ARDUINO NANO EVERY WITH HEADERS 数据手册
A R D U I N O N A N O E V E RY W I T H
HEADERS
Code: ABX00033
Turn your ideas into a reality quickly with the new Arduino
Nano Every.
Estimate shipping date, end of July 2019
This small, robust and powerful board has the same classic Nano footprint
loved worldwide.
It can be programmed with the easy to use Arduino IDE available offline
and online. Get started in minutes with thousands of sketches available in
open-source or write your own: it is the perfect choice for your everyday
projects.
Based on the ATMega4809 AVR processor, the Arduino Nano Every is
flexible to the requirements of your design. It can be used in a breadboard
when mounting pin headers, or as a SMT directly soldered on a PCB
thanks to its castellated pads. An SAMD11 ARM Cortex M0+ processor
acts as a high performance USB to serial converter that can be re -
programmed by skilled users to expand further the applications of this
board.
With headers mounted.
TECH SPEC
This board is based on the ATMega4809 microcontroller.
Clock
Flash
SRAM
EEPROM
20MHz
48KB
6KB
256byte
A ATSAMD11D14A Processor takes care of the USB to SERIAL
communication and it is connected to the following pins of the
ATMega4809 ATMega4809
Pin
Acronym
SAMD11 SAMD11
Pin
Acronym
9
PB05
15
PA22
8
PB04
16
PA23
12
PA15
SAMD11 TX ->
ATMega4809 RX
ATMega4809 TX ->
SAMD11 RX
UPDI RX
11
PA14
UPDI TX
41
Description
UPDI
The board has a two 15 pins connectors - one on each side -, pin to pin
compatible with the original Arduino Nano.
Pin Funcion
1 D13
2
3
4
5
6
7
8
Type
Digital
Power
+3V3
Out
AREF
Analog
A0/DAC0 Analog
A1
Analog
A2
Analog
A3
Analog
A4/SDA Analog
Description
SPI SCK, GPIO
Internally generated power output to external
devices
Analog Reference; can be used as GPIO
ADC in/DAC out; can be used as GPIO
ADC in; can be used as GPIO
ADC in; I2C SDA; Can be used as GPIO
9 A5/SCL
10 A6
11 A7
12
13
14
15
16
17
18
19
22
23
24
25
26
27
28
29
30
Analog
Analog
Analog
Power
+5V
Out
RST
Digital In
GND
Power
VIN
Power In
TX
Digital
RX
Digital
RST
Digital
GND
Power
D2
Digital
D3/PWM Digital
D4
Digital
D5/PWM Digital
D6/PWM Digital
D7
Digital
D8
Digital
D9/PWM Digital
D10/PWM Digital
D11/MOSI Digital
D12/MISO Digital
ADC in; I2C SCL; Can be used as GPIO
devices
Active low reset input (duplicate of pin 18)
Power Ground
Vin Power input
USART TX; can be used as GPIO
USART RX; can be used as GPIO
Active low reset input (duplicate of pin 13)
Power Ground
GPIO
GPIO; can be used as PWM
GPIO
GPIO
GPIO
SPI MOSI; can be used as GPIO
SPI MISO; can be used as GPIO
https://store.arduino.cc/usa/nano-every-with-headers/6-11-19
ARDUINO NANO EVERY WITH HEADERS 价格&库存
很抱歉,暂时无法提供与“ARDUINO NANO EVERY WITH HEADERS”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+162.59931
- 2+159.10255
- 3+150.36066
- 10+143.36714
