SB5100
5.0Amp Schottky Barrier Rectifiers
DO-27
Features
The plastic package carries Underwriters Laboratory
Flammability Classification 94V-0
0.945 (24.0)
MIN.
Guardring for overvoltage protection
Low reverse leakage
0.220 (5.6)
0.197(5.0)
DIA.
High forward surge current capability
High temperature soldering guaranteed
0.375(9.5)
0.285(7.2)
250 C/10 seconds at terminals
Mechanical Data
0.945 (24.0)
MIN.
Case : Molded plastic body
Terminals : Solder plated, solderable per MIL-STD-750,Method 2026
0.052 (1.3)
0.035(0.9)
DIA.
Polarity : Polarity symbol marking on body
Mounting Position : Any
Weight : 0.0345 ounce, 0.98 grams
Dimensions in inches and (millimeters)
Maximum Ratings And Electrical Characteristics
Ratings at 25 C ambient temperature unless otherwise specified. Single phase half-wave 60Hz,resistive or inductive load,
for capacitive load current derate by 20%.
Parameter
SYMBOLS
SB5100
UNITS
Maximum repetitive peak reverse voltage
VRRM
100
V
Maximum RMS voltage
VRMS
70
V
Maximum DC blocking voltage
VDC
100
V
Maximum average forward rectified current
at TL =100 C
I(AV)
5.0
A
Peak forward surge current, 8.3ms single half
sine-wave superimposed on rated load
IFSM
120.0
A
Maximum instantaneous forward voltage at 5.0A
VF
0.85
V
IR
0.05
10
mA
RqJA
55.0
C/W
TJ
-55 to +150
C
TSTG
-55 to +150
C
Maximum DC reverse current T A =25 C
at rated DC blocking voltage TA=125 C
Typical thermal resistance
Operating junction temperature range
Storage temperature range
+86-769-22857832
huixin@hxkj.hk
Rev.01
Page 1 of 2
Ratings And Characteristic Curves
FIG. 2-MAXIMUM NON-REPETITIVE PEAK FORWARD
SURGE CURRENT PERLEG
140
Peak Forward Surage Current
Amperes
8.0
7.0
6.0
Amperes
Average Forward Rectified Current
FIG. 1- DERATING CURVE OUTPUT RECTIFIED CURRENT
5.0
4.0
3.0
2.0
1.0
0.0
60
80
100
120
140
120
100
80
60
f=60Hz
40
1Cycle
1
100
10
Lead Temperature
Number of cycles
FIG. 3-TYPICAL FORWARD VOLTAGE CHARACTERISTICS
FIG. 4-TYPICAL REVERSE LEAKAGE CHARACTERISTICS
50
100
10.0
1
0.1
0.01
0.2
0.3
0.4
0.5
0.6
0.7
0.8
0.9
1.0
INSTANTANEOUS FORWARD VOLTAGE,
VOLTS
INSTANTANEOUS REVERSE CURRENT,
MILLIAMPERES
CURRENT,AMPERES
TJ=25 C
10
TJ=100 C
1
0.1
0.01
0.001
TJ=25 C
60
80
100
PERCENT OF PEAK REVERSE VOLTAGE,%
+86-769-22857832
huixin@hxkj.hk
Rev.01
Page 2 of 2
很抱歉,暂时无法提供与“SB5100”相匹配的价格&库存,您可以联系我们找货
