LSF0102GSX
LSF0102GSX
    NEXPERIA(安世)
    XSON8_1.35X1MM
    LSF0102GSX
LSF0102GSX 数据手册
LSF0102 2-bit bidirectional multi-voltage level translator; open-drain; push-pull Rev. 3 — 4 September 2020 Product data sheet 1. General description The LSF0102 is a 2 channel bidirectional multi-voltage level translator for open-drain and push-pull applications. It supports up to 100 MHz up translation and ≥100 MHz down translation at ≤ 30 pF capacitive load. There is no need for a direction pin which minimizes system effort. The LSF0102 supports 5 V tolerant I/O pins for compatibility with TTL levels in a variety of applications. The ability to set up different voltage translation levels on each channel makes the device very flexible and suitable for a lot of different applications. 2. Features and benefits • • • • • • • • • • • • • Bidirectional voltage translation with no direction pin Up translation • ≤ 100 MHz; CL = 30 pF • ≤ 40 MHz; CL = 50 pF Down translation • ≥ 100 MHz; CL = 30 pF • ≤ 40 MHz; CL = 50 pF Hot insertion Bidirectional voltage level translation between: • 0.95 V and 1.8 V, 2.5 V, 3.3 V and 5.0 V • 1.2 V and 1.8 V, 2.5 V, 3.3 V and 5.0 V • 1.8 V and 2.5 V, 3.3 V and 5.0 V • 2.5 V and 3.3 V and 5.0 V • 3.3 V and 5.0 V Low standby current 5 V tolerant I/O pins to support TTL Low RON provides less signal distortion High-impedance I/O pins for EN = Low. Flow-through pinout for easy PCB trace routing. Latch-up performance exceeds 100 mA per JESD78 class II level A ESD protection: • HBM ANSI/ESDA/JEDEC JS-001 Class 2 exceeds 2000 V • CDM ANSI/ESDA/JEDEC JS-002 Class C3 exceeds 1000 V Specified from -40 °C to +125 °C 3. Applications • • • 2 GPIO, MDIO, PMBus, SMBus, SDIO, UART, I C, and other interfaces in Telecom infrastructure Industrial Personal computing LSF0102 Nexperia 2-bit bidirectional multi-voltage level translator; open-drain; push-pull 4. Ordering information Table 1. Ordering information Type number Package Temperature range Name Description Version LSF0102DP -40 °C to +125 °C TSSOP8 plastic thin shrink small outline package; 8 leads; body width 3 mm; lead length 0.5 mm SOT505-2 LSF0102DC -40 °C to +125 °C VSSOP8 plastic very thin shrink small outline package; 8 leads; body width 2.3 mm SOT765-1 LSF0102GS -40 °C to +125 °C XSON8 extremely thin small outline package; no leads; 8 terminals; body 1.35 × 1.0 × 0.35 mm SOT1203 LSF0102GX -40 °C to +125 °C X2SON8 plastic thermal enhanced extremely thin small outline package; no leads; 8 terminals; body 1.35 × 0.8 × 0.32 mm SOT1233-2 5. Marking Table 2. Marking Type number Marking code[1] LSF0102DP h2 LSF0102DC h2 LSF0102GS h2 LSF0102GX h2 [1] The pin 1 indicator is located on the lower left corner of the device, below the marking code. 6. Functional diagram refA A1 B1 A2 B2 EN Fig. 1. refB aaa-031132 Logic symbol LSF0102 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 4 September 2020 © Nexperia B.V. 2020. All rights reserved 2 / 15 LSF0102 Nexperia 2-bit bidirectional multi-voltage level translator; open-drain; push-pull 7. Pinning information 7.1. Pinning LSF0102 LSF0102 GND 1 8 EN refA 2 7 refB A1 3 6 B1 A2 4 5 B2 GND 1 8 EN refA 2 7 refB A1 3 6 B1 A2 4 5 B2 aaa-031134 aaa-031133 Fig. 2. Transparent top view Pin configuration SOT505-2 (TSSOP8) and SOT765-1 (VSSOP8) Fig. 3. Pin configuration SOT1203 (XSON8) LSF0102 GND 1 7 refB 6 B1 5 B2 8 EN refA 2 4 A2 A1 3 aaa-031135 Transparent top view Fig. 4. Pin configuration SOT1233-2 (X2SON8) 7.2. Pin description Table 3. Pin description Symbol Pin Description GND 1 ground (0 V) refA 2 reference voltage A A1, A2 3, 4 data input/output A B1, B2 6, 5 data input/output B refB 7 reference voltage B EN 8 enable input (active HIGH) LSF0102 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 4 September 2020 © Nexperia B.V. 2020. All rights reserved 3 / 15 LSF0102 Nexperia 2-bit bidirectional multi-voltage level translator; open-drain; push-pull 8. Functional description Table 4. Function table H = HIGH voltage level; L = LOW voltage level; Z = high-impedance OFF-state. Input input/output EN An, Bn channel H An = Bn L Z 9. Limiting values Table 5. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V). Symbol Parameter Conditions VI input voltage pins refA, refB, An, Bn and EN II/O input/ouput current pins refA, refB, An and Bn; continuous channel current IIK input clamping current VI < 0 V Tstg storage temperature Ptot total power dissipation [1] [2] Tamb = -40 °C to +125 °C [1] [2] Min Max Unit -0.5 +7.0 V - +128 mA -50 - mA -65 +150 °C - 250 mW The minimum input voltage rating may be exceeded if the input current rating is observed. For SOT505-2 (TSSOP8) package: Ptot derates linearly with 4.6 mW/K above 96 °C. For SOT765-1 (VSSOP8) package: Ptot derates linearly with 4.9 mW/K above 99 °C. For SOT1203 (XSON8) package: Ptot derates linearly with 3.6 mW/K above 81 °C. For SOT1233-2 (X2SON8) package: Ptot derates linearly with 7.7 mW/K above 118 °C. 10. Recommended operating conditions Table 6. Recommended operating conditions Symbol Parameter Conditions Min VI input voltage pins refA, refB, An, Bn and EN II/O input/ouput current pins refA, refB, An and Bn; continuous channel current Tamb ambient temperature LSF0102 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 4 September 2020 Max Unit 0.0 5.0 V - +64 mA -40 +125 °C © Nexperia B.V. 2020. All rights reserved 4 / 15 LSF0102 Nexperia 2-bit bidirectional multi-voltage level translator; open-drain; push-pull 11. Static characteristics Table 7. Static characteristics At recommended operating conditions voltages are referenced to GND (ground = 0 V). Symbol Parameter Conditions Tamb = -40 °C to +125 °C Unit Min Typ[1] Max -1.2 - - V VIK input clamping voltage VEN = 0 V; II = -18 mA II leakage current pins An, Bn, refA, refB and EN; VI = GND to 5.0 V - 1 5 μA CI input capacitance pins refA, refB and EN; VI = 0 V or 3 V - 6 - pF Cio(off) OFF-state input/output pins An, Bn; VO = 0 V or 3 V; VEN = 0.0 V capacitance - 3 6.0 pF Cio(on) ON-state input/output capacitance pins An, Bn; VO = 0 V or 3 V; VEN = 3.0 V - 6 12.5 pF RON ON resistance see Fig. 5 VrefA = 3.3 V - 3 - Ω VrefA = 1.8 V - 4 - Ω VrefA = 1.0 V - 7 - Ω VrefA = 1.8 V - 4 - Ω VrefA = 2.5 V - 3 - Ω - 4 - Ω - 7 - Ω - 5 - Ω - 6 - Ω [2] VI = 0 V; Vpu = 5.0 V; IO = 64 mA VI = 0 V; Vpu = 5.0 V; IO = 32mA VI = 1.8 V; Vpu = 5.0 V; IO = 15 mA VrefA = 3.3 V VI = 1.0 V; Vpu = 3.3 V; IO = 10 mA VrefA = 1.8 V VI = 0 V; Vpu = 3.3 V; IO = 10 mA VrefA = 1.0 V VI = 0 V; Vpu = 1.8 V; IO = 10 mA VrefA = 1.0 V [1] [2] All typical values are measured at Tamb = 25 °C. Measured by the voltage drop between the An and Bn pins at the indicated current through the switch. ON resistance is determined by the lowest voltage of the two (An or Bn) pins. Rpu Vpu EN refA refB VrefA CEN An VI Bn IO LSF0102 aaa-031136 Rpu = 200 kΩ; CEN = 100 nF (The An and Bn pins may be exchanged.) Fig. 5. Test circuit for measuring RON LSF0102 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 4 September 2020 © Nexperia B.V. 2020. All rights reserved 5 / 15 LSF0102 Nexperia 2-bit bidirectional multi-voltage level translator; open-drain; push-pull 12. Dynamic characteristics Table 8. Switching characteristics GND = 0 V; for waveform see Fig. 6; for test circuit see Fig. 7 Symbol Parameter Conditions Tamb = -40 °C to +125 °C Unit Min Typ[1] Max VrefA = 1.5 V; CL = 15 pF - 0.35 - ns VrefA = 1.5 V; CL = 30 pF - 0.8 - ns VrefA = 1.5 V; CL = 50 pF - 1.2 - ns VrefA = 2.3 V; CL = 15 pF - 0.3 - ns VrefA = 2.3 V; CL = 30 pF - 0.7 - ns VrefA = 2.3 V; CL = 50 pF - 1.1 - ns VrefA = 1.5 V; CL = 15 pF - 0.5 - ns VrefA = 1.5 V; CL = 30 pF - 1.0 - ns VrefA = 1.5 V; CL = 50 pF - 1.3 - ns VrefA = 2.3 V; CL = 15 pF - 0.4 - ns VrefA = 2.3 V; CL = 30 pF - 0.8 - ns VrefA = 2.3 V; CL = 50 pF - 1.2 - ns VrefA = 1.5 V; CL = 15 pF - 0.5 - ns VrefA = 1.5 V; CL = 30 pF - 0.9 - ns VrefA = 1.5 V; CL = 50 pF - 1.1 - ns VrefA = 2.3 V; CL = 15 pF - 0.4 - ns VrefA = 2.3 V; CL = 30 pF - 0.8 - ns VrefA = 2.3 V; CL = 50 pF - 1.0 - ns VrefA = 1.5 V; CL = 15 pF - 0.6 - ns VrefA = 1.5 V; CL = 30 pF - 1.1 - ns VrefA = 1.5 V; CL = 50 pF - 1.3 - ns VrefA = 2.3 V; CL = 15 pF - 0.4 - ns VrefA = 2.3 V; CL = 30 pF - 0.9 - ns VrefA = 2.3 V; CL = 50 pF - 1.0 - ns Translating down An to Bn or Bn to An; LOW to HIGH propagation delay V = V = V IH pu refA + 1 V tPLH An to Bn or Bn to An; HIGH to LOW propagation delay V = V = V IH pu refA + 1 V tPHL Translating up An to Bn or Bn to An; LOW to HIGH propagation delay V = V ; V IH refA EXT = Vpu = VrefA + 1 V tPLH An to Bn or Bn to An; HIGH to LOW propagation delay V = V ; V IH refA EXT = Vpu = VrefA + 1 V tPHL [1] All typical values are measured at Tamb = 25 °C. LSF0102 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 4 September 2020 © Nexperia B.V. 2020. All rights reserved 6 / 15 LSF0102 Nexperia 2-bit bidirectional multi-voltage level translator; open-drain; push-pull 12.1. Waveforms and test circuit VIH input An, Bn VM VM VIL tPHL tPLH VOH VM output Bn, An VM VOL aaa-030284 Measurement points are given in Table 9. Logic levels: VOL and VOH are typical output voltage levels that occur with the output load. Fig. 6. The data input (An, Bn) to output (Bn, An) propagation delay times VIH negative pulse 90 % 90 % 10 % 0V 10 % tf tr VIH positive pulse 0V tr tf 90 % 90 % 10 % 10 % aaa-030285 VI source waveform Rpu Vpu EN refA up/down translating switch Translating up S1 Translating down S2 refB VrefA VEXT CEN RL An Bn VO S1 S2 VI LSF0102 CL 1 MΩ aaa-031137 Test circuit Test data is given in Table 9. The An and Bn pins may be exchanged. All input pulses are supplied by generators having the following characteristics: PRR ≤ 10 MHz; ZO = 50 Ω. Definitions test circuit: CL = Load capacitance including jig and probe capacitance; CEN = Decoupling capacitance; Rpu = Pull-up resistance; RL = Load resistance; S1/S2 = Test selection switch Fig. 7. Test circuit for measuring switching times LSF0102 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 4 September 2020 © Nexperia B.V. 2020. All rights reserved 7 / 15 LSF0102 Nexperia 2-bit bidirectional multi-voltage level translator; open-drain; push-pull Table 9. Test data Input Output Load tr, tf VM VM CL CEN [1] RL [1] Rpu ≤ 2 ns 0.5VrefA 0.5VrefA 15 pF, 30 pF, 50 pF 100 nF 300 Ω 200 kΩ [1] All typical values are measured at Tamb = 25 °C. LSF0102 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 4 September 2020 © Nexperia B.V. 2020. All rights reserved 8 / 15 LSF0102 Nexperia 2-bit bidirectional multi-voltage level translator; open-drain; push-pull 13. Package outline TSSOP8: plastic thin shrink small outline package; 8 leads; body width 3 mm; lead length 0.5 mm D E A SOT505-2 X c HE y v M A Z 5 8 A A2 pin 1 index (A3) A1 θ Lp L 1 4 e detail X w M bp 0 2.5 5 mm scale DIMENSIONS (mm are the original dimensions) UNIT A max. A1 A2 A3 bp c D(1) E(1) e HE L Lp v w y Z(1) θ mm 1.1 0.15 0.00 0.95 0.75 0.25 0.38 0.22 0.18 0.08 3.1 2.9 3.1 2.9 0.65 4.1 3.9 0.5 0.47 0.33 0.2 0.13 0.1 0.70 0.35 8° 0° Note 1. Plastic or metal protrusions of 0.15 mm maximum per side are not included. OUTLINE VERSION SOT505-2 Fig. 8. REFERENCES IEC JEDEC JEITA EUROPEAN PROJECTION ISSUE DATE 02-01-16 --- Package outline SOT505-2 (TSSOP8) LSF0102 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 4 September 2020 © Nexperia B.V. 2020. All rights reserved 9 / 15 LSF0102 Nexperia 2-bit bidirectional multi-voltage level translator; open-drain; push-pull VSSOP8: plastic very thin shrink small outline package; 8 leads; body width 2.3 mm D SOT765-1 E A X c y HE v A Z 5 8 Q A A2 A1 pin 1 index (A3) θ Lp 1 detail X 4 e L w bp 0 5 mm scale Dimensions (mm are the original dimensions) Unit mm A max. max nom min 1 A1 A2 0.15 0.85 0.00 0.60 A3 0.12 D(1) E(2) 0.27 0.23 2.1 2.4 0.17 0.08 1.9 2.2 bp c e HE 0.5 3.2 3.0 L 0.4 Lp Q 0.40 0.21 0.15 0.19 v w y 0.2 0.08 0.1 Z(1) θ 0.4 8° 0.1 0° Note 1. Plastic or metal protrusions of 0.15 mm maximum per side are not included. 2. Plastic or metal protrusions of 0.25 mm maximum per side are not included. Outline version SOT765-1 Fig. 9. References IEC JEDEC JEITA sot765-1_po European projection Issue date 07-06-02 16-05-31 MO-187 Package outline SOT765-1 (VSSOP8) LSF0102 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 4 September 2020 © Nexperia B.V. 2020. All rights reserved 10 / 15 LSF0102 Nexperia 2-bit bidirectional multi-voltage level translator; open-drain; push-pull XSON8: extremely thin small outline package; no leads; 8 terminals; body 1.35 x 1.0 x 0.35 mm SOT1203 b 1 2 3 (4×)(2) 4 L L1 e 8 7 6 e1 e1 5 e1 (8×)(2) A1 A D E terminal 1 index area 0 0.5 Dimensions Unit mm 1 mm scale A(1) A1 b D E e e1 L L1 max 0.35 0.04 0.20 1.40 1.05 0.35 0.40 nom 0.15 1.35 1.00 0.55 0.35 0.30 0.35 min 0.12 1.30 0.95 0.27 0.32 Note 1. Including plating thickness. 2. Visible depending upon used manufacturing technology. Outline version sot1203_po References IEC JEDEC JEITA European projection Issue date 10-04-02 10-04-06 SOT1203 Fig. 10. Package outline SOT1203 (XSON8) LSF0102 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 4 September 2020 © Nexperia B.V. 2020. All rights reserved 11 / 15 LSF0102 Nexperia 2-bit bidirectional multi-voltage level translator; open-drain; push-pull X2SON8: plastic thermal enhanced extremely thin small outline package; no leads; 8 terminals; body 1.35 x 0.8 x 0.32 mm SOT1233-2 C Seating Plane X y C A B D E A A3 2x pin 1 index area 2x e A1 detail X u C e 1 pin 1 index area u C b (6x) 2 8 v w 3 y1 C C A B C 4 Dh L (6x) 7 6 5 b1 (6x) e1 0 1 mm scale Dimensions (mm are the original dimensions) Unit mm A max 0.35 nom 0.32 min 0.30 A1 A3 b b1 D Dh E e e1 L u v w y y1 0.04 0.25 0.27 0.27 0.10 0.11 0.02 0.20 1.35 0.22 0.80 0.50 0.54 0.22 0.05 0.10 0.05 0.05 0.05 (Typ.) (ref) 0.00 0.15 0.17 0.17 sot1233-2_po Outline version SOT1233-2 References IEC JEDEC JEITA European projection Issue date 19-11-12 --- Fig. 11. Package outline SOT1233-2 (X2SON8) LSF0102 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 4 September 2020 © Nexperia B.V. 2020. All rights reserved 12 / 15 LSF0102 Nexperia 2-bit bidirectional multi-voltage level translator; open-drain; push-pull 14. Abbreviations Table 10. Abbreviations Acronym Description CDM Charged Device Model ESD ElectroStatic Discharge HBM Human Body Model TTL Transistor-Transistor Logic 15. Revision history Table 11. Revision history Document ID Release date Data sheet status Change notice Supersedes LSF0102 v.3 20200904 Product data sheet - Modifications: • LSF0102 v.2 20200818 Modifications: • • LSF0102 v.1 LSF0102 Product data sheet LSF0102 v.2 Type number LSF0102DC (SOT765-1/VSSOP8) added. Product data sheet - LSF0102 v.1 LSF0102GS (SOT1203/XSON8) and LSF0102GX (SOT1233-2/X2SON8) are in production. Removed note from ordering information . Type number LSF0102DC (SOT765-1/VSSOP8) is in development and removed from this product data sheet. A preliminary data sheet is available upon request. 20200414 Product data sheet - All information provided in this document is subject to legal disclaimers. Rev. 3 — 4 September 2020 - © Nexperia B.V. 2020. All rights reserved 13 / 15 LSF0102 Nexperia 2-bit bidirectional multi-voltage level translator; open-drain; push-pull 16. Legal information injury, death or severe property or environmental damage. Nexperia and its suppliers accept no liability for inclusion and/or use of Nexperia products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Data sheet status Quick reference data — The Quick reference data is an extract of the product data given in the Limiting values and Characteristics sections of this document, and as such is not complete, exhaustive or legally binding. Document status [1][2] Product status [3] Definition Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] [2] [3] Please consult the most recently issued document before initiating or completing a design. The term 'short data sheet' is explained in section "Definitions". The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the internet at https://www.nexperia.com. Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Nexperia sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between Nexperia and its customer, unless Nexperia and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the Nexperia product is deemed to offer functions and qualities beyond those described in the Product data sheet. Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, Nexperia does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Nexperia takes no responsibility for the content in this document if provided by an information source outside of Nexperia. In no event shall Nexperia be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation - lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Notwithstanding any damages that customer might incur for any reason whatsoever, Nexperia’s aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of Nexperia. Right to make changes — Nexperia reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. Suitability for use — Nexperia products are not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical systems or equipment, nor in applications where failure or malfunction of an Nexperia product can reasonably be expected to result in personal LSF0102 Product data sheet Applications — Applications that are described herein for any of these products are for illustrative purposes only. Nexperia makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using Nexperia products, and Nexperia accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the Nexperia product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. Nexperia does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using Nexperia products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). Nexperia does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — Nexperia products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nexperia.com/profile/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Nexperia hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Nexperia products by customer. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from competent authorities. Non-automotive qualified products — Unless this data sheet expressly states that this specific Nexperia product is automotive qualified, the product is not suitable for automotive use. It is neither qualified nor tested in accordance with automotive testing or application requirements. Nexperia accepts no liability for inclusion and/or use of non-automotive qualified products in automotive equipment or applications. In the event that customer uses the product for design-in and use in automotive applications to automotive specifications and standards, customer (a) shall use the product without Nexperia’s warranty of the product for such automotive applications, use and specifications, and (b) whenever customer uses the product for automotive applications beyond Nexperia’s specifications such use shall be solely at customer’s own risk, and (c) customer fully indemnifies Nexperia for any liability, damages or failed product claims resulting from customer design and use of the product for automotive applications beyond Nexperia’s standard warranty and Nexperia’s product specifications. Translations — A non-English (translated) version of a document is for reference only. The English version shall prevail in case of any discrepancy between the translated and English versions. Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. All information provided in this document is subject to legal disclaimers. Rev. 3 — 4 September 2020 © Nexperia B.V. 2020. All rights reserved 14 / 15 LSF0102 Nexperia 2-bit bidirectional multi-voltage level translator; open-drain; push-pull Contents 1. General description...................................................... 1 2. Features and benefits.................................................. 1 3. Applications.................................................................. 1 4. Ordering information....................................................2 5. Marking.......................................................................... 2 6. Functional diagram.......................................................2 7. Pinning information......................................................3 7.1. Pinning.........................................................................3 7.2. Pin description............................................................. 3 8. Functional description................................................. 4 9. Limiting values............................................................. 4 10. Recommended operating conditions........................4 11. Static characteristics..................................................5 12. Dynamic characteristics............................................ 6 12.1. Waveforms and test circuit........................................ 7 13. Package outline.......................................................... 9 14. Abbreviations............................................................ 13 15. Revision history........................................................13 16. Legal information......................................................14 © Nexperia B.V. 2020. All rights reserved For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 4 September 2020 LSF0102 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 4 September 2020 © Nexperia B.V. 2020. All rights reserved 15 / 15
LSF0102GSX 价格&库存
很抱歉,暂时无法提供与“LSF0102GSX”相匹配的价格&库存,您可以联系我们找货
