LC76G(PA)
LC76G(PA)
    QUECTEL(移远)
    MODULE_10.1X9.7MM_SM
    GNSS模块GPS: L1 C/A 2.55V~3.6V 400kbps 10.1x9.7x2.4mm
LC76G(PA) 数据手册
10.1 mm Quectel LC76G Series Compact GNSS Module 9.7 mm 2.4 mm Based on the latest enhanced chipset, the Quectel LC76G series GNSS module supports concurrent reception of GPS, GLONASS, Galileo, BDS and QZSS. The LC76G series is designed to be compatible with Quectel L76 module, allowing for smooth migration. Compared with single constellation receivers, by enabling multiple GNSS constellations, the LC76G series increases the number of visible satellites, reduces the time to first fix and improves positioning accuracy, especially when driving through dense urban canyons. The integrated LNA delivers high sensitivity and facilitates high accuracy positioning, fast signal tracking and acquisition and excellent module performance even in challenging environments. By combining EASY (Embedded Assist System), an advanced self-seeded AGNSS feature with ALP* (GNSS Low Power) mode, the LC76G series achieves high performance with low power consumption and satisfies industrial standards. The EASY technology allows the module to calculate and predict orbits automatically by using the ephemeris data (duration of up to 3 days) stored in the internal RAM. As a result, the LC76G series acquires a position fix quickly, even at lower signal levels with low power consumption. Moreover, with the ALP* technology, the LC76G series can adaptively adjust the on/off time based on the environmental and motion conditions to achieve a balance between the positioning accuracy and power consumption. Based on its enhanced performance, the LC76G series is ideal for consumer and industrial applications. Extremely low power consumption makes it a preferred solution for power-sensitive applications, such as Toll Tags, Emergency Beacons and Battery operated Container, Pallet or Animal trackers. . Key Features Multi-GNSS engine for GPS, GLONASS, Galileo, BDS and QZSS, ensuring fast and accurate fix in any environment EASY Technology Ultra Low Power Consumption Ultracompact Size Tracking Sensitivity: -166 dBm Operating Temperature Range: -40 °C to +85 °C Anti-jamming RoHS Compliant Multi-constellation System Footprint compatible with L76 module Industry-leading sensitivity: -166 dBm during tracking and -147 dBm during acquisition Integrated LNA improves sensitivity Embedded multi-tone active interference canceller for anti-jamming Supported interfaces: UART and I2C Version: 1.1 EMAIL US: info@quectel.com Status: Released VISIT US: www.quectel.com Quectel LC76G Series GNSS Module LC76G (AB) LC76G (PA) LC76G (PB) Dimensions Weight Temperature Range Operating Temperature Storage Temperature GNSS Features 10.1 mm × 9.7 mm × 2.4 mm Approx. 0.5 g 10.1 mm × 9.7 mm × 2.4 mm Approx. 0.5 g 10.1 mm × 9.7 mm × 2.4 mm Approx. 0.5 g -40 °C to +85 °C -40 °C to +90 °C -40 °C to +85 °C -40 °C to +90 °C -40 °C to +85 °C -40 °C to +90 °C GPS: L1 C/A GLONASS: L1 Galileo: E1 BDS: B1I; B1C QZSS: L1 C/A GPS + GLONASS + Galileo + BDS + QZSS GPS: L1 C/A GLONASS: L1 Galileo: E1 BDS: B1I; B1C QZSS: L1 C/A GPS + GLONASS + Galileo + BDS + QZSS GPS: L1 C/A GLONASS: L1 Galileo: E1 BDS: B1I; B1C QZSS: L1 C/A GPS + GLONASS + Galileo + BDS + QZSS 47 47 47 4 + QZSS WAAS, EGNOS, MSAS and GAGAN 4 + QZSS WAAS, EGNOS, MSAS and GAGAN 4 + QZSS WAAS, EGNOS, MSAS and GAGAN Autonomous: 1.5 m Autonomous: 1.5 m Autonomous: 1.5 m Without Aid: 0.1 m/s Without Aid: 0.1 m/s² Without Aid: 0.1 m/s Without Aid: 0.1 m/s² Without Aid: 0.1 m/s Without Aid: 0.1 m/s² 30 ns 30 ns 30 ns Cold Start: 15 s Warm Start: 2 s Hot Start: 1 s Cold Start: 5 s Cold Start: 28 s Warm Start: 25 s Hot Start: 1 s Acquisition: -147 dBm Tracking: -166 dBm Reacquisition: -159 dBm Maximum Altitude: 10000 m Maximum Velocity: 490 m/s Maximum Acceleration: 4g Cold Start: 15 s Warm Start: 2 s Hot Start: 1 s Cold Start: 5 s Cold Start: 28 s Warm Start: 25 s Hot Start: 1 s Acquisition: -147 dBm Tracking: -166 dBm Reacquisition: -159 dBm Maximum Altitude: 10000 m Maximum Velocity: 490 m/s Maximum Acceleration: 4g Cold Start: 15 s Warm Start: 2 s Hot Start: 1 s Cold Start: 5 s Cold Start: 28 s Warm Start: 25 s Hot Start: 1 s Acquisition: -147 dBm Tracking: -166 dBm Reacquisition: -159 dBm Maximum Altitude: 10000 m Maximum Velocity: 490 m/s Maximum Acceleration: 4g Europe: CE RoHS Europe: CE RoHS Europe: CE* RoHS Up to 400 kbps Adjustable: 9600–921600 bps Default: 115200 bps Update Rate: 1 Hz (Default), up to 10 Hz NMEA 0183 V4.10 Up to 400 kbps Up to 400 kbps Adjustable: 9600–921600 bps Default: 115200 bps Update Rate: 1 Hz Adjustable: 9600–921600 bps Default: 115200 bps Update Rate: 1 Hz NMEA 0183 V4.10 NMEA 0183 V4.10 Supported Bands Default Constellations Number of Tracking Channels Number of Concurrent GNSS SBAS Horizontal Position Accuracy① Velocity Accuracy② Acceleration Accuracy② Accuracy of 1PPS Signal (RMS)② TTFF (with EASY)③ TTFF (with EPO)③ TTFF (without AGNSS)② Sensitivity (@ Default Constellations) Dynamic Performance② Certifications Regulatory Others Interfaces I2C UART Protocol External Antenna Interface Antenna Type Antenna Power Supply Electrical Characteristics Supply Voltage Range I/O Voltage Power Consumption (@ Default Constellations)② Power Consumption (@ GPS + GLONASS)② Active or Passive Active or Passive Active or Passive External or Internal (through VDD_RF) External or Internal (through VDD_RF) External or Internal (through VDD_RF) 2.55–3.6 V, Typ. 3.3 V Same as VCC Normal Operation: 36 mA (118.8 mW) @ Acquisition 36 mA (118.8 mW) @ Tracking Power Saving Mode: 13 μA (42.9 μW) @ Backup Mode Normal Operation: 30 mA (99 mW) @ Tracking 30 mA (99 mW) @ Tracking 2.55–3.6 V, Typ. 3.3 V Same as VCC Normal Operation: 10 mA (33 mW) @ Acquisition 10 mA (33 mW) @ Tracking Power Saving Modes: 5.5 mA (18.15 mW) @ ALP Mode 13 μA (42.9 μW) @ Backup Mode Normal Operation: 9 mA (29.7 mW) @ Acquisition 9 mA (29.7 mW) @ Tracking Power Saving Modes: 4.6 mA (15.18 mW) @ ALP Mode NOTE: 1. The LC76G (AB) is a standard version module while the LC76G (PA) is an enhanced low power consumption version. 2. ①: CEP, 50%, 24 hours static, -130 dBm, more than 6 SVs. 3. ②: Room temperature, all satellites at -130 dBm. 4. ③: Open-sky, active high-precision GNSS antenna. 5. *: Under development/In progress. Copyright © 2023 Quectel Wireless Solutions Co., Ltd. All Rights Reserved http://www.quectel.com HQ address: Building 5, Shanghai Business Park Phase III (Area B), No.1016 Tianlin Road, Minhang District, Shanghai 200233, China Tel: +86 21 51086236 Email: info@quectel.com 1.75–1.98 V, Typ. 1.8 V Same as VCC Normal Operation: 15 mA (27 mW) @ Acquisition 15 mA (27 mW) @ Tracking Power Saving Modes: 7.5 mA (13.5 mW) @ ALP Mode 13 μA (23.4 μW) @ Backup Mode Normal Operation: 14.5 mA (26.1 mW) @ Acquisition 14.5 mA (26.1 mW) @ Tracking Power Saving Modes: 6.5mA (11.7 mW) @ ALP Mode
LC76G(PA) 价格&库存
很抱歉,暂时无法提供与“LC76G(PA)”相匹配的价格&库存,您可以联系我们找货
