P1
TAI-TECH
SMD Type Power Inductor
ECN HISTORY LIST
REV
DATE
DESCRIPTION
APPROVED
CHECKED
DRAWN
1.0
17/01/20
新 發 行
楊祥忠
詹偉特
何秦芝
備
註
P2
TAI-TECH
1. Features
1.Excellent solderability and high heat resistance.
2.Excellent terminal strength construction.
Halogen
Pb
Halogen-free
Pb-free
3.Packed in embossed carrier tape and can be used by automatic mounting machine.
4.100% Lead(Pb) & Halogen-Free and RoHS compliant.
2. Dimension
B
1R0
4R7
C
MARKING
3. Part Numbering
FPI
A
0504 F
B
C
4R7 M
D
E
A: Series
B: Dimension
C: Lead free type
Black marking
D: Inductance
E: Inductance Tolerance
4R7=4.7uH
K=±10%, M=±20%
Size
A(mm)
B(mm)
C(mm)
FPI 0504
5.80±0.3
5.20±0.3
4.50±0.3
P3
TAI-TECH
4. Specification
TAI-TECH
Part Number
Inductance
(uH)
Tolerance
Test
Frequency
(Hz)
DCR
(Ω) max.
IDC
(A) max.
FPI 0504F-1R0M
1.0
± 20%
1V/7.96M
0.018
3.50
FPI 0504F-1R4M
1.4
± 20%
1V/7.96M
0.020
3.50
FPI 0504F-1R8M
1.8
± 20%
1V/7.96M
0.025
3.00
FPI 0504F-2R2M
2.2
± 20%
1V/7.96M
0.030
2.80
FPI 0504F-2R7M
2.7
± 20%
1V/7.96M
0.035
2.60
FPI 0504F-3R3M
3.3
± 20%
1V/7.96M
0.040
2.50
FPI 0504F-3R9M
3.9
± 20%
1V/7.96M
0.050
2.30
FPI 0504F-4R7M
4.7
± 20%
1V/7.96M
0.060
2.60
FPI 0504F-5R6M
5.6
± 20%
1V/7.96M
0.070
2.40
FPI 0504F-6R8M
6.8
± 20%
1V/7.96M
0.080
2.20
FPI 0504F-8R2M
8.2
± 20%
1V/7.96M
0.080
2.00
FPI 0504F-100M
10
± 20%
1V/2.52M
0.090
1.80
FPI 0504F-120M
12
± 20%
1V/2.52M
0.100
1.60
FPI 0504F-150M
15
± 20%
1V/2.52M
0.120
1.50
FPI 0504F-180M
18
± 20%
1V/2.52M
0.150
1.40
FPI 0504F-220M
22
± 20%
1V/2.52M
0.180
1.30
FPI 0504F-270M
27
± 20%
1V/2.52M
0.220
1.20
FPI 0504F-330M
33
± 20%
1V/2.52M
0.260
1.00
FPI 0504F-390M
39
± 20%
1V/2.52M
0.300
0.90
FPI 0504F-470M
47
± 20%
1V/2.52M
0.350
0.85
FPI 0504F-560M
56
± 20%
1V/2.52M
0.400
0.80
FPI 0504F-680M
68
± 20%
1V/2.52M
0.450
0.70
FPI 0504F-820M
82
± 20%
1V/2.52M
0.500
0.70
FPI 0504F-101M
100
± 20%
1V/1K
0.700
0.60
FPI 0504F-121M
120
± 20%
1V/1K
0.750
0.60
FPI 0504F-151M
150
± 20%
1V/1K
0.900
0.55
FPI 0504F-181M
180
± 20%
1V/1K
1.100
0.50
FPI 0504F-221M
220
± 20%
1V/1K
1.200
0.40
FPI 0504F-271M
270
± 20%
1V/1K
1.500
0.25
FPI 0504F-331M
330
± 20%
1V/1K
3.000
0.22
FPI 0504F-391M
390
± 20%
1V/1K
3.500
0.20
FPI 0504F-471M
470
± 20%
1V/1K
4.000
0.19
FPI 0504F-561M
560
± 20%
1V/1K
4.000
0.18
FPI 0504F-681M
680
± 20%
1V/1K
4.500
0.15
* IDC Test
Isat:Based on inductance change (△L/L0:≦-35%)@ ambient temp. 25℃
For all FPI series ,when a IDC current is applied, the temperature rised of the parts is less than 40 degree C
P4
TAI-TECH
5. Material List
a
b
No.
Item
1
2
3
Core
Wire
Terminal
Material
Ferrite DR Core
Enamelled Copper wire
Ag+Ni+Sn
c
6. Schematic Diagram
7. Reliability and Test Condition
Item
Performance
Operating temperature
-40~+125℃ (Including self - temperature rise)
Storage temperature
-40~+125℃ (on board)
Test Condition
Electrical Performance Test
HP4284A,CH11025,CH3302,CH1320,CH1320S
Inductance
Refer to standard electrical characteristics list.
DCR
LCR Meter.
CH16502,Agilent33420A Micro-Ohm Meter.
Saturation DC Current (Isat) will cause L0
Saturation Current (Isat)
△L≦35%
to drop △L(%).
Heat Rated Current (Irms) will cause the coil temperature rise
△T(℃)
Approximately △T40℃
1.Applied the allowed DC current
2.Temperature measured by digital surface thermometer
Reliability Test
Preconditioning: Run through IR reflow for 2 times.( IPC/JEDEC
J-STD-020DClassification Reflow Profiles)
Temperature:125±2℃(Inductor)
Life Test
Applied current:rated current
Duration:1000±12hrs
Measured at room temperature after placing for 24±2 hrs
Humidity:85±2﹪R.H,
Load Humidity
Temperature:85℃±2℃
Duration:1000hrs Min. with 100% rated current
Appearance:No damage.
Inductance:within±10% of initial value
Moisture Resistance
Q:Shall not exceed the specification value.
RDC:within ±15% of initial value and shall not
Thermal
shock
Profiles
1. Baked at50℃ for 25hrs, measured at room temperature after
placing for 4 hrs.
2. Raise temperature to 65±2℃ 90-100%RH in 2.5hrs, and
keep 3 hours, cool down to 25℃ in 2.5hrs.
3. Raise temperature to 65±2℃ 90-100%RH in 2.5hrs, and
2.5hrs,keep at 25℃ for 2 hrs then keep at -10℃ for 3 hrs
4. Keep at 25℃ 80-100%RH for 15min and vibrate at the
frequency of 10 to 55 Hz to 10 Hz, measure at
room temperature after placing for 1~2 hrs.
Reflow Profiles
Condition for 1 cycle
Step1:-40±2℃ 30±5min
Step2:25±2℃ ≦0.5min
Step3:125±2℃ 30±5min
Number of cycles: 500
P5
TAI-TECH
Item
Performance
Test Condition
Oscillation Frequency: 10~2K~10Hz for 20 minutes
Vibration
Equipment: Vibration checker
Total Amplitude:1.52mm±10%
Testing Time : 12 hours(20 minutes, 12 cycles each of 3
orientations)。
Shock
Peak
value
(g’s)
Normal
duration (D)
(ms)
Wave
form
Velocity
change
(Vi)ft/sec
SMD
50
11
Half-sine
11.3
Lead
50
11
Half-sine
11.3
Shall be mounted on a FR4 substrate of the
following dimensions: >=0805 inch(2012mm):40x100x1.2mm
=0805 inch(2012mm):1.2mm
0805
inch(2012mm):1kg ,
很抱歉,暂时无法提供与“FPI0504F-4R7M”相匹配的价格&库存,您可以联系我们找货
