Page 1/6
Data sheet
P/N
311071xx
xx=number of poles
RP025xxHBWC Type 107
2023/01/10
Version: W
Illustrations
Dimensional drawing
See enlarged drawings at the end of document
Product specification
• screw type terminal block, pluggable
• centerline 5.00 mm, direction of connection 90°
• wire protector, fittable without loss of poles
• color black
• Wire entry perpendicular to plug direction
Data sheet
Page 2/6
P/N
311071xx
xx=number of poles
2023/01/10
Version: W
Technical Data
General Data
Tightening torque SEV
Tightening torque UL
0.5 Nm
min. number of poles
2
max. number of poles
24
Insulating material class
CTI 600
clearance/creepage dist.
2.3 mm
Protection category
IP00
Min. insul. strip length
6 mm
Rated current
10 A
Overvoltage category
III
III
II
Pollution degree
3
2
2
Rated voltage
100 V
320 V
320 V
Rated test voltage
2.5 kV
2.5 kV
2.5 kV
4.4 lb-in
Terminal data
rat.wiring solid AWGmax
0.08 mm² - 2.5 mm² / AWG 28 - AWG 12
rat.wiring strand.AWGmax
Approvals
V / A / AWG
approval UL - File No.
2.5 mm²
300 / 10 / 28 - 12
E121004
250 V / 2.5 kV / 10 A
Material
insulating material
PA66
flammability class
V0
contact material
CuSn
Contact surface
Sn
terminal body thread
M3
terminal body material
CuZnPb
terminal body surface
Ni
screw thread
M3
screw material
8,8
screw surface
Zn Cr(VI)-frei/free
wire protector material
CuSn
Data sheet
Page 3/6
P/N
311071xx
xx=number of poles
2023/01/10
Version: W
Technical Data
wire protector surface
Sn
Glow-Wire Flammability GWFI
850 °C acc. to IEC 60695-2-12
Glow-Wire Flammability GWIT
775 °C acc. to IEC 60695-2-13
REACH
compliant
REACH - substance (SVHC)
Lead / 7439-92-1
Climatic Data
upper limit temperature
105 °C
lower limit temperature
-40 °C
general
Tolerance
ISO 2768 -mH
Data sheet
Page 4/6
P/N
311071xx
xx=number of poles
2023/01/10
Version: W
Accessories
P/N
Designation
710084
Mounting flange right for type 07, 08
710085
Mounting flange left for type 07, 08
710121-2
Coding pin short for type 007
710122-2
Coding pin long for type 007
716846
Coding comb pastel blue
Data sheet
Page 5/6
P/N
311071xx
xx=number of poles
2023/01/10
Version: W
Counterpart
P/N
Designation
310171
PR015xxVBHC Type 017
310271
PR015xxVBVC Type 027
310391
PT055xxHBHC Type 039
310411
PT065xxVBEN Type 041
310421
PT065xxVBVN Type 042
314171
PM035xxVBHC Type 417
Data sheet
Page 6/6
P/N
311071xx
xx=number of poles
2023/01/10
Version: W
Illustrations
Dimensional drawing
L=(pole size - 1) x centerline + 5 mm [0.197]
Powered by TCPDF (www.tcpdf.org)
很抱歉,暂时无法提供与“31107106”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 10+17.0516310+2.06358
- 30+16.9719430+2.05393
- 100+16.97157100+2.05389
- 200+16.97120200+2.05384
- 500+16.97082500+2.05380
