Application Note: AN_SY8089/SY8089A
High Efficiency 5.5V, 2A continuous, 3A peak, 1MHz
Synchronous Step Down Regulator
General Description
Features
The SY8089 and SY8089A are high-efficiency, high
frequency synchronous step-down DC-DC regulator IC
capable of delivering up to 2A output current. The
SY8089 and SY8089A operate over a wide input
voltage range from 2.7V to 5.5V and integrate main
switch and synchronous switch with very low RDS(ON)
to minimize the conduction loss.
Low output voltage ripple and small external inductor
and capacitor sizes are achieved with greater than
1MHz switching frequency.
SY8089 integrates short circuit and over-voltage latch
off protection.
Ordering Information
SY8089
Temperature Code
Package Code
Optional Spec Code
Temperature Range: -40°C to 85°C
Ordering Number
Package type
SY8089AAC
SOT23-5
SY8089AAAC
SOT23-5
Low RDS(ON) for internal switches
(top/bottom):110m /80m
2.7-5.5V input voltage range
2A continuous, 3A peak load current capability
1MHz switching frequency minimizes the external
components
Internal softstart limits the inrush current
Reliable short circuit protection:
SY8089: Latch off protection
SY8089A: Hic-cup mode protection
Reliable over-voltage protection:
SY8089A: No latch off protection
100% dropout operation
RoHS Compliant and Halogen Free
Compact package: SOT23-5
Applications
Note
LCD TV
Set Top Box
Net PC
Mini-Notebook PC
Access Point Router
Typical Applications
Figure 1.Schematic diagram
AN_SY8089/A Rev. 0.9
Figure 2.
Efficiency vs Load Current
Silergy Corp. Confidential- Prepared for Customer Use Only 1
SY8089/8089A
Pinout (top view)
SOT23-5
Part Number
SY8089AAC
SY8089AAAC
Pin Name
EN
GND
LX
IN
FB
Pin Number
1
2
3
4
5
Package type
SOT23-5
SOT23-5
Top Mark
JX
KV
Pin Description
Enable control. Pull high to turn on. Do not float.
Ground pin.
Inductor pin. Connect this pin to the switching node of inductor.
Input pin. Decouple this pin to GND pin with at least 10µF ceramic cap.
Output Feedback Pin. Connect this pin to the center point of the output
resistor divider (as shown in Figure 1) to program the output voltage:
Vout=0.6*(1+R1/R2).
Absolute Maximum Ratings (Note 1)
Supply Input Voltage ----------------------------------------------------------------------------------------------- -0.3V to 6.0V
Enable, FB Voltage------------------------------------------------------------------------------------------ -0.3V to VIN + 0.6V
Power Dissipation, PD @ TA = 25°C,
SOT23-5 -------------------------------------------------------------------------------------------------------------- 0.6W
Package Thermal Resistance (Note 2)
JA --------------------------------------------------------------------------------------------------------------- 170°C/W
JC ----------------------------------------------------------------------------------------------------------------130°C/W
Junction Temperature Range ----------------------------------------- ------------------------------------------ -40°C to 150°C
Lead Temperature (Soldering, 10 sec.) ----------------------------------------------------------------------------------- 260°C
Storage Temperature Range ------------------------------------------------------------------------------------- -65°C to 150°C
Recommended Operating Conditions (Note 3)
Supply Input Voltage ------------------------------------------------------------------------------------------------ 2.7V to 5.5V
Junction Temperature Range ------------------------------------------------------------------------------------ -40°C to 125°C
Ambient Temperature Range ------------------------------------------------------------------------------------- -40°C to 85°C
Silergy Corp. Confidential- Prepared for Customer Use Only 2
SY8089/8089A
Block Diagram
(SY8089)
Silergy Corp. Confidential- Prepared for Customer Use Only 3
SY8089/8089A
(SY8089A)
Silergy Corp. Confidential- Prepared for Customer Use Only 4
SY8089/8089A
Electrical Characteristics
(V IN = 5V, VOUT = 2.5V, L = 2.2µH, COUT = 22µF, TA = 25°C, unless otherwise specified)
Parameter
Input Voltage Range
Quiescent Current
Symbol
VIN
IQ
Shutdown Current
Feedback Reference Voltage
FB Input Current
PFET RON
ISHDN
VREF
IFB
RDS(ON),
P
RDS(ON),
N
ILIM
VENH
VENL
VUVLO
VHYS
FOSC
VSCP
NFET RON
PFET Current Limit
EN rising threshold
EN falling threshold
Input UVLO threshold
UVLO hysteresis
Oscillator Frequency
Short Circuit Protection Latch Off
Threshold
Min ON Time
Max Duty Cycle
Soft Start Time
Output Discharge Switch On
Resistance
Thermal Shutdown Temperature
Test Conditions
Min
2.7
IOUT=0,
VFB=VREF 105%
EN=0
VFB=VIN
Typ
Max
5.5
Unit
V
µA
1
0.612
50
110
µA
V
nA
m
80
m
0.2
1
0.25
A
V
V
V
V
MHz
V
55
0.588
-50
0.1
0.6
3.5
1.5
0.4
2.5
IOUT=500mA
75
100
TSS
RDISCH
1.2
50
TSD
160
ns
ms
°C
Note 1: Stresses beyond the “Absolute Maximum Ratings” may cause permanent damage to the device. These are
stress ratings only. Functional operation of the device at these or any other conditions beyond those indicated in the
operational sections of the specification is not implied. Exposure to absolute maximum rating conditions for
extended periods may affect device reliability.
Note 2: Test condition: Device mounted on 2” x 2” FR-4 substrate PCB, 2oz copper, with minimum recommended
pad on top layer and thermal vias to bottom layer ground plane.
Note 3: The device is not guaranteed to function outside its operating conditions.
Silergy Corp. Confidential- Prepared for Customer Use Only 5
SY8089/8089A
Typical Performance Characteristics
Silergy Corp. Confidential- Prepared for Customer Use Only 6
SY8089/8089A
Silergy Corp. Confidential- Prepared for Customer Use Only 7
SY8089/8089A
VOUT
Operation Principle
SY8089 is a synchronous buck regulator IC that
integrates the PWM control, top and bottom switches
on the same die to minimize the switching transition
loss and conduction loss. With ultra low RDS(ON) power
switches and proprietary PWM control, this regulator
IC can achieve the highest efficiency and the highest
switch frequency simultaneously to minimize the
external inductor and capacitor size, and thus achieving
the minimum solution footprint.
SY8089 After the soft start is over, if the output
voltage falls below 40% of the regulation level, IC will
turn off both power switches, entering short circuit
protection. It will remain in this state until the IN or EN
voltage is recycled.
(SY8089A) The frequency is folded back to about 30%
of the nominal frequency and the current limit is folded
back to 3.0A to prevent the inductor current from
runaway and to reduce the power dissipation of the IC
under short circuit conditions.
Over-voltage Protection
If the output voltage exceeds 120% of the regulation
level for more than 20 s, IC will turn off both power
switches and turn on the discharge switch, entering
over-voltage protection. It will remain in this state until
IN or EN voltage is recycled.
Applications Information
Because of the high integration in the SY8089 IC, the
application circuit based on this regulator IC is rather
simple. Only input capacitor C IN, output capacitor COUT,
output inductor L and feedback resistors (R1 and R2)
need to be selected for the targeted applications
specifications.
Feedback resistor dividers R1 and R2:
Choose R1 and R2 to program the proper output
voltage. To minimize the power consumption under
light loads, it is desirable to choose large resistance
values for both R1 and R2. A value of between 10k and
1M is highly recommended for both resistors. If Vout
is 1.8V, R1=100k is chosen, then R2 can be calculated
to be 50k.:
0.6V
R2 =
R1 ( ) .
VOUT -0.6V
R1
FB
GND
R2
Input capacitor CIN:
This ripple current through input capacitor is calculated
as:
ICIN_RMS =IOUT
D(1-D)
This formula has a maximum at VIN=2VOUT condition,
where ICIN_RMS=I OUT/2. This simple worst-case
condition is commonly used for DC/DC design.
With the maximum load current at 2.0A. A typical
X5R or better grade ceramic capacitor with 6.3V rating
and more than 1 pcs 22µF capacitor can handle this
ripple current well. To minimize the potential noise
problem, ceramic capacitor should really be placed
close to the IN and GND pins. Care should be taken to
minimize the loop area formed by CIN, and IN/GND
pins
Output capacitor COUT:
The output capacitor is selected to handle the output
ripple noise requirements. Both steady state ripple and
transient requirements must be taken into consideration
when selecting this capacitor. For the best performance,
it is recommended to use X5R or better grade ceramic
capacitor with 6.3V rating and greater than 22 F
capacitance.
Output inductor L:
There are several considerations in choosing this
inductor.
1) Choose the inductance to provide the desired
ripple current. It is suggested to choose the ripple
current to be about 40% of the maximum output
current. The inductance is calculated as:
L
VOUT (1 VOUT /VIN, MAX )
FSW IOUT, MAX 40%
where Fsw is the switching frequency and IOUT,MAX is
the maximum load current.
The SY8089 regulator IC is quite tolerant of different
ripple current amplitude. Consequently, the final choice
Silergy Corp. Confidential- Prepared for Customer Use Only 8
SY8089/8089A
of inductance can be slightly off the calculation value
without significantly impacting the performance.
2) The saturation current rating of the inductor must
be selected to be greater than the peak inductor
current under full load conditions.
ISAT, MIN IOUT, MAX
VOUT(1-VOUT/VIN,MAX)
2 FSW L
3) The DCR of the inductor and the core loss at the
switching frequency must be low enough to
achieve the desired efficiency requirement. It is
desirable to choose an inductor with DCR
很抱歉,暂时无法提供与“SY8089AAC”相匹配的价格&库存,您可以联系我们找货
