IST8308
IST8308
    ISENTEK(爱盛科技)
    LGA16_3X3MM
    霍尔线性传感器 1.72V~3.6V 3轴
IST8308 数据手册
IST83 308 IST T83 308 3 Mag 3D M gnettometerr Brrief D Datasheeet Brief Datasheeet, Version 1.0 0 IST8308 B 1 IST83 308 Tab ble of Co ontentss 1 GEN NERAL DE ESCRIPTION .......... ................................................ ......................... 3 2 BLO OCK DIAG GRAM, PA ACKAGE D DIMENSIO ON AND AP PPLICATIO ON CIRCU UIT ... 4 2.1 Block diagrram .............................. .................................................................................. 4 nd Pin Descriiption .......................................................................... 4 2.22 Package Diimensions an 2.33 Applicationn Circuit........................ .................................................................................. 6 3 OPE ERATIONA AL MODE ES AND FU UNCTIONA AL DESCR RIPTIONS ......................... 7 3.1 Operation modes m ........................... .................................................................................. 7 4 ELE ECTRICAL L SPECIFIICATIONS S ............................................... ......................... 8 4.1 Absolute Maximum M Rattings ........... .................................................................................. 8 ng Conditionns ................................................................................ 8 4.22 Recommended Operatin 4.33 Electrical Specifications S s ................ .................................................................................. 8 4.44 Magnetic Sensor Speciffications ...... .................................................................................. 9 5 TEC CHNOLOG GY OVERV VIEW....... ................................................ ....................... 10 5.1 AMR Technnology ......................... ................................................................................ 10 5.22 High Reliabbility Planariized Structurre Design ................................................................... 10 5.33 Ultra-low Hysteresis H Deesign .......... ................................................................................ 10 5.44 Magnetic Setting Mechaanism ......... ................................................................................ 10 6 ORD DERING INFORMA I ATION ...... ................................................ ....................... 11 Brief Datasheeet, Version 1.0 0 IST8308 B 2 IST83 308 1 Geneeral Description iSentek IIST8308 is a 3-axis digittal magnetom meter with 3.0x3.0x1.0m mm3, 16-pin L LGA packagee. It is an integrateed chip with 3-axis magn netic sensorss, digital con ntrol logic, built-in tempeerature comp pensation circuit aand self-test function. IST8308 proviides an I2C digital outpu ut with fast mode up to 400kHz. The highh output dataa rate, ultra-low noise, ulltra-low hysteresis and ex xcellent tempperature drifft features make it a perfect canndidate for hiigh accuracyy applicationss. Features  Siingle chip 3-axis magnetiic sensor  3.0x3.0x1.0mm m3, 16-pin LGA L packagee  I2C slave, Fastt Mode up to o 400kHz  Suupports both single measurement andd continuous measuremen nt modes  Dyynamic rangge of maximu um ±500uT.  Hiigh output daata rate of 20 00Hz  Ulltra-high sennsitivity (max ximum 13.2 LSB/uT)  Ulltra-low hystteresis (
IST8308 价格&库存
很抱歉,暂时无法提供与“IST8308”相匹配的价格&库存,您可以联系我们找货
IST8308
    • 10+22.40000
    库存:2410
