FP5501WDPTR
FP5501WDPTR
    FITIPOWER(天鈺科技)
    TDFN10_3X3MM
    低饱和、低电压2通道双向电机驱动器
FP5501WDPTR 数据手册
FP5501 fitipower integrated technology lnc. Low-saturation, Low-voltage 2 Channels Bi-directional Motor Driver Description Features The FP5501 is a monolithic IC for low-saturation bi-directional low cost and high efficiency miniature two DC motor or stepper motor applications, such as driving shutter (DC actuator), auto-focus (stepper motor), iris (stepper motor) and accurate zoom (stepper motor) on cameras, vibration on mobile phone and other motor applications on portable devices.           Low Voltage Operation (VCC Min=1.8V) Full- and Half-Stepping Capability Low Saturation Voltage (Upper + Low Transistor Residual Voltage; 0.46V typ. at 400mA) Low Input Current Low Operating Current, Sleep Mode with Zero Current Drain Dead-Zone Protection High Output Sinking and Driving Capability Small, Thin, Highly Reliable Package (TDFN-10) Available COB Package Thermal Shutdown Protection Applications     Stepper Motor DSC Camera Module Motor Application on Portable Device Pin Assignments Ordering Information WD Package (TDFN-10)(3mm×3mm) FP5501□□□ TR: Tape/Reel Blank: Tube VCC 1 10 VOUT4 VIN4 2 9 VOUT3 VIN3 3 8 VOUT1 VIN1 4 7 VOUT2 VIN2 5 6 VSS FP5501 P: Green Package Type WD: TDFN-10 (3mm×3mm) CH: CHIP Figure 1. Pin Assignment of FP5501 (Top View) FP5501-1.7-JAN-2013 1 fitipower integrated technology lnc. FP5501 Block Diagram & Application Circuit 1. Shutter & Iris application Figure 1a. Dual DC Motor Application 2. Stepping motor for 1-2 phase excitation Figure 1b. Stepper Motor Application 3. Typical single dc motor control (paralleled outputs) Figure 1c. Single (paralleled) DC Motor Application FP5501-1.7-JAN-2013 2 FP5501 fitipower integrated technology lnc. Functional Pin Description Pin No. Pin Name Pin Function 1 VCC Power supply pin. 2 VIN4 Input pin. 3 VIN3 Input pin. 4 VIN1 Input pin. 5 VIN2 Input pin. 6 VSS Ground pin. 7 VOUT2 Output sinking or driving current pin. 8 VOUT 1 Output driving or sinking current pin. 9 VOUT 3 Output sinking or driving current pin. 10 VOUT 4 Output driving or sinking current pin. Block Diagram Figure 2. Block Diagram of FP5501 FP5501-1.7-JAN-2013 3 FP5501 fitipower integrated technology lnc. Absolute Maximum Ratings ● VCC to VSS ----------------------------------------------------------------------------------------------- -0.3V to +5.5V ● VIN and VOUT to VSS ---------------------------------------------------------------------------------- -0.3V to +6V ● Output Current per Channel *1 ----------------------------------------------------------------------- 0mA to 400mA ● Continuous Power Dissipation ------------------------------------------------------------------------ 486mW ● Junction Temperature ----------------------------------------------------------------------------------- +150°C ● Storage Temperature Range -------------------------------------------------------------------------- -65°C to +150°C ● Lead Temperature (Soldering, 10sec.) ------------------------------------------------------------- 260°C ● ESD (Human Body Model) *2 ------------------------------------------------------------------------- 4000V *1: Output current rating may be limited by ambient temperature and heat sinking. exceed the specified. Under any set of conditions, do not *2: ESD caution: ESD (electrostatic discharge) sensitive device. Electrostatic charges as high as 4000V readily accumulate on the human body and test equipment and can discharge without detection. Although this product features proprietary ESD protection circuitry, permanent damage may occur on devices subjected to high energy electrostatic discharges. Therefore, proper ESD precautions are recommended to avoid performance degradation or loss of functionality. Recommended Operating Conditions ● Supply Voltage VCC to VSS -------------------------------------------------------------------------- 1.8V to 5.5V ● Maximum Output Drop Voltage (400mA Output Current) -------------------------------------- 0.46V ● Operation Temperature Range ----------------------------------------------------------------------- -40°C to +125°C FP5501-1.7-JAN-2013 4 FP5501 fitipower integrated technology lnc. Electrical Characteristics (Unless otherwise noted, TA=25°C & VCC=3V) Parameter Symbol Supply Voltage Conditions VCC Supply Current ( ICC + ISS) Min. Typ. Max. Unit 1.8 3.0 5.5 V ICC0 VVIN1, VIN2, VIN3, VIN4=0V - 0.1 10 μA ICC1 VVIN1, VIN2, VIN3, VIN4 ≠0V - 0.15 0.4 mA 1.5 - VIN 1 / VIN 2 / VIN3 / VIN4 Input Terminal ( TJ=25°C) Input Voltage “H” VINH Input Voltage “L” VINL Input Voltage Hysteresis VHsy Input Current “H” IINH Input Current “L” IINL V - 0.4 V - 0.42 - V VIN=VCC - - 5 μA VIN=0V - - 5 μA VOUT1 / VOUT 2 / VOUT 3 / VOUT 4 Output Terminal (TJ=25°C) VSAT1 IOUT=200mA - 0.22 0.4 V VSAT2 IOUT=400mA - 0.46 0.7 V Protection Temperature TTSD VVIN1, VIN2, VIN3, VIN4=H - 150 - °C Temperature Hysteresis THsy VVIN1, VIN2, VIN3, VIN4=H - 25 - °C Output Voltage (Upper + Lower) Thermal Protection Circuit Truth Table VIN1 or 3 VIN2 or 4 VOUT1 or 3 VOUT2 or 4 Low Low OFF OFF Standby High Low High Low Forward Low High Low High Reverse High High --- --- FP5501-1.7-JAN-2013 Mode Keep the Previous Mode (Forward / Reverse) 5 FP5501 fitipower integrated technology lnc. Truth Table Test Waves Figure 3. Truth Table Test Waves Characteristic Performance Curve Figure 4a. VSAT vs. IOUT FP5501-1.7-JAN-2013 Figure 4b. ISS vs. VCC 6 FP5501 fitipower integrated technology lnc. Motor Operation Truth Table INX *1 VOUT1*2 VOUT2 VOUT3 VOUT4 Function Stepper Motor VIN1 VIN2 VIN3 VIN4 VOUT1*2 VOUT2 VOUT3 VOUT4 Full-Stepping Half-Stepping 0 0 0 0 OFF OFF OFF OFF Sleep Mode Sleep Mode 1 0 1 0 H L H L Step1 *3 Step1 0 0 1 0 OFF OFF H L Step1_1 *4 Step2 0 1 1 0 L H H L Step2 Step3 0 1 0 0 L H OFF OFF Step2_1 Step4 0 1 0 1 L H L H Step3 Step5 0 0 0 1 OFF OFF L H Step3_1 Step6 1 0 0 1 H L L H Step4 Step7 1 0 0 0 H L OFF OFF Step4_1 Step8 DC Motor (Dual) VIN1 or VIN3 VIN2 or VIN4 VOUT1*2 VOUT2 VOUT3 VOUT4 Function 0 0 OFF OFF OFF OFF Sleep Mode 1 0 H L H L Forward 0 1 L H L H Reverse 1 1 -- -- -- -- Keep the previous mode (Forward/Reverse) DC Motor (Single, Paralleled) VIN1 or VIN3 VIN2 or VIN4 VOUT1*2 VOUT2 VOUT3 VOUT4 Function 0 0 OFF OFF OFF OFF Sleep Mode 1 0 H L H L Forward 0 1 L H L H Reverse 1 1 -- -- -- -- Keep the previous mode (Forward/Reverse) *1: 0=logic low, VinxVIH (min.). *2: H=voltage high, source driver on; L=voltage low, sink driver on. *3: Two phase on stepper motor drive *4: One phase on stepper motor drive FP5501-1.7-JAN-2013 7 fitipower integrated technology lnc. FP5501 Function Description Device Operation The FP5501 is a dual full-bridge low voltage motor driver capable of operating one stepper motor or up to two dc motors. MOSFET output stages substantially reduce the voltage drop and the power dissipation of the outputs of the FP5501 compared to typical drivers with bipolar transistors. Internal circuit protection includes thermal shutdown with hysteresis and crossover current protection. The FP5501 is designed for portable applications with a power-off (sleep mode) current of 100nA typical, and an operating voltage of 1.8V to 5.5V. The FP5501 logic inputs are 3 to 5V logic compatible. In conditions where the logic supply voltage drops below 1.8V, both the sink and the source voltage drop will increase beyond the specified values. In extreme cases, no power will be delivered to the motors. However, the device will not be damaged. In stepping operation, the device can drive in either full- or half-step mode. The stepping mode is set by the signal pattern on the Inx terminals, as shown in the stepping timing diagrams. Sleep Mode Pulling all inputs to 0.4V or less, sends the FP5501 to sleep mode, during which it draws 100nA typical. Thermal Shutdown The FP5501 will disable the outputs if the junction temperature reaches 150ºC. When thermal shutdown is entered, after the junction temperature drops 15ºC, the outputs will be re-enabled. FP5501-1.7-JAN-2013 8 fitipower integrated technology lnc. FP5501 Application Notes Figure 5a. Typical stepper motor control application Figure 5b. Full step mode timing chart (two phase on) Figure 5c. Full step mode timing chart (one phase on) FP5501-1.7-JAN-2013 9 fitipower integrated technology lnc. FP5501 Application Notes (Continued) Figure 5d. Half step mode timing chart Figure 6. Typical dual dc motor control application. Either IN1 or IN2 and be used to drive OUT1 and OUT2. FP5501-1.7-JAN-2013 Either IN3 or IN4 and be used to drive OUT3 and OUT4. 10 fitipower integrated technology lnc. FP5501 Application Notes (Continued) Figure 7. Typical single dc motor control application (paralleled outputs). Figure 8. Typical dual dc motor control application (timing chart) The power dissipated by the IC varies widely with the supply voltage, the output current, and loading. It is important to ensure the application does not exceed the allowable power dissipation of the IC package. The recommended motor driver power dissipation versus temperature is depicted as follows: FP5501-1.7-JAN-2013 11 FP5501 fitipower integrated technology lnc. Outline Information TDFN-10 3mm x 3mm (pitch 0.5 mm) Package (Unit: mm) SYMBOLS UNIT DIMENSION IN MILLIMETER MIN MAX A 0.70 0.80 A1 0.00 0.05 A2 0.18 0.25 D 2.95 3.05 E 2.95 3.05 a 0.30 0.50 b 0.18 0.30 e 0.45 0.55 D1 2.20 2.70 E1 1.40 1.75 Carrier Dimensions Life Support Policy Fitipower’s products are not authorized for use as critical components in life support devices or other medical systems. FP5501-1.7-JAN-2013 12
FP5501WDPTR 价格&库存
很抱歉,暂时无法提供与“FP5501WDPTR”相匹配的价格&库存,您可以联系我们找货
FP5501WDPTR
  • 1+1.81250
  • 30+1.75000
  • 100+1.62500
  • 500+1.50000
  • 1000+1.43750
