EMZA160ADA470ME61G
EMZA160ADA470ME61G
    NCC(贵弥功)
    AEC-D5X5.8MM_SM
EMZA160ADA470ME61G 数据手册
SURFACE MOUNT ALUMINUM ELECTROLYTIC CAPACITORS TM AIchip MZA - Series Low impedance, 105℃ MZA ・Endurance : 2,000 to 5,000 hours at 105℃ ・Low impedance ・Solvent resistant type(see PRECAUTIONS AND GUIDELINES) ・Vibration resistant structure ・RoHS2 Compliant ・AEC-Q200 compliant : Please contact Chemi-Con for more details, test data, information. Lower Z MVY ◆SPECIFICATIONS Items Characteristics Category Temperature Range Rated Voltage Range Capacitance Tolerance Leakage Current -55 to +105℃ 6.3 to 100Vdc (at 20℃, 120Hz) ±20%(M) I=0.01CV or 3μA, whichever is greater Where, I : Max. leakage current (μA), C : Nominal capacitance (μF), V : Rated voltage (V) (at 20℃ after 2 minutes) Rated voltage(Vdc) 6.3V 10V 16V 25V 35V 50V 63V 80V 100V D61 to JA0 0.26 0.19 0.16 0.14 0.12 0.10 0.08 0.08 tanδ(Max.) KE0 to MN0 0.16 0.14 0.12 0.12 0.10 0.10 When nominal capacitance exceeds 1,000μF, add 0.02 to the value above for each 1,000μF increase. (at 20℃, 120Hz) Rated voltage(Vdc) 6.3V 10V 16V 25V 35V 50V 63V 80V 100V Z(-25℃)/Z(+20℃) 2 2 2 2 2 2 2 2 2 Z(-40℃)/Z(+20℃) 3 3 3 3 3 3 3 3 3 Z(-55℃)/Z(+20℃) 4 4 4 3 3 3 3 3 3 (at 120Hz) The following specifications shall be satisfied when the capacitors are restored to 20℃ after the rated voltage is applied for specified time at 105℃. D61 to JA0 : 2,000 hours Time KE0 to MN0 : 5,000 hours Capacitance change ≦±30% of the initial value D.F. (tanδ) ≦200% of the initial specified value Leakage current ≦The initial specified value Dissipation Factor (tanδ) Low Temperature Characteristics (Max. impedance Ratio) Endurance ◆DIMENSIONS [mm] ● Terminal ● Terminal ● Size ● Size Vent (Except HA0) φD±0.5 P C±0.2 B±0.2 φD±0.5 W 0.3max. L±0.3 (Note) A±0.2 L±0.5 A±0.2 Note : L±0.5 for HA0 to MN0 D61 E61 F61 F80 HA0 JA0 KE0 KG5 LH0 LN0 MH0 MN0 W 0.3max. B±0.2 Vent for JA0 (Except D61 to HA0) Code : G(Vibration resistant structure) code : HA0 to MN0 Size code P C±0.2 Code : A code : D61 to MN0 : Dummy terminals D 4 5 6.3 6.3 8 10 12.5 12.5 16 16 18 18 L 5.8 5.8 5.8 7.7 10.0 10.0 13.5 16.0 16.5 21.5 16.5 21.5 B 4.3 5.3 6.6 6.6 8.3 10.3 13.0 13.0 17.0 17.0 19.0 19.0 A 4.3 5.3 6.6 6.6 8.3 10.3 13.0 13.0 17.0 17.0 19.0 19.0 C 5.1 5.9 7.2 7.2 9.0 11.0 13.7 13.7 18.0 18.0 20.0 20.0 W 0.5 to 0.8 0.5 to 0.8 0.5 to 0.8 0.5 to 0.8 0.7 to 1.1 0.7 to 1.1 1.0 to 1.3 1.0 to 1.3 1.0 to 1.3 1.0 to 1.3 1.0 to 1.3 1.0 to 1.3 P 1.0 1.4 1.9 1.9 3.1 4.5 4.2 4.2 6.5 6.5 6.5 6.5 ◆PART NUMBERING SYSTEM 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 E MZA AAA A DA AAA M AAA G Supplement code Size code Capacitance tolerance code Capacitance code (ex. 4.7µF:4R7,10µF:100) Taping·Tray code Terminal code (A, G) Voltage code (ex. 6.3V:6R3,10V:100,50V:500) Series code Category Please refer to "Product code guide (surface mount type)" ◆MARKING KE0 to MN0 EX) 25V1,000µF D61 to JA0 EX) 16V220µF 0V MZA 2j 220 CZA ●Rated 1000 25V voltage symbol (D61 to JA0) Rated voltage (Vdc) Symbol 6.3 j 10 A 16 C 25 E 35 V 50 H 63 J 80 K Product specifications in this catalog are subject to change without notice.Request our product specifications before purchase and/or use. Please use our products based on the information contained in this catalog and product specifications. CAT. No. E1001U SURFACE MOUNT ALUMINUM ELECTROLYTIC CAPACITORS TM AIchip Low impedance, 105℃ MZASeries - ◆STANDARD RATINGS WV (Vdc) 6.3 10 16 25 35 Cap (µF) Size code Impedance Rated ripple ( Ω max./ current 100kHz) (mArms/ 20℃ -40℃ 105℃ ,100kHz) 22 D61 1.35 – 47 D61 1.35 – 47 E61 0.70 – 100 E61 0.70 – 100 F61 0.36 – 220 F61 0.36 – 330 F80 0.34 – 470 HA0 0.16 – 1,000 HA0 0.16 – 1,500 JA0 0.08 – 22 D61 1.35 – 33 D61 1.35 – 33 E61 0.70 – 220 F80 0.34 – 330 HA0 0.16 – 470 HA0 0.16 – 680 HA0 0.16 – 1,000 JA0 0.08 – 10 D61 1.35 – 22 D61 1.35 – 22 E61 0.70 – 47 E61 0.70 – 47 F61 0.36 – 100 F61 0.36 – 220 F80 0.34 – 330 HA0 0.16 – 470 HA0 0.16 – 680 JA0 0.08 – 10 D61 1.35 – 22 E61 0.70 – 33 E61 0.70 – 33 F61 0.36 – 47 F61 0.36 – 100 F80 0.34 – 220 HA0 0.16 – 330 HA0 0.16 – 470 JA0 0.08 – 1,000 KE0 0.060 0.30 1,300 KG5 0.056 0.28 1,800 LH0 0.047 0.24 2,400 MH0 0.045 0.23 3,000 LN0 0.034 0.17 3,900 MN0 0.032 0.16 4.7 D61 1.35 – 10 D61 1.35 – 10 E61 0.70 – 22 E61 0.70 – 33 F61 0.36 – 47 F61 0.36 – 100 F80 0.34 – 100 HA0 0.16 – 220 HA0 0.16 – 90 90 160 160 240 240 280 600 600 850 90 90 160 280 600 600 600 850 90 90 160 160 240 240 280 600 600 850 90 160 160 240 240 280 600 600 850 1,320 1,470 1,820 2,060 2,400 2,640 90 90 160 160 240 240 280 600 600 Part No. EMZA6R3ARA220MD61G EMZA6R3ARA470MD61G EMZA6R3ARA470ME61G EMZA6R3ARA101ME61G EMZA6R3ARA101MF61G EMZA6R3ARA221MF61G EMZA6R3ARA331MF80G EMZA6R3 □ RA471MHA0G EMZA6R3 □ RA102MHA0G EMZA6R3 □ RA152MJA0G EMZA100ARA220MD61G EMZA100ARA330MD61G EMZA100ARA330ME61G EMZA100ARA221MF80G EMZA100 □ RA331MHA0G EMZA100 □ RA471MHA0G EMZA100 □ RA681MHA0G EMZA100 □ RA102MJA0G EMZA160ARA100MD61G EMZA160ARA220MD61G EMZA160ARA220ME61G EMZA160ARA470ME61G EMZA160ARA470MF61G EMZA160ARA101MF61G EMZA160ARA221MF80G EMZA160 □ RA331MHA0G EMZA160 □ RA471MHA0G EMZA160 □ RA681MJA0G EMZA250ARA100MD61G EMZA250ARA220ME61G EMZA250ARA330ME61G EMZA250ARA330MF61G EMZA250ARA470MF61G EMZA250ARA101MF80G EMZA250 □ RA221MHA0G EMZA250 □ RA331MHA0G EMZA250 □ RA471MJA0G EMZA250 □ RA102MKE0S EMZA250 □ RA132MKG5S EMZA250 □ RA182MLH0S EMZA250 □ RA242MMH0S EMZA250 □ RA302MLN0S EMZA250 □ RA392MMN0S EMZA350ARA4R7MD61G EMZA350ARA100MD61G EMZA350ARA100ME61G EMZA350ARA220ME61G EMZA350ARA330MF61G EMZA350ARA470MF61G EMZA350ARA101MF80G EMZA350 □ RA101MHA0G EMZA350 □ RA221MHA0G WV (Vdc) 35 50 63 80 100 Cap (µF) Size code Impedance Rated ripple ( Ω max./ current 100kHz) (mArms/ 20℃ -40℃ 105℃ ,100kHz) 330 620 820 1,200 1,600 1,800 2,400 4.7 10 10 22 33 47 100 220 330 430 620 820 1,000 1,300 4.7 10 22 33 47 68 100 240 300 430 560 680 910 3.3 4.7 10 22 33 47 150 220 330 430 470 680 110 130 200 270 330 430 JA0 KE0 KG5 LH0 MH0 LN0 MN0 D61 E61 F61 F61 F80 F80 HA0 JA0 KE0 KG5 LH0 MH0 LN0 MN0 E61 F61 F80 HA0 HA0 HA0 JA0 KE0 KG5 LH0 MH0 LN0 MN0 E61 F61 F80 HA0 HA0 JA0 KE0 KG5 LH0 MH0 LN0 MN0 KE0 KG5 LH0 MH0 LN0 MN0 0.08 0.060 0.056 0.047 0.045 0.034 0.032 2.9 1.52 0.88 0.88 0.68 0.68 0.34 0.18 0.11 0.10 0.087 0.087 0.050 0.050 4.8 2.2 2.1 0.70 0.70 0.70 0.45 0.19 0.17 0.15 0.12 0.085 0.070 5.0 3.0 2.4 1.3 1.3 0.70 0.22 0.17 0.15 0.12 0.085 0.070 0.28 0.21 0.18 0.15 0.11 0.091 – 0.30 0.28 0.24 0.23 0.17 0.16 – – – – – – – – 0.55 0.50 0.44 0.44 0.25 0.25 – – – – – – – 1.54 1.19 1.05 0.84 0.58 0.49 – – – – – – 1.54 1.19 1.05 0.84 0.58 0.49 2.24 1.68 1.44 1.2 0.88 0.73 850 1,320 1,470 1,820 2,060 2,400 2,640 60 85 165 165 195 195 350 670 980 1,090 1,320 1,420 1,910 2,180 50 80 120 250 250 250 400 880 1,000 1,220 1,430 1,790 1,960 25 40 60 130 130 200 810 1,000 1,220 1,430 1,790 1,960 740 900 1,090 1,280 1,580 1,690 Part No. EMZA350 □ RA331MJA0G EMZA350 □ RA621MKE0S EMZA350 □ RA821MKG5S EMZA350 □ RA122MLH0S EMZA350 □ RA162MMH0S EMZA350 □ RA182MLN0S EMZA350 □ RA242MMN0S EMZA500ARA4R7MD61G EMZA500ARA100ME61G EMZA500ARA100MF61G EMZA500ARA220MF61G EMZA500ARA330MF80G EMZA500ARA470MF80G EMZA500 □ RA101MHA0G EMZA500 □ RA221MJA0G EMZA500 □ RA331MKE0S EMZA500 □ RA431MKG5S EMZA500 □ RA621MLH0S EMZA500 □ RA821MMH0S EMZA500 □ RA102MLN0S EMZA500 □ RA132MMN0S EMZA630ARA4R7ME61G EMZA630ARA100MF61G EMZA630ARA220MF80G EMZA630 □ RA330MHA0G EMZA630 □ RA470MHA0G EMZA630 □ RA680MHA0G EMZA630 □ RA101MJA0G EMZA630 □ RA241MKE0S EMZA630 □ RA301MKG5S EMZA630 □ RA431MLH0S EMZA630 □ RA561MMH0S EMZA630 □ RA681MLN0S EMZA630 □ RA911MMN0S EMZA800ARA3R3ME61G EMZA800ARA4R7MF61G EMZA800ARA100MF80G EMZA800 □ RA220MHA0G EMZA800 □ RA330MHA0G EMZA800 □ RA470MJA0G EMZA800 □ RA151MKE0S EMZA800 □ RA221MKG5S EMZA800 □ RA331MLH0S EMZA800 □ RA431MMH0S EMZA800 □ RA471MLN0S EMZA800 □ RA681MMN0S EMZA101 □ RA111MKE0S EMZA101 □ RA131MKG5S EMZA101 □ RA201MLH0S EMZA101 □ RA271MMH0S EMZA101 □ RA331MLN0S EMZA101 □ RA431MMN0S □ : Enter the appropriate terminal code. ◆RATED RIPPLE CURRENT MULTIPLIERS ・Frequency Multipliers Size code D61 to JA0 KE0 to MN0 Capacitance(µF) Frequency(Hz) 3.3 to 4.7 10 to 100 220 to 470 680 to 1,500 110 to 200 220 to 620 680 to 1,800 2,400 to 3,000 3,900 120 0.35 0.40 0.50 0.60 0.40 0.50 0.60 0.75 0.85 1k 0.70 0.75 0.85 0.87 0.75 0.85 0.87 0.90 0.95 10k 0.90 0.90 0.94 0.95 0.90 0.94 0.95 0.95 0.98 100k 1.00 1.00 1.00 1.00 1.00 1.00 1.00 1.00 1.00 The endurance of capacitors is reduced with internal heating produced by ripple current at the rate of halving the lifetime with every 5℃ rise. When long life performance is required in actual use, the rms ripple current has to be reduced. Product specifications in this catalog are subject to change without notice.Request our product specifications before purchase and/or use. Please use our products based on the information contained in this catalog and product specifications. CAT. No. E1001U
EMZA160ADA470ME61G 价格&库存
很抱歉,暂时无法提供与“EMZA160ADA470ME61G”相匹配的价格&库存,您可以联系我们找货
