Dongguan Lingxun Electronics Co. ,LTD.
MBR40150CT/FCT/DC
SCHOTTKY BARRIER RECTIFIER
FEATURES
• Low forward voltage
• High current capability
• High forward surge capability
• Low power losses,High efficiency
• Guarding for over voltage protection
TO-220AB/CT
TO-220F/FCT
APPLICATIONS
Low VF Schottky barrier rectifier are designed
for high freqency, miniature switched mode
power supplies such as adapters ,lighting and
on-board DC/DC conerters
TO-263/DC
Primary Characteristic
MECHANICAL DATA
• Case: Molded plastic
IO
2*20A
VRRM
150V
• Polarity: As marked
IFSM
VF
450A
0.71V
• Mounting Position: Any
• Molded Plastic: UL Flammability Classification Rating 94V-0
TJmax
150℃
• Lead free in compliance with EU RoHS 2011/65/EU directive
Assembly code
CP
• Solder bath temperature 275℃ maximum,10s per JESD 22-B106
Maximum Ratings (Per Leg) at Ta=25°C unless otherwise specified
Characteristics
Maximum Repetitive Peak Reverse Voltage
Working Peak Reverse Voltage
Maximum DC Blocking Voltage
Per Leg
Total
Peak Forward Surge Current,8.3 ms Single Half Sine-wave
Superimposed
on RatedRange
Load (JEDEC method)
Operating Temperature
Maximum Average Forward Rectified Current
Symbol
Value
Unit
VRRM
VRWM
VDC
150
150
150
450
150
-40 to +150
V
V
V
IO
IFSM
TJ
TSTG
Storage Temperature Range
Typical Thermal Resistance (Note1)
TO-220AB,TO-263
RθJC
TO-220F
Note1: Thermal resistance from Junction to case per leg mounted on heatsink.
A
A
°C
°C
2
4
°C/W
Electrical Characteristics (Per Leg) unless otherwise specified
Characteristics
Symbol
Value
Forward Voltage Drop(Note2)
TA=25°C
at IF=5A
TA=125°C
TA=25°C
at IF=10A
TA=125°C
TA=25°C
at IF=20A
TA=125°C
TA=25°C
Maximum Reverse Current at VR=150V
TA=125°C
Note2:Pulse test: 300 µs pulse width, 1 % duty cycle
www.dglxdz.com
VF
IR
1 of [3
Typ.
0.70
0.56
0.76
0.63
0.83
0.71
5
3
Unit
Max.
0.88
10
V
µA
mA
Date:03/04/2018 Rev:01
MBR40150CT/FCT/DC
RATINGS AND CHARACTERISTIC CURVES
8.3ms Single Half Sine Wave
JEDEC Method
TA=125℃
TA=125℃
TA=25℃
TA=25℃
Marking on the body
Ordering information
Part Number
Package
Unit Weight
Base Quantity
MBR40150CT
TO-220AB
0.07oz(1.96g)
50 pcs / tube
MBR40150FCT
TO-220F
0.06oz(1.74g)
50 pcs / tube
MBR40150DC
TO-263
0.04oz(1.16g)
50 pcs / tube
MBR40150DC-R
TO-263
0.04oz(1.16g)
800 pcs / reel
Note: For Halogen Free molding compound, add "H" suffix to part number above.
www.dglxdz.com
2 of [3
Delivery mode
1000pcs/box 5000pcs/carton
800pcs/box 4000pcs/carton
MBR40150CT/FCT/DC
Package Outline Dimensions millimeters
www.dglxdz.com
3 of [3
很抱歉,暂时无法提供与“MBR40150CT”相匹配的价格&库存,您可以联系我们找货
