Datasheet SGP41
Air Quality Sensor for VOC and NOx Measurements
MOx based gas sensor for air quality applications
Outstanding long-term stability and lifetime
I2C interface with digital output signals
Very small 6-pin DFN package: 2.44 x 2.44 x 0.85 mm3
Low power consumption: 3.0 mA at 3.3 V
Tape and reel packaged, reflow solderable
Product Summary
The SGP41 is a digital gas sensor designed for easy
integration into air purifiers or demand-controlled
ventilation systems. Sensirion’s CMOSens® technology
offers a complete, easy-to-use sensor system on a single
chip featuring a digital I2C interface and temperaturecontrolled micro hotplates, providing one VOC and one
NOx based indoor air quality signal. Both sensing element
and Gas Index Algorithm feature an unmatched
robustness against contaminating gases present in real-
world applications enabling a unique long-term stability
as well as low drift. The very small 2.44 x 2.44 x 0.85
mm3 DFN package enables applications in limited
spaces. Sensirion’s state-of-the-art production process
guarantees high reproducibility and reliability. Tape and
reel packaging together with suitability for standard
SMD assembly processes make the SGP41
predestined for high-volume applications.
Figure 1 Functional block diagram of the SGP41.
www.sensirion.com
version 1.0 – December 2021
1/22
Table of Contents
1 Sensor Performance................................................................................................................................................................3
2 Specifications ..........................................................................................................................................................................5
2.1 Electrical Specifications .....................................................................................................................................................5
2.2 Timing Specifications .........................................................................................................................................................5
2.3 Recommended Operating and Storage Conditions ...........................................................................................................6
2.4 Absolute Minimum and Maximum Ratings .........................................................................................................................7
2.5 Interface Specifications ......................................................................................................................................................7
2.6 Environmental Stability ......................................................................................................................................................8
2.7 Material Contents ...............................................................................................................................................................8
3 Sensor Output Signal Description .........................................................................................................................................9
3.1 Conditioning .......................................................................................................................................................................9
3.2 Raw Signal Measurement ..................................................................................................................................................9
3.3 VOC and NOx Index Measurement ..................................................................................................................................10
3.4 Built-in Self-Test...............................................................................................................................................................11
3.5 Reading out The Sensor Serial Number ..........................................................................................................................11
3.6 Sensor Start-up Behavior .................................................................................................................................................11
4 Digital Interface Description .................................................................................................................................................12
4.1 General Considerations ...................................................................................................................................................12
4.2 I2C Address ......................................................................................................................................................................12
4.3 I2C Voltage Levels............................................................................................................................................................12
4.4 I2C Protocol Speed...........................................................................................................................................................12
4.5 I2C Sequences .................................................................................................................................................................12
4.6 Checksum Calculation .....................................................................................................................................................13
4.7 I2C Commands .................................................................................................................................................................13
5 Mechanical Specifications ....................................................................................................................................................18
5.1 Traceability.......................................................................................................................................................................18
5.2 Package Outline...............................................................................................................................................................18
5.3 Land Pattern ....................................................................................................................................................................19
5.4 Soldering Instructions ......................................................................................................................................................19
6 Ordering Information .............................................................................................................................................................20
6.1 Packaging Information .....................................................................................................................................................20
www.sensirion.com
2/22
Table 1 lists specifications characterizing the gas sensing performance. The SGP41 chip provides two digital raw signals which
are sensitive to most VOCs typically present in indoor environments and oxidizing gases such as NOx or O3, respectively. The
raw signals are proportional to the logarithm of the resistance of the sensing material. For the specifications given below, ethanol
in clean air has been used as proxy gas for typical VOC based indoor air events and NO2 in clean air has been used as proxy
gas for typical oxidizing gas based indoor air events.
Parameter
Conditions
Output signal
range2
VOC Index, processed value from SRAW_VOC
NOx Index, processed value from SRAW_NOX
SRAW_VOC, digital raw value from VOC pixel
SRAW_NOX, digital raw value from NOx pixel
Ethanol in clean air
NO2 in clean air
NO2 in clean air
VOC Index
Measurement
range
Specified range
Device-to-device
variation4
Values1
Min.
1
1
50
Typ.
很抱歉,暂时无法提供与“SGP41-D-R4”相匹配的价格&库存,您可以联系我们找货
