Transient Voltage Suppressors (TVS)
1.5KE Series
Description
The 1.5KE series is designed specifically to protect sensitive
electronic equipment from voltage transients induced by
lightning and other transient voltage events.
Features
l Fast response time
l Matte tin lead–free Plated
l Low incremental surge resistance
l Halogen free and RoHS compliant
Electrical symbol
l Typical IR less than 1μA above 12V
l Compatible with industrial
ndustrial standard package DO
DO-201
l For surface mounted applications to optimize board space
BI
l 1500W
00W peak pulse power capability with at 10/1000μs
waveform,repetition rate (duty cycle): 0.01%
Cathode
Anode
l High temperature soldering guaranteed
guaranteed:260°C/ 10 seconds
UNI
Part Number Code
1
5
K
E
Series code
x
x
x
C
A
Reverse
Stand-Off
Voltage
5% Voltage
Tolerance
Blank:Uni-Directional
C:Bi-Directional
Mechanical Characteristics
Rating
Symbol
Value
Units
Peak Pulse Power Dissipation by 10x1000μs
1000μs test Waveform (Note1) (Fig. 2)
PPP
1500
W
Steady State Power Dissipation on inifinite heat sink at TL=75°C(Fig. 6)
PD
5.0
W
Peak Forward Surge Current, 8.3ms Single Half Sine
Sine-Wave Unidirectional only
(Note 2)
IFSM
100
A
VF
3.5/6.5
V
TJ,TSTG
-55 to 150
°C
Maximum instantaneous forward voltage at 50 A for unidirectional only
Operating junction and Storage Temperature Range.
1. Non-repetitive current pulse , per Fig. 4 and derated above TA = 25°C per Fig. 3.
2. Measured on 8.3ms single half sine-wave
wave or equivalent square wave, duty cycle=4 pulses per minute maximum.
Specifications are subject to change without notice.
Please refer to http://www.ruilon.com.cn for current information.
Revised: 2022-04-24
Page:1
1.5KE Series
Electrical Characteristics
Reverse
Stand-Off
Off
Voltage
Type Number
VRWM
Breakdown
Voltage
Test Current
Max.
Clamping
Voltage
10/1000µ
µs
Max.
Peak Pulse
Current
10/1000µs
Reverse
Leakage
IT
VC@IPP
IPP
IR@VRWM
VBR @IT
Min
Max
UNI
BI
V
V
V
mA
V
A
µA
1.5KE6.8A
1.5KE6.8CA
5.8
6.45
7.14
10
10.5
143.0
1000
1.5KE7.5A
1.5KE7.5CA
6.4
7.13
7.88
10
11.3
132.0
500
1.5KE8.2A
1.5KE8.2CA
7.0
7.79
8.61
10
12.1
124.0
200
1.5KE9.1A
1.5KE9.1CA
7.8
8.6
9.55
1
13.4
112.0
50
1.5KE10A
1.5KE10CA
8.6
9.50
10.50
1
14.5
103.0
10
1.5KE11A
1.5KE11CA
9.4
10.50
11.60
1
15.6
96.0
5
1.5KE12A
1.5KE12CA
10.2
11.40
12.60
1
16.7
90.0
5
1.5KE13A
1.5KE13CA
11.1
12.40
13.70
1
18.2
82.0
1
1.5KE15A
1.5KE15CA
12.8
14.30
15.80
1
21.2
71.0
1
1.5KE16A
1.5KE16CA
13.6
15.20
16.80
1
22.5
67.0
1
1.5KE18A
1.5KE18CA
15.3
17.10
18.90
1
25.2
59.5
1
1.5KE20A
1.5KE20CA
17.1
19.00
21.00
1
27.7
54.0
1
1.5KE22A
1.5KE22CA
18.8
20.90
23.10
1
30.6
49.0
1
1.5KE24A
1.5KE24CA
20.5
22.80
25.20
1
33.2
45.0
1
1.5KE27A
1.5KE27CA
23.1
25.70
28.40
1
37.5
40.0
1
1.5KE30A
1.5KE30CA
25.6
28.50
31.50
1
41.4
36.0
1
1.5KE33A
1.5KE33CA
28.2
31.40
34.70
1
45.7
33.0
1
1.5KE36A
1.5KE36CA
30.8
34.20
37.80
1
49.9
30.0
1
1.5KE39A
1.5KE39CA
33.3
37.10
41.00
1
53.9
28.0
1
1.5KE43A
1.5KE43CA
36.8
40.90
45.20
1
59.3
25.3
1
1.5KE47A
1.5KE47CA
40.2
44.70
49.40
1
64.8
23.2
1
1.5KE51A
1.5KE51CA
43.6
48.50
53.60
1
70.1
21.4
1
1.5KE56A
1.5KE56CA
47.8
53.20
58.80
1
77.0
19.5
1
1.5KE62A
1.5KE62CA
53.0
58.90
65.10
1
85.0
17.7
1
1.5KE68A
1.5KE68CA
58.1
64.60
71.40
1
92.0
16.3
1
1.5KE75A
1.5KE75CA
64.1
71.30
78.80
1
103.0
14.6
1
1.5KE82A
1.5KE82CA
70.1
77.90
86.10
1
113.0
13.3
1
1.5KE91A
1.5KE91CA
77.8
86.50
95.50
1
125.0
12.0
1
1.5KE100A
1.5KE100CA
85.5
95.00
105.00
1
137.0
11.0
1
1.5KE110A
1.5KE110CA
94.0
105.00
116.00
1
152.0
9.9
1
Revised: 2022-04-24
Page:2
1.5KE Series
Reverse
Stand-Off
Off
Voltage
Type Number
VRWM
Breakdown
Voltage
Test Current
Max.
Clamping
Voltage
10/1000µ
µs
Max.
Peak Pulse
Current
10/1000µs
Reverse
Leakage
IT
VC@IPP
IPP
IR@VRWM
VBR @IT
Min
Max
UNI
BI
V
V
V
mA
V
A
µA
1.5KE120A
1.5KE120CA
102.0
114.00
126.00
1
165.0
9.1
1
1.5KE130A
1.5KE130CA
111.0
124.00
137.00
1
179.0
8.4
1
1.5KE150A
1.5KE150CA
128.0
143.00
158.00
1
207.0
7.2
1
1.5KE160A
1.5KE160CA
136.0
152.00
168.00
1
219.0
6.8
1
1.5KE170A
1.5KE170CA
145.0
162.00
179.00
1
234.0
6.4
1
1.5KE180A
1.5KE180CA
154.0
171.00
189.00
1
246.0
6.1
1
1.5KE200A
1.5KE200CA
171.0
190.00
210.00
1
274.0
5.5
1
1.5KE220A
1.5KE220CA
185.0
209.00
231.00
1
328.0
4.6
1
1.5KE250A
1.5KE250CA
214.0
237.00
263.00
1
344.0
4.4
1
1.5KE300A
1.5KE300CA
256.0
285.00
315.00
1
414.0
3.6
1
1.5KE350A
1.5KE350CA
300.0
332.00
368.00
1
482.0
3.1
1
1.5KE400A
1.5KE400CA
342.0
380.00
420.00
1
548.0
2.8
1
1.5KE440A
1.5KE440CA
376.0
418.00
462.00
1
602.0
2.5
1
1.5KE480A
1.5KE480CA
408.0
456.00
504.00
1
658.0
2.3
1
I-V Curve Characteristics
Uni-directional
I
Bi-directional
IPP
VC VBR VR
IR VF
IT
VC VBR VR
V
IT
IR
IR
IT
VR VBR VC
V
IPP
IPP
PPPM Peak Pulse Power Dissipation -- Max power dissipation
VR Stand-off Voltage -- Maximum voltage that can be applied to the TVS without operation
VBR Breakdown Voltage -- Maximum voltage that flows though the TVS at a specified test current (IT)
VC Clamping Voltage -- Peak voltage measured across the TVS at a specified Ippm (peak impulse current)
IR Reverse Leakage Current – Current measured at VR
VF Forward Voltage Drop for Uni-directional
directional
Revised: 2022-04-24
Page:3
1.5KE Series
Ratings and Characteristic Curves (TA=25°C unless otherwise noted)
Figure 1 - TVS Transients Clamping Waveform
Figure 2 - Peak Pulse Power Rating Curve
100
Voltage Transients
PPPM-Peak Pulse Power (kW)
TJ initial = Tamb
Voltage or Current
Voltage Across TVS
Current Through TVS
stacked-die, 2kW at
stacked
10x1000µs, 25°C
10
Single die, 1.5kW at
10x1000µs, 25°C
1
0.1
0.001
0.01
Figure 3 - Pulse Derating Curve
IPPM - Peak Pulse Cur rent, % IRSM
tr=10μsec
75
50
25
50
75
100
125 150 175
Half Value
IPPM ( IPPM )
2
50
10/1000μsec.Waveform
as defined by R.E.A
td
1.0
Uni-directional
directional V=0V
Uni-directional @VR
100
Bi-directional
directional @VR
1
10.0
100.0
1000.0
PM(AV), Steady State Power Dissipation (W)
Bi-directional V=0V
1.0
4.0
5.0
4.0
3.0
2.0
60Hz Resistive or
Inductive Load
1.0
0.0
VBR - Reverse Breakdown Voltage (V)
3.0
Figure 6 - Steady State Power Derating Curve
10000
Tj=25ºC
f=1.0MHz
Vsig=50mVp-p
2.0
t-Time(ms)
100000
10
TJ =25°C
Pulse Width(td) is defined
as the point where the peak
current decays to 50% of IPPM
Peak Value
IPPM
100
200
Figure 5 -Typical Junction Capacitance
1000
10
150
TA-Ambient temperature (ºC)
C)
Cj (pF)
1
Figure 4 - Pulse Waveform
100
Peak Pulse Power (PPP) or Current (IPP)
Derating in Percentage %
0.
0.1
td-Pulse
Pulse Width (ms)
Time
Revised: 2022-04-24
50
75
100 125 150
TL-Lead
Lead Temperature(ºC)
Temperature(
175
200
Page:4
1.5KE Series
Figure 7 - Maximum Non-Repetitive Surge Current
IFSM - Peak Forward Surve Current
(A)
120
Pulse Width 8.3ms
Single Half-Sine
Sine-Wave
(JEDEC METHOD)
100
80
60
40
10
100
Number of Cycles at 60 Hz
Part Marking System
Cathode band (for Uni-directional products only)
1.5KExxxCA
xxxCA
Type Number
Dimensions
Millimeters
Inches
DIM
Revised: 2022-04-24
Min
Max
Min
Max
A
25.40
1.000
B
7.20
9.50
0.283
0.374
C
0.96
1.07
0.038
0.042
D
4.80
5.50
0.189
0.217
Page:5
1.5KE Series
Packaging Information
Symbol
Millimeters
Inches
A
10±0.5
0.394±0.019
B
53.0±1.0
2.087±0.039
Z
1.2Max
0.047 Max
T
6.0±0.5
0.236±0.019
E
0.8Max
0.031 Max
L1-L2
1.0Max
0.039 Max
Symbol
Millimeters
Inches
D
250.0±5.0
9.843±0.197
C
75.0±5.0
2.953±0.197
H
114.0±5.0
4.488±0.197
Quantity
Revised: 2022-04-24
1000PCS / inner box
Page:6
很抱歉,暂时无法提供与“1.5KE27A”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+0.79000
- 30+0.76500
- 100+0.71500
- 500+0.66500
- 1000+0.64000
- 国内价格
- 5+1.92651
- 50+1.56363
- 150+1.40811
- 1000+1.14480
- 2000+1.05840
- 5000+1.00656
