UMW
R
UMW XC6219
■ Product introducti on
XC6219 series is a high precision, low noise and fast response low dropout linear voltage
regulator manufactured by CMOS process. This series of voltage regulators has built - in fixed reference
voltage, error correction circu it, current limiting circuit, phase compensation circuit and MOSFET
with low internal resistance, which achieves high ripple suppression, low output noise and quick
response to low dropout.
XC6219 series is compatible with ceramic capacitors with smaller volume than tantalum capacitors,
and does not need to use 0.1 μF By- pass capacitors, which can save space and reduce cost. Because of
its high - precision output stability and fast transient response, it can cope with the fluctuation of
load current, so it is especially suitable for handheld devices and RF products.
By controlling the CE pin on the chip, the output can be turned off, and the static current
after turning off the output is only 0.1uA(Typ value), thus greatly reducing the power
consumption.
■ Product features
High precision output voltage:
2.0%;
Selectable output voltage:
1.8V~5.0V;
Very low static current
(Typ.=15μ A);
Very low turn - off current
(Typ.=0.1 μ A);
Good input stability:
Typ.=0.2%/V;
Strong carrying capacity: when Vin=4.3V and
Vout=3.3V, Iout=300mA
Built - in overcurrent protection and load short
circuit protection;
Compatible ceramic capacitor;
Package form: SOT89-5, SOT23- 5
■ product usage
Smart phone/mobile phone
Digital
Bluetooth and other RF products
Portable consumer equipment
camera/video camera
Battery powered equipment
■ Package form and pin definition function
Pin serial
number
Pin
function
MR
PR
on
definiti
declaration
package package
serial
SOT23-3 Pin
SOT89-3
number
Pin
Input
function
1
4
MR
PR VIN
nition
declaratio
n
2
2 package VSS
Grounding terminal
package
3 SOT23-33 SOT89-3 CE
Enable side
empty
4
1
NC
5
5
VOUT
Output
www.umw-ic.com
1
UTD Semiconductor Co.,Limited
semiconductor co.,
ltd
UMW
R
UMW XC6219
functional block diagram
Limit parameter
project
voltage
elect ric current
symbol
explain
Vin
input
voltage
9
V
Vout
Output
voltage
output
current
Vss-0.3 ~ Vin+0.3
V
500
mA
Iout
SOT23-5
Power Consumption
PD
TOPR
Temperature
Tstg
Tsolder
SOT89-5
Maximum allowable
power consumption
Working
temperature
Storage
temperature
welding
temperature
limit value
200
unit
mW
300
- 20~ +60
- 40~ +125
260℃,10s
Note: The limit parameter refers to the limit value that can't be exceeded under any conditions. If it exceeds
this limit value, it may cause physical damage such as product deterioration; At the same time, when the
parameters are close to the limit, the chip can't work normally.
Typical application
www.umw-ic.com
2
UMW
R
UMW XC6219
Electrical characteristics
XC6219 VOUT(T)=3.3V
O
(Ci=Co=10uF,Ta=25 C unless otherwise specified)
trait
symbol
Output voltage
VOUT(E)
IOUT (max)
Maximum output
current
∆VOUT
Load stability
∆VOUT/(∆VIN
Input
stability
•VOUT)
Drop pressure
difference
quiescent
current
CE input
voltage
VCE=1.6V
VIN=4.3V
typical
value
maximum
unit
3.24
3.300
3.360
V
VIN=VCE=4.3V,
1mA≤IOUT≤100mA
IOUT =10mA,
4.3V≤VIN≤7V
VIN=4.3V,IOUT=10mA
Vdrop2
VIN=4.3V,IOUT =100mA
ISS1
VIN=VCE=5V
ISS2
VIN=5V,VCE=VSS
mA
12
mV
0.2
%/V
35
mV
280
mV
15
μA
0.5
μA
VCEH
1.6
VIN
V
VCEL
V
0.5
μA
ICE
Ripple
suppression
ratio
PSRR
∆VOUT/(∆Ta
•VOUT)
VCE=0V to VIN
VIN=VCE=4.3V+1Vp-pAC
IOUT=10mA,f=1kHz
40
dB
±290
ppm/℃
VIN=VCE=4.3V,
IOUT=3.3mA
0℃≤Ta≤60℃
VIN
input voltage
minimum
value
300
Vdrop1
CE input
current
Output
voltage
temperatu re
coefficie nt
test
condition
IOUT=1mA,VIN=5V,
1.8
7
V
Note:
1. V OUT (T): the specified output voltage.
2. V OUT (E): effective output voltage.
3. I OUT (max): slowly increase the output current, and the current value when the output voltage is
≤ VOUT(E)*95%.
4? Vdrop = V
IN1
–VOUT (E)s
VIN1= gradually reduce the input voltage, and the input voltage when the output voltage drops to 98%
of V OUT(E)1.
VOUT (E)s = VOUT (E)1*98%
VOUTE)1= the output voltage value when V IN= VOUTT)+1V and I out = a certain value.
www.umw-ic.com
3
UTD Semiconductor
Co.,Limited
semiconductor
co.,
ltd
UMW
R
UMW XC6219
■ Characteristic curve (3.3V output)
1. Output voltage and output current
2. Output voltage and input voltage
3. Dropout voltage and output current
4. Input voltage and static current
5. Ripple suppression
6. Output voltage and temperature
www.umw-ic.com
4
semiconductor co.,
ltd
UMW
R
UMW XC6219
■ Package Information
SOT23-5
www.umw-ic.com
5
UMW
R
UMW XC6219
SOT89-5
www.umw-ic.com
6
很抱歉,暂时无法提供与“XC6219B332MR”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+3.070151+0.37137
- 10+2.5121310+0.30387
- 25+2.2988825+0.27808
- 100+1.71150100+0.20703
- 250+1.55142250+0.18766
- 500+1.28386500+0.15530
- 1000+0.962861000+0.11647
- 国内价格 香港价格
- 3000+0.882623000+0.10677
- 6000+0.829126000+0.10029
- 15000+0.7756415000+0.09383
- 30000+0.7114530000+0.08606
- 75000+0.6847075000+0.08283
