Version: A1806
TS19820CS
ELECTRICAL SPECIFICATIONS (VCC = 18V, TA = 25°C unless otherwise noted)
PARAMETER
CONDITIONS
SYMBOL
MIN
TYP
MAX
UNIT
VCC(ST)
57
µA
IOPA
2
2.6
mA
Under Voltage Lock Out (off)
VUVLO(off)
6.5
8
9.5
V
Under Voltage Lock Out (on)
VUVLO(on)
16
17.5
19
V
VOVP
30.5
32
33.5
V
VFB
0.19
0.2
0.21
V
CS Limit Voltage
VOCP
1.0
V
Leading-Edge Blanking Time
LEBt
280
Ns
fSTR
3
4.5
6
kHz
VLDO
3.1
3.3
3.5
V
REGLOAD
0.6
REGLINE
0.3
Supply Voltage
Start-up Current
VCC= VUVLO(on) -1V
Operating Current
With 1nF load on out pin
OVP Level on VCC Pin
Voltage Feedback
Feedback Reference Voltage
Current Sensing
Switching Frequency
Start Frequency
Low Drop Out regulator
Reference Voltage
VZCDX = 10V, Io=30mA
VZCD=Vo+6.7V
Load Regulation
Io=10mA~30mA
Vo+2.7V
很抱歉,暂时无法提供与“TS19820CS RLG”相匹配的价格&库存,您可以联系我们找货
