ELR-04NV
ELR-04NV
    JST
    P=4.5mm
ELR-04NV 数据手册
EL CONNECTOR 4.5mm pitch/Disconnectable Crimp style Wire-to-wire connectors Specifications ––––––––––––––––––– • Current rating: 10A AC, DC max. • Voltage rating: 300V AC, DC max. • Temperature range: -25˚C to +90˚C (including temperature rise in applying electrical current) • Contact resistance: Initial value/7m Ω max. After environmental testing/10m Ω max. • Insulation resistance: 1,000M Ω min. • Withstanding voltage: 1,500V AC/minute • Applicable wire: AWG #26 to #16 0.13 to 1.25mm2 • Applicable panel thickness: 0.8 to 2.0mm * Compliant with RoHS. * Refer to "General Instruction and Notice when using Terminals and Connectors" at the end of this catalog. * Contact JST for details. Note: The current rating varies depending on the number of circuits and the wire size used in each connector. The table below lists the current rating as a function of the number of circuits and the wire size. The contacts for the compact EL connector can be easily inserted into the connector housings. The plug housing and the receptacle housing can be smoothly mated even if they are mechanically distorted. • Easy insertion and secure installation of contacts • A smooth connection even when pried during mating • Durable arm lock mechanism • Two contact styles • Interchangeability with ML connector Current unit : A Circuits 2 3 4 6 9 12 15 #16 10 10 10 8 6 6 6 #18 6 6 6 5 4 4 4 Wire size (AWG) #20 #22 5 4 5 4 5 4 4 3 3 3 3 3 3 3 #24 4 4 4 3 2 2 2 #26 3 3 3 3 2 2 2 Standards –––––––––––––––––––––– 0 Recognized E60389 1 Certified LR20812 2 R75052 Panel layout and Assembly layout A 39.2 B C D A Circuits Dimensions A (mm) 2 ∼4 (Single-line arrangement) 10.4 4 (Double-line arrangement) 15.0 6 14.9 9∼15 19.4 Panel hole dimensions (mm) Circuits Receptacle housing Model No. A B 2 15.0 6.0 ELR-02V 3 19.7 6.0 ELR-03V 24.2 6.0 ELR-04V 4 15.6 10.6 ELR-04NV 6 19.7 10.2 ELR-06V 9 19.7 14.8 ELR-09V 12 24.2 14.8 ELR-12V 15 28.7 14.8 ELR-15V General tolerance ±0.13 Applicable panel thickness (mm) C D 6.85 5.2 6.85 5.2 6.85 5.2 11.6 5.2 11.1 5.2 15.7 5.2 15.7 5.2 15.7 5.2 0.8∼2.0 Note: 1. Punch holes in the panel according to the figures and table shown above. Burrs must be removed. 2. The strength of the panel must be considered when punching two or more holes. 3. The connector must be inserted from the same side as the hole is punched. 1 EL CONNECTOR Contact Applicable wire Model No. 1.3 Pin contact mm2 AWG # Insulation O.D. Q´ty / reel (mm) Pin contact Socket contact SLM-01T-P1.3E SLF-01T-P1.3E 0.13∼0.5 26∼20 1.3∼2.7 SLM-41T-P1.3E SLF-41T-P1.3E 0.5 ∼1.25 20∼16 1.9∼3.4 *SLM-42T-P1.3E *SLF-42T-P1.3E 0.3+0.3∼ 0.5+0.5 22+22∼ 20+20 1.7+1.7∼ 2.0+2.0 6,000 4,000 17.7 7.5 4.3 3.8 2.0 Material and Finish Phosphor bronze, tin-plated (reflow treatment) RoHS compliance Note: 1. Contact denoted by * is used for two wires. 2. Contact JST for special products. 3. Contact JST for brass products. Socket contact 17.7 11.3 4.3 Dies Crimp applicator with dies SLM-01T-P1.3E MKS-L SLF-01T-P1.3E *MKS-SC SC/SLF/M-01-13E APLSC SLF/M01-13E SLM-42T-P1.3E MKS-L MK/SLF/M-42-13E APLMK SLF/M42-13E SLF-42T-P1.3E 2.0 Applicator Crimping machine Crimp applicator Contact AP-K2N MK/SLF/M-01-13E APLMK SLF/M01-13E − − − SLM-41T-P1.3E MKS-L MK/SLF/M-41-13E APLMK SLF/M41-13E SLF-41T-P1.3E *MKS-SC SC/SLF/M-41-13E APLSC SLF/M41-13E Note: *Strip-crimp applicator Contact position location numbers Contact position numbers are stamped Plug housing Receptacle housing Receptacle housing 2 5 15 3 2 4 1 3 1 4 2 3 3 2 1 1 1 1 4 3 2 1 3 2 1 3 2 1 2 2 1 1 3 2 1 4 2 3 1 4 2 4 4 3 2 1 4 3 2 1 3 2 2 1 Plug housing 12 14 4 4 8 9 6 3 10 3 10 5 15 4 9 11 6 3 4 14 13 5 9 3 7 8 5 3 13 2 12 2 6 7 1 1 4 8 2 9 4 2 12 1 5 7 1 9 4 11 6 1 1 10 5 7 7 2 10 8 7 11 8 1 8 12 9 2 4 6 3 5 3 6 6 1 11 5 6 6 3 5 2 4 1 2 9 6 3 8 5 2 7 4 1 12 11 10 9 8 7 6 5 4 3 2 1 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 3 6 2 5 1 4 3 6 9 2 5 8 1 4 7 4 3 2 1 8 7 6 5 12 11 10 9 5 4 3 2 1 10 9 8 7 6 15 14 13 12 11 EL CONNECTOR Housing Material: PA 6, UL94V-0, white Circuits Voltage rating Current rating Receptacle housing(for pin contact) Plug housing(for socket contact) Q´ty / bag ELP-02V Q´ty / bag 10.3 ELR-02V 500 2 300V 5.6 10.3 24.6 10A ELR-02VF Q´ty / bag 5.8 14.6 500 10.3 24.6 24.6 5.8 ELR-03V 10A ELP-03V Q´ty / bag 14.8 300V Q´ty / bag 14.8 3 500 500 24.6 24.6 5.6 ELR-04V 500 14.6 5.8 ELP-04V Q´ty / bag 19.3 19.3 Q´ty / bag 500 500 5.8 JST-L 24.6 10A Q´ty / bag ELP-04NV Q´ty / bag 10.3 300V 24.6 5.6 ELR-04NV 4 14.6 10.3 10.3 24.6 ELR-04NVF 14.6 10.3 500 500 10.3 24.6 24.6 10.3 ELR-06V 8A Q´ty / bag 14.8 300V ELP-06V 14.8 6 Q´ty / bag 500 500 14.6 10.3 24.6 9.9 24.6 RoHS compliance 3 EL CONNECTOR Housing Material: PA 6, UL94V-0, white Circuits Voltage rating Current rating Receptacle housing(for pin contact) ELR-09V 6A ELP-09V Q´ty / bag 14.8 300V Q´ty / bag 14.8 9 Plug housing(for socket contact) 500 500 14.6 14.8 24.6 24.6 14.4 ELR-12V 6A Q´ty / bag 19.3 300V ELP-12V 19.3 12 Q´ty / bag 500 500 14.6 14.8 24.6 ELR-15V 6A ELP-15V Q´ty / bag 23.8 300V Q´ty / bag 23.8 15 24.6 14.4 500 500 14.6 14.8 24.6 14.4 24.6 RoHS compliance Note: 1. ELR-02VF and ELR-04NVF are exclusively for free hanging. The other circuits can be used either for panel mounted or free hanging. See "Panel layout" for the panel hole dimensions. 2. Contact JST for special products. 4
ELR-04NV 价格&库存
很抱歉,暂时无法提供与“ELR-04NV”相匹配的价格&库存,您可以联系我们找货
