PRODUCT
SPECIFICATION
DOC NO.:
REV.
PS-103450-01
A
SHEET :
1
OF
13
Specification Approval Sheet(cell)
产
品
规
格
书 (电 芯)
Customer Name 客户名称
Cell
Model 电芯型号
Cell
Capacity 电芯容量
103450
1800 mAh
Customer Model 客户型号
Cell
P/N
电芯料号
103450
PLC.103450-1800mAh
PLC.103450-1800mAh
Prepared by制作
08/26/18
Customer Approved
Checked by审核
08/26/18
Approved by 批准
Approved by批准
08/26/18
Date 日期
客户承认
(Stamp)
(盖章)
Form No.: QF-T-PS-02B
PRODUCT
SPECIFICATION
DOC NO.:
REV.
PS-103450-01
SHEET :
A
2
OF
AMENDMENT RECORDS
规 格 变 更 记 录
Revision
A
Description
New Release
Date
Approval
08/26/18
13
PRODUCT
SPECIFICATION
DOC NO.:
REV.
PS-103450-01
SHEET :
A
3
OF
13
Index 目录
Appendix 附录.......................................................................................................................................3
1.
Scope 使用范围……………………………………………………………………………..
4
2.
Model 型号………………………………………………………………………………….
4
3.
Reference standard参考标准 ……………………………………………………………..
4
4.
Specification 产品参数 ............................................................................................................... 4
5.
Cell Drawing电芯外形尺寸示意图……………………………………………………….
6.
Cell Performance Criteria电芯性能检查及测试..................................................................... 6
5
6.1 Visual inspection外观检查 ................................................................................................... 6
6.2 Standard environmental test condition 标准测试环境......................................................6
6.3 Electrical characteristics 充放电性能................................................................................. 6
6.4 Mechanical and Environmental Test 环境适应性............................................................ 7
6.5 Safety 安全性能 .....................................................................................................................8
7.
Others 其他事项 ......................................................................................................................... 8
8.
Appendix 附录............................................................................................................................9
Handling Precautions and Guideline For LIP Rechargeable Batteries.................................. 9
可再充电锂聚合物电芯操作指引和注意事项......................................................................... 9
Appendix –A Charge…............................................................................................................. 9
附录--------A 充电 .......................................................................................................................9
Appendix –B Discharge…......................................................................................................... 10
附录--------B 放电 ........................................................................................................................ 10
Appendix –C Storage…............................................................................................................. 11
附录------C 存储 .......................................................................................................................... 11
Appendix –D Handling of Cells.................................................................................................11
附录------ D 电芯操作................................................................................................................. 11
Appendix –E Others....................................................................................................................11
附录-------E 其它......................................................................................................................... 11
Customer Inquiry........................................................................................................................13
客户要求...................................................................................................................................... 13
PRODUCT
SPECIFICATION
DOC NO.:
REV.
PS-103450-01
SHEET :
A
4
OF
13
1. Scope 使用范围
This document describes the Product Specification of the Lithium-ion Polymer (LIP) rechargeable battery ce
supplied by Dongguan taisko energy co. LTD
本规格书适用于taisko生产的可充电聚合物锂离子电芯的产品性能指标。
2. Model 型号
602535
3. Reference standard参考标准
GB31241-2014 UL1642
4. Specification 产品参数
NO.
1
2
3
4
5
6
7
8
9
10
11
12
13
Items项 目
Nominal voltage标称电压
Charge cut-off voltage充电截止电压
Discharge cut-off voltage放电截止电
Typical capacity典型容量
Specifications规格
3.7V
4.2V
3.0V
1800mAh@0.2Cdischarge
Charging the cell initially with constant current at 0.5C and then
with constant voltage at 4.2V till charge current declines to
0.02C.
Standard charge method 标准充电
先以0.5C恒流充电,当电芯电压达到4.2V后,改为恒压充电
直到充电电流小于或等于0.02C。
1.0C
Max charage rate 最大充电倍率
Max discharage rate 最大放电倍率 1.0C
Charge temperature
0~15℃ Standard charge method
充电温度
15~45℃ Charage current:0.5C
Operating temperature
Discharge temperature
工作温度
-20~60℃
放电温度
≤180mΩ
Initial Impedance初始内阻
交流阻抗 AC 1kHz
Cell Voltage of shipment 出货电压
3.80-4.00V
否
Whether there is coulometer是否带电量计
Weight 电芯重量
约33.5/ g
Match battery team电芯配组
T
W
配组方式:1S1P
10.20mm Max
34.5mm Max
L
14
15
G
A
B
D
C
3 months三个月内
Storage temperature
6 months六个月内
Long Time Storage长期存储
储存温度
Humidity湿度
外形尺寸
50.5mm Max
3.0±0.5mm
13.0±1.5mm
2.0±0.5mm
6~10mm
0.5~2.0mm
-20℃ ~+45℃
23℃±2 ℃
23℃±2 ℃
60%±20%
Thickness厚度(不含胶纸)
Width 宽度(不含胶纸,双折边
Length(Without sealant)
电芯长度(含极耳胶)
Top sealing length顶边宽度
Tab distance极耳中心距
Tab width极耳宽度
裁极耳尺寸(含极耳胶)
Sealant Length极耳胶尺寸
The capacity for a long time
storage shall be 60~70% range
长期存储容量为60%~70%
PRODUCT
SPECIFICATION
DOC NO.:
REV.
PS-103450-01
SHEET :
A
5
OF
13
5. Cell Drawing电芯外形尺寸示意图
A
T
L
F
G
C
D
B
W
有效长度
6~10mm
PRODUCT
SPECIFICATION
DOC NO.:
REV.
PS-103450-01
SHEET :
A
6
OF
13
6. Cell Performance Criteria电芯性能检查及测试
There shall be no such defect as scratch, flaw, crack, and leakage, which may adversely affect Commercial
value of the cell.
不允许有影响电芯价值的外观缺陷,例如:裂纹、裂缝、泄漏等。
Unless otherwise specified, all tests stated in this Product Specification are conducted at below condition:
除非有其他特殊说明, 本规格书中所有测试都在以下环境条件进行:
Temperature温度 : 20 ± 5 °C , Humidity 相对湿度: 60 ± 20%
NO.
Items 项 目
Test Method and Condition测试方法
1
2
Charge/Discharge
Cycle
充放电循环
Criteria标准
The capacity on 0.5C discharge shall be measured after 150
cycles Of 0.5C charge and discharge at 23±2 ℃.300cls cell
thickness swelling ≤8%
23±2 ℃条件下0.5C充放电循环150次。循环厚度膨胀≤8%
After full charging, storing the battery 28 days with 20 ± 5°C
condition, and then staying 1 hours with discharge current of
Retention Capability
0.5C till 3.0V cut-off voltage.
荷电保持能力
电芯满充电后,在20±5 ℃的环境条件下存放28天,然后以
0.5C电流连续放电至3.0V终止电压。
Capacity≥
80%
THK swelling
≤8%
容量≥80%
厚度膨胀≤
8%
Capacity≥
85%
容量≥85%
※ Typical capacity典型容量
The capacity means the average discharge capacity of the cell, which is measured with discharge current of
0.2C with 3.0V cut-off voltage after the standard charge at 23±5 ℃ environment temperature, unit:mAh
典型容量指23±5 ℃温度下,以0.2C电流放电至终止电压时所放出容量对应的容量分布中心值,单位为
mAh。
※ Charge/Discharge current rate充放电电流倍率
Charge/Discharge current rate:AC(Ah)=A*Minimal capacity(mAh),for example,
0.02C=0.02*Minimal capacity
充放电电流倍率:AC(Ah)=A*最小容量(mAh),例如,0.02C=0.02*最小容量
PRODUCT
SPECIFICATION
No.
Items 项 目
1
2
Vibration
振动
After standard charging, fixed the cell to vibration
table and subjected to vibration cycling that the
frequency is to be varied from 7HZ to 200HZ ,then
return to 7HZ , the excursion of the vibration is
0.8mm. The cell shall be vibrated for 3 hrs.
满充电后的电芯在三个相互垂直的方向按振幅
0.8mm的正弦波进行振动, 频率从7HZ增加到
200HZ 再降回7HZ,往复振动3小时。
After standard charging, put cell into the chamber
that the temperature is 40±2 ℃ and the humidity
Constant
ranges between 90and 95% for 48hours,then put it at
temperature
23±2 ℃ for 2hrs,measure0.5C CAP.
and Humidity
满充电后将电芯放入40℃±2 ℃及相对湿度为90~
恒定湿热
95%的恒温恒湿箱中48小时后,取出在23±2 ℃环境
下搁置2h,再以0.5C电流放电至3.0V。
DOC NO.:
REV.
PS-103450-01
SHEET :
A
7
OF
13
Criteria标 准
Voltage is not less than 90%
of the primary, no leakage, no
venting, no rupture, no fire, no
explosion.
开路电压不低于90%的初始
电压、不泄漏、不泄气、不
破裂、不起火、不爆炸
No distortion, no rust, no
leakage , no venting ,no
rupture , no fire ,no explosion,
the discharge time is not less
than 3hrs
不变形、不锈蚀、不泄漏、
不泄气、不破裂、不起火、
不爆炸、放电时间不低于3h
PRODUCT
SPECIFICATION
6.5 Safety 安全性能
No.
Items 项 目
1
Overcharge
过充
2
Short
protection
短路保护
After discharge to limit voltage, charged at constant
current of 3C and constant voltage of 4.6V, While
voltage reaches to the max ,if charging continued over
7 hours or temperature is 20% less than the top , close
the test.
电芯放电至终止电压后,用3C电流和4.6V的极限
电压充电,电压达到最大值后,当充电时间大于
7h或者温度降至比峰值低20%时终止测试。
After the battery is fully charged, short the positive
for 1 hour
电池满充电后,将正负极用100mΩ电阻短路1H后,
将正负极断开
DOC NO.:
REV.
PS-103450-01
SHEET :
A
8
OF
13
Criteria标 准
No fire, no explosion
不起火、不爆炸
No explosion, no fire, no
smoking.
无冒烟、起火、爆炸
7. Others 其他事项
Any matters that this specification doesn’t cover should be conferred between the customer and
taisko任何本规格书中未提及的事项,需要经双方协商确定。
PRODUCT
SPECIFICATION
8
DOC NO.:
REV.
PS-103450-01
SHEET :
A
9
OF
13
Appendix 附录
对可再充电锂聚合物电芯操作指引和注意事项
Foreword
This document of 'Handling Precautions and Guideline LIP Rechargeable Batteries' shall be applied to the
battery cells manufactured by taisko.
前言
“对可再充电锂聚合物电芯操作指引和注意事项”的文件仅适用于由taisko制作的电
芯。Statement (1):
Customers are requested to contact taisko in advance, if and when the customer needs other applications
or operating conditions than those described in this document. Additional experimentation may be
required to verify performance and safety under such conditions
声明(1):
如果客户需要其他方面的说明或工作条件与规格书内容不一致,请客户提前和taisko公司联系。
客户可以要求验证在规格书提供的条件下的特性和安全性能的测试。
Statement (2):
taisko will take no responsibility for any accident when the cell is used under other conditions than those
described in this Document.
声明(2):
对于没有按规格书提供的条件而其他条件下使用导致电芯出现事故,taisko公司将不承担任何责任。
Statement (3):
taisko will inform, in a written form, customers of improvement(s) regarding proper usage and
handling of cells, if it is deemed necessary.
声明(3):
如果客户需要,taisko公司将以书面形式,提供关于电芯的正确使用和操作方法的改进。
Appendix –A Charge
附录--------A 充电
1.Charging current充电电流
Charging current should be less than the maximum value specified in the Product Specification. Charging
with higher current than recommended value may cause damage to cells’ electrical, mechanical, and
safety performance and could lead to heat generation or leakage.
充电电流应小于产品规格书里提到的最大充电电流,没有按照推荐值而用大电流充电可能会产生电芯
的电气、机械和安全性能事故,会导致发热或漏液。
PRODUCT
SPECIFICATION
DOC NO.:
REV.
PS-103450-01
SHEET :
A
10
OF
13
2.Charging Voltage充电电压
Charging shall be done by voltage less than that specified in the Product Specification (4.2V/cell).
Charging beyond 4.3V, which is the absolute maximum voltage, must be strictly prohibited. The charger
and protection circuit of battery pack shall be designed to comply with this condition. It is very dangerous
that charging with higher voltage than the maximum value and may cause damage to the cell electrical,
mechanical safety performance and could lead to heat generation or leakage.
充电电压应小于产品规格书里提到的电压(4.2V/cell)。充电电压禁止超过最大值4.3V,充电器要和
电芯使用条件相符合。没有按照规格书提供的电压而用高电压充电将会产生电芯的电气、机械和安全
性能事故,会导致发热或电芯燃烧,这是非常危险的。
3.Charging temperature充电温度
The cell shall be charged within the specified temperature range in the Product Specification.
电芯应当在产品规格书中指定的温度范围内充电。
4.Prohibition of Reverse Charge禁止反向充电
Reverse charge is prohibited. Cells shall be connected correctly. The polarity has to be confirmed before
wiring. In case of the cell is connected improperly, the cell cannot be charged. Simultaneously, the reverse
charging may cause damage to the cell which may lead to degradation of cell performance and damage the
cell safety, and could cause heat generation or leakage.
禁止反向充电。电芯按照正确方法连接,焊接导线之前,确定电芯极性。在不正确连接情况下,电芯
不能充电。同时,
反向充电可能对电芯有破坏性,将会导致电芯性能的退化和危害电芯安全性能,
产生发热和漏液现象。
附录-------- B 放电
1. Discharge Current放电电流
The cell shall be discharged at less than the maximum discharge current specified in the Product
Specification. High discharging current may reduce the discharge capacity significantly or cause overheat.
放电电流应小于产品规格书里提到的最大放电电流。高放电电流将极大降低放电容量或者使电芯发
烫。
2. Discharge Temperature放电温度
The cell shall be discharged within the temperature range specified in the Product Specification.
电芯应当在产品规格书中指定的温度范围放电。
3. Over-Discharge过放电
It should be noted that cells would be at an over-discharged status due to self-discharge characteristics in
case they were not used for a long time. In order to prevent over-discharging, cells shall be charged
periodically to maintain the voltage between 3.7V and3.9V. Over-discharging may cause the loss of cell
performance, characteristics, or battery functions.
PRODUCT
SPECIFICATION
DOC NO.:
REV.
PS-103450-01
SHEET :
A
11
OF
13
如果电芯长时间不用,由于自身放电特性,电芯将处于过放电状态,这是应注意的。为了避免过放
电,电芯应周期性充电,使电压保持在3.7V到3.9V之间,过放电会导致电芯性能,特性或功能的降
低。
Appendix –C Storage
附录------ C存储
If the Cell is stored for a long time, the cell’s storage voltage should be 3.7~3.9V and the cell is to be
stored in a condition as Item. 4.11.
电芯在4.11 的存放條件下长期存放后,电芯的存储电压应在3.7~3.9V。
附录------- D 电芯操作
1.Consideration of strength of film package包装膜注意事项
Easily damaged by sharp edge parts such as nail and needle, so don’t strike by those sharp parts.
铝箔软包装比较容易被锐利部件刺破,如钉子、针,不要用这些锐利的部件刻划电池。
Sealed edge may be damaged by heat above 100°C, bend or fold sealed edge.
封边被加热到100°C 以上以及弯折封边都容易使封边受损。
2.Short短路
Don’t bend the tabs.Short terminals of cells is strictly prohibited, it may damage cells, even result in safety
accident.
禁止弯折极耳。禁止短路电芯,它会导致电芯严重损坏,甚至引发安全事故 。
3.Mechanical Shock机械冲击
Don’t Fall, shock, Crush,bend cell body.
禁止跌落,冲击,挤压,弯折电芯。
Appendix –E Others
附录------- E 其他
1. Prevention of short circuit within a battery pack
Enough insulation layers between wiring and the cells shall be used to maintain extra safety protection.
The battery pack shall be structured with no short circuit within the battery pack, which may cause
generation of smoke or firing.
在导线和电芯之间有足够多的绝缘材料将用于保持电芯较好的安全特性。包装盒内不要设计短路电
路,短路会产生冒烟或起火。
2. Prohibition of disassembly禁止拆卸电芯
Never disassemble the cells The disassembling may generate internal short circuit in the cell, which may
cause gassing, fining, explosion, or other problems.
不要拆卸电芯。拆卸电芯会导致电芯内部短路,产生有毒气体,澄清剂,爆炸和其他问题。
PRODUCT
SPECIFICATION
DOC NO.:
REV.
PS-103450-01
SHEET :
A
12
OF
13
Electrolyte is harmful LIP battery should not have liquid from electrolyte flowing, but in case the
electrolyte come into contact with the skin, or eyes, physicians shall flush the electrolyte immediately with
fresh water and medical advice is to be sought
电解液是有毒的。锂聚合物电芯LIP不能有流动的液体,但是如果电解液接触到皮肤,或者进入眼睛
内,医生将立即用清水清洗电解液,尊医嘱检查.。
3. Prohibition of dumping of cells into fire禁止把电芯放进火里
Never incinerate nor dispose the cells in fire. These may cause explosion of the cells, which isvery
dangerous and is prohibited.
不要烧毁电芯也不要投掷火中,这样将导致电芯爆炸,这些是非常危险和禁止的。
4. Prohibition of cells immersion into liquid禁止把电芯放在液体里
The cells shall never be soaked with liquids such as water, seawater, and drinks such as soft drinks, juices,
coffee or others.
电芯不能被液体浸湿比如水、海水, 和饮料如不含酒精的饮料、果汁、咖啡、或其他。
5. Cells replacement置换电芯
The battery replacement shall be done only by either cells supplier or device supplier and never be done
by the user.
电芯置换仅仅由其他电芯厂商或设备厂商操作,不能由使用者置换。
6. Prohibition of using the damaged cells禁止使用损坏电芯
The cells might be damaged during shipping by shock. If any abnormal features of the cells are found
such as damages in a plastic envelop of the cell, deformation of the cell package, smelling of an
electrolyte, an electrolyte leakage and others, the cells shall never be used any more. The Cells with smell
of the electrolyte or leakage shall be placed away from fire to avoid firing or exploding
电芯在运输其间由于振动而损坏,如果发现电芯有任何不正常现象,例如:电芯的塑料包装的损
害,包装的变形,有电解液的气味,漏液和其他现象,电芯将不再使用。有电解液或漏液气味的电芯
应远离火源避免发生火灾或爆炸。
7. Power consumption at standby status整机静态功耗
Products using LIB battery can charge from 0V but not preferred: Power consumption of products with
LIB battery at standby status maybe cause battery discharged deeply.
本产品不支持0V充电,在设计配套产品时请考虑整机静态功耗,以免电芯造成过放。
PRODUCT
SPECIFICATION
DOC NO.:
REV.
PS-103450-01
SHEET :
A
13
OF
13
Customer Inquiry
客户要求
Model:
型 号:
103450
Version:
A
版 本:
A
103450
1. IF clientele ratify specification and showpiece, please sign back specification to
taisko in 1 week, or else blank out it.
如果客户认可规格书和样品,请于7天内回签规格书给taisko公司,过期视为作废。
2.
The customer is requested to write down your information and contact taisko in advance, if
and when the customer needs applications or operating conditions other than those described
in this document. RENCHUAN could design and build such products according to your
special request.
taisko公司联系。
taisko公司将按照贵公司特殊要求设计和开发产品,特殊要求标准如下:
Special Request特殊要求
Criteria标准
Company Name:
Signature:
Date:
公 司 名 称:
签 名 :
日期:
