Additional Resources:
Product Page
3D Model
PCB Footprint
date
08/05/2022
page 1 of 5
MODEL: CMS-16098A-SP | DESCRIPTION: SPEAKER
FEATURES
• micro-speaker
• small footprint
• low profile
• spring leads
SPECIFICATIONS
parameter
conditions/description
min
typ
max
units
input power
maximum power: IEC-60268-5, filter 60s on/120s off, 10
cycles at room temp in 1 cc closed box
0.8
1.0
W
impedance
at 2.0 kHz
6.8
8
9.2
Ω
resonant frequency (Fo)
at 1.0 V
at 1.0 V in 1 cc closed box
467.5
722.5
550
850
632.5
977.5
Hz
Hz
frequency response
output SPL ±10 dB
Fo
sound pressure level
at 0.8 W, 0.1 m, at 2.0 kHz in 1 cc closed box
85
distortion
at 1.0 kHz, 0.8 W
buzz, rattle, etc.
must be normal at sine wave between Fo ~ 20 kHz in 1 cc
closed box
polarity
cone will move forward with positive dc current to “+”
terminal
dimensions
16 x 9.0 x 3.0
magnet
Nd-Fe-B
material
PBT
cone material
PEEK
terminal
spring contact
88
10,000
Hz
91
dB
15
2.53
V
mm
weight
1.0
g
operating temperature
-20
75
°C
storage temperature
-30
85
°C
RoHS
Notes:
yes
1. All specifications measured at 5~35°C, humidity at 45~85%, under 86~106 kPa pressure, unless otherwise noted.
cuidevices.com
Product Page
3D Model
CUI DEVICES | MODEL: CMS-16098A-SP | DESCRIPTION: SPEAKER
MECHANICAL DRAWING
units: mm
tolerance: ±0.2 mm
Recommended
PAD Layout
Note:
1. Maximum compression force between front frame and back frame & yoke is 5 N.
cuidevices.com
PCB Footprint
date 08/05/2022 | page 2 of 5
Product Page
3D Model
PCB Footprint
RESPONSE CURVES
Frequency Response Curve
Total Harmonic Distortion Curve
cuidevices.com
date 08/05/2022 | page 3 of 5
Product Page
3D Model
PACKAGING
units: mm
Tray Size: 290 x 220 mm
Carton Size: 590 x 350 x 290 mm
Tray QTY: 100 pcs per tray
Carton QTY: 5,000 pcs per carton
ഔ
3&6
ഔ
3&6
cuidevices.com
PCB Footprint
date 08/05/2022 | page 4 of 5
Product Page
3D Model
PCB Footprint
date 08/05/2022 | page 5 of 5
REVISION HISTORY
rev.
description
date
1.0
initial release
07/06/2017
1.01
updated packaging
12/17/2019
logo, datasheet style update
08/05/2022
1.02
The revision history provided is for informational purposes only and is believed to be accurate.
CUI Devices offers a one (1) year limited warranty. Complete warranty information is listed on our website.
CUI Devices reserves the right to make changes to the product at any time without notice. Information provided by CUI Devices is believed to be accurate
and reliable. However, no responsibility is assumed by CUI Devices for its use, nor for any infringements of patents or other rights of third parties which may
result from its use.
CUI Devices products are not authorized or warranted for use as critical components in equipment that requires an extremely high level of reliability. A
critical component is any component of a life support device or system whose failure to perform can be reasonably expected to cause the failure of the life
support device or system, or to affect its safety or effectiveness.
cuidevices.com
很抱歉,暂时无法提供与“CMS-16098A-SP”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 100+12.24123100+1.48490
- 300+12.18403300+1.47796
- 500+12.18376500+1.47793
- 1500+12.183491500+1.47790
- 2500+12.183222500+1.47787
