10G Ethernet Optical Bypass Module
PRODUCT NUMBER:OBM-A3CB4-C06_V3
Specification
Quad Ports 10G Base-LR
O B M –A3CB4-C06_V3
FormericaOptoelectronics Inc.
5F,- 11, No. 38, Taiyuan, Zhubei City,
HsinchuCounty 302, Taiwan
Ph: +886- 3- 5600286 Fax: +886 - 3- 5600239
Version 1.3
1
Product Overview
FormericaOEQuad Port 10 Gbit/s Optical Bypass Module is a compact box that
contains four10 G Base-LR1310nm (10KM) ports and can integrated with I/O ports
controllers to be a Network Interface Card (NIC). The FormericaOEQuad Port 10
Gbit/s Optical Bypass Module is targeted to inline network system that maintains
network connectivity when power failure or system fails. FormericaOEQuad Port 10
Gbit/s Optical Bypass Module supports Normal and Bypass modes, and can be
controlled to perform the Block mode. In Normal mode, the ports are independent
interfaces. In Bypass mode, all packets received from one port are transmitted to
the adjacent port. In Block mode, the moduleblocks the route. FormericaOEQuad
Port 10 Gbit/s Optical Bypass Module can Bypass or Block its I/O ports on a host
system failure, power off, or uponsoftware request. FormericaOEQuad Port 10
Gbit/s Optical Bypass Modulecan be integrated withany brand’s Controllers CPU. It
is suitable for connecting with in-line equipment’s for power failure or system
maintenance. When the In-Line unit is not on or is in bypass mode, the relays within
the Optical Bypass Module are set to bridge the optical signals directly through the
optical switch, completely bypassing the In-Line equipment. If the In-Line equipment
is on and operating normally, then it supplies power to the switch through a high
speed connector PIN.Compact and competitive cost, this module provides excellent
performance on your network.
Features
Reliable Passive Fiber Bypass (Latching)
Low Return Loss
Available in 9/125μm Single mode Fiber
PCB Mountable Type
Fast Ethernet Standard Compliant
Digital Diagnostic SFF-8472 Rev.10.2 Compliant
SONET/SDH Standard Compliant
Two Quad LC Adapter
Class 1 Laser Product Complies with EN 60825-1
10G-BASE-LR are available
Compliant with CE& FCC Standard
Compact Format and ROHS Compliant
Version 1.3
2
Block Diagram and Optical Paths
5±0.5V_100mA_OSW1
Bypass/Normal_OSW (High: 3.3V)
3.3V_1.6A_O/E_TX/RX
4x4 Optical Switch 1
Quad
O/E_0_TD+
Normal Mode
TX1
O/E_0_TD-
A0
O/E_0
Normal Mode
RX1
TX2
O/E_0_TDIS
3.3V_O/E_0_RX
B0
3.3V_O/E_1_TX
Normal Mode
RX2
O/E_0_RD+
O/E_0_RD-
A1
Bypass Mode
Normal Mode
LC Adapt er
H
I
G
H
O/E_1_TD+
O/E_1_TD-
B1
O/E_1
S
O/E_1_RD+
P
O/E_1_RD-
E
O/E_1_TDIS
E
D
3.3V_O/E_1_RX
Bypass Control
Logic
Bypass Status Feedback_OSW
WDT
5±0.5V_100mA_OSW2
Quad
Quad
3.3V_1.6A_O/E_TX/RX
4x4 Optical Switch 2
O/E_3_TD+
Normal Mode
TX3
O/E_3_TD-
A0
Normal Mode
O/E_3_RD-
A1
Bypass Mode
Normal Mode
LC Adapt er
TX4
O/E_3_TDIS
3.3V_O/E_3_RX
B0
3.3V_O/E_4_TX
Normal Mode
RX4
O/E_4
N
N
E
O/E_4_TD+
O/E_4_TD-
B1
O
Ethernet I/O Controller
with
GPIO Ports
O/E_3_RD+
O/E_3
RX3
C
C
T
O/E_4_RD+
O/E_4_RDO/E_4_TDIS
O
R
3.3V_O/E_4_RX
Quad Ports Optical Bypass Module
Version 1.3
3
OE1-Link
OSW1 State
OE2-Link
OE3-Link
OSW2 State
OE4-Link
OE1-Link, OE2-Link, OE3-Link and OE4-Link indications:
Green: Link
OSW1 State and OSW2 State indications:
Amber:
Optical Switch State
Version 1.3
4
Module Pin Out
Version 1.3
5
84 PIN Assignments:
Pin
Number
Name
I/O
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
OSW 2 State Output
Vcc5_2
OSW 2 B2
GND
OSW 2 N2
On-Line
OE1 GND
GND
OE1 TDOE1 TX Disable
OE1 TD+
OE1 TX Fault
OE1 GND
OE1 MOD-DEF2
OE1 GND
OE1 MOD-DEF1
OE1 RD+
OE1 Vcc
OE1 RDOE1-Link
OE1 GND
OSW 1 State
OE1 LOS
OE1 Rate Select
OE3 LOS
GND
OE3 GND
OE3 TX Disable
OE3 TDOE3 TX Fault
OE3 TD+
OE3 MOD-DEF2
OE3 GND
OE3 MOD-DEF1
OE3 GND
OE3 Vcc
OE3 RD+
OE3-Link
OE3 RD-
O
40
OSW 2 State
41
42
43
44
45
46
47
48
49
50
51
52
OE3 GND
OE3 Rate Select
OE2 GND
GND
OE2 TDOE2 TX Disable
OE2 TD+
OE2 TX Fault
OE2 GND
OE2 MOD-DEF2
OE2 GND
OE2 MOD-DEF1
I
I
O
Function
Note
High=Normal mode, Low=Bypass mode for OSW2
5.0V Power Supper (OSW2 Power)
Change to Bypass mode for OSW2
7/9
Change to Normal mode for OSW2
1K Ohm to Ground
OE1 Signal Ground
7/9
I
I
I
O
OE1 Inversed Data Input
Transmitter Disable for OE-1
OE1 Data Input
Transmitter Fault Indication for OE-1
OE1 Signal Ground
I/O 2 Wire Serial ID Interface (Data) for OE-1
OE1 Signal Ground
I 2 Wire Serial ID Interface (Clock) for OE-1
O OE1 Data Output
3.3V for Tx1 Power Supply and Rx1 Power Supply – 300mA
O OE1 Inversed Data Output
I OE1-Link LED Indicator (Anode/ LED Green)
OE1 Signal Ground
I OSW 1 State LED Indicator (Anode / LED Amber)
O Loss of Signal for OE-1
I High: 10 Gbps; Low: 1.25 Gbps
O Loss of Signal for OE-3
O
I
O
OE3 Signal Ground
Transmitter Disable for OE-3
OE3 Inversed Data Input
Transmitter Fault Indication for OE-3
OE3 Data Input
2 Wire Serial ID Interface (Data) for OE-3
OE3 Signal Ground
2 Wire Serial ID Interface (Clock) for OE-3
OE3 Signal Ground
3.3V for Tx3 Power Supply and Rx3 Power Supply – 300mA
OE3 Data Output
OE3-Link LED Indicator (Anode / LED Green)
OE3 Inversed Data Output
I
OSW 2 State LED Indicator (Anode / LED Amber)
I
OE3 Signal Ground
High: 10 Gbps; Low: 1.25Gbps
OE2 Signal Ground
I
I
O
I
I/O
I
I
I
I
O
OE2 Inversed Data Input
Transmitter Disable for OE-2
OE2 Data Input
Transmitter Fault Indication for OE-2
OE2 Signal Ground
I/O 2 Wire Serial ID Interface (Data) for OE-2
OE2 Signal Ground
I 2 Wire Serial ID Interface (Clock) for OE-2
6
2
6
1
3
3
5
5
4
4
2
6
1
6
3
3
5
5
2
6
1
6
3
3
Version 1.3
6
Pin
Number
Name
I/O
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
OE2 RD+
OE2 Vcc
OE2 RDOE2-Link
OE2 GND
LED-pair1 common
OE2 LOS
OE2 Rate Select
OE4 LOS
GND
OE4 GND
OE4 TX Disable
OE4 TDOE4 TX Fault
OE4 TD+
OE4 MOD-DEF2
OE4 GND
OE4 MOD-DEF1
OE4 GND
OE4 Vcc4
OE4 RD+
OE4-Link
OE4 RDLED-pair2 common
OE4 GND
OE4 Rate Select
OSW 1 State Output
GND
OSW 1 B1
GND
OSW 1 N1
Vcc5_1
O
O
I
I
O
I
O
Function
Note
OE2 Data Output
3.3V for Tx2 Power Supply and Rx2 Power Supply – 300mA
OE2 Inversed Data Output
OE2-Link LED indicator (Anode / LED Green)
OE2 Signal Ground
LED-pair1 common Cathode
Loss of Signal for OE-2
Loss of Signal for OE-4
5
5
4
4
I
O
OE4 Signal Ground
Transmitter Disable for OE-4
OE4 Data Input
Transmitter Fault indication for OE-4
OE4 Data Input
2 Wire Serial ID Interface (Data) for OE-4
OE4 Signal Ground
2 Wire Serial ID Interface (Clock) for OE-4
OE4 Signal Ground
3.3V for Tx4 Power Supply and Rx4 Power Supply – 300mA
OE4 Data Output
OE4-Link LED Indicator (Anode / LED Green)
OE4 Inversed Data Output
LED-pair2 common Cathode
OE4 Signal Ground
High=Normal Mode, Low=Bypass Mode for OSW1
I
Change to Bypass mode for OSW1
7/9
I
Change to Normal mode for OSW1
5.0V Power Supply (OSW 1 Power)
7/9
8
I
I
O
I
I/O
O
O
I
O
I
2
6
1
6
3
3
5
5
Version 1.3
7
23PIN Assignments:
Pin
Number
Name
1
2
3
4
5
6
Vcc5_1
Vcc5_1
LED-pair2 common
OE1-Link
OE4-Link
OSW 1 State
I
I
I
I
5.0V Power Supper (OSW1 Power)
7
OSW 2 State
I
8
9
10
OE2-Link
OE3-Link
LED-pair1 common
OSW 2 State
Output
OSW 1 State
Output
GND
GND
OSW 2 B2
OSW 1 B1
OSW 2 N2
OSW 1 N1
I
I
I
OE3-Link LED Indicator (Anode/ LED Green)
O
O
11
12
13
14
15
16
17
18
19
22
23
I/O
I
I
I
I
Vcc5_2
Vcc5_2
Function
Note
No Connector
No Connector
No Connector
Version 1.3
8
Notes:
1. TX Fault is an open collector/drain output, which should be pulled up with a 4.7K – 10KΩ resistor on the hostboard. Pull
up voltage between 2.0V and VccT, R+0.3V. When high, output indicates a laser fault of some kind.Low indicates
normal operation. In the low state, the output will be pulled to < 0.5V.
2. TX disable is an input that is used to shut down the transmitter optical output. It is pulled up within the modulewith a
4.7 – 10 K Ω resistor. Its states are:
Low (0 – 0.8V): Transmitter on
(>0.8, < 2.0V): Undefined
High (2.0 – 3.465V): Transmitter Disabled
Open: Transmitter Disabled
3. Mod-Def 1,2, These are the module definition pins. They should be pulled up with a 4.7K – 10KΩ resistor on thehost
board. The pull-up voltage shall be VccT or VccR (see Section IV for further details). Mod-Def 0 is groundedby the
module to indicate that the module is present Mod-Def 1 is the clock line of two wire serial interface forserial ID Mod-Def
2 is the data line of two wire serial interface for serial ID
4. LOS (Loss of Signal) is an open collector/drain output, which should be pulled up with a 4.7K – 10KΩ resistor.Pull up
voltage between 2.0V and VccT, R+0.3V. When high, this output indicates the received optical power isbelow the
worst-case receiver sensitivity (as defined by the standard in use). Low indicates normal operation. Inthe low state, the
5. RD-/+: These are the differential receiver outputs. They are AC coupled 100Ω differential lines which should
beterminated with 100Ω (differential) at the user SERDES. The AC coupling is done inside the module and is thusnot
required on the host board. The voltage swing on these lines will be between 350 and 850 mV differential(175 – 425 mV
single ended) when properly terminated.
6. TD-/+: These are the differential transmitter inputs. They are AC-coupled, differential lines with 100Ω
differentialtermination inside the module. The AC coupling is done inside the module and is thus not required on the
host board.The inputs will accept differential swings of 180 – 700 mV (90 – 350 mV single-ended).
7. Latching Type - The input is used to control the optical switch mode for OSW
Normal mode:
OSW N1/N2: > 3.75V and OSW B1/B2 < 0.5V and over 20ms.
Bypass mode:
OSW N1/N2: < 0.5V and OSW B1/B2 >3.75V and over 20ms
8. Non-Latching Type - High =Normal Mode, Low=Bypass Mode for OSW.
9. Non-Latching Type - Pin 43, 44, 82 and 83: Ground
Version 1.3
9
Absolute Maximu Ratings
Parameter
Symbol
Min.
Power Supply Voltage
Vcc
Storage Temperature
Supply Voltage
Optical Receiver Power (Damage)
Typ.
Max.
Unit
V
Ts
-40
85
Vcc
V
15
dBm
Pmax
Recommended Operating Conditions
Parameter
Symbol
Min.
Max.
Unit
Note
Tc
1
+5.0V Supply Voltage
Vcc5
4.75
5.25
V
Vcc5
+3.3V Supply Voltage
Vcc3
3.10
3.50
V
5
85
10.3125
+100ppm
Gbps
Typ.
Max.
Unit
Case Operating Temperature
Relative Hunidity (non condensation)
Data Rate
-100ppm
Typ.
Note1 : Please see order information
Electrical Characteristics
Parameter
Symbol
Min.
Note
+5.0V Supply Current
Icc5
100
mA
+3.3V Supply Current
Icc3
1200
mA
Gbps
Data Rate
10.3125
Transmitter
Transmitter Differential Input Voltage
VDT
180
700
mV
Transmitter Disable Input-High
VDISH
2
Vcc+0.3
V
Transmitter Disable Input-Low
VDISL
V
1
Receiver
VDR
350
850
mV
3
LOS Output Voltage-High
VLOSH
2.4
Vcc
V
2
LOS Output Voltage-Low
VLOSL
V
2
5.25
V
0.8
V
Receiver Differential Output Voltage
Optical Switch
Latching Voltage-High
VLATH
4.75
Latching Voltage-Low
VLATL
Latching Resistance
RLAT
5
125
Ω
Notes:
1.
Internally AC coupled and terminated to 100Ohm differential load.
2.
Pull up to Vcc on Host Board.
3.
Internally AC coupled, but requies a 100Ohm differential termination at or internal to
Serializer/Deserializer.
Version 1.3
10
Optical Characteristics(Tc=0~70℃, Data Rate=10.3125Gb/sec, PRBS=231-1 NRZ)
Parameter
Symbol
Min.
Typ.
Max.
Unit
Note
Transmitter
Average Launch Power
Po
-8.2
0.5
dBm
Center Wavelength
λC
1260
1355
nm
SMSR
30
nm
ER
3.5
dB
TDP
3.2
dB
POMA
-5.2
dBm
POMA-TDP
-6.2
dBm
Poff
-128
dB/Hz
12
dB
Side Mode Suppression Ratio
Extinction Ratio
Transmitter and dispersion
penalty(max)
Optical Power OMA
OMA-TDP
Average launch power of OFF
transmitted
Optical Return Loss Tolerance
Output eye
Compliant with IEEE802.3ae eye mask
Receiver
Center Wavelength
λC
Average receiver power(max)
Pmax
Average receiver power(min)
Pmin
Receiver Reflectance
Rrx
1260
1355
Nm
0.5
dBm
-14.4
dBm
-12
dB
Receiver Sensitivity in OMA
-12.6
dBm
Stressed Sensitivity in OMA
-10.3
dBm
1
Vertical eye closure penalty
2.2
dB
2
Stressed eye jitter
0.3
UIp-p
1
-30
dBm
Assert
LOSA
Deassert
LOSD
LOS
LOS Hysteresis
LOSH
-12
dBm
0.5
Optical Switch
Wavelength Range
λR
Insertion Loss
OIL
Return Loss
ORL
1260~1360 and 1510~1610
2
50
Latching Resistance
8
7
RLAT
dB
dB
Switch Time
Lifetime
nm
ms
≧10
times
125
Ω
Version 1.3
11
Notes:
1.
Receiver Sensitivity is informative. Stressed receiver sensitivity shall be measured with conformance test signal
for BER 1×10-12.
2.
Vertical eye closure penalty and stressed eye jitter are the test conditions for measuring stressed receiver
sensitivity. They are not the required characteristic of the receiver.
Version 1.3
12
Package Outline Drawing (mm)
Version 1.3
13
Host Board B2B Connector
Samtec QTE-042-01-L-D-DP-A-TR
HRSDF9-23S-1V
Customer Host Board Top View
Samtec QSE-042-01-L-D-DP-A-TR
HRSDF9-23P-1V
Fiber Bypass Module: Bottom View
Version 1.3
14
EEPROM Serial ID Memory Contents (2-Wire Address A0H)
Address
HEX
00
01
02
03
04
05
06
07
03
04
07
00
00
00
08
00
09
10
11
00
00
06
12
67
13
14
15
00
0A
64
16
00
17
00
18
00
19
00
20 ~ 35
36
37 ~ 39
40 ~ 55
56 ~ 59
60 ~ 61
62
63
64
65
66
67
68 ~ 83
84 ~ 89
90 ~ 91
92
93
Name of Field
Identifier
Extended Identifier
Connector type
10G Ethernet Compliance Codes
SONET Compliance Codes
Fiber Channel link length
Fiber Channel transmitter
technology
Fiber Channel transmission media
Fiber Channel speed
Encoding codes:
Nominal Bit Rate (units of
100Mbps)
Rate identifier
Link length supported for 9um fiber
50um,OM2
62.5um,OM1
Link length supported for copper
50um,OM3
46,4F,52,4D,45,52,49,43 ,41,4F,45,
Vendor Name
20,20,20,20,20
00
Unallocated
00,00,00
Vendor OUI
4F,42,4D,2D,41,33,43,42,34,2D,43
Part Number
,30,36,5F,56,33
00,00,00,00
Vendor Revision number
05,1E
Laser Wavelength
00
Unallocated
CC_BASE:
00
Options
1A
Options
00
Bit Rate, max.
00
Bit Rate, min.
Serial Number
Serial Number
yy/mm/dd
Date Code
20,20
Vendor specific lot code
68
Diagnostic Monitoring Type
F0
Enhanced Options (soft)
94
03
95
96~127
SFF-8472 Compliance
CC_EXT
Vendor specific
Description
SFP
SFP
LC
10G Base LR
Not compliant
Not compliant
Not compliant
Not compliant
Not compliant
Not compliant
Not compliant
64B/66B
10.3Gbps
Unspecified
10km (units of km)
10km (units of 100m)
N/A (units of 10m)
N/A (units of 10m)
N/A (units of 1m)
N/A (units of 10m)
FORMERICAOE
Unspecified
OBM-A3CB4-C06_V3
Unspecified
1310nm
Check sum of byte 0 ~ 62
TX-DIS, TX_FAULT, RX-LOS
Unspecified
Unspecified
Unspecified
Internal calibration
Alarm/Warning flags, Soft TxDisable,
Soft TxFault, Soft RxLOS implemented
Rev10.2
Check sum of byte 64 ~ 94
Version 1.3
15
EEPROM Serial ID Memory Contents (2-Wire Address A2H)
Add
Bytes
Name
Hex
Real Value
00-01
02-03
04-05
06-07
08-09
10-11
12-13
14-15
16-17
18-19
20-21
22-23
24-25
26-27
28-29
30-31
32-33
34-35
36-37
38-39
40-55
56-59
60-63
64-67
68-71
72-75
76-77
78-79
80-81
82-83
84-85
86-87
88-89
90-91
92-94
95
2
2
2
2
2
2
2
2
2
2
2
2
2
2
2
2
2
2
2
2
16
4
4
4
4
4
2
2
2
2
2
2
2
2
3
1
Temp High Alarm
Temp Low Alarm
Temp High Warning
Temp Low Warning
Voltage High Alarm
Voltage Low Alarm
Voltage High Warning
Voltage Low Warning
Bias High Alarm
Bias Low Alarm
Bias High Warning
Bias Low Warning
TX Power High Alarm
TX Power Low Alarm
TX Power High Warning
TX Power Low Warning
RX Power High Alarm
RX Power Low Alarm
RX Power High Warning
RX Power Low Warning
Reserved
RX_PWR(4)
RX_PWR(3)
RX_PWR(2)
RX_PWR(1)
RX_PWR(0)
TX_I(Slope)
TX_I(Offset)
TX_PWR(Slope)
TX_PWR(Offset)
T(Slope)
T(Offset)
V(Slope)
V(Offset)
Reserved
Checksum
5500
85℃
0000
5000
0A00
9470
6D60
9088
7148
AFC8
03E8
9C40
05DC
576C
02F8
4574
03B6
576C
00E6
4574
016B
00
00000000
00000000
00000000
3F800000
00000000
0100
0000
0100
0000
0100
0000
0100
0000
00
0℃
80℃
10℃
3.8V
2.8V
3.7V
2.9V
90mA
2mA
80mA
3mA
3.5dBm
-11.2dBm
2.5dBm
-10.2dBm
3.5dBm
-16.4dBm
2.5dBm
-14.4dBm
Version 1.3
16
ESD
This transceiver is specified as ESD threshold 2kV for all electrical input pins,
tested per MIL-STD-883, Method 3015.4 /JESD22-A114-A (HBM). However,
normal ESD precautions are still required during the handling of this module.
This transceiver is shipped in ESD protective packaging. It should be
removed from the packaging and handled only in an ESD protected
environment.
LASER Safety
This is a Class 1 Laser Product according to IEC 60825-1:1993:+A1:1997+A2:2001.
This product complies with 21 CFR 1040.10 a nd 1040.11 except for deviations
pursuant to Laser Notice No. 50, dated (July 26,
2001)
Version 1.3
17
Revision History
Date
Version
08/30/2017
Version
1.3
Description of Changes
Correct 2-Wire Address A0H (40~55)
“4F,42,4D,2D,41,33,43,42,34,2D,43,30,36,5F,56,33”
on page 15.
Author
Jack.Wang
Version 1.3
18
