MBRS340T3G
SURFACE MOUNT SCHOTTKY BARRIER RECTIFIER
Features
DO-214AB/SMC
The plastic package carries Underwriters Laboratory
Flammability Classification 94V-0
For surface mounted applications
Metal silicon junction,majority carrier conduction
Low power loss,high efficiency
Built-in strain relief,ideal for automated placement
0.245(6.22)
0.220(5.59)
0.126 (3.20)
0.114 (2.90)
High forward surge current capability
High temperature soldering guaranteed:
0.280(7.11)
0.260(6.60)
0.012(0.305)
0.006(0.152)
250 °C/10 seconds at terminals
0.103(2.62)
0.079(2.06)
Mechanical Data
0.060(1.52)
0.030(0.76)
0.008(0.203)MAX.
0.320(8.13)
0.305(7.75)
Case : JEDEC DO-214AB/SMC molded plastic body
Terminals : Solderable per MIL-STD-750,Method 2026
Polarity : Color band denotes cathode end Mounting
Position : Any
Weight : 0.0077 ounce, 0.22 grams
Dimensions in inches and (millimeters)
MARKING DIAGRAM
SS34
ORDERING INFORMATION
Device
SS34
www.tokmas.com
Package
Shipping
SMC
(Pb−Free)
3000 /
Tape & Reel
MBRS340T3G
MAXIMUM RATINGS
Rating
Symbol
Peak Repetitive Reverse Voltage
Working Peak Reverse Voltage
DC Blocking Voltage
VRRM
VRWM
VR
Average Rectified Forward Current
IF(AV)
Nonrepetitive Peak Surge Current
(Surge applied at rated load conditions halfwave,
single phase, 60 Hz)
IFSM
Operating Junction Temperature
MBRS320T3G,
SBRS8320T3G
MBRS330T3G,
NRVBRS330T3G
MBRS340T3G,
SBRS8340T3G
Unit
40
V
3.0 @ TL = 110°C
4.0 @ TL = 105°C
A
A
80
TJ
− 65 to +150
ISO 7637 Pulse #1
(100 V, 10W)
°C
Pulses
5000
ESD Ratings:
Machine Model = C
Human Body Model = 3B
V
> 400
> 8000
Stresses exceeding those listed in the Maximum Ratings table may damage the device. If any of these limits are exceeded, device functionality
should not be assumed, damage may occur and reliability may be affected.
THERMAL CHARACTERISTICS
Thermal Resistance, Junction−to−Lead
11
RqJL
°C/W
ELECTRICAL CHARACTERISTICS
Maximum Instantaneous Forward Voltage (Note 1)
(iF = 3.0 A, TJ = 25°C)
VF
Maximum Instantaneous Reverse Current (Note 1)
(Rated dc Voltage, TJ = 25°C)
(Rated dc Voltage, TJ = 100°C)
iR
V
0.50
mA
2.0
Product parametric performance is indicated in the Electrical Characteristics for the listed test conditions, unless otherwise noted. Product
performance may not be indicated by the Electrical Characteristics if operated under different conditions.
1. Pulse Test: Pulse Width = 300 ms, Duty Cycle ≤ 2.0%.
TYPICAL ELECTRICAL CHARACTERISTICS
10
TJ = 100°C
TJ = 125°C
1
0.1
iF, INSTANTANEOUS FORWARD
CURRENT (AMPS)
CURRENT (AMPS)
10
TJ = 25°C
TJ = −40°C
TJ = −65°C
0.2
0.3
0.4
0.5
0.6
0.7
0.8
0.9
VF, INSTANTANEOUS FORWARD VOLTAGE (V)
Figure 1. Typical Forward Voltage
1.0
TJ = 100°C
TJ = 125°C
1
TJ = 25°C
TJ = −40°C
TJ = −65°C
0.1
0.2
0.3
0.4
0.5
0.6
0.7
0.8
0.9 1.0
VF, MAXIMUM INSTANTANEOUS FORWARD VOLTAGE (V)
Figure 2. Maximum Forward Voltage
www.tokmas.com
MBRS340T3G
1.E−01
IR, REVERSE CURRENT (AMPS)
1.E−01
TJ = 125°C
1.E−02
1.E−02 TJ = 125°C
1.E−03
1.E−03
TJ = 100°C
TJ = 100°C
1.E−04
1.E−04
1.E−05
1.E−06
IR, MAXIMUM REVERSE CURRENT (AMPS)
TYPICAL ELECTRICAL CHARACTERISTICS (continued)
TJ = 25°C
1.E−05
TJ = 25°C
10
15
30
35
40
1.E−06
5
VR, REVERSE VOLTAGE (V)
PFO, AVERAGE POWER DISSIPATION (W)
Freq = 20 kHz
RqJL = 11°C/W
dc
4
3.5
3
2.5
SQUARE WAVE
2
1.5
1
0.5
100
110
120
130
140
150
1.6
IPK/IO = p
1.4
SQUARE
WAVE
dc
1
0.8
0.6
0.4
0.2
1
1.5
2
2.5
3
3.5
4
4.5
IO, AVERAGE FORWARD CURRENT (A)
Figure 6. Forward Power Dissipation
TYPICAL CAPACITANCE AT 0 V = 658 pF
TJ = 25°C
500
400
300
200
100
4
40
IPK/IO = 5
1.2
600
30
2
Figure 5. Current Derating
1.8
TL, LEAD TEMPERATURE (°C)
700
Figure 4. Maximum Reverse Current
5
C, CAPACITANCE (pF)
IO, AVERAGE FORWARD CURRENT (AMPS)
Figure 3. Typical Reverse Current
4.5
15
8
12
16
28
32
Figure 7. Typical Capacitance
www.tokmas.com
36
40
5
MBRS340T3G
SMC 2−LEAD
HE
E
D
A1
DIM
A
A1
A2
b
c
D
E
HE
L
c
DETAIL A
TOP VIEW
DETAIL A
A2
L
A
b
END VIEW
SIDE VIEW
RECOMMENDED
SOLDERING FOOTPRINT*
8.750
0.344
2X
3.790
0.149
2X
2.250
0.089
mm Ǔ
ǒinches
SCALE 4:1
www.tokmas.com
MILLIMETERS
MIN
MAX
1.95
2.61
0.05
0.20
1.90
2.41
2.90
3.20
0.15
0.41
5.55
6.25
6.60
7.15
7.75
8.15
0.75
1.60
INCHES
MIN
MAX
0.077
0.103
0.008
0.002
0.075
0.095
0.114
0.126
0.060
0.016
0.246
0.219
0.281
0.260
0.305
0.321
0.030
0.063
很抱歉,暂时无法提供与“MBRS340T3G”相匹配的价格&库存,您可以联系我们找货
