74AHCT594PW118
74AHCT594PW118
    NEXPERIA(安世)
    74AHCT594PW118
74AHCT594PW118 数据手册
74AHC594; 74AHCT594 8-bit shift register with output register Rev. 4 — 7 July 2021 Product data sheet 1. General description The 74AHC594; 74AHCT594 is a high-speed Si-gate CMOS device and is pin compatible with Low-Power Schottky TTL (LSTTL). It is specified in compliance with JEDEC standard No. 7-A. The 74AHC594; 74AHCT594 is an 8-bit, non-inverting, serial-in, parallel-out shift register that feeds an 8-bit D-type storage register. Separate clocks (SHCP and STCP) and direct overriding clears (SHR and STR) are provided on both the shift and storage registers. A serial output (Q7S) is provided for cascading purposes. Both the shift and storage register clocks are positive-edge triggered. If the user wishes to connect both clocks together, the shift register will always be one count pulse ahead of the storage register. 2. Features and benefits • • • • • • • • • • • • • • Wide supply voltage range from 2.0 V to 5.5 V Balanced propagation delays All inputs have Schmitt-trigger action Overvoltage tolerant inputs to 5.5 V High noise immunity CMOS low power dissipation 8-bit serial-in, parallel-out shift register with storage Independent direct overriding clears on shift and storage registers Independent clocks for shift and storage registers Latch-up performance exceeds 100 mA per JESD 78 Class II Level A Input levels: • For 74AHC594: CMOS level • For 74AHCT594: TTL level ESD protection: • HBM JESD22-A114F exceeds 2000 V • MM JESD22-A115-A exceeds 200 V • CDM JESD22-C101E exceeds 1000 V Multiple package options Specified from -40 °C to +85 °C and from -40 °C to +125 °C 3. Applications • • Serial-to parallel data conversion Remote control holding register 74AHC594; 74AHCT594 Nexperia 8-bit shift register with output register 4. Ordering information Table 1. Ordering information Type number Package 74AHC594D Temperature range Name Description Version -40 °C to +125 °C SO16 plastic small outline package; 16 leads; body width 3.9 mm SOT109-1 -40 °C to +125 °C TSSOP16 plastic thin shrink small outline package; 16 leads; body width 4.4 mm SOT403-1 -40 °C to +125 °C DHVQFN16 plastic dual in-line compatible thermal enhanced SOT763-1 very thin quad flat package; no leads; 16 terminals; body 2.5 × 3.5 × 0.85 mm 74AHCT594D 74AHC594PW 74AHCT594PW 74AHC594BQ 74AHCT594BQ 5. Functional diagram 14 DS 11 SHCP 10 SHR 8-STAGE SHIFT REGISTER 9 12 STCP 13 STR 8-BIT STORAGE REGISTER 15 1 2 3 4 5 6 7 Q0 Q1 Q2 Q3 Q4 Q5 Q6 Q7 Fig. 1. mbc320 Functional diagram SHCP STCP 11 STR 12 9 DS Fig. 2. Q7S 74AHC_AHCT594 Product data sheet Q7S SHR R2 12 10 11 C2 R1 SRG8 15 Q0 1 Q1 2 Q2 3 Q3 2 4 Q4 3 5 Q5 4 6 Q6 7 Q7 14 Logic symbol STCP 13 10 13 SHR STR SHCP DS 14 C1/ 1D 15 2D 1 5 6 7 9 mbc319 Q0 Q1 Q2 Q3 Q4 Q5 Q6 Q7 Q7S mbc322 Fig. 3. IEC logic symbol All information provided in this document is subject to legal disclaimers. Rev. 4 — 7 July 2021 © Nexperia B.V. 2021. All rights reserved 2 / 20 74AHC594; 74AHCT594 Nexperia 8-bit shift register with output register STAGE 0 DS D STAGES 1 TO 6 Q D STAGE 7 Q D FFSH0 CP Q7S Q FFSH7 CP R R SHCP SHR D D Q FFST0 CP Q FFST7 CP R R STCP STR Q0 Fig. 4. Q1 Q2 Q3 Q4 Q5 Q6 Q7 mbc321 Logic diagram 6. Pinning information 6.1. Pinning 74AHC594 74AHCT594 Q1 1 16 VCC Q2 2 15 Q0 Q3 3 14 DS Q4 4 13 STR Q5 5 12 STCP Q6 6 11 SHCP Q7 7 10 SHR GND 8 9 Q7S 001aae343 Fig. 5. Pin configuration SOT109-1 (SO16) 74AHC_AHCT594 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 4 — 7 July 2021 © Nexperia B.V. 2021. All rights reserved 3 / 20 74AHC594; 74AHCT594 Nexperia 8-bit shift register with output register 1 Q1 terminal 1 index area 2 Q3 3 14 DS Q4 4 13 STR Q5 5 12 STCP Q6 6 11 SHCP Q7 7 10 SHR GND 8 9 3 14 DS Q4 4 13 STR Q5 5 12 STCP Q6 6 Q7 7 GND(1) 11 SHCP 10 SHR 001aae345 Transparent top view (1) This is not a ground pin. There is no electrical or mechanical requirement to solder the pad. In case soldered, the solder land should remain floating or connected to GND Q7S 001aae344 Fig. 6. Q3 9 Q2 16 VCC 15 Q0 15 Q0 Q7S 1 2 8 Q1 Q2 GND 74AHC594 74AHCT594 16 VCC 74AHC594 74AHCT594 Pin configuration SOT403-1 (TSSOP16) Fig. 7. Pin configuration SOT763-1 (DHVQFN16) 6.2. Pin description Table 2. Pin description Symbol Pin Description Q0, Q1, Q2, Q3, Q4, Q5, Q6, Q7 15, 1, 2, 3, 4, 5, 6, 7 parallel data output GND 8 ground (0 V) Q7S 9 serial data output SHR 10 shift register reset input (active LOW) SHCP 11 shift register clock input STCP 12 storage register clock input STR 13 storage register reset input (active LOW) DS 14 serial data input VCC 16 supply voltage 74AHC_AHCT594 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 4 — 7 July 2021 © Nexperia B.V. 2021. All rights reserved 4 / 20 74AHC594; 74AHCT594 Nexperia 8-bit shift register with output register 7. Functional description Table 3. Function table H = HIGH voltage state; L = LOW voltage state; ↑ = LOW to HIGH transition; X = don’t care; NC = no change. Input Output Function SHCP STCP SHR STR DS Q7S Qn X X L X X L NC a LOW-state on SHR only affects the shift register X X X L X NC L a LOW-state on STR only affects the storage register X ↑ L H X L L empty shift register loaded into storage register ↑ X H X H Q6S NC logic HIGH level shifted into shift register stage 0. Contents of all shift register stages shifted through, e.g. previous state of stage 6 (internal Q6S) appears on the serial output (Q7S). X ↑ H H X NC QnS contents of shift register stages (internal QnS) are transferred to the storage register and parallel output stages ↑ ↑ H H X Q6S QnS contents of shift register shifted through; previous contents of the shift register is transferred to the storage register and the parallel output stages SHCP DS STCP SHR STR Q0 Q1 Q6 Q7 Q7S mbc323 Fig. 8. Timing diagram 74AHC_AHCT594 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 4 — 7 July 2021 © Nexperia B.V. 2021. All rights reserved 5 / 20 74AHC594; 74AHCT594 Nexperia 8-bit shift register with output register 8. Limiting values Table 4. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V). Symbol Parameter VCC Min Max Unit supply voltage -0.5 +7.0 V VI input voltage -0.5 +7.0 V IIK input clamping current VI < -0.5 V [1] -20 - mA IOK output clamping current VO < -0.5 V or VO > VCC + 0.5 V [1] -20 +20 mA IO output current VO = -0.5 V to (VCC + 0.5 V) -25 +25 mA ICC supply current - +75 mA IGND ground current -75 - mA Tstg storage temperature -65 +150 °C Ptot total power dissipation - 500 mW [1] [2] Conditions Tamb = -40 °C to +125 °C [2] The input and output voltage ratings may be exceeded if the input and output current ratings are observed. For SOT109-1 (SO16) package: Ptot derates linearly with 12.4 mW/K above 110 °C. For SOT403-1 (TSSOP16) package: Ptot derates linearly with 8.5 mW/K above 91 °C. For SOT763-1 (DHVQFN16) package: Ptot derates linearly with 11.2 mW/K above 106 °C. 9. Recommended operating conditions Table 5. Operating conditions Symbol Parameter VCC supply voltage VI input voltage VO output voltage Tamb ambient temperature Δt/ΔV Conditions 74AHC594 74AHCT594 Unit Min Typ Max Min Typ Max 2.0 5.0 5.5 4.5 5.0 5.5 V 0 - 5.5 0 - 5.5 V VCC V 0 - VCC 0 - -40 +25 +125 -40 +25 input transition rise and fall rate VCC = 3.0 V to 3.6 V - - 100 - - - ns/V VCC = 4.5 V to 5.5 V - - 20 - - 20 ns/V 74AHC_AHCT594 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 4 — 7 July 2021 © +125 °C Nexperia B.V. 2021. All rights reserved 6 / 20 74AHC594; 74AHCT594 Nexperia 8-bit shift register with output register 10. Static characteristics Table 6. Static characteristics At recommended operating conditions; voltages are referenced to GND (ground = 0 V). Symbol Parameter Conditions 25 °C -40 °C to +85 °C -40 °C to +125 °C Unit Min Typ Max Min Max Min Max VCC = 2.0 V 1.5 - - 1.5 - 1.5 - V VCC = 3.0 V 2.1 - - 2.1 - 2.1 - V VCC = 5.5 V 3.85 - - 3.85 - 3.85 - V VCC = 2.0 V - - 0.5 - 0.5 - 0.5 V VCC = 3.0 V - - 0.9 - 0.9 - 0.9 V 74AHC594 VIH VIL VOH VOL HIGH-level input voltage LOW-level input voltage VCC = 5.5 V - - 1.65 - 1.65 - 1.65 V VI = VIH or VIL HIGH-level output voltage IO = -50 μA; VCC = 2.0 V 1.9 2.0 - 1.9 - 1.9 - V IO = -50 μA; VCC = 3.0 V 2.9 3.0 - 2.9 - 2.9 - V IO = -50 μA; VCC = 4.5 V 4.4 4.5 - 4.4 - 4.4 - V IO = -4.0 mA; VCC = 3.0 V 2.58 - - 2.48 - 2.40 - V IO = -8.0 mA; VCC = 4.5 V 3.94 - - 3.80 - 3.70 - V VI = VIH or VIL LOW-level output voltage IO = 50 μA; VCC = 2.0 V - 0 0.1 - 0.1 - 0.1 V IO = 50 μA; VCC = 3.0 V - 0 0.1 - 0.1 - 0.1 V IO = 50 μA; VCC = 4.5 V - 0 0.1 - 0.1 - 0.1 V IO = 4 mA; VCC = 3.0 V - - 0.36 - 0.44 - 0.55 V IO = 8 mA; VCC = 4.5 V - - 0.36 - 0.44 - 0.55 V - - 0.1 - 1.0 - 2.0 μA II input leakage current ICC supply current VI = VCC or GND; IO = 0 A; VCC = 5.5 V - - 4.0 - 40 - 80 μA CI input capacitance - 3 10 - 10 - 10 pF 74AHC_AHCT594 Product data sheet VI = 5.5 V or GND; VCC = 0 V to 5.5 V VI = VCC or GND All information provided in this document is subject to legal disclaimers. Rev. 4 — 7 July 2021 © Nexperia B.V. 2021. All rights reserved 7 / 20 74AHC594; 74AHCT594 Nexperia 8-bit shift register with output register Symbol Parameter Conditions 25 °C -40 °C to +85 °C -40 °C to +125 °C Unit Min Typ Max Min Max Min Max 74AHCT594 VIH HIGH-level input voltage VCC = 4.5 V to 5.5 V 2.0 - - 2.0 - 2.0 - V VIL LOW-level input voltage VCC = 4.5 V to 5.5 V - - 0.8 - 0.8 - 0.8 V VOH VI = VIH or VIL HIGH-level output voltage IO = -50 μA; VCC = 4.5 V 4.4 4.5 - 4.4 - 4.4 - V - - 3.80 - 3.70 - V IO = -8.0 mA; VCC = 4.5 V 3.94 VOL VI = VIH or VIL LOW-level output voltage IO = 50 μA; VCC = 4.5 V - 0 0.1 - 0.1 - 0.1 V IO = 8 mA; VCC = 4.5 V - - 0.36 - 0.44 - 0.55 V - - 0.1 - 1.0 - 2.0 μA II input leakage current VI = 5.5 V or GND; VCC = 0 V to 5.5 V ICC supply current VI = VCC or GND; IO = 0 A; VCC = 5.5 V - - 4.0 - 40 - 80 μA ΔICC additional per input pin; supply current VI = VCC - 2.1 V; other pins at VCC or GND; IO = 0 A; VCC = 4.5 V to 5.5 V - - 1.35 - 1.5 - 1.5 mA CI input capacitance - 3 10 - 10 - 10 pF VI = VCC or GND 11. Dynamic characteristics Table 7. Dynamic characteristics Voltages are referenced to GND (ground = 0 V); for test circuit see Fig. 15. Symbol Parameter Conditions -40 °C to +85 °C -40 °C to +125 °C Unit 25 °C Min Typ[1] Max Min Max Min Max 74AHC594 tPLH LOW to HIGH SHCP to Q7S; see Fig. 9 propagation V = 3.0 V to 3.6 V CC delay CL = 15 pF - 5.2 8.5 2.2 9.7 2.2 10.6 ns - 7.4 11.5 3.0 13.2 3.0 14.3 ns CL = 15 pF - 3.8 6.3 1.7 7.2 1.7 7.8 ns CL = 50 pF - 4.8 8.0 2.4 9.1 2.4 10.0 ns CL = 15 pF - 5.1 8.3 2.3 9.5 2.3 10.6 ns CL = 50 pF - 7.3 11.9 3.3 13.6 3.3 14.7 ns CL = 15 pF - 3.5 5.7 1.8 6.5 1.8 7.1 ns CL = 50 pF - 4.8 7.8 2.6 9.0 2.6 9.8 ns CL = 50 pF VCC = 4.5 V to 5.5 V STCP to Qn; see Fig. 10 VCC = 3.0 V to 3.6 V VCC = 4.5 V to 5.5 V 74AHC_AHCT594 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 4 — 7 July 2021 © Nexperia B.V. 2021. All rights reserved 8 / 20 74AHC594; 74AHCT594 Nexperia 8-bit shift register with output register Symbol Parameter Conditions -40 °C to +85 °C -40 °C to +125 °C Unit 25 °C Min Typ[1] Max tPHL HIGH to LOW SHCP to Q7S; see Fig. 9 propagation V = 3.0 V to 3.6 V CC delay CL = 15 pF Min Max Min Max - 5.5 8.9 2.3 10.2 2.3 11.0 ns - 7.4 12.1 3.0 13.9 3.0 15.1 ns CL = 15 pF - 4.1 6.7 1.9 7.6 1.9 8.2 ns CL = 50 pF - 5.4 8.8 2.5 10.1 2.5 11.0 ns CL = 15 pF - 5.5 9.1 2.4 10.4 2.4 11.3 ns CL = 50 pF - 7.3 12.0 3.2 13.8 3.2 15.0 ns CL = 15 pF - 3.7 6.0 1.9 6.9 1.9 7.5 ns CL = 50 pF - 5.2 8.5 2.6 9.7 2.6 10.5 ns CL = 15 pF - 5.7 9.5 2.3 10.8 2.3 11.7 ns CL = 50 pF - 7.5 12.2 3.6 14.0 3.6 15.2 ns CL = 15 pF - 4.1 6.7 2.0 7.6 2.0 8.2 ns CL = 50 pF - 5.4 8.8 2.8 10.1 2.8 11.0 ns CL = 15 pF - 5.8 9.6 2.8 11.0 2.8 12.0 ns CL = 50 pF - 7.7 12.5 3.8 14.4 3.8 15.6 ns CL = 15 pF - 4.1 7.2 2.2 8.2 2.2 8.9 ns CL = 50 pF - 5.4 9.4 3.0 10.7 3.0 11.6 ns VCC = 3.0 V to 3.6 V 80 125 - 70 - 65 - MHz VCC = 4.5 V to 5.5 V 90 170 - 80 - 70 - MHz VCC = 3.0 V to 3.6 V 6.0 - - 6.5 - 7.0 - ns VCC = 4.5 V to 5.5 V 5.5 - - 6.0 - 6.5 - ns VCC = 3.0 V to 3.6 V 5.0 - - 5.0 - 5.5 - ns VCC = 4.5 V to 5.5 V 5.0 - - 5.2 - 5.7 - ns CL = 50 pF VCC = 4.5 V to 5.5 V STCP to Qn; see Fig. 10 VCC = 3.0 V to 3.6 V VCC = 4.5 V to 5.5 V SHR to Q7S; see Fig. 13 VCC = 3.0 V to 3.6 V VCC = 4.5 V to 5.5 V STR to Qn; see Fig. 12 VCC = 3.0 V to 3.6 V VCC = 4.5 V to 5.5 V fmax tW maximum frequency pulse width SHCP or STCP; see Fig. 9 and Fig. 10 SHCP and STCP HIGH or LOW; see Fig. 9 and Fig. 10 SHR and STR HIGH or LOW; see Fig. 13 and Fig. 12 74AHC_AHCT594 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 4 — 7 July 2021 © Nexperia B.V. 2021. All rights reserved 9 / 20 74AHC594; 74AHCT594 Nexperia 8-bit shift register with output register Symbol Parameter tsu set-up time Conditions -40 °C to +85 °C -40 °C to +125 °C Unit 25 °C Min Typ[1] Max Min Max Min Max VCC = 3.0 V to 3.6 V 3.5 - - 3.5 - 4.0 - ns VCC = 4.5 V to 5.5 V 3.0 - - 3.0 - 3.5 - ns VCC = 3.0 V to 3.6 V 8.0 - - 9.0 - 9.5 - ns VCC = 4.5 V to 5.5 V 5.0 - - 5.0 - 5.5 - ns VCC = 3.0 V to 3.6 V 8.0 - - 8.5 - 9.0 - ns VCC = 4.5 V to 5.5 V 5.0 - - 5.0 - 5.5 - ns VCC = 3.0 V to 3.6 V 1.5 - - 1.5 - 2.0 - ns VCC = 4.5 V to 5.5 V 2.0 - - 2.0 - 2.5 - ns VCC = 3.0 V to 3.6 V 4.2 - - 4.8 - 5.3 - ns VCC = 4.5 V to 5.5 V 2.9 - - 3.3 - 3.8 - ns VCC = 3.0 V to 3.6 V 4.6 - - 5.3 - 5.8 - ns VCC = 4.5 V to 5.5 V 3.2 - - 3.7 - 4.3 - ns - 55 - - - - - pF - 3.8 6.3 1.7 7.2 1.7 7.8 ns - 4.8 8.0 2.2 9.1 2.2 9.9 ns CL = 15 pF - 3.5 5.7 1.8 6.5 1.8 7.1 ns CL = 50 pF - 4.6 7.7 2.6 8.8 2.6 9.6 ns - 4.1 6.7 1.8 7.6 1.8 8.3 ns - 5.4 8.8 2.4 10.1 2.4 11.0 ns CL = 15 pF - 3.7 6.1 1.9 6.9 1.9 7.2 ns CL = 50 pF - 5.2 8.5 2.6 9.7 2.6 10.5 ns CL = 15 pF - 4.3 7.0 2.4 8.0 2.4 8.7 ns CL = 50 pF - 5.4 8.8 2.7 10.1 2.7 11.0 ns CL = 15 pF - 4.5 7.4 2.3 8.4 2.3 9.2 ns CL = 50 pF - 5.7 9.4 3.1 10.7 3.1 11.7 ns 90 160 - 80 - 70 - DS to SHCP; see Fig. 11 SHR to STCP; see Fig. 14 SHCP to STCP; see Fig. 10 th trec hold time DS to SHCP; see Fig. 11 recovery time SHR to SHCP; see Fig. 13 STR to STCP; see Fig. 12 CPD power dissipation capacitance fi = 1 MHz; VI = GND to VCC [2] 74AHCT594; VCC = 4.5 V to 5.5 V tPLH LOW to HIGH SHCP to Q7S; see Fig. 9 propagation CL = 15 pF delay CL = 50 pF STCP to Qn; see Fig. 10 tPHL HIGH to LOW SHCP to Q7S; see Fig. 9 propagation CL = 15 pF delay CL = 50 pF STCP to Qn; see Fig. 10 SHR to Q7S; see Fig. 13 STR to Qn; see Fig. 12 fmax maximum frequency 74AHC_AHCT594 Product data sheet SHCP or STCP; see Fig. 9 and Fig. 10 All information provided in this document is subject to legal disclaimers. Rev. 4 — 7 July 2021 © MHz Nexperia B.V. 2021. All rights reserved 10 / 20 74AHC594; 74AHCT594 Nexperia 8-bit shift register with output register Symbol Parameter tW pulse width tsu set-up time Conditions -40 °C to +85 °C -40 °C to +125 °C Unit 25 °C Min Typ[1] Max Min Max Min Max SHCP and STCP HIGH or LOW; see Fig. 9 and Fig. 10 5.5 - - 6.0 - 6.5 - ns SHR and STR HIGH or LOW; see Fig. 13 and Fig. 12 5.2 - - 5.5 - 6.0 - ns DS to SHCP; see Fig. 11 3.0 - - 3.0 - 3.5 - ns SHR to STCP; see Fig. 14 5.0 - - 5.0 - 5.5 - ns SHCP to STCP; see Fig. 10 5.0 - - 5.0 - 5.5 - ns DS to SHCP; see Fig. 11 2.0 - - 2.0 - 2.5 - ns th hold time trec recovery time SHR to SHCP; see Fig. 13 2.9 - - 3.3 - 3.8 - ns STR to STCP; see Fig. 12 3.4 - - 3.8 - 4.3 - ns - 55 - - - - - pF CPD [1] [2] power dissipation capacitance fi = 1 MHz; VI = GND to VCC [2] Typical values are measured at nominal supply voltage (VCC = 3.3 V and VCC = 5.0 V). CPD is used to determine the dynamic power dissipation (PD in μW). 2 2 PD = CPD x VCC x fi x N + Σ(CL x VCC x fo) where: fi = input frequency in MHz; fo = output frequency in MHz; CL = output load capacitance in pF; VCC = supply voltage in V; N = number of inputs switching; 2 Σ(CL x VCC x fo) = sum of the outputs. 11.1. Waveforms and test circuit 1/fmax SHCP input VM tW tPLH Q7S output tPHL VM tTLH tTHL 001aae341 Measurement points are given in Table 8. Fig. 9. Shift register clock pulse width, maximum frequency and input to output propagation delays 74AHC_AHCT594 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 4 — 7 July 2021 © Nexperia B.V. 2021. All rights reserved 11 / 20 74AHC594; 74AHCT594 Nexperia 8-bit shift register with output register SHCP input VM tsu 1/fmax VM STCP input tW tPHL tPLH Qn outputs VM mla512 Measurement points are given in Table 8. Fig. 10. Shift register clock to storage register clock set-up time and storage clock pulse width, maximum frequency and input to output propagation delays VM SHCP input t su t su th th VM DS input VM Q7 output 001aae342 Measurement points are given in Table 8. The shaded areas indicate when the input is permitted to change for predictable output performance. Fig. 11. Shift register clock to data input set-up and hold times STR input VM tW trec VM STCP input tPHL Qn outputs VM mbc325 Measurement points are given in Table 8. Fig. 12. Storage register reset pulse width, input to output propagation delay and recovery time 74AHC_AHCT594 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 4 — 7 July 2021 © Nexperia B.V. 2021. All rights reserved 12 / 20 74AHC594; 74AHCT594 Nexperia 8-bit shift register with output register SHR input VM tW trec VM SHCP input tPHL VM Q7S output mbc324 Measurement points are given in Table 8. Fig. 13. Shift register reset pulse width, input to output propagation delay and recovery time SHR input VM tsu STCP input Qn outputs VM VM mbc326 Measurement points are given in Table 8. Fig. 14. Shift register reset to storage register clock set-up time Table 8. Measurement points Type Input Output VM VM 74AHC594 0.5 x VCC 0.5 x VCC 74AHCT594 1.5 V 0.5 x VCC 74AHC_AHCT594 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 4 — 7 July 2021 © Nexperia B.V. 2021. All rights reserved 13 / 20 74AHC594; 74AHCT594 Nexperia 8-bit shift register with output register VI negative pulse VM VI GND VM 10 % GND positive pulse tW 90 % tf tr tr tf 90 % VM VM 10 % tW VCC G VI DUT VO RT CL 001aah768 For test data see Table 9. Definitions for test circuit: RT = Termination resistance should be equal to output impedance Zo of the pulse generator. CL = Load capacitance including jig and probe capacitance. Fig. 15. Test circuit for measuring switching times Table 9. Test data Type Load Input Test VI tr, tf CL 74AHC594 VCC ≤ 3.0 ns 15 pF, 50 pF tPLH, tPHL 74AHCT594 3.0 V ≤ 3.0 ns 15 pF, 50 pF tPLH, tPHL 74AHC_AHCT594 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 4 — 7 July 2021 © Nexperia B.V. 2021. All rights reserved 14 / 20 74AHC594; 74AHCT594 Nexperia 8-bit shift register with output register 12. Package outline SO16: plastic small outline package; 16 leads; body width 3.9 mm SOT109-1 D E A X c y HE v M A Z 16 9 Q A2 A (A 3) A1 pin 1 index θ Lp 1 L 8 e w M bp 0 2.5 detail X 5 mm scale DIMENSIONS (inch dimensions are derived from the original mm dimensions) UNIT A max. A1 A2 A3 bp c D (1) E (1) e HE L Lp Q v w y Z (1) mm 1.75 0.25 0.10 1.45 1.25 0.25 0.49 0.36 0.25 0.19 10.0 9.8 4.0 3.8 1.27 6.2 5.8 1.05 1.0 0.4 0.7 0.6 0.25 0.25 0.1 0.7 0.3 inches 0.069 0.010 0.057 0.004 0.049 0.01 0.019 0.0100 0.39 0.014 0.0075 0.38 0.16 0.15 0.05 0.039 0.016 0.028 0.020 0.01 0.01 0.004 0.028 0.012 0.244 0.041 0.228 θ o 8 o 0 Note 1. Plastic or metal protrusions of 0.15 mm (0.006 inch) maximum per side are not included. REFERENCES OUTLINE VERSION IEC JEDEC SOT109-1 076E07 MS-012 JEITA EUROPEAN PROJECTION ISSUE DATE 99-12-27 03-02-19 Fig. 16. Package outline SOT109-1 (SO16) 74AHC_AHCT594 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 4 — 7 July 2021 © Nexperia B.V. 2021. All rights reserved 15 / 20 74AHC594; 74AHCT594 Nexperia 8-bit shift register with output register TSSOP16: plastic thin shrink small outline package; 16 leads; body width 4.4 mm D SOT403-1 E A X c y HE v M A Z 9 16 Q A2 pin 1 index (A 3 ) A1 A θ Lp 1 L 8 detail X w M bp e 0 2.5 5 mm scale DIMENSIONS (mm are the original dimensions) UNIT A max. A1 A2 A3 bp c D (1) E (2) e HE L Lp Q v w y Z (1) θ mm 1.1 0.15 0.05 0.95 0.80 0.25 0.30 0.19 0.2 0.1 5.1 4.9 4.5 4.3 0.65 6.6 6.2 1 0.75 0.50 0.4 0.3 0.2 0.13 0.1 0.40 0.06 8o 0o Notes 1. Plastic or metal protrusions of 0.15 mm maximum per side are not included. 2. Plastic interlead protrusions of 0.25 mm maximum per side are not included. OUTLINE VERSION SOT403-1 REFERENCES IEC JEDEC JEITA EUROPEAN PROJECTION ISSUE DATE 99-12-27 03-02-18 MO-153 Fig. 17. Package outline SOT403-1 (TSSOP16) 74AHC_AHCT594 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 4 — 7 July 2021 © Nexperia B.V. 2021. All rights reserved 16 / 20 74AHC594; 74AHCT594 Nexperia 8-bit shift register with output register DHVQFN16: plastic dual in-line compatible thermal enhanced very thin quad flat package; no leads; SOT763-1 16 terminals; body 2.5 x 3.5 x 0.85 mm B D A A E A1 c detail X terminal 1 index area terminal 1 index area C e1 e b 2 7 y y1 C v M C A B w M C L 1 8 Eh e 16 9 15 10 Dh X 0 2.5 5 mm scale DIMENSIONS (mm are the original dimensions) UNIT A(1) max. A1 b c D (1) Dh E (1) Eh e e1 L v w y y1 mm 1 0.05 0.00 0.30 0.18 0.2 3.6 3.4 2.15 1.85 2.6 2.4 1.15 0.85 0.5 2.5 0.5 0.3 0.1 0.05 0.05 0.1 Note 1. Plastic or metal protrusions of 0.075 mm maximum per side are not included. REFERENCES OUTLINE VERSION IEC JEDEC JEITA SOT763-1 --- MO-241 --- EUROPEAN PROJECTION ISSUE DATE 02-10-17 03-01-27 Fig. 18. Package outline SOT763-1 (DHVQFN16) 74AHC_AHCT594 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 4 — 7 July 2021 © Nexperia B.V. 2021. All rights reserved 17 / 20 74AHC594; 74AHCT594 Nexperia 8-bit shift register with output register 13. Abbreviations Table 10. Abbreviations Acronym Description CDM Charged Device Model CMOS Complementary Metal-Oxide Semiconductor DUT Device Under Test ESD ElectroStatic Discharge HBM Human Body Model LSTTL Low-power Schottky Transistor-Transistor Logic MM Machine Model TTL Transistor-Transistor Logic 14. Revision history Table 11. Revision history Document ID Release date Data sheet status Change notice Supersedes 74AHC_AHCT594 v.4 20210707 Product data sheet - Modifications: • 74AHC_AHCT594 v.3 20200625 Modifications: • • • • Type numbers 74AHC594DB and 74AHCT594DB (SOT338-1/SSOP16) removed. 20080609 Modifications: • 74AHC_AHCT594 v.1 74AHC_AHCT594 Product data sheet Product data sheet - 74AHC_AHCT594 v.2 The format of this data sheet has been redesigned to comply with the identity guidelines of Nexperia. Legal texts have been adapted to the new company name where appropriate. Section 2 updated. Table 4: Derating values for Ptot total power dissipation updated. 74AHC_AHCT594 v.2 • • 74AHC_AHCT594 v.3 Product data sheet - 74AHC_AHCT594 v.1 The format of this data sheet has been redesigned to comply with the new identity guidelines of NXP Semiconductors. Legal texts have been adapted to the new company name where appropriate. Table 6: the conditions for input leakage current have been changed. 20060704 Product data sheet - All information provided in this document is subject to legal disclaimers. Rev. 4 — 7 July 2021 - © Nexperia B.V. 2021. All rights reserved 18 / 20 74AHC594; 74AHCT594 Nexperia 8-bit shift register with output register 15. Legal information injury, death or severe property or environmental damage. Nexperia and its suppliers accept no liability for inclusion and/or use of Nexperia products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Data sheet status Quick reference data — The Quick reference data is an extract of the product data given in the Limiting values and Characteristics sections of this document, and as such is not complete, exhaustive or legally binding. Document status [1][2] Product status [3] Definition Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] [2] [3] Please consult the most recently issued document before initiating or completing a design. The term 'short data sheet' is explained in section "Definitions". The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the internet at https://www.nexperia.com. Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Nexperia sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between Nexperia and its customer, unless Nexperia and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the Nexperia product is deemed to offer functions and qualities beyond those described in the Product data sheet. Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, Nexperia does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Nexperia takes no responsibility for the content in this document if provided by an information source outside of Nexperia. In no event shall Nexperia be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation - lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Notwithstanding any damages that customer might incur for any reason whatsoever, Nexperia’s aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of Nexperia. Right to make changes — Nexperia reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. Suitability for use — Nexperia products are not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical systems or equipment, nor in applications where failure or malfunction of an Nexperia product can reasonably be expected to result in personal 74AHC_AHCT594 Product data sheet Applications — Applications that are described herein for any of these products are for illustrative purposes only. Nexperia makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using Nexperia products, and Nexperia accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the Nexperia product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. Nexperia does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using Nexperia products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). Nexperia does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — Nexperia products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nexperia.com/profile/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Nexperia hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Nexperia products by customer. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from competent authorities. Non-automotive qualified products — Unless this data sheet expressly states that this specific Nexperia product is automotive qualified, the product is not suitable for automotive use. It is neither qualified nor tested in accordance with automotive testing or application requirements. Nexperia accepts no liability for inclusion and/or use of non-automotive qualified products in automotive equipment or applications. In the event that customer uses the product for design-in and use in automotive applications to automotive specifications and standards, customer (a) shall use the product without Nexperia’s warranty of the product for such automotive applications, use and specifications, and (b) whenever customer uses the product for automotive applications beyond Nexperia’s specifications such use shall be solely at customer’s own risk, and (c) customer fully indemnifies Nexperia for any liability, damages or failed product claims resulting from customer design and use of the product for automotive applications beyond Nexperia’s standard warranty and Nexperia’s product specifications. Translations — A non-English (translated) version of a document is for reference only. The English version shall prevail in case of any discrepancy between the translated and English versions. Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. All information provided in this document is subject to legal disclaimers. Rev. 4 — 7 July 2021 © Nexperia B.V. 2021. All rights reserved 19 / 20 74AHC594; 74AHCT594 Nexperia 8-bit shift register with output register Contents 1. General description...................................................... 1 2. Features and benefits.................................................. 1 3. Applications.................................................................. 1 4. Ordering information....................................................2 5. Functional diagram.......................................................2 6. Pinning information......................................................3 6.1. Pinning.........................................................................3 6.2. Pin description............................................................. 4 7. Functional description................................................. 5 8. Limiting values............................................................. 6 9. Recommended operating conditions..........................6 10. Static characteristics..................................................7 11. Dynamic characteristics.............................................8 11.1. Waveforms and test circuit.......................................11 12. Package outline........................................................ 15 13. Abbreviations............................................................ 18 14. Revision history........................................................18 15. Legal information......................................................19 © Nexperia B.V. 2021. All rights reserved For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 7 July 2021 74AHC_AHCT594 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 4 — 7 July 2021 © Nexperia B.V. 2021. All rights reserved 20 / 20
74AHCT594PW118 价格&库存
很抱歉,暂时无法提供与“74AHCT594PW118”相匹配的价格&库存,您可以联系我们找货
74AHCT594PW118
