PCF8574
Remote 8-bit I/O expander for I2C-bus
FEATURES
GENERAL DESCRIPTION
• Operating supply voltage 2.5 to 6 V
The PCF8574 is a silicon CMOS circuit. It provides general
purpose remote I/O expansion for most microcontroller
families via the two-line bidirectional bus (I2C).
• Low standby current consumption of 10 µA maximum
• I2C to parallel port expander
• Open-drain interrupt output
• 8-bit remote I/O port for the I2C-bus
• Compatible with most microcontrollers
• Latched outputs with high current drive capability for
directly driving LEDs
• Address by 3 hardware address pins for use of up to
8 devices (up to 16 with PCF8574A)
• DIP16, or space-saving SO16 or SSOP20 packages.
The device consists of an 8-bit quasi-bidirectional port and
an I2C-bus interface. The PCF8574 has a low current
consumption and includes latched outputs with high
current drive capability for directly driving LEDs. It also
possesses an interrupt line (INT) which can be connected
to the interrupt logic of the microcontroller. By sending an
interrupt signal on this line, the remote I/O can inform the
microcontroller if there is incoming data on its ports without
having to communicate via the I2C-bus. This means that
the PCF8574 can remain a simple slave device.
The PCF8574 and PCF8574A versions differ only in their
slave address as shown in Fig.9.
BLOCK DIAGRAM
handbook, full pagewidth
INT
13
INTERRUPT
LOGIC
A0
A1
A2
SCL
SDA
LP FILTER
PCF8574
1
2
4
3
5
6
14
15
INPUT
FILTER
I 2 C BUS
CONTROL
7
SHIFT
REGISTER
8 BIT
I/O
PORT
9
10
11
12
P0
P1
P2
P3
P4
P5
P6
P7
WRITE pulse
VDD
V SS
16
8
READ pulse
POWER-ON
RESET
Fig.1 Block diagram (SOT38-1 and SOT162-1).
http://www.hgsemi.com.cn
1
2018 AUG
PCF8574
PINNING
DIP16 and SO16 packages
SYMBOL
PIN
DESCRIPTION
A0
1
address input 0
A1
2
address input 1
A2
3
address input 2
P0
4
quasi-bidirectional I/O 0
P1
5
quasi-bidirectional I/O 1
P2
6
quasi-bidirectional I/O 2
P3
7
quasi-bidirectional I/O 3
VSS
8
supply ground
P4
9
quasi-bidirectional I/O 4
P5
10
quasi-bidirectional I/O 5
P6
11
quasi-bidirectional I/O 6
P7
12
quasi-bidirectional I/O 7
INT
13
interrupt output (active LOW)
SCL
14
serial clock line
SDA
15
serial data line
VDD
16
supply voltage
handbook, halfpage
A0 1
16 VDD
A1 2
15 SDA
A1
A2 3
14 SCL
handbook, halfpage
P0 4
A0 1
16 VDD
2
15 SDA
A2 3
14 SCL
PCF8574P 13 INT
PCF8574AP
12 P7
P1 5
P0
P2 6
11 P6
P2 6
11 P6
P3 7
10 P5
P3 7
10 P5
VSS
8
9
P1 5
VSS
P4
Fig.2 Pin configuration (DIP16).
4
8
PCF8574T 13 INT
PCF8574AT 12 P7
9
P4
Fig.3 Pin configuration (SO16).
2
2018 AUG
PCF8574
2C-BUS
CHARACTERISTICS OF THE I
Start and stop conditions
The I2C-bus is for 2-way, 2-line communication between
different ICs or modules. The two lines are a serial data
line (SDA) and a serial clock line (SCL). Both lines must be
connected to a positive supply via a pull-up resistor when
connected to the output stages of a device. Data transfer
may be initiated only when the bus is not busy.
Both data and clock lines remain HIGH when the bus is not
busy. A HIGH-to-LOW transition of the data line, while the
clock is HIGH is defined as the start condition (S).
A LOW-to-HIGH transition of the data line while the clock
is HIGH is defined as the stop condition (P) (see Fig.5).
System configuration
Bit transfer
One data bit is transferred during each clock pulse. The
data on the SDA line must remain stable during the HIGH
period of the clock pulse as changes in the data line at this
time will be interpreted as control signals (see Fig.4).
A device generating a message is a ‘transmitter’, a device
receiving is the ‘receiver’. The device that controls the
message is the ‘master’ and the devices which are
controlled by the master are the ‘slaves’ (see Fig.6).
SDA
SCL
data line
stable;
data valid
change
of data
allowed
Fig.4 Bit transfer.
SDA
SDA
SCL
SCL
S
P
START condition
STOP condition
Fig.5 Definition of start and stop conditions.
SDA
SCL
MASTER
TRANSMITTER /
RECEIVER
SLAVE
RECEIVER
SLAVE
TRANSMITTER /
RECEIVER
MASTER
TRANSMITTER
MASTER
TRANSMITTER /
RECEIVER
Fig.6 System configuration.
3
2018 AUG
PCF8574
Acknowledge
The number of data bytes transferred between the start
and the stop conditions from transmitter to receiver is not
limited. Each byte of eight bits is followed by one
acknowledge bit. The acknowledge bit is a HIGH level put
on the bus by the transmitter whereas the master
generates an extra acknowledge related clock pulse.
A slave receiver which is addressed must generate an
acknowledge after the reception of each byte. Also a
master must generate an acknowledge after the reception
of each byte that has been clocked out of the slave
transmitter. The device that acknowledges has to pull
down the SDA line during the acknowledge clock pulse, so
that the SDA line is stable LOW during the HIGH period of
the acknowledge related clock pulse, set-up and hold
times must be taken into account.
A master receiver must signal an end of data to the
transmitter by not generating an acknowledge on the last
byte that has been clocked out of the slave. In this event
the transmitter must leave the data line HIGH to enable the
master to generate a stop condition.
DATA OUTPUT
BY TRANSMITTER
not acknowledge
DATA OUTPUT
BY RECEIVER
acknowledge
SCL FROM
MASTER
1
2
8
9
S
clock pulse for
acknowledgement
START
CONDITION
Fig.7 Acknowledgment on the I2C-bus.
4
2018 AUG
PCF8574
FUNCTIONAL DESCRIPTION
VDD
write pulse
100
µA
data from
shift register
D
Q
FF
CI
S
P0 to P7
power-on
reset
V SS
D
Q
FF
CI
read pulse
S
to interrupt
logic
data to
shift register
Fig.8 Simplified schematic diagram of each I/O.
Addressing
For addressing see Figs 9, 10 and 11.
slave address
S
A2
slave address
A1
A0
A
S
a.
1
1
A2
A1
A0
A
b.
(a) PCF8574.
(b) PCF8574A.
Fig.9 PCF8574 and PCF8574A slave addresses.
Each of the PCF8574’s eight I/Os can be independently
used as an input or output. Input data is transferred from
the port to the microcontroller by the READ mode
(see Fig.11). Output data is transmitted to the port by the
WRITE mode (see Fig.10).
5
2018 AUG
DATA OUT
FROM PORT
WRITE TO
PORT
3
4
5
6
1
A2
A1
slave address (PCF8574)
2
start condition
SDA
S
1
SCL
A0
7
R/W
6
DATA 1
t pv
Fig.10 WRITE mode (output).
acknowledge
from slave
A
data to port
acknowledge
from slave
A
DATA 1 VALID
DATA 2
data to port
t pv
DATA 2 VALID
acknowledge
from slave
A
PCF8574
2018 AUG
7
t iv
start condition
S
A2
A1
A0
t ph
R/W
1
t ir
DATA 2
acknowledge
from slave
A
DATA 3
t ps
t ir
acknowledge
from slave
DATA 4
DATA 4
DATA 1
A
data from port
data from port
htdiwegap lluf ,koobdnah
P
stop
condition
1
Fig.11 READ mode (input).
A LOW-to-HIGH transition of SDA, while SCL is HIGH is defined as the stop condition (P). Transfer of data can be stopped at any moment by a stop condition. When this occurs, data present
at the last acknowledge phase is valid (output mode). Input data is lost.
INT
DATA INTO
PORT
READ FROM
PORT
SDA
PCF8574
2018 AUG
PCF8574
• Interrupts which occur during the acknowledge clock
pulse may be lost (or very short) due to the resetting of
the interrupt during this pulse.
Interrupt (see Figs 12 and 13)
The PCF8574 provides an open drain output (INT) which
can be fed to a corresponding input of the microcontroller.
This gives these chips a type of master function which can
initiate an action elsewhere in the system.
Each change of the I/Os after resetting will be detected
and, after the next rising clock edge, will be transmitted as
INT. Reading from or writing to another device does not
affect the interrupt circuit.
An interrupt is generated by any rising or falling edge of the
port inputs in the input mode. After time tiv the signal INT is
valid.
Quasi-bidirectional I/Os (see Fig.14)
Resetting and reactivating the interrupt circuit is achieved
when data on the port is changed to the original setting or
data is read from or written to the port which has generated
the interrupt.
A quasi-bidirectional I/O can be used as an input or output
without the use of a control signal for data direction.
At power-on the I/Os are HIGH. In this mode only a current
source to VDD is active. An additional strong pull-up to VDD
allows fast rising edges into heavily loaded outputs. These
devices turn on when an output is written HIGH, and are
switched off by the negative edge of SCL. The I/Os should
be HIGH before being used as inputs.
Resetting occurs as follows:
• In the READ mode at the acknowledge bit after the rising
edge of the SCL signal
• In the WRITE mode at the acknowledge bit after the
HIGH-to-LOW transition of the SCL signal
V DD
MICROCOMPUTER
PCF8574
(1)
PCF8574
(2)
PCF8574
(16)
INT
INT
INT
INT
Fig.12 Application of multiple PCF8574s with interrupt.
SDA
S
A2
A1
data from port
A0
start condition
SCL
1
2
1
R/W
3
4
5
6
7
A
1
acknowledge P5
from slave
1
P
stop
condition
8
DATA INTO
P5
INT
t iv
t ir
Fig.13 Interrupt generated by a change of input to I/O P5.
8
2018 AUG
9
P3
PULL-UP
OUTPUT
CURRENT
P3
OUTPUT
VOLTAGE
SCL
SDA
2
3
1
4
1
5
A2
6
A1
7
A0
8
R/W
acknowledge
from slave
A
P3
1
I OHt
A
P3
data to port
Fig.14 Transient pull-up current IOHt while P3 changes from LOW-to-HIGH and back to LOW.
1
start condition
S
data to port
slave address (PCF8574A)
I OH
A
P
PCF8574
2018 AUG
PCF8574
LIMITING VALUES
In accordance with the Absolute Maximum Rating System (IEC 134).
SYMBOL
PARAMETER
MIN.
MAX.
UNIT
VDD
supply voltage
−0.5
+7.0
V
VI
input voltage
VSS − 0.5
VDD + 0.5
V
II
DC input current
±20
mA
IO
DC output current
±25
mA
IDD
supply current
±100
mA
ISS
supply current
±100
mA
Ptot
total power dissipation
400
mW
PO
power dissipation per output
100
mW
Tstg
storage temperature
−65
+150
°C
Tamb
operating ambient temperature
−40
+85
°C
HANDLING
Inputs and outputs are protected against electrostatic discharge in normal handling. However, to be totally safe, it is
desirable to take precautions appropriate to handling MOS devices. Advice can be found in Data Handbook IC12 under
“Handling MOS Devices”.
DC CHARACTERISTICS
VDD = 2.5 to 6 V; VSS = 0 V; Tamb = −40 to +85 °C; unless otherwise specified.
SYMBOL
PARAMETER
CONDITIONS
MIN.
TYP.
MAX.
UNIT
Supply
VDD
supply voltage
IDD
supply current
Istb
standby current
VPOR
Power-on reset voltage
6.0
V
operating mode; VDD = 6 V; −
no load; VI = VDD or VSS;
fSCL = 100 kHz
40
100
µA
standby mode; VDD = 6 V;
2.5
10
µA
VDD = 6 V; no load;
VI = VDD or VSS; note 1
1.3
2.4
V
2.5
Input SCL; input/output SDA
VIL
LOW level input voltage
−0.5
+0.3VDD
V
VIH
HIGH level input voltage
0.7VDD
VDD + 0.5
V
IOL
LOW level output current
VOL = 0.4 V
3
mA
IL
leakage current
VI = VDD or VSS
−1
+1
µA
Ci
input capacitance
VI = VSS
7
pF
10
2018 AUG
PCF8574
SYMBOL
PARAMETER
CONDITIONS
MIN.
TYP.
MAX.
UNIT
I/Os
VIL
−0.5
+0.3VDD
V
VIH
0.7VDD
VDD + 0.5
V
IIHL(max)
maximum allowed input
current through protection
diode
VI ≥ VDD or VI ≤ VSS
±400
µA
IOL
VOL = 1 V; VDD = 5 V
10
25
mA
IOH
HIGH level output current
VOH = VSS
30
300
µA
IOHt
transient pull-up current
HIGH during acknowledge
(see Fig.14); VOH = VSS;
VDD = 2.5 V
−1
mA
Ci
input capacitance
10
pF
Co
output capacitance
10
pF
Port timing; CL ≤ 100 pF (see Figs 10 and 11)
tpv
output data valid
4
µs
tsu
input data set-up time
µs
th
input data hold time
4
µs
Interrupt INT (see Fig.13)
IOL
VOL = 0.4 V
1.6
mA
IL
leakage current
VI = VDD or VSS
−1
+1
µA
TIMING; CL ≤ 100 PF
tiv
input data valid time
4
µs
tir
reset delay time
4
µs
Select inputs A0 to A2
VIL
−0.5
+0.3VDD
V
VIH
0.7VDD
VDD + 0.5
V
ILI
input leakage current
−250
+250
nA
pin at VDD or VSS
Note
1. The Power-on reset circuit resets the I2C-bus logic with VDD < VPOR and sets all I/Os to logic 1 (with current source
to VDD).
11
2018 AUG
PCF8574
I 2 C-BUS TIMING CHARACTERISTICS
SYMBOL
PARAMETER
MIN.
TYP.
MAX.
UNIT
I2C-BUS TIMING (see Fig.15; note 1)
fSCL
SCL clock frequency
100
kHz
tSW
tolerable spike width on bus
100
ns
tBUF
bus free time
4.7
µs
tSU;STA
START condition set-up time
4.7
µs
tHD;STA
START condition hold time
4.0
µs
tLOW
SCL LOW time
4.7
µs
tHIGH
SCL HIGH time
4.0
µs
tr
SCL and SDA rise time
1.0
µs
tf
SCL and SDA fall time
0.3
µs
tSU;DAT
data set-up time
250
ns
tHD;DAT
data hold time
ns
tVD;DAT
SCL LOW to data out valid
3.4
µs
tSU;STO
STOP condition set-up time
4.0
µs
Note
1. All the timing values are valid within the operating supply voltage and ambient temperature range and refer to VIL
and VIH with an input voltage swing of VSS to VDD.
t SU;STA
BIT 6
(A6)
BIT 7
MSB
(A7)
START
CONDITION
(S)
PROTOCOL
t LOW
t HIGH
BIT 0
LSB
(R/W)
ACKNOWLEDGE
(A)
STOP
CONDITION
(P)
1 / f SCL
SCL
t
tf
tr
BUF
SDA
t HD;STA
t
SU;DAT
t
HD;DAT
t
VD;DAT
t SU;STO
Fig.15 I2C-bus timing diagram.
12
2018 AUG
PCF8574
Important statement:
Huaguan Semiconductor Co,Ltd. reserves the right to change
the products and services provided without notice. Customers
should obtain the latest relevant information before ordering,
and verify the timeliness and accuracy of this information.
Customers are responsible for complying with safety
standards and taking safety measures when using our
products for system design and machine manufacturing to
avoid potential risks that may result in personal injury or
property damage.
Our products are not licensed for applications in life support,
military, aerospace, etc., so we do not bear the consequences
of the application of these products in these fields.
Our documentation is only permitted to be copied without
any tampering with the content, so we do not accept any
responsibility or liability for the altered documents.
13
2018 AUG
很抱歉,暂时无法提供与“PCF8574T/TR”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+6.45650
- 10+5.33610
- 30+4.77020
- 100+4.21580
- 500+3.76530
- 1000+3.59200
