EEG CLICK
EEG CLICK
    MIKRO
EEG CLICK 数据手册
    EEG CLICK  PID: MIKROE‐3359   Weight: 27 g    EEG Click is a Click board™ that allows monitoring of brain activity. Although not suitable for clinical  examination, it is quite sufficient to allow some insight into brain activity. EEG click is equipped with a high‐ sensitivity circuit which amplifies faint electrical signals from the brain, allowing them to be sampled by a  host MCU. To allow sufficiently high gain with no interferences, EEG click uses the INA114, a precision  instrumentation amplifier, LASER trimmed for very low offset voltage, featuring very good common mode  rejection ratio. This Click board™ can be used with the set of silver‐chloride electrodes.    EEG click is supported by a mikroSDK compliant library, which includes functions that simplify software  development. This Click board™ comes as a fully tested product, ready to be used on a system equipped with  the mikroBUS™ socket.  Monitoring brain activity gains its popularity lately, as due to the fact that many commercially  available integrated circuits emerge on market, almost daily. High‐performance  instrumentation amplifier ICs are affordable, making applications such as EEG click possible.  EEG training, a technique of mental training method which makes the trainee consciously  aware of the general activity in the brain is one of the applications where EEG click can be very  useful. It can be also used for experimentation and development of brain‐machine interface  applications, or for simple monitoring of the brain activity.  WHAT IS EEG?  Electroencephalography is a method used to record the electrical activity of the brain. This is a  non‐invasive method which uses a number of electrodes placed along the scalp. EEG measures  voltage fluctuations which appear as a result of the ionic currents within the neurons of the  brain. The measurement can be focused either on event‐related potential changes (ERP) or on  spectral content of the signal, collected during a certain period. EEG is most often used to  diagnose epilepsy, which causes abnormal changes of EEG readings.  HOW DOES IT WORK?  EEG click is a single channel EEG monitoring device, based on the INA114, a precision  instrumentation amplifier (IA) by Burr Brown®, a division of Texas Instruments, specialized in  high‐performance analog and mixed signal ICs. This IC offers a very low noise, LASER trimmed  offset voltage, and very good common‐mode rejection ratio. It uses a single resistor to set up its  gain, which can easily be set up to 10,000. On this Click board™, the INA114 IA has its gain set  to about 12 times. Further amplification and signal filtering is done by the MCP609, a four‐ channel op‐amp from Microchip, so that the final gain factor is about 7800 times. Such high  amplification is necessary in order to amplify very faint voltages generated during the brain  activity. To fine‐tune the amplification, there is a multi‐turn precision potentiometer which  allows to set the gain of the intermediate amplification stage between 10 and 100 times.    Since the "brain waves " can be both positive and negative, EEG click uses a virtual GND at the  potential of 2.048V. This also helps reducing the noise from the common GND, improving the  readings quality. The amplified brain activity signal is available at the AN pin of the mikroBUS™,  allowing sampling by the host MCU.  EEG measurements should be ideally conducted in an electrically isolated room, since any type  of electromagnetic interference (EMI) could corrupt the measurement data. However, the  INA114 offers some EMI protection, as it features an extremely good common‐mode rejection  ratio (CMRR), allowing to successfully cancel out most of induced interferences.  This Click board™ uses 3‐electrode setup, which can be connected over a 3.5mm Jack connector  on the Click board™. Although the best results can be achieved by using silver‐chlorine plated  electrodes, any type of electrodes can be used. EEG uses the DRL electrode placement scheme:  two electrodes are placed behind the ears, while the third electrode is placed on the forehead.  The DRL electrode (on the forehead) helps eliminating the common voltage, while two other  electrodes are connected to the differential inputs of the INA114 IA.  The complete signal path is very well protected against voltage spikes and transients, that  might appear as a result of the electrostatic discharge (ESD) in contact with the human body, so  there is a set of ESD suppressing diodes and TVS diodes, which prevent sensitive IA and  operational amplifiers on its output to become damaged by ESD events.  SPECIFICATIONS  Type  Biomedical  Applications  EEG click can be used in EEG biofeedback mental training, for experimentation and  development of brain‐machine interface applications, or for simple monitoring of the  brain activity.  On‐board  modules  INA114, a precision instrumentation amplifier (IA) by Texas Instruments; MCP609, a  four‐channel operational amplifier from Microchip; MAX6106, a 2.048V reference from  Maxim Integrated.  Key Features  ESD and EMI protection of the inputs, compatible with several types of electrodes, high‐ precision instrumentation amplifier with high CMRR, gain regulation, etc.  Interface  Analog  Input Voltage  5V  Click board  size  L (57.15 x 25.4 mm)  PINOUT DIAGRAM  This table shows how the pinout on EEG Click corresponds to the pinout on the mikroBUS™  socket (the latter shown in the two middle columns).  Notes  Pin  Pin  Notes    EEG signal OUT  AN  1  AN  PWM  16  NC        NC  2  RST  INT  15  NC        NC  3  CS  RX  14  NC        NC  4  SCK  TX  13  NC        NC  5  MISO  SCL  12  NC        NC  6  MOSI  SDA  11  NC        NC  7  3.3V  5V  10  5V  Power Supply  GND  8  GND  GND  9  GND          Ground  Ground  ONBOARD SETTINGS AND INDICATORS  Label  Name  Default  PWR  PWR  ‐  Power LED indicator  CN1  3.5mm JACK  ‐  3.5mm electrodes connector   Description  SOFTWARE SUPPORT  We provide a library for the EEG Click on our LibStock page, as well as a demo application  (example), developed using MikroElektronika compilers. The demo can run on all the main  MikroElektronika development boards.    Library Description  Library only initializes GPIO interface. For more details check documentation.  Examples description  The application is composed of the three sections :   System Initialization ‐ Initializes peripherals and pins.   Application Initialization ‐ Initializes ADC and timer interrupt function.   Application Task ‐ (code snippet) ‐ Reads ADC value and sends results on serial plotter every time when  interrupt occurres.  void applicationTask()  {      if (interrFlag == 1)      {          interrFlag = 0;                    readADC = ADC_Get_Sample( 0 );          timeRead = interrCnt * time_ms;          plotRes( readADC, timeRead );      }  }      Additional Functions :    void initTimer() ‐ Initializes interrupt time to the desired value.  void plotRes( uint16_t plotData, uint32_t plotTime ) ‐ Sends ADC data on the serial plotter.  The full application code, and ready to use projects can be found on our LibStock page.  Other mikroE Libraries used in the example:     Conversions  UART  ADC  Additional notes and informations  Depending on the development board you are using, you may need USB UART click, USB UART  2 click or RS232 click to connect to your PC, for development systems with no UART to USB  interface available on the board. The terminal available in all MikroElektronika compilers, or  any other terminal application of your choice, can be used to read the message.  MIKROSDK  This click board is supported with mikroSDK ‐ MikroElektronika Software Development Kit. To  ensure proper operation of mikroSDK compliant click board demo applications, mikroSDK  should be downloaded from the LibStock and installed for the compiler you are using.    For more information about mikroSDK, visit the official page.        https://www.mikroe.com/eeg‐click/3‐13‐19
EEG CLICK 价格&库存
很抱歉,暂时无法提供与“EEG CLICK”相匹配的价格&库存,您可以联系我们找货
EEG CLICK
    • 1+610.10022
