M3444
M3444
    HEYCO
M3444 数据手册
“Stay Connected” with Liquid Tight Cordgrips ® NO O-RING REQUIRED! ® Heyco -Tite Liquid Tight Cordgrips Straight-Thru, PG* Hubs with Integral Sealing Ring The Ultimate in Liquid Tight Strain Relief Protection • Integral Sealing Ring ensures a superior seal at the clearance or threaded mounting hole location, every time. • Widest range of approved cable diameters. Cable ranges listed are for the maximum IP68 sealing range. Contact Heyco for UL approved 514B cable ranges. • IP 68 rated. • Approved for NEMA 4,4X, 6 and 6P applications. • Ratchet design of sealing nut assembly provides superior antivibration protection and ensures a firm grip on the cable. • Acme threads on body prevent skipping and speed installation. • All nylon construction with Buna N or TPE sealing gland resists salt water, weak acids, gasoline, alcohol, oil, grease, and common solvents. (This feature is not assessed by UL.) • Multiple sizes for flexible cord diameters ranging from .065˝ (1,7 mm) to 1.730˝ (44,0 mm). • We recommend using the fitting with the smallest maximum diameter that will fit your application. • Unassembled Nylon Locknuts INCLUDED. • For Heyco Liquid Tight Threaded Plugs, see page 3-51. • Consult Heyco for cordgrips molded in other colors. CABLE DIA. RANGE Minimum in. mm. Maximum in. PART NO. Including Nylon Nut** No Nut Black Gray Black DESCRIPTION mm. PART DIMENSIONS A B C E or Clearance Max. O.A. Thread Wrenching Hole Dia. Length Length Nut Flats in. mm. in. mm. in. mm. in. mm. Standard Thread .065 1,7 .210 5,3 M3444 M3445 M4754 RLTCG 7 .115 2,9 .250 6,4 M3207 M3208 M4752 LTCG 7 .065 1,7 .230 5,8 M3446 M3447 M4758 RLTCG 9 .105 2,7 .315 8,0 M3210 M3211 M4756 LTCG 9 .069 1,8 .260 6,6 M3448 M3449 M4762 RLTCG 11 .230 5,8 .400 10,2 M3213 M3214 M4760 LTCG 11 .095 2,4 .290 7,4 M4500 M4501 M4506 RLTCG 13.5 .170 4,3 .450 11,4 M3216 M3217 M4764 LTCG 13.5 .180 4,6 .400 10,2 M4502 M4503 M4508 RLTCG 16 .260 6,6 .545 13,8 M3219 M3220 M4766 LTCG 16 .250 6,4 .490 12,4 M3454 M3455 M4748 RLTCG 21 .492 12,5 1.16 29,5 .32 8,1 .63 16,0 .599 15,2 1.25 31,8 .32 8,1 .82 20,8 .733 18,6 1.48 37,6 .38 9,7 .94 23,9 .804 20,4 1.53 38,9 .41 10,4 .98 24,9 .886 22,5 1.68 42,7 .44 11,2 1.06 26,9 1.12 .420 10,7 .630 16,0 M3222GA M3223GA - .435 11,0 .705 17,9 M3222 M3223 M4768 .490 12,4 28,3 1.89 48,0 .52 13,2 1.30 33,0 1.470 37,3 2.23 56,6 .57 14,5 1.73 43,9 1.88 47,6 2.39 60,7 .47 11,9 2.05 52,7 LTCG 21 .785 19,9 M4504 M4505 M4512 RLTCG 29 .590 15,0 1.000 25,4 M3225 M3226 M4770 LTCG 29 .787 20,0 1.020 25,9 M3206 M3205 M4772 RLTCG 36 .875 22,2 1.260 32,0 M3204 M3203 M4774 LTCG 36 1.000 25,4 1.240 31,5 1.230 31,2 1.560 39,6 M3218 M3212 M3215 M3209 M4740 M4742 RLTCG 42 LTCG 42 2.130 54,1 2.50 63,5 .48 12,2 2.46 62,5 1.160 29,5 1.350 34,3 1.450 36,8 1.730 43,9 M3283 M3281 M3284 M3282 M4744 M4776 RLTCG 48 LTCG 48 2.340 59,4 2.63 66,7 .50 12,7 2.73 69,3 Short Thread .069 1,8 .230 5,8 .250 6,4 .435 11,0 .260 6,6 M3448ST M3449ST RLTCG 11 ST M3213ST LTCG 11 ST .400 10,2 .490 12,4 M3454ST M3455ST RLTCG 21 ST LTCG 21 ST .705 17,9 M3222ST M3223ST Standard colors black and gray. *Steel conduit threads per DIN 40430, see page 3-57 **Nylon locknuts shipped unassembled A For No Nut Part Nos. in gray color please visit our Cordgrip product section at heyco.com – .733 18,6 1.41 35,8 .31 7,9 .94 23,9 – 1.115 28,3 1.80 45,7 .43 10,9 1.30 33,0 B D*** C E SUGGESTED CLEARANCE HOLE FOR NONTHREADED MOUNTING SEALING NUT INTEGRAL SEALING RING ***Consult Heyco for Wrenching Nut Thickness “D” Material Certifications Quick Specs 3-3 Flammability Rating Temperature Range IP Rating Nylon 6/6 w/Buna N or TPE Sealing Gland Listed under Underwriters’ Laboratories File E51579 (Standard Thread Only) Recognized under the Component Program of Underwriters’ Laboratories File E51579 (Standard Thread Only) Certified by Canadian Standard Association File 93876C (Standard Thread Only) Approved for NEMA 4, 4X, 6 and 6P Applications 94V-2 Static -40°F (-40°C) to 239°F (115°C) Dynamic -4°F (-20°C) to 212°F (100°C) IP 68 (70 PSI, 5 BAR) 1-800-526-4182 • 732-286-1800 (NJ) • FAX: 732-244-8843 • www.heyco.com
M3444 价格&库存
很抱歉,暂时无法提供与“M3444”相匹配的价格&库存,您可以联系我们找货
