24C02
24C02
    HX(恒佳兴)
    SOP8_150MIL
    EEPROM存储器 1.8V~5.5V 2K bits
24C02 数据手册
24C02 串行 I2C总线 EEPROM 1. PROM ,采用 256×8-bit 的组织架构 24C02 1.8V ,待机电流和工作 以及两行串行接口。 。 1μA 1mA 24C02 具有页写能力,每页为 8 电流分别为 8-pin PDIP 8-pin SOP 5-pin SOT23-5 字节。24C02 三种封装形式。 2. ● ● ● 1.8V~5.5V SCL GND SDA 1 5 WP 4 VCC 2 3 封装:SOP-8 - 1mA - 1μA - 24C02, 256 X 8 (2K bits) ● 2 I2C ● I2C 1 MHz (5V), 400 kHz (1.8V, 2.5V, 2.7V) ● ● ( 5 ms) ● ● ● 8 ● ● ● ESD 2.5kV ● 100 00 100 ● 8-pin DIP 8-pin n SOP RoHS ● ● ● ● ● ● ● 4. 封装 工作温度范围 SOP8L D IP 8 L 订购型号 无铅 24C02D 24C02P A0 1 8 VCC A1 2 7 WP A2 3 6 SCL GND 4 5 SDA ( 3. -4 0 ℃~ + 8 5 ℃ 封装: 5L SOT-23-5 标准包装数 1 0 0 片/ 管 5 0 片/ 管 C02 ) 24C02 串行 I2C总线 EEPROM 5. Ḛ೒ WP VCC SCL GND START STOP LOGIC SDA EN SERIAL CONTROL LOGIC HIGH VOLTAGE PUMP/TIMING LOAD COMP DATA RECOVERY DEVICE ADDRESS COMPARATOR 24C02 LOAD A0 INC X DECODER A1 DATA WORD ADDRESS COUNTER A2 EEPROM Y DECODER SERIAL MUX DIN DOUT/ACKNOWLEDGE DOUT ೒1Ḛ೒ 6. ᳔໻乱ᅮখ᭄ ໻乱ᅮখ᭄ ᳔໻乱ᅮখ᭄ৃ㛑Ӯᇐ㟈఼ӊᤳണ (䍙ߎ᳔໻乱ᅮখ᭄ৃ㛑Ӯᇐ㟈఼ӊᤳണ) খ খ᭄ ヺো ؐ ऩԡ Ⳉ⌕կ⬉⬉य़ VCC -0.3 ~ +6.5 V Ⳉ⌕䕧ܹ⬉य़ 䕧ܹ⬉य़ VIN -0.3 ~ VCC +0.3 V Ⳉ⌕䕧ߎ⬉य़ ߎ⬉य़ VOUT -0.3 ~ VCC +0.3 V ᄬ‫⏽ټ‬ᑺ TSTG -65 ~ +150 °C 2500 V 200 V ESD⬉य़ (Ҏԧ῵ൟ) VESD ESD⬉य़ (ᴎ఼῵ൟ) 7. ᥼㤤Ꮉ԰ᴵӊ (ᑨ೼᥼㤤Ꮉ԰ᴵӊϟᅲ⦄ࡳ㛑) খ᭄ ヺো ᳔ᇣؐ ᳔໻ؐ ऩԡ Ⳉ⌕կ⬉⬉य़ VCC 1.8 5.5 V Ꮉ԰⏽ᑺ TA -40 +85 °C 24C02 串行 I2C总线 EEPROM 8. ᓩ㛮⬉ᆍ (ᴵӊ˖TA = 25°C, f = 1.0 MHz, VCC = +1.8V) ᳔ᇣؐ ᳔໻ؐ ヺো ⌟䆩ᴵӊ 䕧ܹ/䕧ߎ⬉ᆍ(SDA) CI/O VI/O = 0V 8 pF 䕧ܹ⬉ᆍ(A0, A1, A2, SCL) CIN VIN = 0V 6 pF খ᭄ ऩԡ 9. Ⳉ⌕⬉⇨⡍ᗻ (ᴵӊ˖TA = 0°C ̚ +70°C, VCC = +1.8V ̚ +5.5Vˈ䰸䴲঺᳝⊼䞞) খ᭄ ⌟䆩ᴵӊ ヺো ᳔ᇣؐ ؐ ‫݌‬ൟؐ ᳔໻ؐ ऩԡ 100kHz 䇏 0.4 04 1.0 mA m 100kHz ‫ݭ‬ 2.0 3.0 mA VIN = VCC ៪ GND 1.0 μA ILI VIN = VCC ៪ GND 3.0 μA 䕧ߎⓣ⬉⌕ ILO VOUT = VCC ៪ GND 3.0 μA 䕧ܹԢ⬉ᑇ⬉य़ VIL -0.6 VCC×0.3 V 䕧ܹ催⬉ᑇ⬉य़ VIH VCC×0.7 VCC+0.5 V կ⬉⬉⌕ ICC VCC =5V ᕙᴎ⬉⌕ ISB 䕧ܹⓣ⬉⌕ 䕧ߎԢ⬉ᑇ⬉य़ 0.05 VOL3 VCCC =5.0V, IOL = 3.0 mA 0.4 V VOL2 VCC =3.0V, IOL = 2.1 mA 0.4 V VOL1 VCC =1.8V, IOL = 0.15 mA 0.2 V 10. Ѹ⌕⬉⇨⡍ᗻ (ᴵӊ˖TA = 0°C C ̚ +70°C, VCC = +1.8V ̚ +5.5V, +5.5 CL = 100 pFˈ䰸䴲঺᳝⊼䞞)     খ᭄ ヺো ᯊ䩳乥⥛, SCL fSCL ᯊ䩳Ԣ⬉ᑇᆑᑺ tLOW ᯊ䩳催⬉ᑇᆑᑺ tHIGH ాໄ⍜䰸ᯊ䯈 tI ᯊ䩳ϟ䰡⊓ࠄ᭄᥂ ᳝ᬜ䕧ߎ䯈䱨ᯊ䯈 tAA ᘏ㒓䞞ᬒᯊ䯈 tBUF ⌟䆩ᴵӊ ᳔ᇣؐ ‫݌‬ൟؐ ᳔໻ؐ ऩԡ VCC =1.8V 400 VCC =5V 1000 VCC =1.8V 1.2 VCC =5V 0.6 VCC =1.8V 0.6 VCC =5V 0.4 kHz μs μs VCC =1.8V 50 VCC =5V 40 VCC =1.8V 0.05 0.9 VCC =5V 0.05 0.55 VCC =1.8V 1.2 VCC =5V 0.5 ns μs μs 24C02 串行 I2C总线 EEPROM 10. Ѹ⌕⬉⇨⡍ᗻ(㓁) খ᭄ ヺো ⌟䆩ᴵӊ ᳔ᇣؐ ‫݌‬ൟؐ ᳔໻ؐ ऩԡ VCC =1.8V 0.6 VCC =5V 0.25 VCC =1.8V 0.6 VCC =5V 0.25 䍋ྟᴵӊֱᣕᯊ䯈 tHD.STA 䍋ྟᴵӊᓎゟᯊ䯈 tSU.STA ᭄᥂䕧ֱܹᣕᯊ䯈 tHD.DAT 0 μs μ ᭄᥂䕧ܹᓎゟᯊ䯈 tSU.DAT 100 0 ns 䕧ܹϞछᯊ䯈 tR 䕧ܹϟ䰡ᯊ䯈 tF ‫ذ‬ℶᴵӊᓎゟᯊ䯈 tSU.STO ᭄᥂䕧ߎֱᣕᯊ䯈 tDH ‫਼ݭ‬ᳳ tWR μs 300 VCC =1.8V 300 3 VCC =5V 100 100 8V VCC =1.8V 0.6 VCC =5V 0.25 ns n ns μs 50 ns 5 tHIG HIGH tF μs ms tR tLOW tLOW SCL tSU.STA tHD.STA tHD.DAT tSU.DAT tSU.STO SDA_IN tAA A tDH tBUF SDA_OUT ೒2ᘏ㒓ᯊᑣ SCL SDA 8th BIT ACK tWR(1) STOP CONDITION START CONDITION ⊼‫਼ݭ‬ᳳᯊ䯈W:5ᰃᣛҢϔϾ‫ݭ‬ᑣ߫ⱘ᳝ᬜ‫ذ‬ℶᴵӊᓔྟ㟇‫ݙ‬䚼‫਼ݭ‬ᳳ㒧ᴳⱘᯊ䯈DŽ ೒3 ‫਼ݭ‬ᳳᯊᑣ   24C02 串行 I2C总线 EEPROM 11. 1 A0 2 A1 3 A2 5 SDA 6 SCL 7 WP 4 GND 8 VCC A2 A1 A0 24C02 使用A2,A1和 A0输入引脚作为硬件地址,总线上可同时级联 8 个24C02 器件(详见器件寻址) VCC / SDA 10kΩ SCL WP WP VCC WP 12. 器件 24C02 总容量(位) 总页数 字节/ 页 2K 32 8 字地址长度 8位 24C02 串行 I2C总线 EEPROM 24C02 ᬃᣕI 2 Cᘏ㒓Ӵ䕧ण䆂DŽI 2 Cᰃϔ⾡ঠ৥ǃϸ㒓І㸠䗮䆃᥹ষˈߚ߿ᰃІ㸠᭄᥂ 㒓SDA੠І㸠ᯊ䩳㒓SCLDŽϸḍ㒓䛑ᖙ乏䗮䖛ϔϾϞᢝ⬉䰏᥹ࠄ⬉⑤DŽ‫݌‬ൟⱘᘏ㒓䜡㕂བ೒4᠔ ⼎ VCC RP RP SDA ϸ㒓І㸠 㒓І㸠 ᭄᥂ᘏ㒓 SCL MPU 24C02 ݊Ҫ໪ೈ ೒4‫݌‬ൟϸ㒓ᘏ㒓䜡㕂 ᘏ㒓Ϟথ䗕᭄᥂ⱘ఼ӊ㹿⿄԰থ䗕఼ˈ᥹ᬊ᭄᥂ⱘ఼ӊ㹿⿄԰᥹ᬊ఼DŽ᥻ࠊֵᙃѸᤶⱘ ఼ӊ㹿⿄԰Џ఼ӊˈফЏ఼ӊ᥻ࠊⱘ఼ӊ߭㹿⿄԰Ң఼ӊDŽЏ఼ӊѻ⫳І㸠ᯊ䩳SCLˈ᥻ࠊ ᘏ㒓ⱘ䆓䯂⢊ᗕǃѻ⫳START੠STOPᴵӊDŽ24C02 ೼I 2 C ᘏ㒓Ё԰ЎҢ఼ӊᎹ԰DŽ া᳝ᔧᘏ㒓໘Ѣぎ䯆⢊ᗕᯊᠡৃҹਃࡼ᭄᥂Ӵ䕧DŽ↣⃵᭄᥂Ӵ䕧ഛᓔྟѢSTARTᴵӊˈ 㒧ᴳѢSTOPᴵӊˈѠ㗙П䯈ⱘ᭄᥂ᄫ㡖᭄ᰃ≵᳝䰤ࠊⱘˈ⬅ᘏ㒓ϞⱘЏ఼ӊ‫އ‬ᅮDŽֵᙃҹᄫ 㡖˄8ԡ˅ЎऩԡӴ䕧ˈ㄀9ԡᯊ⬅᥹ᬊ఼ѻ⫳ᑨㄨDŽ 䍋ྟ੠‫ذ‬ℶᴵӊ ᭄᥂੠ᯊ䩳㒓䛑Ў催߭⿄ᘏ㒓໘೼ぎ䯆⢊ᗕDŽᔧSCLЎ催⬉ᑇᯊSDAⱘϟ䰡⊓˄催ࠄԢ S Ў催 ি‫خ‬䍋ྟᴵӊ˄STARTˈㅔ‫ݭ‬ЎS˅ˈSDAⱘϞछ⊓˄Ԣࠄ催˅߭ি‫ذخ‬ℶᴵӊ˄STOPˈㅔ ㅔ‫ݭ‬ЎS˅ˈSDAⱘϞछ⊓˄Ԣࠄ ‫ݭ‬ЎP˅DŽখ㾕೒5DŽ S S 䍋ྟᴵӊ ೒5 䍋ྟᴵӊ੠‫ذ‬ℶᴵӊⱘᅮН 24C02 串行 I2C总线 EEPROM 13. 䆺㒚᪡԰䇈ᯢ˄㓁˅ ԡӴ䕧 ↣Ͼᯊ䩳㛝‫ކ‬Ӵ䗕ϔԡ᭄᥂DŽSCLЎ催ᯊSDAᖙ乏ֱᣕ〇ᅮˈ಴ЎℸᯊSDAⱘᬍব㹿䅸Ў ᰃ᥻ࠊֵোDŽԡӴ䕧খ㾕೒6DŽ SDA ᭄᥂㒓 〇ᅮ ᭄᥂᳝ᬜ SCL ‫ܕ‬䆌 ᭄᥂ ᬍব ೒6 ԡӴ䕧 ᑨㄨ ѻ⫳ϔϾᑨㄨˈЏ఼ӊᖙ乏ѻ⫳ϔ ᘏ㒓Ϟⱘ᥹ᬊ఼↣᥹ᬊࠄϔϾᄫ㡖ህѻ⫳ϔϾᑨㄨˈЏ఼ӊᖙ乏ѻ⫳ϔϾᇍᑨⱘ乱໪ⱘ ᯊ䩳㛝‫ˈކ‬㾕೒7DŽ থ䗕఼䕧ߎⱘ᭄᥂ 䴲ᑨㄨ ᥂ ᥹ᬊ఼䕧ߎⱘ᭄᥂ ᑨㄨ ఼ӊথߎⱘSCL Џ఼ӊথߎⱘSCL 1 2 S 8 9 ᑨㄨᯊ䩳㛝‫ކ‬ 䍋ྟᴵӊ 䍋ྟᴵӊ ೒7 I 2 Cᘏ㒓ⱘᑨㄨ ԢSDA㒓 ᥹ᬊ఼ᢝԢSDA㒓㸼⼎ᑨㄨˈᑊ೼ᑨㄨ㛝‫ކ‬ᳳ䯈ֱᣕ〇ᅮⱘԢ⬉ᑇDŽᔧЏ఼ӊ԰᥹ᬊ఼ ᥂Ӵ ᯊˈᖙ乏থߎ᭄᥂Ӵ䕧㒧ᴳⱘֵো㒭থ䗕఼ˈेᅗ೼᳔ৢϔϾᄫ㡖Пৢⱘᑨㄨ㛝‫ކ‬ᳳ䯈ϡӮ ѻ⫳ᑨㄨֵো˄ϡᢝԢSDA˅DŽ䖭⾡ᚙ‫މ‬ϟˈথ䗕఼ᖙ乏䞞ᬒSDA㒓Ў催ҹ֓Џ఼ӊѻ⫳‫ذ‬ ℶᴵӊDŽ 24C02 串行 I2C总线 EEPROM ఼ӊᇏഔ 䍋ྟᴵӊՓ㛑㢃⠛䇏‫ݭ‬᪡԰ৢˈEEPROM䛑㽕∖᳝8ԡⱘ఼ӊഄഔֵᙃ˄㾕೒8˅DŽ ఼ӊഄഔֵᙃ⬅"1"ǃ"0"ᑣ߫㒘៤ˈࠡ4ԡབ೒Ё᠔⼎ˈᇍѢ᠔᳝І㸠EEPROM䛑ᰃϔḋⱘ DŽ ᇍѢ24C02ˈ䱣ৢ3ԡA2ǃA1੠A0Ў఼ӊഄഔԡˈᖙ乏Ϣ⹀ӊ䕧ܹᓩ㛮ֱᣕϔ㟈DŽ ఼ӊഄഔֵᙃⱘLSBЎ䇏/‫ݭ‬᪡԰䗝ᢽԡˈ催Ў䇏᪡԰ˈԢЎ‫ݭ‬᪡԰DŽ 㢹↨䕗఼ӊഄഔϔ㟈ˈEEPROMᇚ䕧ߎᑨㄨ"0"DŽབᵰϡϔ㟈ˈ߭䖨ಲࠄᕙᴎ⢊ᗕDŽ 24C02 24C02 1 0 1 0 A2 A1 A0 MSB R/W LSB ೒8 ఼ӊഄഔ ఼ӊ᪡԰ ᕙᴎ῵ᓣ EEPROM‫݋‬᳝Ԣࡳ㗫ᕙᴎⱘ⡍⚍ˈᴵӊЎ˖˄1˅⬉⑤Ϟ⬉˗˄2˅᥹ᬊ‫ذ‬ℶᴵӊঞᅠ៤ӏ ԩ‫ݙ‬䚼᪡԰ৢDŽ ᄬ‫ټ‬໡ԡ ᔧण䆂Ёѻ⫳Ёᮁǃᥝ⬉៪㋏㒳໡ԡৢˈI 2 Cᘏ㒓ৃ䗮䖛ҹϟℹ偸໡ԡ˖   ˄1˅ѻ⫳9Ͼᯊ䩳਼ᳳDŽ ˄2˅ᔧSCLЎ催ᯊˈSDAгЎ催DŽ ˄3˅ѻ⫳ϔϾ䍋ྟᴵӊDŽ ‫ݭ‬᪡԰ 1. ᄫ㡖‫ݭ‬ ‫ݭ‬᪡԰㽕∖೼᥹ᬊ఼ӊഄഔ੠ACKᑨㄨৢˈ᥹ᬊ8ԡⱘᄫഄഔDŽ᥹ᬊࠄ䖭ϾഄഔৢEEPROM ᑨㄨ"0"ˈ✊ৢᰃϔϾ8ԡ᭄᥂DŽ೼᥹ᬊ8ԡ᭄᥂ৢˈEEPROMᑨㄨ"0"ˈ᥹ⴔᖙ乏⬅Џ఼ӊথ䗕 ‫ذ‬ℶᴵӊᴹ㒜ℶ‫ݭ‬ᑣ߫DŽ ℸᯊEEPROM䖯ܹ‫ݙ‬䚼‫਼ݭ‬ᳳtWRˈ᭄᥂‫ܹݭ‬䴲ᯧ༅ᗻᄬ‫఼ټ‬Ёˈ೼ℸᳳ䯈᠔᳝䕧ܹ䛑᮴ᬜDŽ Ⳉࠄ‫਼ݭ‬ᳳᅠ៤ˈEEPROMᠡӮ᳝ᑨㄨ˄㾕೒9˅DŽ 䍋ྟ ᴵӊ ఼ӊ ഄഔ ‫ݭ‬ ᄫഄഔ ᭄᥂ ‫ذ‬ℶ ᴵӊ SDA 㒓 M S B L R AM S / CS BWK B LA SC BK ೒9 ᄫ㡖‫ݭ‬ A C K 24C02 串行 I2C总线 EEPROM 13. 2. 24C02器件按8字节/页执行页写。 页写初始化与字节写相同,只是主器件不会在第一个数据后发送停止条件,而是在EEPROM 收到每个数据后都应答“0”。最后仍需由主器件发送停止条件,终止写序列(见图10)。 接收到每个数据后,字地址的低3 位 内部自动加1 ,高位地址不变,维持在当前页内。当 随后的数据将写入该页的页首。如果超过 8 个数据传 内部产生的字地址达到该页边界地址时, 送给了EEPROM,字地址将回转到该页的首字节,先前的字节将会被覆盖。 䍋ྟ ᴵӊ ఼ӊ ഄഔ ‫ݭ‬ ᭄᥂ ( n ) ᄫ地址(n) ᭄᥂ ᥂ ( n+x ) ᭄᥂ ( n+1 ) ‫ذ‬ℶ ᴵӊ SDA 㒓 M S B L R AM S / CS BWK B LA SC BK A C K A C K A C K 图10页写 3. ᑨㄨᶹ䆶 ϔᮺ‫ݙ‬䚼‫਼ݭ‬ᳳਃࡼˈEEPROM䕧ܹ᮴ᬜˈℸᯊेৃਃࡼᑨㄨᶹ䆶˖থ䗕䍋ྟᴵӊ੠఼ӊ ᬜˈℸᯊेৃਃࡼᑨㄨᶹ䆶˖থ䗕 ഄഔ˄䇏/‫ݭ‬ԡЎᳳᳯⱘ᪡԰˅DŽা᳝‫ݙ‬䚼‫਼ݭ‬ᳳᅠ៤ˈEEPROMᠡᑨㄨ"0"DŽПৢৃ㒻㓁䇏/‫ݭ‬᪡ ‫਼ݭ‬ᳳᅠ៤ˈ ៤ EEPROMᠡᑨㄨ"0" ԰DŽ  ᑨㄨᶹ䆶⌕⿟㾕೒11DŽ থ䗕‫ݭ‬ੑҸ থ䗕‫ذ‬ℶᴵӊ ਃࡼ‫਼ݭ‬ᳳ থ䗕䍋ྟᴵӊ থ䗕᥻ࠊᄫ㡖 R/W = 0 ఼ӊᰃ৺ᑨㄨ (ACK = 0)? ৺ ᰃ ϟϔ᪡԰ ೒ᑨㄨᶹ䆶⌕⿟  24C02 串行 I2C总线 EEPROM 䇏᪡԰ 䇏᪡԰Ϣ‫ݭ‬᪡԰߱ྟ࣪Ⳍৠˈাᰃ఼ӊഄഔЁⱘ䇏/‫ݭ‬䗝ᢽԡᑨЎ"1"DŽ᳝ϝ⾡ϡৠⱘ䇏᪡԰ᮍ ᓣ˖ᔧࠡഄഔ䇏ˈ䱣ᴎ䇏੠乎ᑣ䇏DŽ 1. ᔧࠡഄഔ䇏 ‫ݙ‬䚼ഄഔ䅵఼᭄ֱᄬⴔϞ⃵䆓䯂ᯊ᳔ৢϔϾഄഔࡴ1ⱘؐDŽা㽕㢃⠛᳝⬉ˈ䆹ഄഔህϔⳈֱᄬDŽ ᔧ䇏ࠄ᳔ৢ义ⱘ᳔ৢᄫ㡖ˈഄഔӮಲ䕀ࠄ0˗ᔧ‫ࠄݭ‬ᶤ义ሒⱘ᳔ৢϔϾᄫ㡖ˈഄഔӮಲ䕀ࠄ䆹义ⱘ 佪ᄫ㡖DŽ ᥹ᬊ఼ӊഄഔ˄䇏/‫ݭ‬䗝ᢽԡЎ"1"˅ǃEEPROMᑨㄨACKৢˈᔧࠡഄഔⱘ᭄᥂ህ䱣ᯊ䩳䗕ߎ DŽ Џ఼ӊ᮴䳔ᑨㄨ"0"ˈԚ䳔থ䗕‫ذ‬ℶᴵӊ˄㾕೒12˅DŽ 䍋ྟ ᴵӊ ఼ӊ ഄഔ ᭄᥂ 䇏 ‫ذ‬ℶ ᴵӊ SDA 㒓 M S B N O L RA S/C BWK A C K ೒12ᔧࠡഄഔ䇏 2. 䱣ᴎ䇏 EEPROM 䱣ᴎ䇏䳔‫ݭܜ‬ϔϾⳂᷛᄫഄഔˈϔᮺEEPROM᥹ᬊ఼ӊഄഔ੠ᄫഄഔᑊᑨㄨњACKˈЏ ఼ӊህѻ⫳ϔϾ䞡໡ⱘ䍋ྟᴵӊDŽ ✊ৢˈЏ఼ӊথ䗕఼ӊഄഔ˄䇏/‫ݭ‬䗝ᢽԡЎ"1"˅ˈEEPROMᑨㄨACKˈᑊ䱣ᯊ䩳䗕ߎ᭄ ᥂DŽЏ఼ӊ᮴䳔ᑨㄨ"0"ˈԚ䳔থ䗕‫ذ‬ℶᴵӊ˄㾕೒13˅DŽ 䍋ྟ ᴵӊ ఼ӊ ഄഔ ഔ ᄫഄഔ (n) ‫ݭ‬ 䍋ྟ ᴵӊ ఼ӊ ഄഔ 䇏 ᭄᥂ (n) ‫ذ‬ℶ ᴵӊ SDA 㒓 M S B L R AM S / CS BWK B LA M SC S BK B N O LRA S /C BWK A C K ‫ݭ‬ഄഔ ೒13 䱣ᴎ䇏 3. 乎ᑣ䇏 ᑣ䇏 乎ᑣ䇏ৃҹ䗮䖛“ᔧࠡഄഔ䇏”៪“䱣ᴎ䇏”ਃࡼDŽЏ఼ӊ᥹ᬊࠄϔϾ᭄᥂ৢˈᑨㄨACKDŽা㽕 ᑣ䇏ৃҹ䗮䖛“ᔧࠡഄ EEPROM᥹ᬊࠄACKˈᇚ㞾ࡼ๲ࡴᄫഄഔᑊ㒻㓁䱣ᯊ䩳থ䗕ৢ䴶ⱘ᭄᥂DŽ㢹䖒ࠄᄬ‫఼ټ‬ഄഔ᳿ ᥹ᬊࠄACKˈᇚ ሒˈഄഔ㞾ࡼಲ䕀ࠄ0ˈҡৃ㒻㓁乎ᑣ䇏প᭄᥂DŽ ࡼಲ䕀ࠄ0 Џ఼ӊϡᑨㄨ"0"ˈ㗠থ䗕‫ذ‬ℶᴵӊˈेৃ㒧ᴳ乎ᑣ䇏᪡԰˄㾕೒14˅DŽ ㄨ"0 ఼ӊ ഄഔ 䇏 ᭄᥂ ( n ) ᭄᥂ ( n+1 ) ‫ذ‬ℶ ᭄᥂ ( n+x ) ᴵӊ ᭄᥂ ( n+2 ) SDA 㒓 RA /C WK A C K ೒14乎ᑣ䇏 A C K A C K N O A C K 24C02 串行 I2C总线 EEPROM 14. ‫݌‬ൟᑨ⫼ Vcc 1 2 3 4 1 2 3 4 U1 A0 24C02 VCC A1 SCL A2 SDA GND WP ఼ӊഄഔ˖ 0xA2 U2 A0 24C02 VCC A1 SCL A2 SDA GND WP ഄഔ˖ 0xA0 0xxA0 A ఼ӊഄഔ˖ R1 10K 8 R2 10K SCL L 6 SDA D 5 7 Vcc 8 6 5 7 ೒15 ೒ 15 EEPROMⱘ㑻㘨 24C02 串行 I2C总线 EEPROM ᇕ㺙ሎᇌ 15. SOP8L A3 A1 A2 1 4 B B1 R2 3 2 A R R1 C33 C C4 C2 C C1 B2 D1 D ヺো A A1 A2 A3 B B1 B2 C C1 C2 ሎᇌ(mm) ᳔ ᳔໻ؐ ᳔ᇣؐ 4.95 5.15 0.47 0.37 1.27(‫݌‬ൟؐ) 0.41(‫݌‬ൟؐ) 5.80 6.20 4.00 3.80 5.0(‫݌‬ൟؐ) 1.30 0.55 0.55 1.50 0.65 0.65 ヺো C3 C4 D D1 R1 R2 1 2 3 4 ሎᇌ(mm) ᳔ᇣؐ ᳔໻ؐ 0.05 0.20 0.20(‫݌‬ൟؐ) 1.05(‫݌‬ൟؐ) 0.40 0.60 0.07(‫݌‬ൟؐ) 0.07(‫݌‬ൟؐ) 17 (‫݌‬ൟؐ) 13 (‫݌‬ൟؐ) 4 (‫݌‬ൟؐ) 12 (‫݌‬ൟؐ) 24C02 串行 I2C总线 EEPROM DIP8L D2 A θ1 θ2 B θ3 D1 C3 C2 C C1 C4 C 4 D A5 A1 A3 4 A4 A2 ヺো A A1 A2 2 ሎᇌ(mm) ᳔ᇣؐ ᳔໻ؐ ヺো ሎᇌ(mm) ᳔ᇣؐ ᳔໻ؐ 9 9.50 C2 0.5(‫݌‬ൟؐ) 1.524(‫݌‬ൟؐ) 1.524(‫݌‬ C3 3.3(‫݌‬ൟؐ) 0.53 C4 1.57(‫݌‬ൟؐ) 9.30 0.39 A3 2.54(‫݌‬ൟؐ) D 8.20 8.80 A4 0.66(‫݌‬ൟؐ) D1 0.20 0.35 D2 7.62 7.87 A5 B C C1 0.99(‫݌‬ൟؐ) 6.3 6.5 7.20(‫݌‬ൟؐ) 3.30 3.50 1 8 (‫݌‬ൟؐ) 2 8 (‫݌‬ൟؐ) 3 5 (‫݌‬ൟؐ) 24C02 串行 I2C总线 EEPROM TSOT-23-5 PACKAGE OUTLINE DIMENSIONS Symbol Dimensions In Millimeters Dimensions In Inches Min Max Min Max A A1 0.700 0.000 0.900 0.100 0.028 0.000 0.035 0.004 A2 0.700 0.800 0.028 0.031 b 0.350 0.500 0.014 0.020 c 0.080 0.200 0.003 0.008 D 2.820 3.020 0.111 0.119 E 1.600 1.700 0.063 0.067 E1 2.650 2.950 0.104 0.116 e 0.95 (BSC) 0.037 (BSC) e1 1.90 (BSC) 0.075 (BSC) L  0.300 0.600 0.012 0.024 0° 8° 0° 8°
24C02 价格&库存
很抱歉,暂时无法提供与“24C02”相匹配的价格&库存,您可以联系我们找货
24C02
    • 5+0.46767
    • 20+0.42640
    • 100+0.38514
    • 500+0.34387
    • 1000+0.32462
    • 2000+0.31086
