ASDM3020S
30V Dual N-Channel MOSFET
Features
Dual N-Channel
Enhancement mode
Fast Switching
High Effective
Product Summary
VDS
RDS(on),max.@VGS=10V
$SSOLFDWLRQV
ID
Power Management in Inverter System
Synchronous Rectification
30
V
12.5
mΩ
12
A
top view
ASCEND
SOP-8
Maximum ratings, at T A=25 °C, unless otherwise specified
Symbol
Parameter
V(BR)DSS
Drain-Source breakdown voltage
IS
Diode continuous forward current
ID
Continuous drain current @VGS=10V
IDM
Pulse drain current tested ①
EAS
Avalanche energy, single pulsed ②
PD
Maximum power dissipation
VGS
Gate-Source voltage
Unit
30
V
TA =25°C
12
A
TA =25°C
12
A
TA =100°C
7.3
A
TA =25°C
48
A
26
mJ
2
W
±20
V
TA =25°C
MSL
TSTG , TJ
Rating
Level 3
Storage and junction temperature range
-55 to 150
°C
Typical
Unit
40
°C/W
62.5
°C/W
Thermal Characteristics
Symbol
Parameter
RθJL
Thermal Resistance, Junction-to-Lead
R JA
Thermal Resistance, Junction-to-Ambient
NOV 2021 Version1.0
1/7
www.ascendsemi.com
0755-86970486
ASDM3020S
Typical Electrical Characteristics
Symbol
Parameter
Condition
Min.
Typ.
Max.
Unit
Static Electrical Characteristics @ TJ = 25°C (unless otherwise stated)
Drain-Source Breakdown Voltage
VGS=0V, ID=250μA
30
V
Zero Gate Voltage Drain Current(Tj=25℃)
VDS=30V,VGS=0V
1
μA
Zero Gate Voltage Drain Current(Tj=125℃)
VDS=30V,VGS=0V
100
μA
IGSS
Gate-Body Leakage Current
VGS=±20V,VDS=0V
±100
nA
VGS(TH)
Gate Threshold Voltage
VDS=VGS,ID=250μA
1.0
1.3
2.0
V
RDS(ON)
Drain-Source On-State Resistance
③
VGS=10V, ID=10A
10.5
12.5
mΩ
RDS(ON)
③
VGS=4.5V, ID=6A
13.5
16
mΩ
780
1250
1500
pF
100
210
250
pF
70
150
200
pF
3.5
Ω
17
nC
3.8
nC
4.8
nC
6.5
nS
V(BR)DSS
IDSS
Dynamic Electrical Characteristics @ TJ = 25°C (unless otherwise stated)
Ciss
Input Capacitance
Coss
Output Capacitance
Crss
Reverse Transfer Capacitance
Rg
Gate Resistance
Qg
Total Gate Charge
Qgs
Gate-Source Charge
Qgd
Gate-Drain Charge
VDS=15V,VGS=0V,
f=1MHz
f=1MHz
VDS=15V,ID=10A,
VGS=10V
Switching Characteristics
t d(on)
Turn-on Delay Time
tr
Turn-on Rise Time
ID=10A,
11.2
nS
t d(off)
Turn-Off Delay Time
RG=3Ω,
20.7
nS
tf
Turn-Off Fall Time
5.3
nS
VDD=15V,
VGS=10V
Source- Drain Diode Characteristics@ TJ = 25°C (unless otherwise stated)
VSD
Forward on voltage
ISD=2A,VGS=0V
0.8
1.2
V
t rr
Reverse Recovery Time
Tj=25℃,Isd=10A,
nS
Qrr
Reverse Recovery Charge
VGS=0V
di/dt=500A/μs
11.5
nC
NOTE:
① Repetitive rating; pulse width limited by max. junction temperature.
② Limited by TJmax, starting TJ = 25°C, L = 0.5mH,RG = 25Ω, IAS = 8A, VGS =10V. Part not recommended for use above this value
③ Pulse width ≤ 300μs; duty cycle≤ 2%.
NOV 2021 Version1.0
2/7
www.ascendsemi.com
0755-86970486
ASDM3020S
ID, Drain-Source Current (A)
VGS(TH), Gate -Source Voltage (V)
Typical Performance Characteristics
Tj - Junction Temperature (°C)
Fig2. Threshold Voltage Vs. Temperature
Normalized On Resistance
VDS, Drain -Source Voltage (V)
Fig1. Typical Output Characteristics
Fig4. Normalized On-Resistance Vs. Temperature
I
SD,
ID - Drain Current (A)
Reverse Drain Current (A)
VGS, Gate -Source Voltage (V)
Fig3. Typical Transfer Characteristics
VSD, Source-Drain Voltage (V)
Fig5. Typical Source-Drain Diode Forward Voltage
NOV 2021 Version1.0
3/7
Fig6. Maximum Safe Operating Area
www.ascendsemi.com
0755-86970486
ASDM3020S
C, Capacitance (pF)
VGS, Gate-Source Voltage (V)
VDS , Drain-Source Voltage (V)
Fig8. Typical Gate Charge Vs.Gate-Source Voltage
Transient Thermal Resistance
r(t) , Normalized Effective
Fig7. Typical Capacitance Vs.Drain-Source Voltage
Qg -Total Gate Charge (nC)
T1, Square Wave Pulse Duration(sec)
Fig9. T1 ,Transient Thermal Response Curve
Fig10. Unclamped Inductive Test Circuit and
Fig11. Switching Time Test Circuit and waveforms
waveforms
NOV 2021 Version1.0
4/7
www.ascendsemi.com
0755-86970486
ASDM3020S
Ordering and Marking Information
Ordering Device No.
Marking
Package
Packing
Quantity
ASDM3020S-R
3020
SOP8
Tape&Reel
4000/Reel
PACKAGE
MARKING
3020
SOP8
NOV 2021 Version1.0
5/7
www.ascendsemi.com
0755-86970486
ASDM3020S
SOP-8 PACKAGE IN FORMATION
Symbol
Dimensions in Millimeters
Min
Dimensions in Inches
Min
Max
A
1.75
0.069
A1
0.00
0.26
0.000
0.010
A2
1.30
1.70
0.051
0.067
b
0.30
0.55
0.012
0.022
C
0.15
0.35
0.006
0.014
D
4.80
5.00
0.189
0.197
E
3.80
4.00
0.150
0.157
1.27 TYP
e
NOV 2021 Version1.0
Max
0.050 TYP
H
5.70
6.30
0.224
0.248
L
0.45
0.85
0.018
0.033
θ
0∘
8∘
0∘
8∘
6/7
www.ascendsemi.com
0755-86970486
ASDM3020S
IMPORTANT NOTICE
ShenZhen Ascend Semiconductor incorporated MAKES NO WARRANTY OF ANY KIND, EXPRESS OR IMPLIED, WITH REGARDS TO THIS
DOCUMENT, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR
PURPOSE (AND THEIR EQUIVALENTS UNDER THE LAWS OF ANY JURISDICTION).
ShenZhen Ascend Semiconductor Incorporated and its subsidiaries reserve the right to make modifications, enhancements, improvements,
corrections or other changes without further notice to this document and any product described herein. ShenZhen Ascend Semiconductor
Incorporated does not assume any liability arising out of the application or use of this document or any product described herein; neither
does ShenZhen Ascend Semiconductor Incorporated convey any license under its patent or trademark rights, nor the rights of others. Any
Customer or user of this document or products described herein in such applications shall assume .
all risks of such use and will agree to hold Ascendsemi Incorporated and all the companies whose products are represented on ShenZhen
Ascend Semiconductor Incorporated website, harmless against all damages.
ShenZhen Ascend Semiconductor Incorporated does not warrant or accept any liability whatsoever in respect of any products purchased
through unauthorized sales channel. Should Customers purchase or use ShenZhen Ascend Semiconductor Incorporated products for any
unintended or unauthorized application, Customers shall indemnify and hold ShenZhen Ascend Semiconductor Incorporated and its
representatives harmless against all claims, damages, expenses, and attorney fees arising out of, directly or indirectly, any claim of personal
injury or death associated with such unintended or unauthorized application.
www.ascendsemi.com
NOV 2021 Version1.0
7/7
www.ascendsemi.com
0755-86970486
