IST8310
IST8310
    ISENTEK(爱盛科技)
    LGA-16_3x3mm
    3轴数字磁强计 LGA16_3X3MM
IST8310 数据手册
IST83 310 IST T83 310 3 Mag 3D M gnettometerr Brrief D Datasheeet Datasheet, Version 1.2 IST8310 D 1 IST83 310 Tab ble of Co ontentss 1 GEN NERAL DE ESCRIPTION .......... ................................................ ......................... 3 2 BLO OCK DIAG GRAM, PA ACKAGE D DIMENSIO ON AND AP PPLICATIO ON CIRCU UIT ... 4 2.1 Block diagrram .............................. .................................................................................. 4 nd Pin Descriiption .......................................................................... 4 2.22 Package Diimensions an 2.33 Applicationn Circuit........................ .................................................................................. 6 3 ELE ECTRICAL L SPECIFIICATIONS S ............................................... ......................... 7 3.1 Absolute Maximum M Rattings ........... .................................................................................. 7 3.22 Recommended Operatin ng Conditionns ................................................................................ 7 3.33 Electrical Specifications S s ................ .................................................................................. 7 3.44 Magnetic Sensor Speciffications ...... .................................................................................. 8 4 ORD DERING INFORMA I ATION ...... ................................................ ......................... 9 Datasheet, Version 1.2 IST8310 D 2 IST83 310 1 Geneeral Description iSentek IIST8310 is a 3-axis digittal magnetom meter with 3.0x3.0x1.0m mm3, 16-pin L LGA packagee. It is an integrateed chip with 3-axis magn netic sensorss, digital con ntrol logic, built-in tempeerature comp pensation circuit aand self-test function. IST8310 proviides an I2C digital outpu ut with fast mode up to 400kHz. The highh output dataa rate, ultra-llow hysteressis, excellent temperaturee drift and loow noise perfformance feathers make it a peerfect candidaate for high aaccuracy app plications. Features  Siingle chip 3-axis magnetiic sensor  3.0x3.0x1.0mm m3, 16-pin LGA L packagee  I2C slave, Fastt Mode up to o 400kHz  144 bits data ouutput  W Wide dynamicc range of ±1 1600uT (x, y--axis) and ±2 2500uT (z-ax xis)  Hiigh output daata rate of maximum m 2000Hz  Ulltra-low hystteresis (
IST8310 价格&库存
很抱歉,暂时无法提供与“IST8310”相匹配的价格&库存,您可以联系我们找货
IST8310
    IST8310
      IST8310
        IST8310
