CT3407M
P-CHANNEL ENHANCEMENT MODE POWER MOSFET
»Features
■ Simple Drive Requirement
■ Small Package Outline
BVDSS
RDS(ON)typ
■ Surface Mount Device
■ RoHS Compliant & Halogen-Free
ID
-30V
48mΩ
-4.1
»Description
CT3407M is from Coretong innovated design and silicon process technology to
achieve the lowest possible on- resistance and fast switching performance. It
provides the designer with an extreme efficient device for use in a wide range of
»Schematic & PIN Configuration
SOT-23
»Absolute Maximum Ratings@Tj=25oC(unless otherwise specified)
Symbol
VDS
VGS
ID@TA=25℃
ID@TA=70℃
IDM
Parameter
Drain-Source Voltage
Gate-Source Voltage
Drain Current, VGS @ 10V1
Pulsed Drain Current2
PD@TA=25℃ Total Power Dissipation3
TSTG
Storage Temperature Range
Operating Junction Temperature Range
TJ
»Thermal Data
Symbol
Rthj-a
Parameter
Maximum Thermal Resistance, Junction-ambient3
www.coretong.com
Rating
-30
±20
-4.1
-3.2
-15
0.3
-55 to 150
150
Units
V
V
A
A
A
W
Value
100
Unit
℃/W
1/4
CT3407M
»Electrical Characteristics@Tj=25 oC(unless otherwise specified)
Symbol
Parameter
BVDSS
Drain-Source Breakdown Voltage
RDS(ON)
Static Drain-Source On-Resistance
Test Conditions
Min.
Typ.
Max.
Units
VGS=0V, ID=250uA
-30
V
VGS=10V, ID=-4.1A
48
65
mΩ
VGS=-4.5V, ID=-3A
60
95
mΩ
VGS(th)
Gate Threshold Voltage
VDS=VGS, ID=250uA
-1
-3
V
gfs
Forward Transconductance
VDS=5V, ID=-4A
5.5
S
IDSS
Drain-Source Leakage Current
VDS=24V, VGS=0V
-1
uA
IGSS
Gate-Source Leakage
VGS=±20V, VDS=0V
±100
nA
td(on)
Turn-on Delay Time
8.5
ns
tr
td(off)
Rise Time
4.5
ns
26
ns
tf
Ciss
Fall Time
VDS=-16V
ID=1A
RG=6Ω
VGS=-4.5V
12.5
ns
700
pF
Coss
Output Capacitance
120
pF
Crss
Reverse Transfer Capacitance
VGS=0V
VDS=-6V
f=1.0MHz
75
pF
Min.
Typ.
Max.
Units
-1.2
V
Turn-off Delay Time
Input Capacitance
»Source-Drain Diode
Symbol Parameter
VSD
Forward On Voltage²
Test Conditions
IS=1A, VGS=0V
Notes:
1.Pulse width limited by Max. junction temperature.
2.Pulse test
3.Surface mounted on 1 in2 2oz copper pad of FR4 board, t
很抱歉,暂时无法提供与“CT3407M”相匹配的价格&库存,您可以联系我们找货
