ZM4742A L0G
ZM4742A L0G
    TAIWANSEMICONDUCTOR(台半)
    MELF
ZM4742A L0G 数据手册
ZM4728A - ZM4758A Taiwan Semiconductor 1W, 5% Tolerance Hermetically Sealed Glass Zener Voltage Regulators FEATURES KEY PARAMETERS ● Wide zener voltage range selection: 3.3V to 56V ● Compliant to RoHS directive 2011/65/EU and in accordance to WEEE 2002/96/EC ● Halogen-free according to IEC 61249-2-21 PARAMETER VALUE UNIT VZ 3.3-56 V PD 1 W TJ Max. 175 °C APPLICATIONS ● Low voltage stabilizers or voltage references ● Adapters ● On-board DC/DC converter Package MELF Configuration Single die MECHANICAL DATA ● Case: MELF ● Terminal: Matte tin plated leads, solderable per J-STD-002 ● Polarity: Indicated by cathode band ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted) PARAMETER Power dissipation SYMBOL VALUE UNIT PD 1 W Junction temperature range TJ -65 to +175 °C Storage temperature range TSTG -65 to +200 °C SYMBOL TYP UNIT RӨJA 170 °C/W THERMAL PERFORMANCE PARAMETER Junction-to-ambient thermal resistance 1 Version:D1804 ZM4728A - ZM4758A Taiwan Semiconductor ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted) ZENER VOLTAGE TEST REGULAR TEST LEAKAGE CURRENT IMPEDANCE CURRENT CURRENT IR @ V R VZ @ IZT IZT ZZT @ IZT ZZK @ IZK IZK V mA Ω Ω mA Max. Max. ZM4728A 3.3 76 10 400 1.0 100 1.0 ZM4729A 3.6 69 10 400 1.0 100 1.0 ZM4730A 3.9 64 9 400 1.0 50 1.0 ZM4731A 4.3 58 9 400 1.0 10 1.0 ZM4732A 4.7 53 8 500 1.0 10 1.0 ZM4733A 5.1 49 7 550 1.0 10 1.0 ZM4734A 5.6 45 5 600 1.0 10 2.0 ZM4735A 6.2 41 2 700 1.0 10 3.0 ZM4736A 6.8 37 3.5 700 1.0 10 4.0 ZM4737A 7.5 34 4.0 700 0.5 10 5.0 ZM4738A 8.2 31 4.5 700 0.5 10 6.0 ZM4739A 9.1 28 5.0 700 0.5 10 7.0 ZM4740A 10 25 7.0 700 0.25 10 7.6 ZM4741A 11 23 8.0 700 0.25 5.0 8.4 ZM4742A 12 21 9.0 700 0.25 5.0 9.1 ZM4743A 13 19 10 700 0.25 5.0 9.9 ZM4744A 15 17 14 700 0.25 5.0 11.4 ZM4745A 16 15.5 16 700 0.25 5.0 12.2 ZM4746A 18 14.0 20 700 0.25 5.0 13.7 ZM4747A 20 12.5 22 750 0.25 5.0 15.2 ZM4748A 22 11.5 23 750 0.25 5.0 16.7 ZM4749A 24 10.5 25 750 0.25 5.0 18.2 ZM4750A 27 9.5 35 750 0.25 5.0 20.6 ZM4751A 30 8.5 40 1000 0.25 5.0 22.8 ZM4752A 33 7.5 45 1000 0.25 5.0 25.1 ZM4753A 36 7.0 50 1000 0.25 5.0 27.4 ZM4754A 39 6.5 60 1000 0.25 5.0 29.7 ZM4755A 43 6.0 70 1500 0.25 5.0 32.7 ZM4756A 47 5.5 80 1500 0.25 5.0 35.8 ZM4757A 51 5.0 95 1500 0.25 5.0 38.8 ZM4758A 56 4.5 110 2000 0.25 5.0 42.6 PART NUMBER µA V Max. Notes: 1. The device numbers listed have a standard tolerance on the nomial zener voltage of ±5%. 2. For detailed information on price, availability and delivery of nominal zener voltages between the voltages shown and tighter voltage tolerances, contact your nearest Taiwan Semiconductor representative. 3. The Zener impedance is derived from the 60-cycle ac voltage, which results when an ac current having an rms value equal to 10% of the DC zener current(IZT or IZK) is superimposed to IZT or IZK. 2 Version:D1804 ZM4728A - ZM4758A Taiwan Semiconductor ORDERING INFORMATION PART NO. (Note 1) PACKAGE PACKING ZM47xxA L0 MELF 5K / 13" Reel ZM47xxA L0G MELF 5K / 13" Reel Note: 1. "xx" defines voltage from 3.3V (ZM4728A) to 56V (ZM4758A) 3 Version:D1804 ZM4728A - ZM4758A Taiwan Semiconductor PACKAGE OUTLINE DIMENSION MELF DIM. Unit (mm) Unit (inch) Min Max Min Max A 4.80 5.50 0.189 0.217 B 2.25 2.67 0.089 0.105 C 0.30 0.60 0.012 0.024 SUGGEST PAD LAYOUT Unit (mm) Unit (inch) Typ. Typ. C 4.80 0.189 G 3.30 0.130 X 1.50 0.059 X1 6.30 0.248 Y 2.70 0.106 DIM. 4 Version:D1804 ZM4728A - ZM4758A Taiwan Semiconductor Notice Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf, assumes no responsibility or liability for any errors or inaccuracies. Information contained herein is intended to provide a product description only. No license, express or implied, to any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty, relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose, merchantability, or infringement of any patent, copyright, or other intellectual property right. The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications. Customers using or selling these products for use in such applications do so at their own risk and agree to fully indemnify TSC for any damages resulting from such improper use or sale. 5 Version:D1804
ZM4742A L0G 价格&库存
很抱歉,暂时无法提供与“ZM4742A L0G”相匹配的价格&库存,您可以联系我们找货
