DC/DC Converter
TME Series, 1 Watt
Unregulated outputs
3-year product warranty
I/O isolation voltage 1'000VDC
Efficiency up to 80%
Operating temperature range –40 °C to
+85 °C
The TME series is a range of sub-miniature, isolated DC/DC-converters in a
SIP-package, which requires only 0.7 cm2 of board space. They provide a cost
effective solution to generate supplementary, isolated voltages. Full SMD-design and a 100% production test of parameters ensure a high reliability of this
product.
Models
Order Code
Input Voltage
Output Voltage
Output Current
Efficiency
Range
nom.
max.
typ.
2.97 - 3.63 VDC
(3.3 VDC nom.)
3.3 VDC
260 mA
74 %
5 VDC
200 mA
77 %
TME 0503S
3.3 VDC
260 mA
72 %
TME 0505S
5 VDC
200 mA
69 %
9 VDC
110 mA
76 %
12 VDC
84 mA
77 %
TME 0303S
TME 0305S
TME 0509S
TME 0512S
4.5 - 5.5 VDC
(5 VDC nom.)
TME 0515S
15 VDC
67 mA
78 %
TME 1205S
5 VDC
200 mA
71 %
9 VDC
110 mA
77 %
12 VDC
84 mA
79 %
TME 1209S
TME 1212S
10.8 - 13.2 VDC
(12 VDC nom.)
TME 1215S
15 VDC
67 mA
80 %
TME 2405S
5 VDC
200 mA
70 %
9 VDC
110 mA
76 %
12 VDC
84 mA
79 %
15 VDC
67 mA
79 %
TME 2409S
TME 2412S
TME 2415S
www.tracopower.com
21.6 - 26.4 VDC
(24 VDC nom.)
November 30, 2022
Page 1 / 4
TME Series, 1 Watt
Input Specifications
Input Current
- At no load
3.3 Vin models:
5 Vin models:
12 Vin models:
24 Vin models:
3.3 Vin models:
- At full load
5 Vin models:
12 Vin models:
24 Vin models:
Surge Voltage
3.3 Vin models:
5 Vin models:
12 Vin models:
24 Vin models:
3.3 Vin models:
5 Vin models:
12 Vin models:
24 Vin models:
Recommended Input Fuse
Input Filter
35 mA typ.
30 mA typ.
13 mA typ.
7 mA typ.
351 mA typ. (3.3 Vout model)
394 mA typ. (5 Vout model)
238 mA typ. (3.3 Vout model)
290 mA typ. (5 Vout model)
260 mA typ. (9 Vout model)
262 mA typ. (12 Vout model)
258 mA typ. (15 Vout model)
117 mA typ. (5 Vout model)
107 mA typ. (9 Vout model)
106 mA typ. (12 Vout model)
105 mA typ. (15 Vout model)
60 mA typ. (5 Vout model)
54 mA typ. (9 Vout model)
53 mA typ. (12 Vout model)
53 mA typ. (15 Vout model)
6 VDC max. (1 s max.)
9 VDC max. (1 s max.)
18 VDC max. (1 s max.)
30 VDC max. (1 s max.)
750 mA (slow blow)
750 mA (slow blow)
750 mA (slow blow)
750 mA (slow blow)
(The need of an external fuse has to be assessed
in the final application.)
Internal Capacitor
Output Specifications
Voltage Set Accuracy
Regulation
Ripple and Noise
- Input Variation (1% Vin step)
- Load Variation
- 20 MHz Bandwidth
Capacitive Load
Minimum Load
Temperature Coefficient
Start-up Time
Short Circuit Protection
±3% max.
1.5% max.
See application note: www.tracopower.com/overview/tme
100 mVp-p typ.
150 mVp-p max.
33 µF max.
2.5 % of Iout max.
(Operation at lower load will not damage the
converter, but it may not meet all specifications)
±0.02 %/K max.
2.9 ms max.
Limited 0.5 s max., Automatic recovery
General Specifications
Relative Humidity
Temperature Ranges
Power Derating
Cooling System
- Operating Temperature
- Case Temperature
- Storage Temperature
- High Temperature
95% max. (non condensing)
–40°C to +85°C
+105°C max.
–50°C to +125°C
3.33 %/K above 70°C (5 Vout models)
4 %/K above 75°C (other models)
Natural convection (20 LFM)
All specifications valid at nominal voltage, resistive full load and +25°C after warm-up time, unless otherwise stated.
www.tracopower.com
November 30, 2022
Page 2 / 4
TME Series, 1 Watt
Switching Frequency
Insulation System
Isolation Test Voltage
Isolation Resistance
Isolation Capacitance
Reliability
Washing Process
- Input to Output, 60 s
- Input to Output, 1 s
- Input to Output, 500 VDC
- Input to Output, 100 kHz, 1 V
- Calculated MTBF
See Cleaning Guideline:
Housing Material
Base Material
Potting Material
Pin Material
Pin Foundation Plating
Pin Surface Plating
Housing Type
Mounting Type
Connection Type
Footprint Type
Soldering Profile
Weight
3.3 Vin models:
5 Vin models:
12 Vin models:
24 Vin models:
Thermal Impedance
- Case to Ambient
Environmental Compliance - REACH Declaration
- RoHS Declaration
50 - 110 kHz (PFM)
90 kHz typ. (PFM)
Functional Insulation
1'000 VDC
1'200 VDC
1'000 MΩ min.
60 pF typ.
100 pF max.
2'000'000 h (MIL-HDBK-217F, ground benign)
Allowed (hermetical product)
www.tracopower.com/info/cleaning.pdf
Non-conductive Plastic (UL 94 V-0 rated)
Epoxy (UL 94 V-0 rated)
Nickel-Iron (Alloy 42)
Nickel (1 µm min.)
Tin (3 - 5 µm), matte
Plastic Case
PCB Mount
THD (Through-Hole Device)
SIP4
Wave Soldering
260°C / 10 s max.
1.3 g
1.3 g
1.3 g
1.7 g
78 K/W typ.
www.tracopower.com/info/reach-declaration.pdf
REACH SVHC list compliant
REACH Annex XVII compliant
www.tracopower.com/info/rohs-declaration.pdf
Exemptions: No Exemptions
Supporting Documents
Overview Link (for additional Documents)
www.tracopower.com
November 30, 2022
Page 3 / 4
TME Series, 1 Watt
Outline Dimensions
11.5 (0.45)
Pinout
10.2 (0.40)
3.2
0.5
(0.02)
Single
1
in (GND)
2
+Vin (Vcc)
3
out
4
+Vout
(0.13)
0.5 (0.02)
Pin
1.9
(0.07)
10.5 (0.41)
2
3
4
Bottom view
T
1
1.8 (0.07)
0.25 (0.010)
3X 2.54 (3X 0.100)
0.50
(0.020)
T: 6.1 (0.24) for 3.3Vin & 5Vin & 12Vin Models
T: 7.1 (0.28) for 24Vin Models
Dimensions in mm (inch)
Tolerance: x.x ±0.25 (x.xx ±0.01)
x.xx ±0.13 (x.xxx ±0.005)
Pin tolerance: ±0.05 (±0.002)
© Copyright 2022 Traco Electronic AG
Specifications can be changed without notice.
www.tracopower.com
Rev. November 30, 2022
Page 4 / 4
很抱歉,暂时无法提供与“TME 1205S”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+35.987191+4.37374
- 10+29.5041710+3.58582
- 50+26.3110550+3.19774
- 100+25.00477100+3.03898
- 500+24.99670500+3.03800
- 1000+24.125851000+2.93216
