SK310
SK310
    DY(迪一电子)
    SMB
    100V, 3A, VF=0.85V @ 3A. 温度:-55~+150 C
SK310 数据手册
SK32 THRU SK325 3.0 AMP SURFACE MOUNT SCHOTTKY BARRIER RECTIFIERS Features ·Low Power Loss,High Efficiency · Ideally Suited for Automatic Assembly SMB/DO-214AA · For Use in Low Voltage Application · Plastic Case Material has UL Flammability 0.154(3.90) 0.130(3.30) 0.083(2.11) 0.075(1.91) Classification Rating 94V-0 Mechanical Data 0.187(4.75) 0.163(4.15) · Case: Molded plastic SMB 0.012(0.300) 0.004(0.100) · Terminals: Plated leads solderable per MIL-STD-750,Method 2026 guaranteed 0.096(2.44) 0.084(2.13) · Polarity: Color band dentes cathode end · Mounting Position: Any 0.057(1.45) 0.033(0.85) · Making: Type Number 0.008(0.20) 0.004(0.10) 0.010(0.25) 0.004(0.1) 0.217(5.50) 0.197(5.00) Maximum Ratings and Electrical Characteristics Rating at 25℃ ambient temperature unless otherwise specified Single phase,half wave,60Hz,resistive or inductive load For capacitive load derate current by 20% SK 33 30 SK 34 40 SK SK 345 35 45 50 SK 36 60 SK SK SK 38 310 315 80 100 150 SK 320 200 SK Unit 325 250 V Maximum Recurrent Peak Reverse Voltage VRRM SK 32 20 Maximum RMS Voltage VRMS 14 21 28 31 35 42 56 70 105 140 175 V VDC 20 30 40 45 50 60 80 100 150 200 250 V Type Number SYMBOL Maximum DC Blocking Voltage Average Rectified Output Current @TL =100℃ Peak Forward Surge Current 8.3ms Single half sine-wave superimposed on rated load (JEDEC Method) Forward Voltage @IF=3.0A (Note 1) Peak Reverse Current @TA =25 ℃ At Rated DC Blocking Voltage @TA =100 ℃ 2 IFSM VFM 0.55 IR 3.0 A 80 A 0.7 0.85 0.92 0.1 0.05 10 5 2 0.95 V mA I t Rating for fusing (t
SK310 价格&库存
很抱歉,暂时无法提供与“SK310”相匹配的价格&库存,您可以联系我们找货
SK310
    • 1+0.30430
    库存:40
