RS621BXF
RS621BXF
    RUNIC(润石)
    SOT23-5
RS621BXF 数据手册
RS621S, RS622S, RS62X 7MHz, Rail-to-Rail I/O CMOS Operational Amplifier FEATURES DESCRIPTION • HIGH GAIN BANDWIDTH:7MHz • RAIL-TO-RAIL INPUT AND OUTPUT 0.7mV Typical Vos • INPUT VOLTAGE RANGE: -0.1V to +5.6V with Vs = 5.5V • SUPPLY RANGE: +2.5V to +5.5V • SHUTDOWN: RS621S/RS622S • SPECIFIED UP TO +125°C • Micro SIZE The RS62X families of products offer low voltage operation and rail-to-rail input and output, as well as excellent speed/power consumption ratio, providing an excellent bandwidth (7MHz) and slew rate of 3.7V/us. The op-amps are unity gain stable and feature an ultra-low input bias current. The devices are ideal for sensor interfaces, active filters and portable applications. The RS621S, RS622S include a shutdown mode. Under logic control, the amplifiers can be switched from normal operation to a standby current that is less than 1uA.The RS62X families of operational amplifiers are specified at the full temperature range of −40°C to +125°C under single or dual power supplies of 2.5V to 5.5V. PACKAGES: SOT23-5, SOT23-6 APPLICATIONS • SENSORS • PHOTODIODE AMPLIFICATION • ACTIVE FILTERS • TEST EQUIPMENT • DRIVING A/D CONVERTERS Device Information (1) PART NUMBER RS621 RS622 RS624 PACKAGE BODY SIZE(NOM) SOT23-5 2.90mm×1.60mm SOT23-6 2.90mm×1.60mm SOIC-8(SOP8) 4.90mm×3.90mm MSOP-8 3.00mm×3.00mm SOIC-8(SOP8) 4.90mm×3.90mm MSOP-8 3.00mm×3.00mm TSSOP-8 3.00mm×4.40mm MSOP-10 3.00mm×3.00mm TDFN2×2-8L 2.00mm×2.00mm TDFN3×3-8L 3.00mm×3.00mm SOIC-14(SOP14) 8.65mm×3.90mm TSSOP-14 5.00mm×4.40mm TDFN3×2-14L 3.00mm×2.00mm (1) For all available packages, see the orderable addendum at the end of the data sheet. REV C.1 1 / 27 www.run-ic.com RS621S, RS622S, RS62X Revision History Note: Page numbers for previous revisions may different from page numbers in the current version. VERSION Change Date C.1 2020.12 Change Item 1) Change “Package Qty” in ordering information table for production management. 2) Change the layout of the document 2 / 27 www.run-ic.com RS621S, RS622S, RS62X Pin Configuration and Functions (Top View) RS621 2 +IN 3 V+ +IN 1 V- 2 -IN 3 5 V+ + - 4 -IN 4 SOT23-5 NC 1 -IN 2 +IN 3 V- 4 + V- 5 - 1 + OUT RS621 RS621B 8 NC 7 V+ 6 OUT OUT SOT23-5 5 NC SOIC-8(SOP8),MSOP-8 Pin Description SOT23-5 SOT23-5 4 3 1 2 5 3 1 4 2 5 RS621 SOIC-8(SOP8)/ MSOP8 2 3 1,5,8 6 4 7 I/O DESCRIPTION I I O - Negative (inverting) input Positive (noninverting) input No internal connection (can be left floating) Output Negative (lowest) power supply Positive (highest) power supply RS621S RS621S OUT 1 6 V+ V- 2 5 EN +IN 3 4 -IN + - NC 1 -IN 2 +IN 3 V- 4 SOT23-6 8 EN 7 V+ + -IN +IN NC OUT VV+ PIN RS621B - NAME RS621 6 OUT 5 NC SOIC-8(SOP8) Pin Description NAME -IN +IN OUT PIN RS621S SOT23-6 SOIC-8(SOP8) 4 2 3 3 1 6 I/O DESCRIPTION I I O Inverting input Noninverting input Output Enable pin. This pin turns the regulator on or off. Low = disabled, high = normal operation (pin must be driven) No internal connection (can be left floating) Negative (lowest) power supply Positive (highest) power supply EN 5 8 I NC VV+ 2 6 1,5 4 7 - 3 / 27 www.run-ic.com RS621S, RS622S, RS62X Pin Configuration and Functions (Top View) 1 -IN A 2 +IN A 3 V- 4 + A B+ OUT A 1 OUTB -IN A 2 - 6 -IN B +IN A 3 + OUT A 5 +IN B V- 4 En A 5 8 V+ 7 SOIC-8(SOP8),MSOP-8, TSSOP-8,TDFN2×2-8L,TDFN3×3-8L A B 10 V+ 9 OUT B - 8 -IN B + RS622S RS622 7 +IN B 6 En B MSOP-10 Pin Description PIN -INA +INA -INB +INB OUTA OUTB RS622 SOIC-8(SOP8), MSOP-8, TSSOP-8,TDFN2×2-8L, TDFN3×3-8L 2 3 6 5 1 7 EnA - 5 I EnB - 6 I VV+ 4 8 4 10 - NAME RS622S I/O DESCRIPTION 2 3 8 7 1 9 I I I I O O Inverting input, channel A Noninverting input, channel A Inverting input, channel B Noninverting input, channel B Output, channel A Output, channel B Enable pin, channel A. This pin turns the regulator on or off. Low = disabled, high = normal operation (pin must be driven) Enable pin, channel B. This pin turns the regulator on or off. Low = disabled, high = normal operation (pin must be driven) Negative (lowest) power supply Positive (highest) power supply MSOP-10 4 / 27 www.run-ic.com RS621S, RS622S, RS62X Pin Configuration and Functions (Top View) RS624P OUT A 1 -IN A 2 +IN A 14 OUT D 13 -IN D 3 12 +IN D V+ 4 11 V- +IN B 5 10 +IN C 9 -IN C 8 OUT C -IN B 6 OUT B 7 A - + - + B D + - + C SOIC-14(SOP14),TSSOP-14, TDFN3×2-14L Pin Description NAME -INA +INA -INB +INB -INC +INC -IND +IND OUTA OUTB OUTC OUTD VV+ PIN SOIC-14(SOP14)/TSSOP-14 2 3 6 5 9 10 13 12 1 7 8 14 11 4 I/O DESCRIPTION I I I I I I I I O O O O - Inverting input, channel A Noninverting input, channel A Inverting input, channel B Noninverting input, channel B Inverting input, channel C Noninverting input, channel C Inverting input, channel D Noninverting input, channel D Output, channel A Output, channel B Output, channel C Output, channel D Negative (lowest) power supply Positive (highest) power supply 5 / 27 www.run-ic.com RS621S, RS622S, RS62X SPECIFICATIONS Absolute Maximum Ratings Over operating free-air temperature range (unless otherwise noted) (1) MIN Voltage Current Temperature MAX 7 (V-)-0.5 (V+) +0.5 (V-)-0.5 (V+) +0.5 -10 10 -70 70 Continuous -40 125 150 -65 150 Supply, Vs=(V+) - (V-) Signal input pin (2) Signal output pin (3) Signal input pin (2) Signal output pin (3) Output short-circuit (4) Operating range, TA Junction, TJ Storage, Tstg UNIT V mA mA °C (1) Stresses above these ratings may cause permanent damage. Exposure to absolute maximum conditions for extended periods may degrade device reliability. These are stress ratings only, and functional operation of the device at these or any other conditions beyond those specified is not implied. (2) Input terminals are diode-clamped to the power-supply rails. Input signals that can swing more than 0.5V beyond the supply rails should be currentlimited to 10mA or less. (3) Output terminals are diode-clamped to the power-supply rails. Output signals that can swing more than 0.5V beyond the supply rails should be current-limited to ±70mA or less. (4) Short-circuit to ground, one amplifier per package. ESD Ratings V(ESD) Electrostatic discharge Human-body model (HBM) Machine Model (MM) VALUE UNIT ±5000 ±400 V Recommended Operating Conditions Over operating free-air temperature range (unless otherwise noted) Supply voltage,Vs= (V+) - (V-) MIN 2.5 ±1.25 Single-supply Dual-supply NOM MAX 5.5 ±2.75 UNIT V Thermal Information:RS621 THERMAL METRIC (1) RS621 5PINS 8PINS SOT23-5 SOT23-6 SOIC-8 MSOP8 273.8 187.3 116 165 RϴJA Junction-to-ambient thermal resistance RϴJC(top) Junction-to-case(top) thermal resistance 126.8 126.5 RϴJB Junction-to-board thermal resistance 85.9 32.6 ѰJT ѰJB Junction-to-top characterization parameter Junction-to-board characterization parameter 10.9 84.9 24.1 32.1 RϴJC(bot) Junction-to-case(bottom) thermal resistance N/A N/A N/A 6 / 27 60 UNIT °C/W 53 °C/W 56 87 °C/W 12.8 98.3 4.9 85 °C/W °C/W N/A °C/W www.run-ic.com RS621S, RS622S, RS62X Thermal Information:RS622 THERMAL METRIC (1) RϴJA RϴJC(top) RϴJB ѰJT ѰJB RϴJC(bot) Junction-to-ambient thermal resistance Junction-to-case(top) thermal resistance Junction-to-board thermal resistance Junction-to-top characterization parameter Junction-to-board characterization parameter Junction-to-case(bottom) thermal resistance RS622 8PINS TSSOP MSOP-8 10 UNIT TDFN2× 2-8L TDFN3× 3-8L 169.5 80.1 66.9 °C/W 95.4 84.1 100 54.5 °C/W 87 128.6 113 45 40.4 °C/W 12.8 4.9 27.2 15.8 6.8 1.9 °C/W 98.3 85 127.2 111.6 45.2 40.4 °C/W N/A N/A N/A N/A 22.7 10.8 °C/W SOIC-8 MSOP-8 116 165 200.7 60 53 56 Thermal Information:RS624 RS624 14PINS THERMAL METRIC (1) UNIT SOIC-14 TSSOP-14 RϴJA Junction-to-ambient thermal resistance 83.8 120.8 °C/W RϴJC(top) Junction-to-case(top) thermal resistance 70.7 34.3 °C/W RϴJB ѰJT ѰJB Junction-to-board thermal resistance 59.5 62.8 °C/W Junction-to-top characterization parameter Junction-to-board characterization parameter 11.6 37.7 1 56.5 °C/W °C/W RϴJC(bot) Junction-to-case(bottom) thermal resistance N/A N/A °C/W 7 / 27 www.run-ic.com RS621S, RS622S, RS62X PACKAGE/ORDERING INFORMATION Orderable Device Package Type Pin Channel Op Temp(°C) Device Marking(1) Package Qty RS621XF SOT23-5 5 1 -40℃~125℃ 621 Tape and Reel,3000 RS621BXF SOT23-5 5 1 -40℃~125℃ 621B Tape and Reel,3000 RS621XK SOIC-8(SOP8) 8 1 -40℃~125℃ RS621 Tape and Reel,4000 RS621XM MSOP-8 8 1 -40℃~125℃ RS621 Tape and Reel,4000 RS621SXK SOIC-8(SOP8) 8 1 -40℃~125℃ RS621S Tape and Reel,4000 RS621SXH SOT23-6 6 1 -40℃~125℃ 621S Tape and Reel,3000 RS622XK SOIC-8(SOP8) 8 2 -40℃~125℃ RS622 Tape and Reel,4000 RS622XM MSOP-8 8 2 -40℃~125℃ RS622 Tape and Reel,4000 RS622XTDE8 TDFN2x2-8L 8 2 -40℃~125℃ 622 Tape and Reel,3000 RS622XTDC8 TDFN3x3-8L 8 2 -40℃~125℃ RS622 Tape and Reel,3000 RS622XQ TSSOP-8 8 2 -40℃~125℃ RS622 Tape and Reel,4000 RS622SXN MSOP-10 10 2 -40℃~125℃ RS622S Tape and Reel,4000 RS624XP SOIC-14(SOP14) 14 4 -40℃~125℃ RS624 Tape and Reel,4000 RS624XQ TSSOP-14 14 4 -40℃~125℃ RS624 Tape and Reel,4000 RS624XTDB14 TDFN3x2-14L 14 4 -40℃~125℃ RS624 Tape and Reel,3000 NOTE: (1) There may be additional marking, which relates to the lot trace code information(data code and vendor code),the logo or the environmental category on the device. 8 / 27 www.run-ic.com RS621S, RS622S, RS62X ELECTRICAL CHARACTERISTICS (At TA = +25C, Vs=5V, RL = 10kΩ connected to VS/2, and VOUT = VS/2, unless otherwise noted.) PARAMETER CONDITIONS RS621S, RS622S, RS621, RS622, RS624 TJ MIN TYP MAX UNIT 5.5 V 600 93 800 uA 0.7 3 POWER SUPPLY Vs Operating Voltage Range IQ Quiescent Current/Amplifier PSRR Power-Supply Rejection Ratio 25C Vs=2.5V to 5.5V, Vcm=(V-)+0.5V 25C 25C -40C to 125C 2.5 78 72 dB INPUT Vos IB Input Offset Voltage Input Offset Voltage Average Drift Input Bias Current Ios Input Offset Current Vos TC Vcm CMRR Common-Mode Voltage Range 25C -3 2 -40C to 125C ±1 ±1 25C 25C Vs= 5.5V 25C -0.1 Vs= 5.5V, Vcm =-0.1V to 4V 25C 74 Common-Mode Rejection Ratio Vs= 5.5V, Vcm =-0.1V to 5.6V -40C to 125C 25C mV uV/C ±10 ±10 pA 5.6 V pA 92 68 62 -40C to 125C 60 25C -40C to 125C 25C -40C to 125C 96 83 98 85 dB 83 OUTPUT AOL Open-Loop Voltage Gain RL=10KΩ, Vo= 0.05V to 4.95V RL=2KΩ RL=10KΩ 102 dB 106 25C 40 7 mV 25C 50 mA Slew Rate 25C 3.7 V/us Gain-Bandwidth Product 25C 7 MHz Phase Margin 25C 64 ° 0.5 us 0.5 us Output Swing From Rail Iout RL=2KΩ, Vo= 0.15V to 4.85V Output Short-Circuit Current FREQUENCY RESPONSE SR GBP PM ts Setting Time,0.1% Overload Recovery Time VIN·Gain≥VS NOISE en Input Voltage Noise Density f = 1KHz 25C 11 nV/√Hz f = 10KHz 25C 7.5 nV/√Hz 25C
RS621BXF 价格&库存
很抱歉,暂时无法提供与“RS621BXF”相匹配的价格&库存,您可以联系我们找货
