SMB10J9.0(A) – SMB10J40(A)
Taiwan Semiconductor
1000W, 9V - 40V Surface Mount Transient Voltage Suppressor
FEATURES
KEY PARAMETERS
Low profile package
Ideal for automated placement
Glass passivated chip junction
Excellent clamping capability
Fast response time: Typically less than 1.0ps
Meets ISO 7637-2 (Pulse 1/2a/2b/3a/3b)
Moisture sensitivity level: level 1, per J-STD-020
RoHS Compliant
Halogen-free according to IEC 61249-2-21
PARAMETER
VALUE
UNIT
VWM
9 - 40
V
VBR
10.0 - 49.1
V
PPK
1,000
W
TJ MAX
175
°C
Package
DO-214AA (SMB)
Configuration
Single die
APPLICATIONS
Protect sensitive circuit from damage by high voltage transients
Lighting, ESD transient voltage protection of IC, system
Inductive switching load protection of IC, system
Electrical Fast Transient Immunity protection of IC, system
MECHANICAL DATA
Case: DO-214AA (SMB)
Molding compound meets UL 94V-0 flammability rating
Terminal: Matte tin plated leads, solderable per J-STD-002
Meet JESD 201 class 2 whisker test
Polarity: As marked
Weight: 0.110g (approximately)
DO-214AA (SMB)
ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted)
PARAMETER
Peak power dissipation at TA = 25°C, tp = 1ms
(1)
SYMBOL
VALUE
UNIT
PPK
1,000
W
Steady state power dissipation
Peak forward surge current, 8.3ms single half sine-wave
superimposed on rated load
PD
5
W
IFSM
100
A
Forward Voltage @ IF = 50A for Uni-directional only
VF
3.5
V
Junction temperature
TJ
-55 to +175
°C
-55 to +175
°C
Storage temperature
TSTG
Note:
1. Non-repetitive current pulse per Fig.3 and derated above TA = 25°C per Fig.2
Devices for Bipolar Applications
1. For bidirectional use CA suffix
1
Version: B2102
THERMAL PERFORMANCE
PARAMETER
SYMBOL
TYP
UNIT
Junction-to-lead thermal resistance
RӨJL
°C/W
Junction-to-ambient thermal resistance
RӨJA
100
°C/W
ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted)
Device
Device
Marking
Code
UNI
SMB10J9.0A
SMB10J10A
SMB10J11A
SMB10J12A
SMB10J13A
SMB10J14A
SMB10J15A
SMB10J16A
SMB10J17A
SMB10J18A
SMB10J20A
SMB10J22A
SMB10J24A
SMB10J26A
SMB10J28A
SMB10J30A
SMB10J33A
SMB10J36A
SMB10J40A
Breakdown
Voltage
Test
@ IT
Current
VBR (V)
IT (mA)
BI
UNI
BI
Min Max
SMB10J9.0CA 1KV KVC 10.0 11.1
SMB10J10CA 1KX KXC 11.1 12.3
SMB10J11CA 1KZ KZC 12.2 13.5
SMB10J12CA 1LE LEC 13.3 14.7
SMB10J13CA 1LG LGC 14.4 15.9
SMB10J14CA 1LK LKC 15.6 17.2
SMB10J15CA 1LM LMC 16.7 18.5
SMB10J16CA 1LP LPC 17.8 19.7
SMB10J17CA 1LR LRC 18.9 20.9
SMB10J18CA 1LT LTC 20.0 22.1
SMB10J20CA 1LV LVC 22.2 24.5
SMB10J22CA 1LX LXC 24.4 26.9
SMB10J24CA 1LZ LZC 26.7 29.5
SMB10J26CA 1ME MEC 28.9 31.9
SMB10J28CA 1MG MGC 31.1 34.4
SMB10J30CA 1MK MKC 33.3 36.8
SMB10J33CA 1MM MMC 36.7 40.6
SMB10J36CA 1MP MPC 40.0 44.2
SMB10J40CA 1MR MRC 44.4 49.1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
Stand-Off
Voltage
VWM
(V)
9
10
11
12
13
14
15
16
17
18
24
26
28
30
33
36
40
Maximum Maximum Maximum
Reverse
Peak
clamping
Leakage
Pulse
voltage
@VWM
Current
@IPPM
ID (µA)
IPPM (A)
VC (V)
10
8
5
5
5
5
1
1
1
1
1
1
1
1
1
1
1
1
1
64.9
58.8
54.9
50.3
46.5
43.1
41.0
38.5
36.2
34.2
30.9
28.2
25.7
23.8
22.0
20.7
18.8
17.2
15.5
15.4
17.0
18.2
19.9
21.5
23.2
24.4
26.0
27.6
29.2
32.4
35.5
38.9
42.1
45.4
48.4
53.3
58.1
64.5
ORDERING INFORMATION
ORDERING CODE(1)
PACKAGE
PACKING
SMB10Jx
DO-214AA (SMB)
3,000 / Tape & Reel
Notes:
1. "x" defines voltage from 9V(SMB10J9.0A) to 40V(SMB10J40CA)
2
Version: B2102
CHARACTERISTICS CURVES
Fig.1 Peak Pulse Power Rating Curve
Fig.2 Pulse Derating Curve
PEAK PULSE POWER(PPP) OR CURRENT (IPP)
ADERATING IN PERCENTAGE (%)
PPPM, PEAK PULSE POWER, KW
100
Non-reperirive
pulse waveform
shown in Fig.3
10
1
1
10
100
125
100
75
50
25
50
75
100
125
150
175
TA, AMBIENT TEMPERATURE (°C)
tp, PULSE WIDTH, (μs)
Fig.3 Clamping Power Pulse Waveform
Fig.4 Maximum Non-Repetitive Forward Surge
Current Unidirectional Only
100
140
Pulse width(td) is defined
as the point where the peak
current decays to 50% of IPPM
120
PEAK FORWARD SURGE CURRENT (A)
IPPM, PEAK PULSE CURRENT (%)
25
Rise time tr=10μs to 100%
100
Peak value
IPPM
80
60
Half value-IPPM/2
10/1000μs, waveform
40
td
10
8.3ms single salf sine wave
1
1.5
2
2.5
1
3
PERCENT OF RATEDt, PEAK
REVERSE VOLTAGE (%)
TIME (ms)
10
100
NUMBER OF CYCLES AT 60 Hz
3
Version: B2102
PACKAGE OUTLINE DIMENSIONS
DO-214AA (SMB)
SUGGESTED PAD LAYOUT
MARKING DIAGRAM
P/N
= Marking Code
G
= Green Compound
YW
= Date Code
F
= Factory Code
Cathode band for uni-directional products only
4
Version: B2102
Notice
Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf,
assumes no responsibility or liability for any errors or inaccuracies.
Purchasers are solely responsible for the choice, selection, and use of TSC products and TSC assumes no liability
for application assistance or the design of Purchasers’ products.
Information contained herein is intended to provide a product description only. No license, express or implied, to
any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of
sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty,
relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose,
merchantability, or infringement of any patent, copyright, or other intellectual property right.
The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications.
Customers using or selling these products for use in such applications do so at their own risk and agree to fully
indemnify TSC for any damages resulting from such improper use or sale.
5
Version: B2102
很抱歉,暂时无法提供与“SMB10J24CAHR5G”相匹配的价格&库存,您可以联系我们找货
