12
H
11
MATERIAL NO.
LOOSE PC
190130025
190130029
190130033
ENGINEERING NO.
LOOSE PC
AA-2317
BB-2318
C-2319
10
MATERIAL NO.
ON TAPE
190130026
190130030
190130034
9
ENGINEERING NO.
ON TAPE
AA-2317T
BB-2318T
C-2319T
WIRE SIZE
22-18 AWG
16-14 AWG
12-10 AWG
7
8
INSULATOR
COLOR
RED
BLUE
YELLOW
ID
MIN REF
.056/1.42
.081/2.06
.147/3.73
D
MAX
.380/9.65
.380/9.65
.380/9.65
MWID
.138/3.50
.159/4.04
.277/7.03
5
6
C2 "H"
L
NOMINAL
MAX
.56/14.2
.860/21.84
.860/21.84
.56/14.2
.53/13.5
1.030/26.162
4
3
2
1
BARE TAB
POSITION
AWAY FROM TAPE
AWAY FROM TAPE
TOWARD TAPE
H
"L"
G
G
"D"
INSULATOR
TERMINAL
F
F
WIRE STOP
MWID
ID
.156 REF
3.96
E
.60 REF
15.2
90°REF
TYP ALL MATERIAL NUMBERS
SINGLE SPACED
CENTER TO CENTER
TAB AWAY
FROM TAPE
.032+.001
-.002
TAB TOWARD TAPE
E
.160REF
4.06
96°REF
0.81+0.03
-0.05
D
D
.310REF
7.86
.370REF
9.41
C
C
C2
"H"
TO TAB
.250+.003
-.006
6.35+0.08
-0.15
B
B
PARTS ON TAPE
(SCALE 2:1)
SYMBOLS
= 0
NOTES:
1.
2.
3.
4.
5.
A
= 0
THIS DRAWING CONTAINS INFORMATION THAT IS PROPRIETARY TO MOLEX ELECTRONIC TECHNOLOGIES, LLC AND SHOULD NOT BE USED WITHOUT WRITTEN PERMISSION
DIMENSION UNITS
SCALE
IN/MM
10:1
GENERAL TOLERANCES
(UNLESS SPECIFIED)
= 0
TERMINAL MATERIAL: BRASS
TERMINAL FINISH: TIN PLATED
INSULATOR MATERIAL: NYLON
MWID = MAXIMUM WIRE INSULATION DIAMETER.
ASSEMBLY IS RoHS COMPLIANT.
= 0
= 0
MM
4 PLACES ±
3 PLACES ±
2 PLACES ±
1 PLACE
= 0
0 PLACES ±
ANGULAR TOL
DOCUMENT STATUS
12
FORMAT: Eng-lega-master-tb-prod-C
REVISION: D
DATE: 2018/01/18
P1
RELEASE DATE
11
2018/10/11
10
14:34:15
C
9
8
7
6
INCH
= 0
= 0
= 0
CURRENT REV DESC: DIM TO TAB, NOT CURL
DRAFT WHERE APPLICABLE
MUST REMAIN
WITHIN DIMENSIONS
5
EC NO: 605784
DRWN: DMYRICK
CHK'D: GROJAS01
APPR: GROJAS01
INITIAL REVISION:
DRWN: BRE
APPR: RWD
THIRD ANGLE PROJECTION
4
2018/10/10
2018/10/11
2018/10/11
PIGGYBACK FIQD,
.250 X .032 TAB, INSULKRIMP
PRODUCT CUSTOMER DRAWING
DOC TYPE DOC PART REVISION
DOCUMENT NUMBER
2003/03/19
2003/03/19
DRAWING
SERIES
C-SIZE
19013
3
SD-19013-001
MATERIAL NUMBER
PSD 001
CUSTOMER
SEE CHART
2
C2
SHEET NUMBER
GENERAL MARKET
1 OF 1
1
A
很抱歉,暂时无法提供与“19013-0029”相匹配的价格&库存,您可以联系我们找货
