UPGRADE
DVN
ELECTRICDOUBLE
DOUBLELAYER
LAYERCAPACITORS
CAPACITORS
“DYNACAP”
ELECTRIC
“DYNACAP”
5.5V SMD, Low Resistance Capacitors
GREEN
CAP
70°C
Size : φ12.5×8.5mm, compatible with surface mounting and low ESR.
Unlike batteries, safe and high reliability without containing active and
hazardous substance.
Unlike batteries, excellent charge and discharge characteristics with no
chemical reactions.
Responds to temperature 260℃ during the reflow peek.
Marking color : White print on an brown sleeve
Convert to chip
DBN
DVN
Specifications
Item
Performance
Category temperature range (℃)
ー 25 to +70
Tolerance at rated capacitance (%)
ー 20 to +80
Internal resistance
at 1 kHz
Rated capacitance (F)
0.047
0.1
0.22
0.33
Internal resistance (Ω Max.)
30
30
30
30
Characteristics at high
and low temperature
Percentage of capacitance change
Endurance (70℃)
Within ±30% of the value at 20℃
Less than five times of the value at 20℃
Internal resistance
1000 hours
Test time
Within ±30% of the initial measured value
Less than four times of the initial specified value
Internal resistance
Shelf life (70℃)
Test time : 1000 hours ; Same as endurance.
Applicable standards
Conforms to JIS C5160-1 2009 (IEC 62391-1 2006)
Outline Drawing
Recommended land pattern size
Unit : mm
3.2
6.0
4.0
(5.0) (5.0) (5.0)
φD±0.5
6.0
0.7±0.3
13±0.2
13±0.2
0.3 Max
Unit : mm
L Max
(1.2)
Part numbering system (example : 5.5V0.1F)
DVN
Series code
5R5
D
104
Max. operating voltage
symbol
Terminal
code
Rated capacitance
symbol
T ̶
R5
Taping
symbol
Part number is refer to following table.
Standard Ratings
5.5
0.047
DVN-5R5D473T-R5
12.5×8.5
5.5
0.1
DVN-5R5D104T-R5
12.5×8.5
5.5
0.22
DVN-5R5D224T-R5
12.5×8.5
5.5
0.33
DVN-5R5D334T-R5
12.5×8.5
EDLC
Max. operating voltage (V)
*soldering
ELNA Parts No.
φD×L (mm)
conditions are described on page 191.
CAT.No.2015/2016E
196
NOTE : Design, Specifications are subject to change without notice.
It is recommended that you shall obtain technical specifications
from ELNA to ensure that the component is suitable for your use.
很抱歉,暂时无法提供与“RSCVN4735R5G08012T”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 300+12.18354300+1.47424
- 600+10.82976600+1.31043
- 900+10.15295900+1.22853
- 1500+9.476101500+1.14663
- 2100+9.137662100+1.10568
- 7500+8.799247500+1.06473
- 国内价格 香港价格
- 1+52.708381+6.37784
- 10+45.3086410+5.48246
- 50+41.0917650+4.97221
- 100+33.92693100+4.10524
