SSD-250-102
SSD-250-102
    BIVAR
SSD-250-102 数据手册
REV. DESCRIPTION H J SW A DATE APPROVED 11/01/13 03/08/16 T. Y. J. C. 0.187 [4.7mm] 0.170 [4.3mm] 0.075 [1.9mm] 0.125 [3.2mm] 0.31 [7.9mm] B A ±.032 (.8) PART NO. 0.50 [12.7mm] 0.225+0.003 -0.001 Ø.180+.003 -.001 Engineering Release. Updated Material Note. 0.176+0.003 -0.001 B ±0.005 Recommended Mounting Holes SSD-250 SSD-300 SSD-350 SSD-400 SSD-450 3X SSD-450 SSD-500 SSD-550 SSD-600 SSD-650 SSD-700 SSD-750 SSD-800 SW=0.075 (1.9) B ±.016 (.4) 2.5 (63.5) 3.0 (76.2) 3.5 (88.9) 4.0 (101.6) 4.5 (114.3) 4.5 (114.3) 5.0 (127.0) 5.5 (139.7) 6.0 (152.4) 6.5 (165.1) 7.0 (177.8) 7.5 (190.5) 8.0 (203.2) SSD-250-102 SSD-300-102 SSD-350-102 SSD-400-102 SSD-450-102 SSD-500-102 SSD-550-102 SSD-600-102 SSD-650-102 SSD-700-102 SSD-750-102 SSD-800-102 1.5 (38.1) 2.0 (50.8) 2.5 (63.5) 3.0 (76.2) 3.0 (76.2) 3.5 (88.9) 4.0 (101.6) 4.5 (114.3) 5.0 (127.0) 5.5 (139.7) 6.0 (152.4) 6.5 (165.1) 7.0 (177.8) SW=0.102 (2.6) STANDARD TOLERANCE ® ( UNLESS OTHERWISE SPECIFIED ) DECIMALS 3. ALL DIMENSIONS IN INCHES, UNLESS OTHERWISE SPECIFIED. 2. MATERIAL: NYLON 6/6, 94V-2, NATURAL. 1. GENERAL SPECIFICATIONS: BIVAR MOLDED COMPONENT SPECIFICATION BV00-E101. .X .XX .XXX ± .1 ± .01 ± .005 DESIGNED: David Green CHECKED: M. Chen ANGULAR X° ± 1° 4 THOMAS, IRVINE, CA. 92618 TEL: (949) 951-8808 FAX: (949) 951-3974 TITLE: INTERCHANGEABLE SNAP-IN CARD GUIDE DATE: 11/26/02 DATE: 11/26/02 PART NO: REVISION: SSD-XXX-XXX CAGE CODE : 32559 J SHEET # 1 OF 1 CAD GENERATED DOCUMENT, DO NOT MEASURE DRAWING.
SSD-250-102 价格&库存
很抱歉,暂时无法提供与“SSD-250-102”相匹配的价格&库存,您可以联系我们找货
SSD-250-102
    • 1+5.24436
