TSD2G
Taiwan Semiconductor
2A, 400V ESD Capability Rectifier
FEATURES
KEY PARAMETERS
High ESD capability
Glass passivated chip junction
Ideal for automated placement
Low forward voltage drop
High surge current capability
Moisture sensitivity level: level 1, per J-STD-020
RoHS Compliant
Halogen-free according to IEC 61249-2-21
PARAMETER
VALUE
UNIT
IF
2
A
VRRM
400
V
IFSM
50
A
TJ MAX
175
°C
Package
DO-214AA (SMB)
Configuration
Single die
APPLICATIONS
Switching mode power supply (SMPS)
Adapters
Lighting application
Converter
MECHANICAL DATA
Case: DO-214AA (SMB)
Molding compound meets UL 94V-0 flammability rating
Terminal: Matte tin plated leads, solderable per J-STD-002
Meet JESD 201 class 2 whisker test
Polarity: Indicated by cathode band
Weight: 0.090g (approximately)
DO-214AA (SMB)
SOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted)
SYMBOL
PARAMETER
TSD2G
UNIT
TSD2G
Marking code on the device
Repetitive peak reverse voltage
VRRM
400
V
Reverse voltage, total rms value
VR(RMS)
280
V
Forward current
Surge peak forward current, 8.3ms single half sine-wave
superimposed on rated load
Junction temperature
IF
2
A
IFSM
50
A
TJ
- 55 to +175
°C
Storage temperature
TSTG
- 55 to +175
°C
1
Version: F2102
TSD2G
THERMAL PERFORMANCE
PARAMETER
SYMBOL
TYP
UNIT
Junction-to-lead thermal resistance
RӨJL
26
°C/W
Junction-to-ambient thermal resistance
RӨJA
73
°C/W
Junction-to-case thermal resistance
RӨJC
27
°C/W
Thermal Performance Note: Units mounted on PCB (10mm x 10mm Cu pad test board)
ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted)
PARAMETER
CONDITIONS
SYMBOL
TYP
MAX
UNIT
0.87
0.95
V
0.90
1.00
V
0.80
0.90
V
0.75
0.85
V
1
µA
50
µA
pF
IF = 1A, TJ = 25°C
Forward voltage
IF = 2A, TJ = 25°C
(1)
VF
IF = 1A, TJ = 125°C
IF = 2A, TJ = 125°C
Reverse current @ rated VR
(2)
Junction capacitance
TJ = 25°C
IR
TJ = 125°C
1MHz, VR = 4.0V
CJ
Notes:
1. Pulse test with PW = 0.3ms
2. Pulse test with PW = 30ms
IMMUNITY TO ELECTRICAL STATIC DISCHARGE TO THE FOLLOWING
STANDARDS (TA = 25°C unless otherwise noted)
STANDARD
AEC-Q101-001
IEC 61000-4-2
ISO 10605
TEST TYPE
Human body
model(contact mode)
Contact mode
TEST
CONDITION
SYMBOL
C=100pF,R=1.5kΩ
C=150pF,R=330Ω
Vc
CLASS
VALUE
TYPICAL
H3B
≥8kV
N/A
4
≥8kV
25kV
4
≥15kV
30kV
Air-discharge mode
C=150pF,R=330Ω
Contact mode
C=330pF,R=330Ω
L4
≥15kV
25kV
Air-discharge mode
C=330pF,R=330Ω
L4
≥25kV
30kV
ORDERING INFORMATION
ORDERING CODE
PACKAGE
PACKING
TSD2G
DO-214AA (SMB)
3,000 / Tape & Reel
2
Version: F2102
TSD2G
CHARACTERISTICS CURVES
Fig.1 Forward Current Derating Curve
Fig.2 Typical Junction Capacitance
100
CAPACITANCE (pF) A
2
1
10
f=1.0MHz
Vsig=50mVp-p
60
90
120
150
1
180
1
10
LEAD TEMPERATURE (°C)
REVERSE VOLTAGE (V)
Fig.4 Typical Forward Characteristics
100
TJ=125°C
1
0.1
TJ=25°C
0.01
0.001
10
40
50
60
70
80
90
100
INSTANTANEOUS FORWARD CURRENT (A)
INSTANTANEOUS REVERSE CURRENT (μA)
Fig.3 Typical Reverse Characteristics
10
100
PERCENT OF RATED PEAK REVERSE VOLTAGE (%)
100 10
1
10
UF1DLW
TT
J=125°C
J=125°C
TJ=25°C
0.1
(A)
AVERAGE FORWARD CURRENT (A)
3
TJ=25°C
1
0.01
Pulse width
Pulse width 300μs
1% duty cycle
0.001
0.3
0.4
0.1
0.40
0.60
0.5
0.80
0.6
0.7
1.00
0.8
0.9
1.20
1
1.40
1.1
1.60
FORWARD VOLTAGE (V)
3
Version: F2102
1.2
TSD2G
PACKAGE OUTLINE DIMENSIONS
DO-214AA (SMB)
SUGGESTED PAD LAYOUT
MARKING DIAGRAM
4
P/N
= Marking Code
G
= Green Compound
YW
= Date Code
F
= Factory Code
Version: F2102
TSD2G
Notice
Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf,
assumes no responsibility or liability for any errors or inaccuracies.
Purchasers are solely responsible for the choice, selection, and use of TSC products and TSC assumes no liability
for application assistance or the design of Purchasers’ products.
Information contained herein is intended to provide a product description only. No license, express or implied, to
any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of
sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty,
relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose,
merchantability, or infringement of any patent, copyright, or other intellectual property right.
The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications.
Customers using or selling these products for use in such applications do so at their own risk and agree to fully
indemnify TSC for any damages resulting from such improper use or sale.
5
Version: F2102
很抱歉,暂时无法提供与“TSD2GH R5G”相匹配的价格&库存,您可以联系我们找货
