Light Weight Micro SMT Coaxial Connector, 1.9mm to 2.4mm Mated Height
U.FL Series
Plug U.FL(A) : Up to 18GHz
Plug U.FL : Up to 8GHz
(2.5Max)
●Space Factor of Mated Connector
U.FL-LP-040HF
4
1.5
2.4
Ø0.81
U.FL-LP-066HF
U.FL-LP-068HF
4
1
2.4
Ø1.32
Ø1.13
3.4
U.FL-LP(V)-040HF
Ø0.81
1
The maximum height from the board surface when
the plug and Receptacle are mated is 2.0 to 2.0mm
Max. depending on the plug for a low profile.
(Refer to diagram on right)
(2Max)
1. Mated Height (1.9mm to 2.4mm NOM)
U.FL-R-SMT-1
1.9
■Features
2. Receptacle
4. Plug compatible with ultra-fine coaxial
(fluorinated resin insulated) cable
(2.4Max)
Ø0.95
1.3
Receptacle can be used with both U.FL(A) and U.FL.
U.FL-LP-062HF
4
2.3
3. Frequency
U.FL-R-SMT-1
U.FL-R-SMT-1
(2.4Max)
Small and light weight with a mass of 15.7mg and
occupied mounting space of 7.7mm2.
Compatible with board mounting. (Embossed
packaging)
U.FL-LP-088HF
5
Ø1.37, Ø1.32, Ø1.13, Ø0.95, Ø0.81
0.9
2.3
U.FL(A)-LP(P)-068
Ø1.13
1
Tactile click sensation confirms fully mated
condition, assuring complete electrical and
mechanical connection.
5.9
7. Environmental Compatibility
U.FL-R-SMT-K(800)
U.FL-R-SMT-1
(2.2Max)
◆Halogen Free
Chlorine and bromine above the standard values
are not used for receptacle and plug harnesses.
*As defined by IEC61249-2-21
Br-900 ppm maximum, Cl-900 ppm maximum,
Cl+Br combined-1,500 ppm maximum
◆ROHS2 Compatible
5.9
U.FL(A)-LP(P)-088
Ø1.37
■Applications
Wireless LAN Devices (Wi-Fi 6), Bluetooth devices,
Car navigation, drone, PDA, GPS, wireless
transmission devices, electronic measuring devices,
etc.
In cases where the application will demand a high level of reliability, such as automotive,
please contact a company representative for further information.
U.FL-R-SMT-K(800)
U.FL-R-SMT-1
0.65
6. Tactile Mating
U.FL-R-SMT-1
(2.2Max)
Plug insertion/extraction tools, adapter for inspection
and internal wiring, and SMA, MMCX, and TNC
connectors for U.FL back end connection are
available.
Ø1.37
2.1
5. Various Accessories
2.1
Dec.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved.
(2.5Max)
U.FL-R-SMT-1
2021.8⑧
1
U.FL Series●Light Weight Micro SMT Coaxial Connector, 1.9mm to 2.4mm Mated Height
■Product Specifications
Nominal characteristic impedance
Frequency range
Ratings
Item
1. Contact resistance
2. Insulation resistance
3. Withstanding voltage
4. V.S.W.R.*
5. Female Contact
Retention Force
6. Durability
(mating / un-mating,
with corresponding plug)
7. Vibration
50ø
DC to 8GHz
Operating temperature range -40˚C to +105˚C Storage temperature range
Operating humidity
90%RH max.
Storage humidity
Specification
Center : 20mø max. (50mø max.)
Outer : 10mø max. (20mø max.)
(U.FL(A))
500Mømin.
No flashover or insulation breakdown.
Cable Type
U.FL-LP-040HF
Ø0.81
U.FL-LP(V)-040HF Ø0.81
U.FL-LP-068HF
Ø1.13
U.FL-LP-066HF
Ø1.32
Ø0.95
U.FL-LP-062HF
U.FL-LP-088HF
Ø1.37
U.FL(A)-LP(P)-068
Ø1.13
U.FL(A)-LP(P)-088
Ø1.37
10. Temperature cycle
11. Salt spray
Conditions
10mA max.
100V DC
200V AC / 1 minute
DC∼3GHz
3∼6GHz
6∼8GHz
1.3 Max
1.35 Max
1.4 Max
1.3 Max
1.3 Max
1.4 Max
1.6 Max
1.3 Max
1.5 Max
1.7 Max
1.3 Max
1.4 Max
1.3 Max
1.4 Max
1.6 Max
6-9GHz : 1.5 Max
9-12GHz : 1.6 Max
1.3 Max
1.4 Max
12-15GHz : 1.7 Max
15-18GHz : 2.0 Max
0.15N Min./0.1N Min. (062 Plug, U.FL(A))
Measured with Ø0.475 pin gauge
Contact resistance
Initial Value+5mø
30 cycles
No electrical discontinuity of 1µs min.
No damage, cracks or parts dislocation.
Frequency : 10 to 100Hz, single amplitude of 1.5mm,
acceleration of 59m/s2, for 5 cycles in the direction of each
of the 3 axis.
Acceleration of 735m/s2, 11ms duration, sine half-wave
waveform, 3 cycles in each of 3 axes.
8. Shock
9. Humidity
(Steady state)
-30˚C to +70˚C
90%RH max.
Insulation Resistance
10Mø min. (High Temperature)
500Mø min. (When Dry)
Contact resistance : 25mø max. (Center)
15mø max. (Outer)
V.S.W.R.
Satisfies initial value
96 hours at temperature of 40ç and humidity of 95%.
Temperature : -40˚C/+5 to +35˚C/+105˚C/+5 to +35˚C
Time : 30min. / 3min. / 30min. / 3min.
5 cycles
5% salt water solution, 48 hours
*V.S.W.R. Measurement System
The above V.S.W.R. standard values were measured using the measurement connection shown below.
Note 1 : Cable type connectors were measured with SMA conversion
adapters attached to both ends of the harness product of a
suitable 100cm cable.
Note 2 : Board type connectors were mounted to a 50ø glass epoxy
board and measurements were conducted with SMA
conversion adapters attached.
■Material / Finish
●Plug-right angle
Part
Shell
Insulator
Female center contact
Material
Phosphor bronze
PBT, Color : Gray
LCP, Color : Milky-white
LCP (Black)
Phosphor bronze
Finish/Remarks
Silver plated / Nickel plated (Contact gold plated) (U.FL(A))
UL94HB (LP(V)-040HF)
UL94V-0 (040HF,066HF, 068HF, 062HF, 088HF)
UL94V-0 (U.FL(A))
Gold plated
Material
Phosphor bronze
LCP (Black)
Brass
Finish/Remarks
Silver plated (U.FL-R-SMT-1) / Gold Plated (U.FL-R-SMT-K)
UL94V-0 (U.FL-R-SMT-1)
UL94V-0 (U.FL-R-SMT-K)
Gold plated
●Receptacle
Part
Shell
Insulator
Male center contact
2
■Receptacle
GND
No conductive traces in this area
3.9±0.05
1±0.05
2.2±0.05
GND
GND
SIG
1±0.05
(3.1)
2.6
1.8
1.05±0.05
3
2.6
0.6
2.1±0.05
2±0.05
1.2Max(Note)
1.25
4±0.05
1.9±0.05
1.1±0.05
SIG
Ø2
0.35
BRecommended
Metal Mask
Dimensions
0.85±0.05
GND
BRecommended
PCB Mounting
Pattern
0.8±0.03
(Note 1) The sales unit of the (01) specification receptacle is one pack (100 units per
pack). Please order based on the number of packs.
(Note 2) The sales unit of the (60) specification receptacle is 1 reel (4,000 pcs per
reel) so please order based on the number of reels.
(Note 3) The sales unit of the (80) specification receptacle is 1 reel (10,000 pcs per
reel), so please order based on number of reels.
(Note 4) Tolerance value of mold resin applied to center contact.
(3.1)
2.6
1.8
GND
Part No.
HRS No.
Packaging
U.FL-R-SMT-K(800) 480-0761-0 00 10,000 pcs per reel
Mass
15.7/pc
.5
Center contact
0.85±0.05
0.8±0.03
(Note 5) The sales unit of the receptacle is 1 reel (10,000 pcs per reel), so please
BReel Dimensions
Material: PS(Black) U.FL-R-SMT-1
PS(White) U.FL-R-SMT-K
13.5
Ø330
12
5.5
1.75
Ø1
4
3.9±0.05
2.1±0.05
Mask Thickness : 0.1mm/0.12mm
Embossed Carrier Tape Dimensions(IEC 60286-3 compliant)
2
No conductive
traces in this area
GND
SIG
1±0.05
U.FL-R-SMT-K
Shell : Gold plated
BRecommended
Metal Mask
Dimensions
2.2±0.05
1.2Max(注4)
0.35
1.25
Ø2
2±0.05
SIG
3
2.6
0.6
4±0.05
1.9±0.05
GND
1±0.05
GND
1±0.05
GND
BRecommended
PCB Mounting
Pattern
0.85±0.05
GND
2±0.05
Part No.
HRS No.
Packaging
Weight / EA
U.FL-R-SMT-1(01) 331-0472-2 01 100 pcs/pack
15.7/mg
U.FL-R-SMT-1(60) 331-0472-2 60 4,000 pcs/reel
U.FL-R-SMT-1(80) 331-0472-2 80 10,000 pcs/reel
2.2±0.05
Shell : Silver plated
8
4
.5
2
Ø1
1.75
U.FL-R-SMT-1(60) : 8mm pitch
A
Center contact
5.5
A(SCALE FREE)
2
Ø13
12
U.FL-R-SMT-1
4
Unreeling direction
Ø2
1
U.FL-R-SMT-1(80) / U.FL-R-SMT-K(800) : 4mm pitch
3
■Plug (Center Solder Type)
◆U.FL Plug
U.FL-LP-088HF
4
1.8
1.5
5
1.85
3.4
4
1.93
1.93
4
Mated Height
U.FL-LP-062HF
3
3
3
Part No.
Size
U.FL-LP(V)-040HF
2.8
U.FL-LP-066HF
U.FL-LP-068HF
U.FL-LP-040HF
2.8
・The center contact is gold plated and the outer contact
is silver plated.
2.5mm Max.
2.5mm Max.
2.0mm Max.
2.4mm Max.
2.4mm Max.
(2.4mm Nom.)
(2.4mm Nom.)
(1.9mm Nom.)
(2.3mm Nom.)
(2.3mm Nom.)
Dia. 0.81mm
Dia. 0.95mm
Dia. 1.37mm
35
45.5
72
Applicable
cable
Dia. 0.81mm
Weight (mg)
54
Dia. 1.13mm and
Dia. 1.32mm
59
●Cable Guide
Description
Dia.0.81mm
Coaxial Cable
Dia.1.13mm
Coaxial Cable
Dia.1.32mm
Coaxial Cable
Dia.0.95mm
Coaxial Cable
Dia.1.37mm
Coaxial Cable
Dia.1.37mm
Coaxial Cable
(Low Loss)
Cable Specification
Cable
Type
04
068
066
062
088
088
Inner
Conductor*
Dielectric
Diameter
Outer
Conductor*
7/0.05 SA
Dia.0.4mm
Single
(AWG#36)
FEP
Shield TA
7/0.08 SA
Dia.0.68mm
Single
(AWG#32)
FEP
Shield TA
7/0.08 SA
Dia.0.66mm
Double
(AWG#32)
FEP
Shield TA
7/0.071 SA
Dia.0.62mm
Tape, single
(AWG#33)
FEP
Shield TA
7/0.102 SA
Dia.0.88mm
Single
(AWG#30)
FEP
Shield TA
7/0.102 SA
Dia.0.88mm
Tape, Single
(AWG#30)
FEP/PTFE
Shield TA
Jacket
FEP
(Attenuation is a reference value.)
* SA : Silver plated annealed copper wire, TA : Tin plated annealed copper wire
[Plugs can be ordered only as terminated cable assemblies.]
4
Flame Retardant Nominal attenuation (dB/m)
Grade
At 3GHz At 6GHz At 8GHz
5.4
8.0
10.2
3.73
5.44
6.5
3.8
5.6
7.1
3.1
4.4
5.3
2.8
4.3
5.0
2.5
3.4
3.8
VW-1
■Plug (No Solder Type)
◆U.FL(A) Plug
・Harness product guarantees frequency up to 18GHz and impedance
matching.
・The inner and outer contact portion are gold plated
(the main body is nickel plated)
・The receptacle can be mated with U.FL-R-SMT-1 (shell : silver plated)
and U.FL-R-SMT-K (shell : gold plated).
・The SMA inspection adapter and extraction tool are only for the U.FL(A) Plug.
・Controls variation and improves extraction force by 50% compared to
conventional products and competing products (Approx. 30N).
It is difficult to remove the connector even when bending the cable.
Part No.
Size
2.66
2.66
U.FL(A)-LP(P)-088
5.9
1.73
5.9
1.73
Mated Height
2.2mm Max. (2.1mm Nom.)
Applicable cable
Ø1.13
Ø1.37
Weight (mg)
56
58
4
HRS V.S.W.R.
Company A V.S.W.R.
3.5
m
m
00
1
Measuring Adapter
HRMP-U.FLAJ
V.S.W.R.
※Cable Length = 100mm
3
2.5
2
Reference Plane
APC 3.5
1.5
1
2
3
4
5
6
7
8 9 10 11 12 13 14 15 16 17 18 19 20
Frequency (GHz)
■U.FL(A) Inspection SMA Conversion Adapter
(Mated Portion: U.FLA Jack- SMA Plug)
8HEX
10.7
Part No.
HRS No.
HRMP-U.FLAJ
311-2400-0
(Note) Since the U.FL side mated portion has a weaker lock than
standard products, it cannot be used for purposes other than
performance measurement.
■U.FL(A) Insertion/Extraction Tool
12
3.7
10
For removing from the mated condition
12
38
10
2
U.FL(A)-LP(P)-068
Part No.
HRS No.
U.FL(A)-LP-IN.OUT
331-2401-0
5
■The Procedure for ordering patch cord
Please select the specifications in 3 steps. No need product name for ordering patch cords.
STEP 1 : Single end or both ends
[Single ended cable assembly]
[Double ended cable assembly]
L
L
Ordering information
STEP 2 : Cable and mating height
Cable color Mating height (Max)
Plug
Gray / Black 2.3mm (2.4mm) U.FL-LP-088HF
Gray / Black
Gray / Black
Gray / Black
Gray / Black
Gray / Black
White / Black
White / Black
2.1mm (2.2mm)
2.4mm (2.5mm)
2.4mm (2.5mm)
2.1mm (2.2mm)
2.3mm (2.4mm)
2.4mm (2.5mm)
2.0mm (1.9mm)
-1
U.FL(A)-LP(P)-088
U.FL-LP-066HF
U.FL-LP-068HF
U.FL(A)-LP(P)-068
U.FL-LP-062HF
U.FL-LP-040HF
U.FL-LP(V)-040HF
INSERTION LOSS (dB)
No. Jacket diameter
1
Ø1.37
2 Ø1.37 Low Loss
3
Ø1.37
4
Ø1.32
5
Ø1.13
6
Ø1.13
7
Ø0.95
8
Ø0.81
9
Ø0.81
Insertion Loss comparison
between each cable size【dB/m】
STEP 3 : Cable length (mm)
-3
-4
-5
-6
-7
-8
-9
●Standard tolerances for (L)
(L)(mm)
*L=35 to 200
L=201 to 500
L=501 to 1000
L=Longer than 1000
-2
-10
Standard tolera(mm)
±4
±8
±12
±1.5% of (L)
2
3
4
5
6
7
Frequency (GHz)
Note : Minimum available length(L) is 35mm. (U.FL(A) is from 80 to 1200mm)
■Patch cord name example
Characters that are not red are for Hirose internal identification.
●Plug (Center Solder Type)
●Plug (No Solder Type)
U.FL-2LPHF6-04N1TV-A-300
UFL-2LPA-068Y2T-A-300
Cable length : STEP 3
Cable type : STEP 2
Double ended or single ended : STEP 1
Series name
Cable type : STEP 2
Series name
STEP 1 Example Notation
[Double ended]
[Single ended]
U.FL-LPHF6-04N1TV-A-300
STEP 2 Example Notation
1 Cable-mating height
[Dia. 1.37 cable (088 cable)]
088 is listed in the third block representing the cable type.
U.FL-2LPHF6-088N1T-A-300 (Plug : U.FL)
U F L-2LPA-088Y1T-A-300 (Plug : U.FL(A))
[Dia. 1.37 Cable (088) Low Loss]
Block 3 that shows the cable times says 088.
U F L-2LPHF6-088N1PD-A-300 (Plug : U.FL)
[Dia. 1.32 cable (066 cable)]
066 is listed in the third block representing the cable type.
U.FL-2LPHF6-066N1-A-300 (Plug : U.FL)
[Dia. 1.13 cable (068 cable)]
068 is listed in the third block representing the cable type.
U.FL-2LPHF6-068N1T-A-300 (Plug : U.FL)
U F L-2LPA-068Y1T-A-300 (Plug : U.FL(A))
[Dia. 0.95 cable (062 cable)]
062 is listed in the third block representing the cable type.
U.FL-2LPHF6-062N1D-A-300 (Plug : U.FL)
[Dia. 0.81 cable (040 cable)]
04 is listed in the third block representing the cable type.
When the height is 1.9mm, V enters affer LP.
Dot does not needed for U.FL series name.
U.FL-2LPHF6-04N1TV-A-300 : Mating height 2.4mm
U F L-2LPVHF6-04N1TV-A-300 : Mating height 1.9mm
STEP 3 Example Notation
Cable length is written in millimeters at the end.
EX : 300mm
6
2 Cable color
∼Except Dia. 0.81 cable∼
[Gray]
1 is listed in the third block representing the cable type.
[Black]
U.FL-2LPHF6-062N2D-A-300 (Plug : U.FL)
∼Dia. 0.81 cable∼
[White]
U.FL-2LPHF6-04N1TV-A-300 (Plug : U.FL)
[Black]
U.FL-2LPHF6-04N2TV-A-300 (Plug : U.FL)
8
■Conversion Adapter
●SMA Conversion Adapter (Mated Portion : UFL Jack - SMA Plug)
(10.7)
Part No.
HRS No.
HRMP-U.FLJ(40)
311-0300-2 40
8HEX
●SMA Conversion Adapter (Mated Portion : U.FL Plug - SMA Jack)
14.05
(4.05)
5.6
Ø6.35
6
1/4-36UNS-2A
Part No.
HRS No.
HRMJ-U.FLP(40)
311-0301-5 40
(Note) Since the U.FL side mating portion has a weaker lock than standard products, it cannot be used for purposes other than performance measurement.
(18.6)
(4)
6
5.5
1/4-36UNS-2A
Part No.
HRS No.
HRMJ-U.FLP-ST1(40)
311-0385-5 40
This connector is used by pressing the mating portion of the U.FL side with the mating portion of U.FL-R-SMT.
●SMA Conversion Adapter (Mated Portion: SMA Jack (Measuring Device Connection Side) -SMA Plug)
2×
Ø2
Ø10.86
.3
Part No.
HRS No.
HRM-PA-PJ(F)-1(40)
323-0805-9 40
8
11.6
4.4
18.84
31.3
(Note) HRMJ-U.FLP-ST1 aborbs misalignment when mated with the plug (coupling side) and connecting the jack with the measuring device.
(Refer to next page)
7
●Probe for Inspect of Multiple Narrow Pitch Receptacles (Mated Portion : U.FL Plug (No lock) - ML51 Jack)
2×
Ø2
Ø3.8
12
8.5
Ø4
.4
4.2
1.75
15.5
22.8
Part No.
HRS No.
U.FLP-ML51.J-PA(F)-ST
311-0446-8
(Note) Hirose's ML51 is used for the measuring device interface. It is ideal for simultaneous inspection of multiple narrow pitch mounted receptacles.
●Harness for Narrow Pitch Probe Connection (Mated Portion : SMA Plug (Measuring Device Connection Side) - ML55 Plug
350±8
Part No.
HRS No.
HRMP-ML51LP-DTR178-350RS
321-4926-2 01
(Note) Used to connect U.FLP-ML51J-PA(F)-ST and the measuring device. It is recommended to provide slack to the cable length so that it can
absorb misalignment smoothly.
■Inspection Probe
●HRMJ-U.FLP-ST1 and HRM-PA-PJ(F)1 Combination and Usage
(A)
12mm min
Shortest Pitch for Adjacency
Flange to Board Surface
(A)
Recommendation for Measurement
32.5±0.2
Starting Load
33.2
●U.FLP-ML51.J-PA(F)-ST and HRMP-ML51LP-DTR178-350RS Combination and Usage
(A)
4.5mm min
(A)
15.1±0.2
Beginning Load
16
*For the inspection probe do not tilt the tip contact from the tensile load of the connecting cable.
8
■Inspection Receptacle
Receptacle for inspecting the conduction and withstanding voltage of harness products.
12.9
(7.9)
(4.4)
7HEX
5
1
M5∞0.5
Part No.
HRS No.
U.FL-R-1
331-0466-0
■Inspection Assistance Device
●SMA Mating Push On Conversion Adapter
Ø7.8
Ø9
Push On Mating Portion
(Mates with SMA-J)
8
Part No.
HRS No.
HRMP(PO)-HRMJ
323-0741-8
6
3
10.6
Coverts SMA plug mating portion to push on type, reducing the number of steps required for repeated SMA mating.
-IN
-LP
h) W.FL
g
ou from
hr
(T hing
2
Ø guis
n
isti
le d
Ho
■Insertion Tool
8
Ø10
Tool for plug insertion.
100
Part No.
HRS No.
U.FL-LP-IN
331-0334-9
BExtraction Tool
(90)
Tool for unmating.
5
Ø15
50
U.FL
Marking
U.FL
U.FL/V
2.1
(Note 1) Product cannot be used for purposes other than conduction or withstanding voltage inspection because there is no lock on the mating portion.
(Note) U.FL-LP-N is also used with E.FL Series.
Part No.
HRS No.
Applicable Plug
U.FL-LP-N-2(V)
331-0494-5
U.FL-LP-040HF, 066HF, 088HF, 068HF
U.FL-LP(V)-N-2
331-0493-2
U.FL-LP-062HF, U.FL-LP(V)-040HF
9
Usage Precautions
1. Plugs
(1) Mating / unmating
1) To disconnect connectors, insert the end portion of U.FL-LP-N-2 and U.FL-LP(V)-N-2 under the
connector flanges and pull off vertically, in the direction of the connector mating axis. However for
U.FL(A) (Solderless connection type, use U.FL(A)-LP-IN.OUT and
Extraction Tool
pull out vertically. When removing the connector directly, hold the
connector lid and pull out vertically in relation to the connector mating
U.FL Cable
Assembly
axis. (Be careful not to damage the connector with fingers or nails.)
2) To mate the connectors, the mating axes of both connectors must be
aligned and the connectors can be mated. The "click" will confirm fully
mated connection.Do not attempt to insert on an extreme angle.
U.FL-R-SMT-1
After the connectors are mating, do not apply a load to the cable in excess of the values indicated in the
diagram below.
U.FL-LP
Cable Assembly
(2) Pull forces on the cable
after connectors are
mated.
1N max (U.FL-LP(V)-040HF, U.FL-LP-062HF)
2N max (U.FL-LP-040HF, U.FL-LP-066HF, U.FL-LP-068HF, U.FL-LP-088HF,
U.FL(A)-LP(P)-068, U.FL(A)-LP(P)-088)
U.FL-R-SMT-1
3N max (U.FL-LP(V)-040HF, U.FL-LP-062HF)
4N max (U.FL-LP-040HF, U.FL-LP-066HF, U.FL-LP-068HF, U.FL-LP-088HF,
(3) Precautions
Do NOT forcefully twist or deform wires.
2. Receptacles
250 ç max. for
10 seconds
[ç]
(1) Recommended reflow
temperature profile
260
240
220
200
180
160
140
120
100
80
Preheat
(130 to 180ç)
120 seconds max.
230ç
220ç
50 seconds max.
60 seconds max.
Time
q The temperature of the printed circuit
board surface temperature at the
points of contact with the terminals.
w Reflow soldering should be
performed at a printed circuit surface
temperature of 250°C max.
e In individual applications the actual
temperature may vary, depending on
the solder paste type, volume /
thickness and board size / thickness.
Consuly your solder paste and
equipment manufacturer for specific
recommendations.
(2) Recommended manual
Manual soldering : 350˚C for 5 seconds
soldering
(3) Recommended metal
mask thickness
0.1 to 0.12mm
(4) Reflow cycles
2 times
3. Operating environment and storage conditions
(1) Operating environment
(2) Storage conditions Receptacle
(3) Silver Plating
Discoloration
10
The connectors are not designed to operate in the following environments :
• Exposed to a excessive amounts of fine particles and dust
• Regions and places having a high density of sulfur dioxide, hydrogen sulfide, nitrogen dioxide or other corrosive
gasses.
• Environments having large rapid variations in temperature.
Store in the Hirose Electric packaging.
Temperature : -10 to +40ç, Humidity : 85% max.
Use within 6 months of delivery.
Receptacles for which the storage period has elapsed must be tested for solderability to the PC board
mounting surface.
Discoloration occurs only on the plating surface. Since the contact portion is wiped, there is no effect on the
electrical contact.
■Standard Connectors that Connect with U.FL
SMA Cable Type
Straight Plug
HRS No.
8HEX
Applicable cable
HRM-200-040PBN
(40) 323-0790-3 40
Dia. 0.81 type
HRM-200-066PBN
(40) 323-0791-6 40
Dia. 1.13, Dia.1.32 type
HRM-200-088PBN
(40) 323-0800-5 40
Dia. 1.37 type
Notes
SMA
(Male
Contact)
Straight Jack
17
4.5
Part No.
1/4-36UNS-2A
8
8HEX
HRS No.
Applicable cable
HRM-200-040JBN
(40) 323-0792-9 40
Dia. 0.81 type
HRM-200-066JBN
(40) 323-0793-1 40
HRM-200-088JBN
(40) 323-0801-8 40
Dia. 1.37 type
●Panel mount Jack (Four Screws)
17
9.55
1.7
1/4-36UNS-2A
4-Ø2.6
Notes
SMA
(Female
Contact)
12.7
8.64
Ø6.4
Part No.
1/4-36UNS-2B
15
Part No.
HRS No.
Applicable cable
HRM-200-040PJ4BN(40) 323-0795-7 40
Dia. 0.81 type
HRM-200-066PJ4BN(40) 323-0796-0 40
HRM-200-088PJ4BN(40) 323-0803-3 40
Dia. 1.37 type
Notes
SMA
(Female
Contact)
11
17
9.55
1.7
8
1/4-36UNS-2A
●Panel mount Jack (Two Screws)
Ø6.4
2∞Ø2.6
Part No.
HRS No.
Applicable cable
HRM-200-040PJ2BN(40) 323-0794-4 40
Dia. 0.81 type
HRM-200-066PJ2BN(40) 323-0788-1 40
HRM-200-088PJ2BN(40) 323-0802-0 40
Dia. 1.37 type
17
1.5
11
8HEX
5.85
5.9+0.1
Ø6.4+0.1
Part No.
HRS No.
Applicable cable
HRM-200-040BPJBN(40) 323-0797-2 40 Dia. 0.81 type
HRM-200-066BPJBN(40) 323-0798-5 40 Dia. 1.13, Dia.1.32 type
HRM-200-088BPJBN(40) 323-0804-6 40 Dia. 1.37 type
2
16.98
11
1/4-36UNS-2A
8HEX
5.85
SMA
(Female
Contact)
Ø6.4+0.1
Part No.
12
Notes
5.9+0.1
Ø12
●Panel mount Jack
(Bulkhead, Waterproof Mounting Surface Type)
SMA
(Female
Contact)
BPanel Cutouts
Ø10
●Panel mount Jack (Bulkhead)
1/4-36UNS-2A
Notes
HRS No.
Applicable cable
HRM-200-040WBPJBN
323-0945-8
Dia. 0.81 type
HRM-200-066WBPJBN
323-0946-0
HRM-200-088WBPJBN
323-0920-7
Dia. 1.37 type
Notes
SMA
(Female
Contact)
■SMA-U.FL Cable Assembly Representative Product
SMA Straight Plug-U.FL Plug
L
Part No.
HRS No.
Cable (Color)
HRMP-UFLHF6-04N2TV-A200RS
321-0753-0-04
Ø0.81(Black)
HRMP-UFLHF6-068N2T-A200RS
321-0854-0-02
Ø1.13(Black)
HRMP-UFLHF6-066N2-A200RS
321-0862-0-05
Ø1.32(Black)
HRMP-UFLHF6-088N2T-A200RS
321-0755-0-07
Ø1.37(Black)
Lmm
Notes
200±4
SMA
(Female
Contact)
Lmm
Notes
200±4
SMA
(Male
Contact)
Lmm
Notes
200±4
SMA
(Female
Contact)
SMA Straight Jack-U.FL Plug
L
HRS No.
Cable (Color)
HRMJ-UFLHF6-04N2TV-A200RS
Part No.
321-0881-0-02
Ø0.81(Black)
HRMJ-UFLHF6-068N2T-A200RS
321-0869-0-03
Ø1.13(Black)
HRMJ-UFLHF6-066N2-A200RS
321-0868-0-02
Ø1.32(Black)
HRMJ-UFLHF6-088N2T-A200RS
321-0904-0-04
Ø1.37(Black)
SMA Panel Mount Jack (Four Screws)-U.FL Plug
L
Part No.
HRS No.
Cable (Color)
HPJ-UFLHF6-04N2TV-A200RS
321-0965-0-02
Ø0.81(Black)
HPJ-UFLHF6-068N2T-A200RS
321-3660-0-02
Ø1.13(Black)
HPJ-UFLHF6-066N2-A200RS
321-0905-0-01
Ø1.32(Black)
HPJ-UFLHF6-088N2T-A200RS
321-0911-0-03
Ø1.37(Black)
◆For cable lengths, cable colors and connector combinations other than those listed above, please contact a Hirose representative.
13
SMA Panel Mount Jack (Two Screws)-U.FL Plug
L
Part No.
HRS No.
Cable (Color)
HPJ2-UFLHF6-04N2TV-A200RS
321-0969-0-03
Ø0.81(Black)
HPJ2-UFLHF6-068N2T-A200RS
321-1083-0-03
Ø1.13(Black)
HPJ2-UFLHF6-066N2-A200RS
321-1084-0-03
Ø1.32(Black)
HPJ2-UFLHF6-088N2T-A200RS
321-0812-0-04
Ø1.37(Black)
Lmm
Notes
200±4
SMA
(Female
Contact)
SMA Panel Mount Jack (Bulkhead)-U.FL Plug
L
5.9+0.1
Ø6.4+0.1
L
5.9+0.1
Ø6.4+0.1
SMA Side: Die Cast Product
11.5
1.5
17
HRS No.
Cable (Color)
HBPJ-UFLHF6-04N2TV-A200RS
Part No.
321-0964-0-02
Ø0.81(Black)
HBPJD-UHF6-068N2T-A200(Note)
321-5463-0-02
Ø1.13(Black)
HBPJD-UHF6-066N2-A200(Note)
321-5464-0-02
Ø1.32(Black)
HBPJD-UHF6-088N2T-A200(Note)
321-5600-0-02
Ø1.37(Black)
Lmm
Notes
200±4
SMA
(Female
Contact)
(Note) Die Cast Body on SMA Side (Different product than those listed on the SMA Cable Type Page)
SMA Panel Mount Jack (Bulkhead, Waterproof Mounting Surface)-U.FL Plug
L
5.9+0.1
Ø6.4+0.1
Part No.
HRS No.
Cable (Color)
HWBPJ-UHF6-068N2T-A-200
321-1235-0-03
Ø1.13(Black)
HWBPJ-UFLHF6-088N2T-A200
321-0760-0-04
Ø1.37(Black)
Lmm
Notes
200±4
SMA
(Female Contact)
14
SMA/R Cable Type
/R : Reverse Polarity SMA Connector
15
8HEX
1/4-36UNS-2B
Straight Plug
Part No.
HRS No.
SMA(R)-200-040PBN
323-0925-0
Applicable cable
Dia. 0.81 type
SMA(R)-200-066PBN
323-0930-0
SMA(R)-200-088PBN
323-0905-3
Dia. 1.37 type
Notes
SMA
Reverse
(Female
Contact)
17
Straight Jack
4.5
8
8 HEX
1/4-36UNS-2A
Part No.
HRS No.
Applicable cable
SMA(R)-200-040JBN
323-0926-3
Dia. 0.81 type
SMA(R)-200-066JBN
323-0931-3
SMA(R)-200-088JBN
323-0904-0
Dia. 1.37 type
17
SMA
Reverse
(Male
Contact)
12.7
9.55
1.7
Notes
8.64
1/4-36UNS-2A
.6
Ø2
4∞
Part No.
HRS No.
Applicable cable
SMA(R)-200-040PJ4BN
323-0928-9
SMA(R)-200-066PJ4BN
323-0932-6
SMA(R)-200-088PJ4BN
323-0934-1
Dia. 1.37 type
Dia. 0.81 type
Notes
SMA
Reverse
(Male
Contact)
15
17
1.7
9.55
8
1/4-36UNS-2A
12.2
6
Ø2.
2∞
Part No.
HRS No.
SMA(R)-200-040PJ2BN
323-0929-1
Dia. 0.81 type
SMA(R)-200-066PJ2BN
323-0933-9
SMA(R)-200-088PJ2BN
323-0935-4
Dia. 1.37 type
17
8HEX
11
1.5
Applicable cable
Notes
SMA
Reverse
(Male
Contact)
BPanel Cutouts
5.85
5.9+0.1
Ø6
.4 +
Ø10
1/4-36UNS-2A
Part No.
HRS No.
Applicable cable
Notes
SMA(R)-200-040BPJBN
323-0927-6
SMA(R)-200-066BPJBN
323-0902-5
SMA(R)-200-088BPJBN
323-0901-2
Dia. 1.37 type
Panel Mount Jack
2
17
Dia. 0.81 type
8HEX
5.85
11
SMA
Reverse
(Male
Contact)
5.9+0.1
Ø6
.4 +
Ø12
1/4-36UNS-2A
Part No.
16
HRS No.
Applicable cable
SMA(R)-200-040WBPJBN
323-0947-3
Dia. 0.81 type
SMA(R)-200-066WBPJBN
323-0948-6
SMA(R)-200-088WBPJBN
323-0949-9
Dia. 1.37 type
Notes
SMA
Reverse
(Male
Contact)
TNC Cable Type
Panel Jack (Bulkhead, Waterproof Panel Mounting Surface Type)
28.31
18.14
15.9
7/16-28UNEF-2A
BPanel Cutouts
.15
+0 0
3
2.8
Ø1
+0.2
Part No.
HRS No.
Applicable cable
TNC-WBPJ-088-1
313-0004-0
Ø1.37 cable
*Please order the product after designating the harness specifications
including product length, etc.
TNC/R Cable Type
28.31
18.14
15.9
7/16-28UNEF-2A
BPanel Cutouts5
.1
+0 0
3
2.8
Ø1
+0.2
12.01−0.05
Part No.
HRS No.
Applicable cable
TNC(R)-WBPJ-088
313-0003-0
Ø1.37 cable
Panel Mount Adapter (Two Screws)
8
(22.25)
14.25
(2.25)
12.7
7/16-28UNEF-2A
U.FL
TNC(R)-J
18
TNC/R Conversion Adapter
Ø6.9
12.01−0.05
No
2∞
Part No.
HRS No.
TNC(R)J-U.FLJ-PA-2
311-0416-7
2B
F-
UN
6
3-5
Notes
TNC Reverse
(Male Contact)
17
Note : Please avoid mating with the U.FL(A) plug.
17.9
Panel Mount Adapter (Four Screws)
12.7
9.55
1.7
8.64
1/4-36UNS-2A
.6
Ø2
4∞
Part No.
HRS No.
HRMJ-U.FLJ-PA4
311-0465-2
Notes
SMA
(Female Contact)
17.9
9.55
8
1.7
12.2
1/4-36UNS-2A
2∞
Ø2.
Part No.
HRS No.
HRMJ-U.FLJ-PA2
311-0467-8
6
Notes
SMA
(Female Contact)
Panel Mount Adapter (Bulkhead)
17.9
1.5
11.5
1/4-36UNS-2A
8HEX
5.85
5.9+0.1
Ø6
.4 +0
PCB Mount Adapter
Part No.
HRS No.
HRMJ-U.FLJ-BPAD-5
311-1004-0
6
Notes
SMA (Female Contact)
Body : Die Cast Type
16
BPanel Cutouts
1/4-36UNS-2A
5.08±0.05
12.7
9.7
6.4
5.08±0.05
0.1
.5 0
4∞Ø1
5.08
Part No.
HRMJ-U.FLJ-PC
18
0 .1
HRS No.
Notes
311-0411-3
Nickel Exterior
SMA/R Conversion Adapter
17.9
12.7
9.55
1.7
8.64
1/4-36UNS-2A
Ø2.
6
Part No.
HRS No.
Notes
SMA(R)J-U.FLJ-PA4
311-0466-5
(Male Contact)
17.9
8
9.55
1.7
1/4-36UNS-2A
12.2
2∞
Part No.
HRS No.
SMA(R)J-U.FLJ-PA2
311-0468-0
1.5
6
Notes
(Male Contact)
8HEX
17.9
Ø2.
BPanel Cutouts
5.85
11
5.9 +0.1
1/4-36UNS-2A
Ø6
4 +
Ø10
4∞
Part No.
HRS No.
SMA(R)J-U.FLJ-BPA-4
311-0464-0
Notes
(Male Contact)
19
MEMO:
2-6-3,Nakagawa Chuoh,Tsuzuki-Ku,Yokohama-Shi 224-8540,JAPAN
https://www.hirose.com/
The characteristics and the specifications contained herein are for reference purpose. Please refer to the latest customer drawings prior to use.
The contents of this catalog are current as of date of 08/2021. Contents are subject to change without notice for the purpose of improvements.
