62100621821
    WURTHELEKTRONIKIBE
62100621821 数据手册
Dimensions: [mm] Recommended Land Pattern: [mm] 1 pl 2 0,89 2 2 End End O 0,50 x 0,20 ±0.25 1 2 6,80 1,65 L ±0.30 2,10 ±0.25 2 ±0.10 2 ±0.10 1 2 ±0.10 Pl ±0.25 6 ±0.25 4 ±0.15 General tolerance ±0.05 Pattern Properties: Properties Pin to Pin (Middle) Article Properties: Properties Value Pins Value Unit 4 mm pl CHECKED REVISION DATE (YYYY-MM-DD) GENERAL TOLERANCE CPo 002.002 2022-03-02 DIN ISO 2768-1m PROJECTION METHOD Unit DESCRIPTION 6 Pin to Pin (Middle) Pl 4 mm Length L 6 mm Würth Elektronik eiSos GmbH & Co. KG EMC & Inductive Solutions Max-Eyth-Str. 1 74638 Waldenburg Germany Tel. +49 (0) 79 42 945 - 0 www.we-online.com eiSos@we-online.com WR-PHD SMT Straight Dual Low Profile Bottom Entry Socket Header ORDER CODE 62100621821 SIZE/TYPE BUSINESS UNIT STATUS PAGE 2.00 mm eiCan Valid 1/7 This electronic component has been designed and developed for usage in general electronic equipment only. This product is not authorized for use in equipment where a higher safety standard and reliability standard is especially required or where a failure of the product is reasonably expected to cause severe personal injury or death, unless the parties have executed an agreement specifically governing such use. Moreover Würth Elektronik eiSos GmbH & Co KG products are neither designed nor intended for use in areas such as military, aerospace, aviation, nuclear control, submarine, transportation (automotive control, train control, ship control), transportation signal, disaster prevention, medical, public information network etc.. Würth Elektronik eiSos GmbH & Co KG must be informed about the intent of such usage before the design-in stage. In addition, sufficient reliability evaluation checks for safety must be performed on every electronic component which is used in electrical circuits that require high safety and reliability functions or performance. Kind Properties: Properties Pitch P Durability Value Unit 2 mm 500 Mating cycles Material Properties: Insulator Material PA9T Insulator Flammability Rating UL94 V-0 Insulator Color Black Contact Material Copper Alloy Contact Plating Gold Contact Type Stamped General Information: Operating Temperature -40 up to +105 °C Electrical Properties: Properties Rated Current Test conditions Value Unit 2 A 200 V (AC) 500 V (AC) R 20 mΩ max. RISO 1000 MΩ min. IR Working Voltage Withstanding Voltage Contact Resistance Insulation Resistance 1 min Tol. Certification: RoHS Approval Compliant [2011/65/EU&2015/863] REACh Approval Conform or declared [(EC)1907/2006] Halogen Free Conform [JEDEC JS709B] Halogen Free Conform [IEC 61249-2-21] UL Approval E323964 CHECKED REVISION DATE (YYYY-MM-DD) GENERAL TOLERANCE CPo 002.002 2022-03-02 DIN ISO 2768-1m PROJECTION METHOD DESCRIPTION Würth Elektronik eiSos GmbH & Co. KG EMC & Inductive Solutions Max-Eyth-Str. 1 74638 Waldenburg Germany Tel. +49 (0) 79 42 945 - 0 www.we-online.com eiSos@we-online.com WR-PHD SMT Straight Dual Low Profile Bottom Entry Socket Header ORDER CODE 62100621821 SIZE/TYPE BUSINESS UNIT STATUS PAGE 2.00 mm eiCan Valid 2/7 This electronic component has been designed and developed for usage in general electronic equipment only. This product is not authorized for use in equipment where a higher safety standard and reliability standard is especially required or where a failure of the product is reasonably expected to cause severe personal injury or death, unless the parties have executed an agreement specifically governing such use. Moreover Würth Elektronik eiSos GmbH & Co KG products are neither designed nor intended for use in areas such as military, aerospace, aviation, nuclear control, submarine, transportation (automotive control, train control, ship control), transportation signal, disaster prevention, medical, public information network etc.. Würth Elektronik eiSos GmbH & Co KG must be informed about the intent of such usage before the design-in stage. In addition, sufficient reliability evaluation checks for safety must be performed on every electronic component which is used in electrical circuits that require high safety and reliability functions or performance. Packaging Specification - Tube: [mm] L Detail View: W TUB TUB detail A A TUB TUB H T Tube NB: Actual packaging may slightly differ from datasheet LTUB (mm) WTUB (mm) HTUB (mm) TTUB (mm) typ. 600 typ. 5.3 typ. 7.1 typ. 0.8 Packaging Unit pcs. 95 Material Plastic CHECKED REVISION DATE (YYYY-MM-DD) GENERAL TOLERANCE CPo 002.002 2022-03-02 DIN ISO 2768-1m PROJECTION METHOD DESCRIPTION Würth Elektronik eiSos GmbH & Co. KG EMC & Inductive Solutions Max-Eyth-Str. 1 74638 Waldenburg Germany Tel. +49 (0) 79 42 945 - 0 www.we-online.com eiSos@we-online.com WR-PHD SMT Straight Dual Low Profile Bottom Entry Socket Header ORDER CODE 62100621821 SIZE/TYPE BUSINESS UNIT STATUS PAGE 2.00 mm eiCan Valid 3/7 This electronic component has been designed and developed for usage in general electronic equipment only. This product is not authorized for use in equipment where a higher safety standard and reliability standard is especially required or where a failure of the product is reasonably expected to cause severe personal injury or death, unless the parties have executed an agreement specifically governing such use. Moreover Würth Elektronik eiSos GmbH & Co KG products are neither designed nor intended for use in areas such as military, aerospace, aviation, nuclear control, submarine, transportation (automotive control, train control, ship control), transportation signal, disaster prevention, medical, public information network etc.. Würth Elektronik eiSos GmbH & Co KG must be informed about the intent of such usage before the design-in stage. In addition, sufficient reliability evaluation checks for safety must be performed on every electronic component which is used in electrical circuits that require high safety and reliability functions or performance. H IC Packaging Specification - Tube and Carton: [mm] L IC W H C IC L W C C NB: Actual packaging may slightly differ from datasheet LIC (mm) WIC (mm) HIC (mm) LC (mm) WC (mm) HC (mm) typ. 630 typ. 170 typ. 150 typ. 650 typ. 330 typ. 190 No. of tube per outer packaging tube. 720 Outer packaging unit pcs. 68400 Material Paper CHECKED REVISION DATE (YYYY-MM-DD) GENERAL TOLERANCE CPo 002.002 2022-03-02 DIN ISO 2768-1m PROJECTION METHOD DESCRIPTION Würth Elektronik eiSos GmbH & Co. KG EMC & Inductive Solutions Max-Eyth-Str. 1 74638 Waldenburg Germany Tel. +49 (0) 79 42 945 - 0 www.we-online.com eiSos@we-online.com WR-PHD SMT Straight Dual Low Profile Bottom Entry Socket Header ORDER CODE 62100621821 SIZE/TYPE BUSINESS UNIT STATUS PAGE 2.00 mm eiCan Valid 4/7 This electronic component has been designed and developed for usage in general electronic equipment only. This product is not authorized for use in equipment where a higher safety standard and reliability standard is especially required or where a failure of the product is reasonably expected to cause severe personal injury or death, unless the parties have executed an agreement specifically governing such use. Moreover Würth Elektronik eiSos GmbH & Co KG products are neither designed nor intended for use in areas such as military, aerospace, aviation, nuclear control, submarine, transportation (automotive control, train control, ship control), transportation signal, disaster prevention, medical, public information network etc.. Würth Elektronik eiSos GmbH & Co KG must be informed about the intent of such usage before the design-in stage. In addition, sufficient reliability evaluation checks for safety must be performed on every electronic component which is used in electrical circuits that require high safety and reliability functions or performance. Classification Reflow Profile for SMT components: Classification Reflow Soldering Profile: Profile Feature Tp tp Max. Ramp Up Rate Max. Ramp Down Rate TL Temperature Ts max tL Preheat Area Ts min TC –5°C Value Preheat Temperature Min Ts min 150 °C Preheat Temperature Max Ts max 200 °C Preheat Time ts from Ts min to Ts max ts Ramp-up Rate (TL to TP) 60 - 120 seconds 3 °C/ second max. Liquidous Temperature TL 217 °C Time tL maintained above TL tL 60 - 150 seconds Peak package body temperature Tp Tp ≤ Tc, see Table below Time within 5°C of actual peak temperature tp 20 - 30 seconds Ramp-down Rate (TP to TL) 6 °C/ second max. Time 25°C to peak temperature 8 minutes max. refer to IPC/ JEDEC J-STD-020E tS Package Classification Reflow Temperature (Tc): Volume mm³ 350-2000 Volume mm³ >2000 PB-Free Assembly | Package Thickness 260 °C < 1.6 mm 260 °C 260 °C PB-Free Assembly | Package Thickness 260 °C 1.6 mm - 2.5 mm 250 °C 245 °C PB-Free Assembly | Package Thickness 250 °C > 2.5 mm 245 °C 245 °C Properties 25 Time 25°C to Peak Time Volume mm³
62100621821 价格&库存
很抱歉,暂时无法提供与“62100621821”相匹配的价格&库存,您可以联系我们找货
