4960
    ADAFRUIT
4960 数据手册
东莞市欧思科光电科技有限公司 DONGGUAN OPSCO OPTOELECTRONICS CO., LTD Factory : Lianxing industrial park, xiajie village, Qishi Town, Dongguan City. guangdong province, China Dongguan Tel: (769)82632725 Dongguan Fax: (769)82632735 SK6812MINI-E 3.2x2.8x1.78 mm 0.2W Intelligent external control surface mount SMD LED (MSL:5a) ELECTROSTATIC SENSITIVE DEVICES Change History 1 / 18 Date Rev. No. Changes/Reason of changes 2017-08-04 01 Initial Document KEVIN ZHU 2019-01-18 02 Revision of Specification Format KEVIN ZHU Signature Document No.: SPC / SK6812MINI-E Rev. No.: 02 东莞市欧思科光电科技有限公司 DONGGUAN OPSCO OPTOELECTRONICS CO., LTD Factory : Lianxing industrial park, xiajie village, Qishi Town, Dongguan City. guangdong province, China Dongguan Tel: (769)82632725 Dongguan Fax: (769)82632735 CONTENTS 1、 Product overview........................................................................3 2、 Main Application Field...............................................................3 3、 Description...................................................................................3 4、 Mechanical Dimensions...............................................................4 5、 PIN configuration.........................................................................4 6、 Recommended dimensions for PCB ...........................................4 7、General description of product naming........................................5 8、 Electrical parameters....................................................................5 9、 Electrical/Optical Characteristics.................................................5 10、 IC The electrical parameters......................................................6 11、 Switching characteristics............................................................6 12、 The data transmission time ........................................................7 13 、 Timing waveform.......................................................................7 14、 The method of data transmission................................................8 15、 The data structure of 24bit.......................................................... 9 16、 The typica l application circuit....................................................9 17、 Standard LED Performance Graph..............................................10 18、 Packaging Standard......................................................................11 19、 Reliability Test..............................................................................12 Appendix 1、 TOP SMD LED Application Notes...............................13~18 2 / 18 Document No.: SPC / SK6812MINI-E Rev. No.: 02 东莞市欧思科光电科技有限公司 DONGGUAN OPSCO OPTOELECTRONICS CO., LTD Factory : Lianxing industrial park, xiajie village, Qishi Town, Dongguan City. guangdong province, China Dongguan Tel: (769)82632725 Dongguan Fax: (769)82632735 1. Product Overview : SK6812MINI-E is a smart LED control circuit and light emitting circuit in one controlled LED source, which has the shape of a 3528 LED chip. Each lighting element is a pixel, and the intensities of the pixels are contained within the intelligent digital interface input. The output is driven by patented PWM technology, which effectively guarantees high consistency of the color of the pixels. The control circuit consists of a signal shaping amplification circuit, a built-in constant current circuit, and a high precision RC oscillator. The data protocol being used is unipolar RZ communication mode. The 24-bit data is transmitted from the controller to DIN of the first element, and if it is accepted it is extracted pixel to pixel. After an internal data latch, the remaining data is passed through the internal amplification circuit and sent out on the DO port to the remaining pixels. The pixel is reset after the end of DIN. Using automatic shaping forwarding technology makes the number of cascaded pixels without signal transmission only limited by signal transmission speed. The LED has a low driving voltage (which allows for environmental protection and energy saving), high brightness, scattering angle, good consistency, low power, and long life. The control circuit is integrated in the LED above. 2. Main Application Field: ● Full color LED string light, LED full color module, LED super hard and soft lights, LED guardrail tube, LED appearance / scene lighting ● LED point light, LED pixel screen, LED shaped screen, a variety of electronic products, electrical equipment etc.. 3. Description: ● Top SMD internal integrated high quality external control line serial cascade constant current IC; ● control circuit and the RGB chip in SMD 3528 components, to form a complete control of pixel, color mixing uniformity and consistency; ●built-in data shaping circuit, a pixel signal is received after wave shaping and output waveform distortion will not guarantee a line; ●The built-in power on reset and reset circuit, the power does not work; ●gray level adjusting circuit (256 level gray scale adjustable); ● red drive special treatment, color balance; ● line data transmission; ● plastic forward strengthening technology, the transmission distance between two points over 10M; ●Using a typical data transmission frequency of 800 Kbps, when the refresh rate of 30 frames per sec 3 / 18 Document No.: SPC / SK6812MINI-E Rev. No.: 02 东莞市欧思科光电科技有限公司 DONGGUAN OPSCO OPTOELECTRONICS CO., LTD Factory : Lianxing industrial park, xiajie village, Qishi Town, Dongguan City. guangdong province, China Dongguan Tel: (769)82632725 Dongguan Fax: (769)82632735 4. Mechanical Dimensions: 1 VDD 4 DIN 2 DOUT 3 GND 角 Notes: 1. All dimensions are in millimeters. 2. Tolerance is ±0.1mm unless otherwise noted 5. PIN configuration NO. Symbol Function description 1 VDD Power supply LED 2 DOUT Control data signal output 3 GND Ground 4 DIN Control data signal input 6. Recommended dimensions for PCB 4 / 18 1 VDD 4 DIN 2 DOUT 3 GND Document No.: SPC / SK6812MINI-E Rev. No.: 02 东莞市欧思科光电科技有限公司 DONGGUAN OPSCO OPTOELECTRONICS CO., LTD Factory : Lianxing industrial park, xiajie village, Qishi Town, Dongguan City. guangdong province, China Dongguan Tel: (769)82632725 Dongguan Fax: (769)82632735 7. General description of product naming SK 6812 MINI-E ① ③ ② ① ② ③ Series IC series and current code package outline The default is to integrate the RGB chip with the IC in the Refers to the 68 series IC 5/12MA current version 3.2x2.8x1.78mm package outline 8. Electrical parameters (Ta=25℃,VSS=0V) : Parameter Symbol Range Unit Power supply voltage VDD +3.7~+5.5 V Logic input voltage VIN -0.5~VDD+0.5 V Working temperature Topt -40~+85 ℃ Storage temperature Tstg -50~+150 ℃ ESD pressure(HBM) VESD 4K V ESD pressure(DM) VESD 200 V 9. Electrical/Optical Characteristics: SK6805MINI -E 5mA SK6812MINI -E 12mA Color Dominate Waveleng th(nm) Luminance( mcd) luminous flux(lm) Dominate Waveleng th(nm) Luminanc e(mcd) luminous flux(lm) 红色(RED) 620-630 100-200 0.5-1.0 620-625 400-700 1.0-2.0 绿色(GREEN) 520-535 400-700 2.0-3.0 520-530 1000-1500 3.0-4.0 蓝色(BLUE) 460-475 50-100 0.1-0.5 460-470 200-400 0.5-1.0 5 / 18 Document No.: SPC / SK6812MINI-E Rev. No.: 02 东莞市欧思科光电科技有限公司 DONGGUAN OPSCO OPTOELECTRONICS CO., LTD Factory : Lianxing industrial park, xiajie village, Qishi Town, Dongguan City. guangdong province, China Dongguan Tel: (769)82632725 Dongguan Fax: (769)82632735 10. The IC electrical parameters (unless otherwise specified, TA=-20 ~ +70 ℃, VDD=4.5 ~ 5.5V, VSS=0V): Parmeter Symb ol Min Typic al Max Unit Test conditions The chip supply voltage VDD --- 5.2 --- V --- VIH 0.7*VDD --- --- V VIL --- --- 0.3*VDD V The frequency of PWM FPWM --- 1.2 --- KHZ --- Static power consumption IDD --- 1 --- mA --- The signal input flip threshold VDD=5.0V 11. Switching characteristics(VCC=5V Ta=25 ℃): Parameter Symbol Min Typical Max Unit Test conditions The speed of data transmission fDIN --- 800 --- KHZ The duty ratio of 67% (data 1) DOUT transmission delay TPLH --- --- 500 ns TPHL --- --- 500 ns IOUT Rise/Drop Time Tr --- 100 --- ns Tf --- 100 --- ns 6 / 18 DIN→DOUT VDS=1.5 IOUT=13mA Document No.: SPC / SK6812MINI-E Rev. No.: 02 东莞市欧思科光电科技有限公司 DONGGUAN OPSCO OPTOELECTRONICS CO., LTD Factory : Lianxing industrial park, xiajie village, Qishi Town, Dongguan City. guangdong province, China Dongguan Tel: (769)82632725 Dongguan Fax: (769)82632735 12. The data transmission time : Name Min. Standard value Max. Unit T Code period 1.20 -- -- µs T0H 0 code, high level time 0.2 0.32 0.4 µs T0L 0 code, low level time 0.8 -- -- µs T1H 1 code, high level time 0.58 0.64 1.0 µs T1L 1 code, low level time 0.2 -- -- µs Trst Reset code,low level time >80 -- -- µs 1. The protocol uses a unipolar zeroing code. Each symbol must have a low level. Each symbol in this protocol starts with a high level. The high time width determines the "0" or "1" code. . 2. When writing programs, the minimum symbol period is 1.2μs. 3. The high time of “0” code and “1” code should be in accordance with the stipulated range in the above table. The low time requirement of “0” code and “1” code is less than 20μs. 13. Timing waveform: Input code: T Symbol period T0L 0 code T0H T1L 1 code T1H Reset code Trst Connection mode: D1 DIN DO PIX1 7 /18 D2 DIN DO PIX2 D3 D4 DIN DO PIX3 Document No.: SPC / SK6812MINI-E Rev. No.: 02 东莞市欧思科光电科技有限公司 DONGGUAN OPSCO OPTOELECTRONICS CO., LTD Factory : Lianxing industrial park, xiajie village, Qishi Town, Dongguan City. guangdong province, China Dongguan Tel: (769)82632725 Dongguan Fax: (769)82632735 14. The method of data transmission: Note: the D1 sends data for MCU, D2, D3, D4 for data forwarding automatic shaping cascade circuit. 8 / 18 Document No.: SPC / SK6812MINI-E Rev. No.: 02 东莞市欧思科光电科技有限公司 DONGGUAN OPSCO OPTOELECTRONICS CO., LTD Factory : Lianxing industrial park, xiajie village, Qishi Town, Dongguan City. guangdong province, China Dongguan Tel: (769)82632725 Dongguan Fax: (769)82632735 15. The data structure of 24bit: G7 G6 G5 G4 G3 G2 G1 G0 R7 R6 R5 R4 R3 R2 R1 R0 B7 B6 B5 B4 B3 B2 B1 B0 Note: high starting, in order to send data (G7 - G6 - ...... ..B0) 16. The typica l application circuit: In the practical application circuit, the signal input and output pins of the IC signal input and output pins should be connected to the signal input and output terminals. In addition, in order to make the IC chip is more stable, even the capacitance between beads is essential back; Application: used for soft lamp strip or hard light, lamp beads transmission distance is short, suggested in signal in time the clock line input and output end of each connected in series protection resistors, R1=R0 of about 500 ohms. Application: for module or general special-shaped products, lamp beads transmission distance is long, because of different wire and transmission distance, in the signal in time clock at both ends of the line on grounding protection resistance will be slightly different; to the actual use of fixed; 9 / 18 Document No.: SPC / SK6812MINI-E Rev. No.: 02 东莞市欧思科光电科技有限公司 DONGGUAN OPSCO OPTOELECTRONICS CO., LTD Factory : Lianxing industrial park, xiajie village, Qishi Town, Dongguan City. guangdong province, China Dongguan Tel: (769)82632725 Dongguan Fax: (769)82632735 17. Standard LED Performance Graph: Normalized Luminous Flux 120% BLUE/GREEN 100% 80% RED 60% 40% 20% 0.00 20 0 40 60 80 100 120 Thermal Pad Temperature (T=25°C) Relative Emission Distribution Wavelength Characteristics 100% BLUE GREEN RED 80% 60% 40% 20% 0.00 400 450 500 550 600 650 700 750 800 Wavelength (nm) Typical Radiation Pattern 120° 0 30° 60° 90° 90 75 60 45 30 15 0 0.2 0.4 0.6 0.8 1.0 Radiation Angle 10 / 18 Document No.: SPC / SK6812MINI-E Rev. No.: 02 东莞市欧思科光电科技有限公司 DONGGUAN OPSCO OPTOELECTRONICS CO., LTD Factory : Lianxing industrial park, xiajie village, Qishi Town, Dongguan City. guangdong province, China Dongguan Tel: (769)82632725 18. Packaging Standard: Dongguan Fax: (769)82632735 S K 6 8 1 2 M IN I C A T H O D E ID E N T IF IC A T IO N T A P E F E E D D IR E C T IO N C A R R IE R T A P E CO VER TAPE S M D R E E L (1 7 8 x 1 2 m m ) (IN N E R 1 5 0 0 p c s L E D M A X ) P R O D U C T N O .: S K 6 8 1 2 M IN I Q U A N T IT Y .: 1 5 0 0 P C S L o t N o .: L W 2 0 1 5 0 7 0 9 0 2 -1 0 ESD PO LYETH YLEN E BAG D A T E :2 0 1 6 -0 8 -2 3 L A B E L S K E T C H IN G C A R D B O A R D (IN N E R 1 0 B A G M A X .) C A R D B O A R D (IN N E R 4 C A R D B O A R D M A X .) The reel pack is applied in SMD LED. The LEDs are packed in cardboard boxes after packaging in normal or antielectrostatic bags. cardboard boxes will be used to protect the LEDs from mechanical shocks during transportation. The boxes are not water resistant and therefore must be kept away from water and moisture. 11 / 18 Document No.: SPC / SK6812MINI-E Rev. No.: 02 东莞市欧思科光电科技有限公司 DONGGUAN OPSCO OPTOELECTRONICS CO., LTD Factory : Lianxing industrial park, xiajie village, Qishi Town, Dongguan City. guangdong province, China Dongguan Tel: (769)82632725 Dongguan Fax: (769)82632735 19. Reliability Test : NO. Test item Test Conditions Reference Criterion 1 Thermal Shock 100 ± 5°C ~ -40°C ± 5°C 30min~30min 300 cycles MIL-STD-202G 0/22 2 High Temperature Storage Ta= +100ºC JEITA ED-4701 200 201 0/22 3 Low Temperature Storage Ta= -40ºC JEITA ED-4701 200 202 0/22 4 High Temperature High Humidity Storage RH=90% 1000hrs JEITA ED-4701 100 103 0/22 JEITA ED-4701 100 105 0/22 Ta=60ºC 1000hrs 1000hrs 5 Temperature Cycle -55ºC~25ºC~100ºC~25ºC 30min~5min~30min~5mi n 100 cycles 6 Resistance to Soldering Heat Tsld = 260°C, 10sec. 3 times JEITA ED-4701 300 301 0/22 7 Room temp Life Test 25°C, IF: Typical current , 1000hrs JESD22-A 108D 0/22 Criteria for Judging the Damage: Item Symbol Test Condition Luminous Intensity IV DC=5V, Typical current Resistance to Soldering Heat --- DC=5V, Typical current 12 /18 Limit Min Max Init. Value*0.7 --- No dead lights or obvious damage Document No.: SPC / SK6812MINI-E Rev. No.: 02 东莞市欧思科光电科技有限公司 DONGGUAN OPSCO OPTOELECTRONICS CO., LTD Factory : Lianxing industrial park, xiajie village, Qishi Town, Dongguan City. guangdong province, China Dongguan Tel: (769)82632725 Dongguan Fax: (769)82632735 Appendix 1、 TOP SMD LED Application Notes 1. Features The Purposes of making OPSCO’s customers and users to have a clear understanding on the ways how to use the LED. 2. Description Generally. The LED can be used the same way as other general purposed semiconductors. When using OPSCO’s TOP SMD LED, the following precautions must be taken to protect the LED. 3. Cautions 3.1. Dust & Cleaning This emitter has a silicone surface, There are many benefits to the silicone surface in terms of optical properties and improved reliability. However, silicone is a softer material and prone to attract dust. While a minimal amount of dust and debris on the LED will not cause significant reduction in illumination, steps should be taken to keep the emitter free of dust. These include keeping the LEDs in the manufacturer’s package prior to assembly and storing assemblies in an enclosed area after installing the emitters. Surface condition of this device may change when organic solvents such as trichloroethylene or acetone were applied. Avoid using organic solvent, it is recommended that isopropyl be used as a solvent for cleaning the LEDs. When using other solvents, it should be confirmed beforehand whether the solvents will dissolve the package and the resin of not. Do not clean the LEDs by the ultrasonic. When it is absolutely necessary, the influence as ultrasonic cleaning on the LEDs depends on factors such as ultrasonic power. Baking time and assembled condition. Before cleaning, a pre-test should be done to confirm whether any damage to the LEDs will occur. 3.2. Shipment and storage TOP SMD LED is a humidity sensor, the LED packaging in the aluminum bag is to avoid the LED in the transport and storage of moisture absorption, in the bag with a desiccant to absorb the moisture inside the bag. If the LED absorbs water vapor, then in the LED over reflow, in the high temperature state, into which the rapid expansion of gas vaporization and produce a greater internal stress, so that the material crack, layered or damaged bonding wire , Resulting in product failure. TOP SMD LED with a moisture-proof anti-static aluminum foil bag packaging, handling should avoid the process of squeezing, piercing the case of bags, and do the necessary anti-static protective measures; promise products on the line before the leak or broken, Please stop the use of direct use of the product; , Resulting in product failure; Such as before the material has been found to prevent moisture-proof aluminum foil bags have been opened, damaged, perforated can be returned to the original re-dehumidification, must not be on-line use; The humidity level of this product is LEVEL5a. 13 / 18 Document No.: SPC / SK6812MINI-E Rev. No.: 02 东莞市欧思科光电科技有限公司 DONGGUAN OPSCO OPTOELECTRONICS CO., LTD Factory : Lianxing industrial park, xiajie village, Qishi Town, Dongguan City. guangdong province, China Dongguan Tel: (769)82632725 Dongguan Fax: (769)82632735 Chart 1:Definition of material’s MSL prescribed by IPC/JEDECJ-STD-020E Workshop lifespan after open the packaging Moisture proof Time condition LEVEL1 unlimited ≦30℃/85 % RH LEVEL2 1 year ≦30℃/60 % RH Weeks ≦30℃/60 % RH LEVEL3 168 Hours ≦30℃/60 % RH LEVEL4 72 Hours ≦30℃/60 % RH LEVEL5 48 Hours ≦30℃/60 % RH LEVEL5a 24 Hours ≦30℃/60 % RH LEVEL6 Take off and use immediately ≦30℃/60 % RH LEVEL2a 4 3.3. Storage before unsealing In order to avoid the moisture barrier caused by the reliability of the failure problem, need to do LED products SMT prestorage and moisture-proof measures; If the moisture-proof bag is not open, the TOP SMD element will be stored for less than 2 months at
很抱歉,暂时无法提供与“4960”相匹配的价格&库存,您可以联系我们找货
