SMAJ15CA-Q
SMAJ15CA-Q
    OTHER
    SMAJ15CA-Q
SMAJ15CA-Q 数据手册
AN T C- *R Q1 oH 01 S a CO nd M PL I AE ** Features Applications ■ Surface Mount SMA package ■ Protection of power buses ■ Standoff Voltage: 5 to 220 volts ■ Protection of I/O interfaces ■ Power Dissipation: 400 watts ■ Overvoltage transient protection ■ RoHS compliant* ■ Telecom, computer, industrial and consumer electronics applications ■ AEC-Q101 compliant** SMAJ-Q Transient Voltage Suppressor Diode Series General Information Additional Information Bourns offers Transient Voltage Suppressor Diodes for surge and ESD protection applications, in compact chip package DO-214AC (SMA) size format. The Transient Voltage Suppressor series offers a choice of Working Peak Reverse Voltage from 5 V up to 220 V. Typical fast response times are less than 1.0 picosecond from 0 V to Breakdown Voltage. Bourns® Chip Diodes conform to JEDEC standards, are easy to handle with standard pick and place equipment and the flat configuration minimizes roll away. Click these links for more information: PRODUCT TECHNICAL INVENTORY SAMPLES SELECTOR LIBRARY CONTACT Agency Recognition Electrical Characteristics (@ TA = 25 °C Unless Otherwise Noted) Parameter Description Symbol Value Unit Minimum Peak Pulse Power Dissipation (TP = 1 ms) (Note 1,2) PPK 400 Watts Peak Forward Surge Current 8.3 ms Single Half Sine Wave Superimposed on Rated Load (JEDEC Method) (Note 3) IFSM 40 Amps Operating Temperature Range Storage Temperature Range TJ -55 to +150 °C TSTG -55 to +150 °C UL File Number: E153537 WARNING Cancer and Reproductive Harm www.P65Warnings.ca.gov 1. Non-repetitive current pulse, per Pulse Waveform graph and derated above TA = 25 °C per Pulse Derating Curve. 2. Mounted on 5.0 mm2 (0.03 mm thick) copper pads to each terminal. 3. 8.3 ms Single Half-Sine Wave duty cycle = 4 pulses maximum per minute (unidirectional units only). *RoHS Directive 2015/863, Mar 31, 2015 and Annex. **“Q” part number suffix indicates AEC-Q101 compliance. Specifications are subject to change without notice. Users should verify actual device performance in their specific applications. The products described herein and this document are subject to specific legal disclaimers as set forth on the last page of this document, and at www.bourns.com/docs/legal/disclaimer.pdf. Electrical Characteristics (@ TA = 25 °C Unless Otherwise Noted) Unidirectional Device Part No. SMAJ5.0A-Q SMAJ6.0A-Q SMAJ6.5A-Q SMAJ7.0A-Q SMAJ7.5A-Q SMAJ8.0A-Q SMAJ8.5A-Q SMAJ9.0A-Q SMAJ10A-Q SMAJ11A-Q SMAJ12A-Q SMAJ13A-Q SMAJ14A-Q SMAJ15A-Q SMAJ16A-Q Bidirectional Device Marking Part No. Marking HEQ HGQ HKQ HMQ HPQ HRQ HTQ HVQ HXQ HZQ IEQ IGQ IKQ IMQ IPQ SMAJ5.0CA-Q SMAJ6.0CA-Q SMAJ6.5CA-Q SMAJ7.0CA-Q SMAJ7.5CA-Q SMAJ8.0CA-Q SMAJ8.5CA-Q SMAJ9.0CA-Q SMAJ10CA-Q SMAJ11CA-Q SMAJ12CA-Q SMAJ13CA-Q SMAJ14CA-Q SMAJ15CA-Q SMAJ16CA-Q TEQ TGQ TKQ TMQ TPQ TRQ TTQ TVQ TXQ TZQ UEQ UGQ UKQ UMQ UPQ Breakdown Voltage VBR (Volts) Min. Max. 6.40 6.67 7.22 7.78 8.33 8.89 9.44 10.0 11.1 12.2 13.3 14.4 15.6 16.7 17.8 7.00 7.37 7.98 8.60 9.21 9.83 10.4 11.1 12.3 13.5 14.7 15.9 17.2 18.5 19.7 Notes: 1. Suffix ‘A’ denotes a 5 % tolerance unidirectional device. 2. Suffix ‘CA’ denotes a 5 % tolerance bidirectional device. Working Peak Reverse Voltage Maximum Maximum Maximum Maximum Maximum Clamping Peak Clamping Peak Reverse Voltage Pulse Voltage Pulse Leakage @ Ipp Current @ Ipp Current @ VRWM (10/1000 μs) (10/1000 μs) (8/20 μs) (8/20 μs) @ IT (mA) VRWM (V) IR (μA) Vc (V) Ipp (A) Vc (V) Ipp (A) 10 10 10 10 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 5.0 6.0 6.5 7.0 7.5 8.0 8.5 9.0 10 11 12 13 14 15 16 800 800 500 200 100 50 20 10 5 1.0 1.0 1.0 1.0 1.0 1.0 9.2 10.3 11.2 12.0 12.9 13.6 14.4 15.4 17.0 18.2 19.9 21.5 23.2 24.4 26.0 43.5 38.8 35.7 33.3 31.0 29.4 27.8 26.0 23.5 22.0 20.1 18.6 17.2 16.4 15.4 12.0 13.4 14.6 15.6 16.8 17.7 18.7 20.0 22.1 23.7 25.9 28.0 30.2 31.7 33.8 217.5 194.0 178.5 166.5 155.0 147.0 139.0 130.0 117.5 110.0 100.5 93.0 86.0 82.0 77.0 ~ Continued on next page ~ SMAJ-Q Transient Voltage Suppressor Diode Series Electrical Characteristics (@ TA = 25 °C Unless Otherwise Noted) - Continued Unidirectional Device Part No. Bidirectional Device Breakdown Voltage VBR (Volts) @ IT Marking Min. Max. (mA) Maximum Clamping Voltage @ Ipp Maximum Maximum Maximum Peak Clamping Peak Pulse Voltage Pulse Current @ Ipp Current Working Peak Reverse Voltage Maximum Reverse Leakage @ VRWM (10/1000 μs) (10/1000 μs) (8/20 μs) (8/20 μs) VRWM (V) IR (μA) Vc (V) Ipp (A) Vc (V) Ipp (A) Marking Part No. SMAJ17A-Q IRQ SMAJ17CA-Q URQ 18.9 20.9 1.0 17 1.0 27.6 14.5 35.9 72.5 SMAJ18A-Q ITQ SMAJ18CA-Q UTQ 20.0 22.1 1.0 18 1.0 29.2 13.7 38.0 68.5 SMAJ20A-Q IVQ SMAJ20CA-Q UVQ 22.2 24.5 1.0 20 1.0 32.4 12.3 42.1 61.5 SMAJ22A-Q IXQ SMAJ22CA-Q UXQ 24.4 26.9 1.0 22 1.0 35.5 11.3 46.2 56.5 SMAJ24A-Q IZQ SMAJ24CA-Q UZQ 26.7 29.5 1.0 24 1.0 38.9 10.3 50.6 51.5 SMAJ26A-Q JEQ SMAJ26CA-Q VEQ 28.9 31.9 1.0 26 1.0 42.1 9.5 54.7 47.5 SMAJ28A-Q JGQ SMAJ28CA-Q VGQ 31.1 34.4 1.0 28 1.0 45.4 8.8 59.0 44.0 SMAJ30A-Q JKQ SMAJ30CA-Q VKQ 33.3 36.8 1.0 30 1.0 48.4 8.3 62.9 41.5 SMAJ33A-Q JMQ SMAJ33CA-Q VMQ 36.7 40.6 1.0 33 1.0 53.3 7.5 69.3 37.5 SMAJ36A-Q JPQ SMAJ36CA-Q VPQ 40 44.2 1.0 36 1.0 58.1 6.9 75.5 34.5 SMAJ40A-Q JRQ SMAJ40CA-Q VRQ 44.4 49.1 1.0 40 1.0 64.5 6.2 83.9 31.0 SMAJ43A-Q JTQ SMAJ43CA-Q VTQ 47.8 52.8 1.0 43 1.0 69.4 5.8 90.2 29.0 SMAJ45A-Q JVQ SMAJ45CA-Q VVQ 50 55.3 1.0 45 1.0 72.7 5.5 94.5 27.5 SMAJ48A-Q JXQ SMAJ48CA-Q VXQ 53.3 58.9 1.0 48 1.0 77.4 5.2 100.6 26.0 SMAJ51A-Q JZQ SMAJ51CA-Q VZQ 56.7 62.7 1.0 51 1.0 82.4 4.9 107.1 24.5 SMAJ54A-Q REQ SMAJ54CA-Q WEQ 60 66.3 1.0 54 1.0 87.1 4.6 113.2 23.0 SMAJ58A-Q RGQ SMAJ58CA-Q WGQ 64.4 71.2 1.0 58 1.0 93.6 4.3 121.7 21.5 SMAJ60A-Q RKQ SMAJ60CA-Q WKQ 66.7 73.7 1.0 60 1.0 96.8 4.1 125.8 20.5 SMAJ64A-Q RMQ SMAJ64CA-Q WMQ 71.1 78.6 1.0 64 1.0 103 3.9 133.9 19.5 SMAJ70A-Q RPQ SMAJ70CA-Q WPQ 77.8 86.0 1.0 70 1.0 113 3.5 146.9 17.5 SMAJ75A-Q RRQ SMAJ75CA-Q WRQ 83.3 92.1 1.0 75 1.0 121 3.3 157.3 16.5 SMAJ78A-Q RTQ SMAJ78CA-Q WTQ 86.7 95.8 1.0 78 1.0 126 3.2 163.8 16.0 SMAJ85A-Q RVQ SMAJ85CA-Q WVQ 94.4 104 1.0 85 1.0 137 2.9 178.1 14.5 SMAJ90A-Q RXQ SMAJ90CA-Q WXQ 100 111 1.0 90 1.0 146 2.7 189.8 13.5 SMAJ100A-Q RZQ SMAJ100CA-Q WZQ 111 123 1.0 100 1.0 162 2.5 210.6 12.5 SMAJ110A-Q SEQ SMAJ110CA-Q XEQ 122 135 1.0 110 1.0 177 2.3 230.1 11.5 SMAJ120A-Q SGQ SMAJ120CA-Q XGQ 133 147 1.0 120 1.0 193 2.1 250.9 10.5 SMAJ130A-Q SKQ SMAJ130CA-Q XKQ 144 159 1.0 130 1.0 209 1.9 271.7 9.5 SMAJ150A-Q SMQ SMAJ150CA-Q XMQ 167 185 1.0 150 1.0 243 1.6 315.9 8.0 SMAJ160A-Q SPQ SMAJ160CA-Q XPQ 178 197 1.0 160 1.0 259 1.5 336.7 7.5 SMAJ170A-Q SRQ SMAJ170CA-Q XRQ 189 209 1.0 170 1.0 275 1.5 357.5 7.5 SMAJ180A-Q STQ SMAJ180CA-Q XTQ 201 222 1.0 180 1.0 292 1.4 379.6 7.0 SMAJ200A-Q SVQ SMAJ200CA-Q XVQ 224 247 1.0 200 1.0 324 1.2 421.2 6.0 SMAJ220A-Q SXQ SMAJ220CA-Q XXQ 246 272 1.0 220 1.0 356 1.1 462.8 5.5 Notes: 1. Suffix ‘A’ denotes a 5 % tolerance unidirectional device. 2. Suffix ‘CA’ denotes a 5 % tolerance bidirectional device. Specifications are subject to change without notice. Users should verify actual device performance in their specific applications. The products described herein and this document are subject to specific legal disclaimers as set forth on the last page of this document, and at www.bourns.com/docs/legal/disclaimer.pdf. SMAJ-Q Transient Voltage Suppressor Diode Series Performance Graphs Maximum Non-Repetitive Surge Current 100 45 Peak Forward Surge Current (Amps) Peak Pulse Power Derating in Percent of Peak Power or Current Peak Pulse Power Derating Curve 75 50 25 10 x 1000 Waveform as Defined by R.E.A. 40 35 30 25 20 15 5 0 0 25 0 50 75 100 125 Pulse Width 8.3 ms Single Half Sine-Wave 10 150 10 1 Pulse Waveform Typical Junction Capacitance 10000 TR=10 µs Half value= IRSM 2 CJ - Junction Capacitance (pF) IP, Peak Pulse Current (%) Bidirectional v-0v Peak value (IRSM) 100 Pulse width (TP) is defined as that point where the peak current decays to 50 % of IPSM. 50 10 x 1000 waveform as defined by R.E.A. TA=25 °C TP 1000 Unidirectional @ VR 0 1.0 2.0 3.0 Unidirectional v-0v 100 TJ = 25 °C f = 1.0 MHz Vsig = 50 mVp-p 10 0 Bidirectional @ VR 1 4.0 1 10 T, Time (ms) 100 1000 VBR - Reverse Breakdown Voltage (V) Pulse Rating Curve Steady State Power Derating Curve 10 1.0 Steady State Power Dissipation (W) PPPM - Peak Pulse Power (kW) 100 Number of Cycles at 60 Hz Ambient Temperature ( °C) 1.0 TA = 25 °C Non-repetitive Pulse Waveform Shown in Pulse Waveform Graph 0.1 0.1 µs 0.8 0.6 0.4 0.2 0.0 1.0 µs 10 µs 100 µs Td, Pulse Width (Seconds) 1.0 ms 10 ms 0 25 50 75 100 125 150 TL - Lead Temperature (°C) Specifications are subject to change without notice. Users should verify actual device performance in their specific applications. The products described herein and this document are subject to specific legal disclaimers as set forth on the last page of this document, and at www.bourns.com/docs/legal/disclaimer.pdf. SMAJ-Q Transient Voltage Suppressor Diode Series Product Dimensions Recommended Footprint A A B C B C G Dimension A (Max.) F H D B (Min.) E C (Min.) Dimension A B C D E F G H SMA (DO-214AC) 3.99 - 4.50 (0.157 - 0.177) 2.54 - 2.79 (0.100 - 0.110) 1.25 - 1.65 (0.049 - 0.065) 0.15 - 0.31 (0.006 - 0.012) 4.93 - 5.28 (0.194 - 0.208) 0.203 MAX. (0.008) 1.98 - 2.29 (0.078 - 0.090) 0.76 - 1.52 (0.030 - 0.060) DIMENSIONS: YWW XXX DIMENSIONS: MM (INCHES) Physical Specifications Case ............................................ Molded plastic per UL Class 94V-0 Polarity.........................Cathode band indicates unidirectional device No cathode band indicates bidirectional device How to Order SMAJ 12 CA - Q Package SMAJ = SMA/DO-214AC Working Peak Reverse Voltage 12 = 12 VRWM (Volts) Suffix A = 5 % Tolerance Unidirectional Device CA = 5 % Tolerance Bidirectional Device MM (INCHES) Typical Part Marking MANUFACTURER’S TRADEMARK SMA (DO-214AC) 2.70 (0.106) 2.10 (0.083) 1.27 (0.050) DATE CODE: Y = LAST DIGIT OF YEAR WW = WEEK NUMBER AEC-Q101 Suffix Q = AEC-Q101 Compliant, 13-inch Reel QH = AEC-Q101 Compliant, 7-inch Reel (available only for 12 V to 58 V models) Environmental Specifications Moisture Sensitivity Level ................................................................. 1 ESD Classification (HBM)...............................................................3B DEVICE ID Specifications are subject to change without notice. Users should verify actual device performance in their specific applications. The products described herein and this document are subject to specific legal disclaimers as set forth on the last page of this document, and at www.bourns.com/docs/legal/disclaimer.pdf. SMAJ-Q Transient Voltage Suppressor Diode Series Packaging Information The product will be dispensed in tape and reel format (see diagram below). P 0 P 1 d T E Index Hole 120 ° F D2 W B D1 D P A Unidirectional Product Orientation Trailer ....... ....... End C Leader Device ....... ....... ....... ....... ....... ....... W1 Start DIMENSIONS: 10 pitches (min.) 10 pitches (min.) Devices are packed in accordance with EIA 481 standard specifications shown here. Direction of Feed Item Symbol Carrier Width A Carrier Length B Carrier Depth C Sprocket Hole d Reel Outside Diameter D Reel Inner Diameter D1 Feed Hole Diameter D2 Sprocket Hole Position E Punch Hole Position F Punch Hole Pitch P Sprocket Hole Pitch P0 Embossment Center P1 Overall Tape Thickness T Tape Width W Reel Width W1 Quantity per Reel -- MM (INCHES) SMA (DO-214AC) 7-Inch Reel 13-Inch Reel 2.90 ± 0.20 (0.114 ± 0.008) 5.50 ± 0.20 (0.217 ± 0.008) 2.26 ± 0.20 (0.089 ± 0.008) 1.50 ± 0.10 (0.061 ± 0.004) 178 (7.008) 330 (12.992) 50.0 MIN. (1.969) 13.0 ± 0.20 (0.512 ± 0.008) 1.75 ± 0.10 (0.069 ± 0.004) 5.50 ± 0.05 (0.217 ± 0.002) 4.00 ± 0.10 (0.157 ± 0.004) 4.00 ± 0.10 (0.157 ± 0.004) 2.00 ± 0.05 (0.079 ± 0.002) 0.30 ± 0.10 (0.012 ± 0.004) 12.00 ± 0.30 (0.472 ± 0.012) 18.4 MAX. (0.724) 1,000 5,000 REV. 03/20 Specifications are subject to change without notice. Users should verify actual device performance in their specific applications. The products described herein and this document are subject to specific legal disclaimers as set forth on the last page of this document, and at www.bourns.com/docs/legal/disclaimer.pdf. Legal Disclaimer Notice This legal disclaimer applies to purchasers and users of Bourns® products manufactured by or on behalf of Bourns, Inc. and P[ZHɉSPH[LZJVSSLJ[P]LS`¸)V\YUZ¹ Unless otherwise expressly indicated in writing, Bourns® products and data sheets relating thereto are subject to change ^P[OV\[UV[PJL
SMAJ15CA-Q 价格&库存
很抱歉,暂时无法提供与“SMAJ15CA-Q”相匹配的价格&库存,您可以联系我们找货
SMAJ15CA-Q
  • 5000+0.818315000+0.09934
SMAJ15CA-Q
  • 1+3.821501+0.46392
  • 10+2.9753910+0.36120
  • 100+1.78544100+0.21675
  • 500+1.65294500+0.20066
  • 1000+1.124041000+0.13646
  • 2000+1.034772000+0.12562
