INTEGRATED CIRCUITS
74LV165
8-bit parallel-in/serial-out shift register
Product specification
Supersedes data of 1997 May 15
IC24 Data Handbook
1998 May 07
Philips Semiconductors
FEATURES
74LV165
DESCRIPTION
• Wide operating voltage: 1.0 to 5.5 V
• Optimized for low voltage applications: 1.0 to 3.6 V
• Accepts TTL input levels between VCC = 2.7 V and VCC = 3.6 V
• Typical VOLP (output ground bounce) < 0.8 V at VCC = 3.3 V,
The 74LV165 is a low-voltage Si-gate CMOS device and is pin and
function compatible with 74HC/HCT165.
The 74LV165 is an 8-bit parallel-load or serial-in shift register with
complementary serial outputs (Q7 and Q7) available from the last
stage. When the parallel load (PL) input is LOW, parallel data from the
D0 to D7 inputs are loaded into the register asynchronously. When PL
is HIGH, data enters the register serially at the DS input and shifts one
place to the right (Q0→Q1→Q2, etc.) with each positive-going clock
transition. This feature allows parallel-to-serial converter expansion by
tying the Q7 output to the DS input of the succeeding stage.
Tamb = 25°C
• Typical VOHV (output VOH undershoot) > 2 V at VCC = 3.3 V,
Tamb = 25°C
• Asynchronous 8-bit parallel load
• Synchronous serial input
• Output capability: standard
• ICC category: MSI
The clock input is a gated-OR structure which allows one input to be
used as an active LOW clock enable (CE) input. The pin assignment
for the CP and CE inputs is arbitrary and can be reversed for layout
convenience. The LOW-to-HIGH transition of input CE should only
take place while CP HIGH for predictable operation. Either the CP or
the CE should be HIGH before the LOW-to-HIGH transition of PL to
prevent shifting the data when PL is activated.
QUICK REFERENCE DATA
GND = 0 V; Tamb = 25°C; tr = tf ≤ 2.5 ns
SYMBOL
PARAMETER
tPHL/tPLH
fmax
Maximum clock frequency
CI
Input capacitance
CPD
CONDITIONS
TYPICAL
UNIT
18
18
14
ns
78
MHz
3.5
pF
35
pF
CL = 15 pF;
VCC = 3.3 V
Propagation delay
CE, CP to Q7, Q7
PL to Q7, Q7
D7 to Q7, Q7
Power dissipation capacitance per gate
VCC = 3.3 V
VI = GND to VCC1
NOTES:
1. CPD is used to determine the dynamic power dissipation (PD in µW)
PD = CPD × VCC2 × fi (CL × VCC2 × fo) where:
fi = input frequency in MHz; CL = output load capacitance in pF;
fo = output frequency in MHz; VCC = supply voltage in V;
(CL × VCC2 × fo) = sum of the outputs.
ORDERING INFORMATION
PACKAGES
TEMPERATURE RANGE
OUTSIDE NORTH AMERICA
NORTH AMERICA
16-Pin Plastic DIL
–40°C to +125°C
74LV165 N
74LV165 N
SOT38-4
16-Pin Plastic SO
–40°C to +125°C
74LV165 D
74LV165 D
SOT109-1
16-Pin Plastic SSOP Type II
–40°C to +125°C
74LV165 DB
74LV165 DB
SOT338-1
16-Pin Plastic TSSOP Type I
–40°C to +125°C
74LV165 PW
74LV165PW DH
SOT403-1
PIN CONFIGURATION
PIN DESCRIPTION
PIN NUMBER
PL
1
16
V
CC
CP
2
15
CE
D4
3
14
D3
D5
4
13
D2
D6
5
12
D1
D7
6
11
D0
Q7
7
10
DS
Q7
GND
8
1
9
SV00585
1998 May 07
PKG. DWG. #
2
SYMBOL
PL
FUNCTION
Asynchronous parallel load
input (active LOW)
2
CP
Clock input (LOW to
HIGH, edge-triggered)
7
Q7
Complementary output from
the last stage
8
GND
Ground (0 V)
9
Q7
Serial output from last stage
10
DS
Serial data input
11, 12, 13, 14, 3, 4, 5, 6
D0 to D7
Parallel data inputs
15
CE
Clock enable input
(active LOW)
16
VCC
Positive supply voltage
853–1915 19349
74LV165
LOGIC SYMBOL
FUNCTIONAL DIAGRAM
10
DS
11
D0
12
D1
13
D2
14
D3
3
D4
4
D5
5
D6
Q7
9
D7
Q7
7
6
1
PL
1
PL
10
DS
2
CP
15
CE
11
12
13
14
3
4
5
6
D0
D1
D2
D3
D4
D5
D6
D7
8–BIT SHIFT REGISTER
PARALLEL– IN / SERIAL – OUT
CP CE
2
Q7
9
Q7
7
15
SV00586
SV00588
LOGIC SYMBOL (IEEE/IEC)
1
15
2
10
11
12
13
SRG8
C2 [LOAD]
G1 [SHIFT]
>1
1
C3/
3D
2D
2D
14
3
4
5
9
6
7
SV00587
LOGIC DIAGRAM
D0
D1
D2
D3
D4
D5
D6
D7
DS
CP
D
CE
PL
SD
CP
FF0
RD
Q
D
SD
CP
FF1
RD
Q
D
SD
CP
FF2
RD
Q
D
SD
CP
FF3
RD
Q
D
SD
CP
FF4
RD
Q
D
SD
CP
FF5
RD
Q
D
SD
CP
FF6
RD
Q
D
SD
Q
CP
FF7
RD
Q
Q7
Q7
SV00589
1998 May 07
3
74LV165
FUNCTION TABLE
INPUTS
OPERATING MODES
PL
CE
CP
DS
L
X
X
X
L
L
L
X
X
X
H
H
H
L
l
X
L
H
L
h
X
H
H
H
X
X
X
q0
Parallel load
Serial Shift
Hold “do nothing”
Qn REGISTERS
D0–D7
Q0
OUTPUTS
Q1–Q6
Q7
Q7
L–L
L
H
H–H
H
L
q0–q5
q6
q6
q0–q5
q6
q6
q1–q6
q7
q7
NOTES:
H = HIGH voltage level
h = HIGH voltage level one set-up time prior to the LOW-to-HIGH clock transition
L = LOW voltage level
I = LOW voltage level level one set-up time prior to the LOW-to-HIGH clock transition
q = lower case letters indicate the state of the referenced output one set-up time prior to the LOW-to-HIGH clock transition
X = don’t care
↑ = LOW-to-HIGH clock transition
RECOMMENDED OPERATING CONDITIONS
SYMBOL
VCC
PARAMETER
CONDITIONS
MIN
TYP
MAX
UNIT
See Note 1
1.0
3.3
5.5
V
DC supply voltage
VI
Input voltage
VCC
V
VO
Output voltage
VCC
V
+85
+125
°C
500
200
100
50
ns/V
Tamb
Operating ambient temperature range in free air
tr, tf
Input rise and fall times
See DC and AC
characteristics
–40
–40
VCC = 1.0V to 2.0V
VCC = 2.0V to 2.7V
VCC = 2.7V to 3.6V
VCC = 3.6V to 5.5V
NOTE:
1. The LV is guaranteed to function down to VCC = 1.0V (input levels GND or VCC); DC characteristics are guaranteed from VCC = 1.2V to VCC = 5.5V.
ABSOLUTE MAXIMUM RATINGS1, 2
In accordance with the Absolute Maximum Rating System (IEC 134).
Voltages are referenced to GND (ground = 0 V).
SYMBOL
PARAMETER
VCC
DC supply voltage
CONDITIONS
RATING
UNIT
–0.5 to +7.0
V
IIK
DC input diode current
VI < –0.5 or VI > VCC + 0.5V
mA
IOK
DC output diode current
VO < –0.5 or VO > VCC + 0.5V
50
mA
IO
DC output source or sink current
– standard outputs
–0.5V < VO < VCC + 0.5V
25
IGND,
ICC
Tstg
PTOT
DC VCC or GND current for types with
– standard outputs
50
Storage temperature range
Power dissipation per package
– plastic DIL
– plastic mini-pack (SO)
– plastic shrink mini-pack (SSOP and TSSOP)
–65 to +150
for temperature range: –40 to +125°C
above +70°C derate linearly with 12 mW/K
above +70°C derate linearly with 8 mW/K
above +60°C derate linearly with 5.5 mW/K
750
500
400
mA
mA
°C
mW
NOTES:
1. Stresses beyond those listed may cause permanent damage to the device. These are stress ratings only and functional operation of the
device at these or any other conditions beyond those indicated under “recommended operating conditions” is not implied. Exposure to
absolute-maximum-rated conditions for extended periods may affect device reliability.
2. The input and output voltage ratings may be exceeded if the input and output current ratings are observed.
1998 May 07
4
74LV165
DC ELECTRICAL CHARACTERISTICS
Over recommended operating conditions. Voltages are referenced to GND (ground = 0 V).
LIMITS
SYMBOL
PARAMETER
-40°C to +85°C
TEST CONDITIONS
MIN
VIH
VIL
HIGH level Input
voltage
LOW level Input
voltage
TYP1
VOH
O
VOL
VOL
O
HIGH level output
voltage;
g
STANDARD
outputs
l
l output
t t
LOW level
voltage
out uts
voltage; all outputs
LOW level output
voltage;
g
STANDARD
outputs
MIN
0.9
0.9
VCC = 2.0 V
1.4
1.4
VCC = 2.7 to 3.6 V
2.0
2.0
VCC = 4.5 to 5.5 V
0.7VCC
UNIT
MAX
V
0.7VCC
VCC = 1.2 V
0.3
0.3
VCC = 2.0 V
0.6
0.6
VCC = 2.7 to 3.6 V
0.8
0.8
0.3VCC
0.3VCC
VCC = 1.2 V; VI = VIH or VIL; –IO = 100µA
VOH
MAX
VCC = 1.2 V
VCC = 4.5 to 5.5
HIGH level
l
l output
t t
voltage
out uts
-40°C to +125°C
V
1.2
VCC = 2.0 V; VI = VIH or VIL; –IO = 100µA
1.8
2.0
1.8
VCC = 2.7 V; VI = VIH or VIL; –IO = 100µA
2.5
2.7
2.5
VCC = 3.0 V; VI = VIH or VIL; –IO = 100µA
2.8
3.0
2.8
VCC = 4.5 V; VI = VIH or VIL; –IO = 100µA
4.3
4.5
4.3
VCC = 3.0 V; VI = VIH or VIL; –IO = 6mA
2.40
2.82
2.20
VCC = 4.5 V; VI = VIH or VIL; –IO = 12mA
3.60
4.20
3.50
V
V
VCC = 1.2 V; VI = VIH or VIL; IO = 100µA
VCC = 2.0 V; VI = VIH or VIL; IO = 100µA
0.2
VCC = 2.7 V; VI = VIH or VIL; IO = 100µA
0.2
VCC = 3.0 V; VI = VIH or VIL; IO = 100µA
0.2
VCC = 4.5 V; VI = VIH or VIL; IO = 100µA
0.2
VCC = 3.0 V; VI = VIH or VIL; IO = 6mA
0.25
0.40
0.50
VCC = 4.5 V; VI = VIH or VIL; IO = 12mA
0.35
0.55
0.65
V
V
Input leakage
current
VCC = 5.5 V; VI = VCC or GND
1.0
1.0
µA
ICC
Quiescent supply
current; MSI
VCC = 5.5 V; VI = VCC or GND; IO = 0
20.0
160
µA
∆ICC
Additional
quiescent supply
current per input
VCC = 2.7 V to 3.6 V; VI = VCC – 0.6 V
500
850
µA
II
NOTE:
1. All typical values are measured at Tamb = 25°C.
1998 May 07
5
74LV165
AC CHARACTERISTICS
GND = 0V; tr = tf ≤ 2.5ns; CL = 50pF; RL = 1KΩ
SYMBOL
tPLH/tPHL
tPLH/tPHL
tPLH/tPHL
PARAMETER
Propagation delay
CE, CP to Q7, Q7
Propagation delay
PL to Q7, Q7
Propagation delay
D7 to Q7, Q7
WAVEFORM
Figures 1, 2
Figures 1, 2
Figures 1, 2
tw
trem
tsu
tsu
1998 May 07
Clock Pulse width
HIGH or LOW
Parallel load pulse
width LOW
Removal time
PL to CP, CE
Set-up time
DS to CP, CE
Set-up time
CE to CP;
CP CP to CE
–40 to +85 °C
MIN
TYP1
1.2
115
2.0
38
61
76
Figures 1, 2
MIN
27
43
54
222
36
45
4.5 to 5.5
15
24
30
1.2
110
2.0
35
56
70
2.7
24
39
49
3.0 to 3.6
202
33
41
4.5 to 5.5
14
22
27
1.2
90
2.0
28
45
56
2.7
40
172
27
33
ns
ns
4.5 to 5.5
11
18
22
2.0
34
10
41
2.7
25
8
30
3.0 to 3.6
24
4.5 to 5.5
15
5
18
2.0
34
10
41
2.7
25
8
30
3.0 to 3.6
24
4.5 to 5.5
15
5
18
1.2
40
2.0
24
15
30
2.7
18
11
23
3.0 to 3.6
17
102
21
4.5 to 5.5
12
7
15
1.2
–8
2.0
22
–2
26
2.7
16
–1
19
3.0 to 3.6
13
–12
15
4.5 to 5.5
9
1.2
22
7
26
2.7
16
5
19
3.0 to 3.6
13
42
15
4.5 to 5.5
9
3
10
6
UNIT
MAX
2.7
Figures 1
1, 2
Figures 1, 2
MAX
3.0 to 3.6
Figures 1
1, 2
Figures 1, 2
–40 to +125 °C
VCC(V)
3.0 to 3.6
tw
LIMITS
CONDITION
ns
ns
ns
ns
ns
ns
74LV165
AC CHARACTERISTICS (Continued)
SYMBOL
PARAMETER
Set-up time
Dn to PL
tsu
th
th
TYP1
MAX
MIN
MAX
1.2
25
2.0
22
8
26
2.7
16
6
19
3.0 to 3.6
13
52
15
4.5 to 5.5
9
4
10
1.2
22
7
26
2.7
16
5
19
3.0 to 3.6
13
4
15
4.5 to 5.5
9
3
10
1.2
–30
2.0
5
–8
5
2.7
5
–6
5
3.0 to 3.6
5
–52
5
4.5 to 5.5
5
–4
5
2.0
14
40
12
2.7
19
60
16
3.0 to 3.6
24
652
75
30
Figures 1, 2
Maximum clock
pulse frequency
fmax
MIN
Figures 1, 2
Hold time
CE to CP,
CP to
t CE
Figures 1
1, 2
–40 to +125 °C
VCC(V)
Figures 1, 2
Hold time
Ds to CP, CE
Dn to PL
–40 to +85 °C
CONDITION
WAVEFORM
4.5 to 5.5
NOTES:
1. Unless otherwise stated, all typical values are measured at Tamb = 25°C
2. Typical values are measured at VCC = 3.3 V.
UNIT
ns
ns
ns
MHz
AC WAVEFORMS
VM = 1.5 V at VCC ≥ 2.7 V.
VM = 0.5 × VCC at VCC < 2.7 V;
VOL and VOH are the typical output voltage drop that occur with the
output load.
VI
1/fmax
PL INPUT
VI
CP INPUT
VM
GND
VM
tW
trem
GND
tW
VI
tPLH
tPHL
VM
CE, CP INPUT
VOH
Q7 or Q7
OUTPUT
GND
VM
tPHL
VOL
The changing to output assumes internal Q6 opposite state from Q7.
VOH
Q7 or Q7 OUTPUT
SV00590
VM
VOL
Figure 1. Clock (CP) to output (Q7 or Q7) propagation delays,
the clock pulse width and the maximum clock frequency.
SV00591
Note to Figures 1 and 2
Figure 2. Parallel load (PL) pulse width, the parallel load to
output (Q7 or Q7) propagation delays, the parallel load to clock
(CP) and clock enable (CE) removal time.
1998 May 07
7
74LV165
AC WAVEFORMS
output load.
VI
Dn INPUT
VM
GND
VI
tsu
D7 INPUT
tsu
tH
VM
tH
VI
GND
PL INPUT
VM
GND
tPLH
tPHL
SV00593
VOH
Q7 OUTPUT
Figure 5. Set-up and hold times from the data inputs (Dn)
to the parallel load input (PL).
VM
VOL
TEST CIRCUIT
tPHL
tPLH
Vcc
VOH
Q7 OUTPUT
VM
VO
Vl
VOL
PULSE
GENERATOR
SV00592
D.U.T.
Figure 3. Data input (Dn) to output (Q7 or Q7) propagation
delays when PL is LOW.
DS INPUT
VM
RL = Load resistor
CL = Load capacitance includes jig and probe capacitiance
tsu (H)
RT = Termination resistance should be equal to ZOUT of pulse generators.
th
th
TEST
stable
VM
tPLH/tPHL
GND
tsu
th
tW
VI
CP, CE
INPUT
GND
VCC
VI
< 2.7V
VCC
2.7–3.6V
2.7V
≥ 4.5 V
VCC
SV00902
VM
Figure 6. Load circuitry for switching times.
CE may change only from HIGH-to-LOW while CP is LOW. The shaded
areas indicate when the input is permitted to change for predictable output
performance.
SV00595
Figure 4. Set-up and hold times from the serial data input (DS) to
the clock (CP) and the clock enable (CE) inputs, from the clock
enable input (CE) to the clock input (CP) and from the clock input
(CP) to the clock enable input (CE).
Note to Figure 4
shaded areas indicate when the input is permitted to change for
predictable output performance.
1998 May 07
RL= 1k
DEFINITIONS
tsu (L)
VI
CL
Test Circuit for Outputs
see note
VI
CP, CE
INPUT
GND
50pF
RT
8
74LV165
DIP16: plastic dual in-line package; 16 leads (300 mil)
1998 May 07
9
SOT38-4
74LV165
SO16: plastic small outline package; 16 leads; body width 3.9 mm
1998 May 07
10
SOT109-1
74LV165
SSOP16: plastic shrink small outline package; 16 leads; body width 5.3 mm
1998 May 07
11
SOT338-1
74LV165
TSSOP16: plastic thin shrink small outline package; 16 leads; body width 4.4 mm
1998 May 07
12
SOT403-1
74LV165
NOTES
1998 May 07
13
74LV165
DEFINITIONS
Data Sheet Identification
Product Status
Definition
Objective Specification
Formative or in Design
This data sheet contains the design target or goal specifications for product development. Specifications
may change in any manner without notice.
Preliminary Specification
Preproduction Product
This data sheet contains preliminary data, and supplementary data will be published at a later date. Philips
Semiconductors reserves the right to make changes at any time without notice in order to improve design
and supply the best possible product.
Product Specification
Full Production
This data sheet contains Final Specifications. Philips Semiconductors reserves the right to make changes
at any time without notice, in order to improve design and supply the best possible product.
Philips Semiconductors and Philips Electronics North America Corporation reserve the right to make changes, without notice, in the products,
including circuits, standard cells, and/or software, described or contained herein in order to improve design and/or performance. Philips
Semiconductors assumes no responsibility or liability for the use of any of these products, conveys no license or title under any patent, copyright,
or mask work right to these products, and makes no representations or warranties that these products are free from patent, copyright, or mask
work right infringement, unless otherwise specified. Applications that are described herein for any of these products are for illustrative purposes
only. Philips Semiconductors makes no representation or warranty that such applications will be suitable for the specified use without further testing
or modification.
LIFE SUPPORT APPLICATIONS
Philips Semiconductors and Philips Electronics North America Corporation Products are not designed for use in life support appliances, devices,
or systems where malfunction of a Philips Semiconductors and Philips Electronics North America Corporation Product can reasonably be expected
to result in a personal injury. Philips Semiconductors and Philips Electronics North America Corporation customers using or selling Philips
Semiconductors and Philips Electronics North America Corporation Products for use in such applications do so at their own risk and agree to fully
indemnify Philips Semiconductors and Philips Electronics North America Corporation for any damages resulting from such improper use or sale.
Copyright Philips Electronics North America Corporation 1998
All rights reserved. Printed in U.S.A.
811 East Arques Avenue
P.O. Box 3409
Sunnyvale, California 94088–3409
Telephone 800-234-7381
print code
Document order number:
1998 May 07
14
Date of release: 05-96
9397-750-04432
