ECS-RTC-3225-5699C3-TR 数据手册
ECS-RTC-3225-5699C3
Low Power Consumption I²C RTC
The ECS-RTC-3225-5699C3 Real Time Clock Module (I²C-Bus) with built
in 32.768 kHz TCXO. It supports calendar (year, month, day, hour,
minute,second), clock, temp sensor, VBAT and timer functions.
ECS-RTC-5699C3
OPERATING CONDITIONS / ELECTRICAL CHARACTERISTICS
PARAMETERS
CONDITIONS
ECS-RTC-3225-5699C3
MIN
MAX
Power Supply Voltage
Normal mode
2.5
3.0
5.0
V
VDD=VBAT (Note 1)
1.6
3.0
5.0
V
VBAT
1.6
3.0
5.0
V
Backup Battery
Built in 32.768 khz TCXO
Backup battery switchover
function
Extended temp range
±3 ppm Stability -40 ~ +85°C
Built in temperature sensor
TYP
UNITS
1.0
µA
Current Consumption IDD
Battery Supply
Stability
-40 ~ +85°C
±3
ppm
Oscillation start time
@ +25°C
1
s
Aging
Per Year
±3
ppm
Temp VDD=3.0V
±5
°C
Temp. Sensor Accuracy
Duty Cycle
tw/t
40
60
Operating Temperature
Topr
-40
+85
°C
Storage Temperature
Tstg
-40
+85
°C
Note 1) To apply Min Value of VDD and VBAT, VDD and VBAT need to be supplied with more
than 2.5V at least for the oscillation to stabilize (oscillation start time tSTA).
Block Diagram
Figure 1) Top, and Side Views
PART NUMBER: ECS-RTC-3225-5699C3-TR
Rev.2022
15351 West 109th Street| Lenexa, KS 66219 | Phone: 913.782.7787 | Fax: 913.782.6991 | www.ecsxtal.com
ECS-RTC-3225-5699C3
Dimensions (mm)
Figure 1) Tope, Side, Bottom View
Figure 2) Suggested Soldering Pattern
Figure 3) Pin Function
ECS-RTC-3225-5699C3-TR 价格&库存
很抱歉,暂时无法提供与“ECS-RTC-3225-5699C3-TR”相匹配的价格&库存,您可以联系我们找货
