31166105
    METZCONNECT
31166105 数据手册
Page 1/6 Data sheet P/N 311661xx xx=number of poles RP023xxHBWC Type 166 2023/01/10 Version: Y Illustrations Dimensional drawing See enlarged drawings at the end of document Product specification • screw type terminal block, pluggable • centerline 3.50 mm, direction of connection 90° • wire protector, fittable without loss of poles • color black • Wire entry perpendicular to plug direction Data sheet Page 2/6 RP023xxHBWC Type 166 P/N 311661xx xx=number of poles 2023/01/10 Version: Y Technical Data General Data Tightening torque SEV Tightening torque UL 0.15 Nm min. number of poles 2 max. number of poles 24 Insulating material class CTI 600 clearance/creepage dist. 2 mm Protection category IP00 Min. insul. strip length 5 mm Rated current 6A Overvoltage category III III II Pollution degree 3 2 2 Rated voltage 32 V 250 V 250 V Rated test voltage 1.5 kV 1.5 kV 1.5 kV 1.3 lb-in Terminal data rat.wiring solid AWGmax 0.08 mm² - 1.5 mm² / AWG 28 - AWG 16 rat.wiring strand.AWGmax 0.08 mm² - 1.5 mm² / AWG 28 - AWG 16 Approvals V / A / AWG approval UL - File No. 1 mm² 125 / 8 / 28 - 16 E121004 200 V / 2.5 kV / 6 A Material insulating material PA66 flammability class V0 contact material CuNiZn terminal body thread M2 terminal body material CuZnPb terminal body surface Ni screw thread M2 screw material 8,8 screw surface Zn Cr(VI)-frei/free wire protector material CuNiZn Glow-Wire Flammability GWFI 850 °C acc. to IEC 60695-2-12 Data sheet Page 3/6 RP023xxHBWC Type 166 P/N 311661xx xx=number of poles 2023/01/10 Version: Y Technical Data Glow-Wire Flammability GWIT 775 °C acc. to IEC 60695-2-13 REACH compliant REACH - substance (SVHC) Lead / 7439-92-1 Climatic Data upper limit temperature 105 °C lower limit temperature -40 °C general Tolerance ISO 2768 -mH Data sheet Page 4/6 RP023xxHBWC Type 166 P/N 311661xx xx=number of poles 2023/01/10 Version: Y Accessories P/N Designation 720158-01-0 Befestigungsflansch kurz LP1mmfür Typ 165, 166 F_Befest_165_brg_kurz 1mm 720158-01-2 720158 720158-02-2 Mounting flange for type 166 720159-01-0 Kodierstift kurz für Typ 165, 166 F_Kodier_Typ165_brg_kurz 720159-01-2 Coding pin short for type 166 720159-02-0 Kodierstift lang für Typ 165, 166 F_Kodier_Typ165_brg_lang 720159-02-2 Coding pin long for type 166 Data sheet Page 5/6 RP023xxHBWC Type 166 P/N 311661xx xx=number of poles 2023/01/10 Version: Y Counterpart P/N Designation 312241 PR033xxVBHC Type 224 312251 PT153xxHBEC Typ 225 312261 PT153xxVBEC Type 226 313331 PT023xxHBHC 314241 PM013xxVBHC Type 424 Data sheet RP023xxHBWC Type 166 Page 6/6 P/N 311661xx xx=number of poles 2023/01/10 Version: Y Illustrations Dimensional drawing L=(pole size - 1) x centerline + 3.5 mm [0.138] Powered by TCPDF (www.tcpdf.org)
31166105 价格&库存
很抱歉,暂时无法提供与“31166105”相匹配的价格&库存,您可以联系我们找货
